alien88 Posted 1 hour ago Posted 1 hour ago hi, using rpi5, sometimes swap with rpi400, I have problem with the last upgrade, after reboot kernel does not boot, stuck in starting system. One or two of theses pkg fail. Thanks in advance 0 Quote
alien88 Posted 1 hour ago Author Posted 1 hour ago hi, when upgrade I found these errors https://paste.armbian.com/utesitikah.sql what else logs do you need? var/log boot.log? 0 Quote
Werner Posted 45 minutes ago Posted 45 minutes ago just tested with a clean image, featuring 6.18.y and works just fine. Quote WARNING: Unsupported kernel version (6.18.10-current-bcm2711) - skipping setup This may be an issue if your setup is quite old, because at some point upstream changes caused Armbian kernel to break IIRC and this was worked around. The warning is persistent but doesn't actually matter. Please verify that a clean system boots normally. 0 Quote
