alien88 Posted March 22 Posted March 22 hi, using rpi5, sometimes swap with rpi400, I have problem with the last upgrade, after reboot kernel does not boot, stuck in starting system. One or two of theses pkg fail. Thanks in advance 0 Quote
alien88 Posted March 22 Author Posted March 22 hi, when upgrade I found these errors https://paste.armbian.com/utesitikah.sql what else logs do you need? var/log boot.log? 0 Quote
Werner Posted March 22 Posted March 22 just tested with a clean image, featuring 6.18.y and works just fine. Quote WARNING: Unsupported kernel version (6.18.10-current-bcm2711) - skipping setup This may be an issue if your setup is quite old, because at some point upstream changes caused Armbian kernel to break IIRC and this was worked around. The warning is persistent but doesn't actually matter. Please verify that a clean system boots normally. 0 Quote
alien88 Posted March 22 Author Posted March 22 hi, I installed in usb the last version and boot. something wrong happen here, only left these two upgrades, I tried again with backup-img and falied to boot again 0 Quote
alien88 Posted March 29 Author Posted March 29 I been testing new install in pendrive, the os boot in rpi4, but no in rpi5 0 Quote
