alien88 Posted Sunday at 07:48 AM Posted Sunday at 07:48 AM hi, using rpi5, sometimes swap with rpi400, I have problem with the last upgrade, after reboot kernel does not boot, stuck in starting system. One or two of theses pkg fail. Thanks in advance 0 Quote
Werner Posted Sunday at 08:00 AM Posted Sunday at 08:00 AM hard to tell without any logs whatsoever 0 Quote
alien88 Posted Sunday at 08:22 AM Author Posted Sunday at 08:22 AM hi, when upgrade I found these errors https://paste.armbian.com/utesitikah.sql what else logs do you need? var/log boot.log? 0 Quote
Werner Posted Sunday at 08:57 AM Posted Sunday at 08:57 AM just tested with a clean image, featuring 6.18.y and works just fine. Quote WARNING: Unsupported kernel version (6.18.10-current-bcm2711) - skipping setup This may be an issue if your setup is quite old, because at some point upstream changes caused Armbian kernel to break IIRC and this was worked around. The warning is persistent but doesn't actually matter. Please verify that a clean system boots normally. 0 Quote
alien88 Posted Sunday at 12:56 PM Author Posted Sunday at 12:56 PM hi, I installed in usb the last version and boot. something wrong happen here, only left these two upgrades, I tried again with backup-img and falied to boot again 0 Quote
