Mohammad Adel Posted yesterday at 11:31 AM Posted yesterday at 11:31 AM i need secure image x98h pro 0 Quote
Nick A Posted yesterday at 12:54 PM Posted yesterday at 12:54 PM (edited) @Mohammad Adel Here are the steps to make a secure boot image. In your case you want to modify the X98H defconfig. git clone https://github.com/NickAlilovic/build.git --branch v20250306 cd build pico patch/u-boot/u-boot-h616/171-add-x98h-defconfig.patch You need to add this line to the bottom. "+CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y" and change "@@ -0,0 +1,31 @@" to @@ -0,0 +1,32 @@. From 25669b44bab8ffdc4d07e140226c6385a9d13950 Mon Sep 17 00:00:00 2001 From: Nick Alilovic <nickalilovic@gmail.com> Date: Tue, 11 Mar 2025 22:09:15 -0400 Subject: [PATCH] add x98h defconfig add x98h defconfig --- configs/x98h_defconfig | 31 +++ .../src/arm64/allwinner/sun50i-h618-x98h.dts | 223 ++++++++++++++++++ 2 files changed, 254 insertions(+) create mode 100644 configs/x98h_defconfig create mode 100644 dts/upstream/src/arm64/allwinner/sun50i-h618-x98h.dts diff --git a/configs/x98h_defconfig b/configs/x98h_defconfig new file mode 100644 index 0000000000..b87498cd10 --- /dev/null +++ b/configs/x98h_defconfig @@ -0,0 +1,32 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_DEFAULT_DEVICE_TREE="allwinner/sun50i-h618-x98h" +CONFIG_SPL=y +CONFIG_DRAM_SUN50I_H616_DX_ODT=0x03030303 +CONFIG_DRAM_SUN50I_H616_DX_DRI=0x0e0e0e0e +CONFIG_DRAM_SUN50I_H616_CA_DRI=0x1f12 +CONFIG_DRAM_SUN50I_H616_TPR0=0xc0001002 +CONFIG_DRAM_SUN50I_H616_TPR10=0x2f1107 +CONFIG_DRAM_SUN50I_H616_TPR11=0xddddcccc +CONFIG_DRAM_SUN50I_H616_TPR12=0xeddc7665 +CONFIG_MACH_SUN50I_H616=y +CONFIG_SUNXI_DRAM_H616_DDR3_1333=y +CONFIG_DRAM_CLK=648 +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_R_I2C_ENABLE=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_I2C=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_SYS_I2C_LEGACY=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_SYS_I2C_SLAVE=0x7f +CONFIG_SYS_I2C_SPEED=400000 +CONFIG_PHY_REALTEK=y +CONFIG_SUN8I_EMAC=y +CONFIG_I2C3_ENABLE=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_AXP313_POWER=y +CONFIG_AXP_DCDC3_VOLT=1360 +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OHCI_HCD=y +CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y Then create the secure boot patch. pico patch/u-boot/u-boot-h616/secure-boot.patch diff --git a/root_key.pem b/root_key.pem new file mode 100644 index 0000000000..892a10ef90 --- /dev/null +++ b/root_key.pem @@ -0,0 +1,28 @@ +-----BEGIN PRIVATE KEY----- +MIIEvgIBADANBgkqhkiG9w0BAQEFAASCBKgwggSkAgEAAoIBAQCWZ7G39E+RCi+9 +B48yiD4GxnfqNzvlXOxAd+GHQuKbgynXZd5pIuNHt3ewhZTHZkdHxuO9liqX9MmU +8OhiG+Skww2LzHPPi/eLeN4vCt/waXkjFrkblkhNzB3c6MejKdiz9sfw8oeOFX1S +teP/MJBoRaj6Hexj5g/oCspU+KFfv0cOBcWuq4vZwPJ6+U44IBi7EGleShGHNhBI +xQEyvNaDLWoDCPGLrjRM0DrIbUpzEntk9KJ0z+3Th8O/FtvlW21atolIVr5F96Pw +EEv3CDUHrY+IvK0z+IwNhnYo99kMPi5djB6vviz4In530JQ+OdPxhi4cQY3Yw9wx +Sm8EFaRRAgMBAAECggEAEaEcZ+k7VU8aGuBStNPa31zui9XHD8KlT4YtuXbJzHwi +kKSYXf7woISdAyQZNQkkREHICn4aRn7zDOHy/yLxWS2ivhbsITDxBlhXxLBT4OBg +ClCcyGLEXVgWTQE8+z9Jrwh3VaL76BfVPXdj/tKwroQxwwV0Yp5CEYsIPc75zVjW +Y2tppJL9XlTfKXTSo7FAxJmjkTC8QGPSHgMglR5FOfZ/D3Nj4KV4LV1gHCkICKUy +c2jklHISy8S6/pvgpWb50TKArEhbN6uAKQBNb74ZsChKJ9h9aof/vjH/8Ab1rwUJ +g91lpkR3mEefTjJTW1JOuoT49Y3lfWmkRVh75GiCsQKBgQDUo3uMcy9VdbbmY9Gt +2JuhbSvwR/dOHZJoXvtlNYVJ+1JvavExBy2u31cYsK/2SH/Upc8AXS6H02dXbnC3 +wjlUFi21Xi7/PCQM8TUz05km3+9qOkDYw53EBBBnCdjawBpDgcUSkoZGU+ltBzcR +sj0nsmI29DjwfYHXhofnlfI52QKBgQC1E2Q0hGfk3YUtfzTjDJCfd3gs6QYGQGeT +49jvnsbYsnz9vsK4Ao2skN8nBhSefDJR8h2X+7tRXEefQB2Hy/+9qoiuoVzPJGWD +IiHjeVJDoEqA2Q483UhZ+OPjUGFDTI7O/j1A1HkEBKswdJpKlGVygdoXYaieUAfz +Sb+dCYf7OQKBgQCWkE/aSnE4vQpOJl4BEABbFFdpYzvcpxnVJ3Qw3O3NTdS4Keww +wBl72o7sX6eo5vsE0oc5hcF90ZY6FWxg4XkAblfdNZxng+ku9NisIuct3KDFAgyK +sDCU7B/FJfbUJfQy2r91gCTtxVripZo7wI6G/kuHB/UNbIE04AB5XfZPOQKBgAGw +K5f9wAY3Nn2lGPYg8Nw7vegVSBQY155eWnBpd4sfpuCqvZ//jhiUxS/U865ClCmF +a1c2ZpmslZJbg6r3cOvwwhN2t6nKuhON5uj7AZRV0zv+Sg6xNXJ5So6c+jspZI9z +eVi4YmRyMrJh8+pMFeIKaeEb7PmE334aKuoo45apAoGBAKNp7ssXgU4Ma7cUr7+L +TKGBNVsMZyM3T2qsXJjFY1f90+lwp7TlNQGVMPOSOHxyINWkuLNgAgetlhavnc0S +0l+SbSaO6SfnHfQWBFPEJfol8V/Xa4rcVP7fGxQn4phYnk14N09xKIQa24Mi2Xa5 +9G0C2VOB8Yz6OWcQZELs0uFp +-----END PRIVATE KEY----- -- 2.34.1 ./compile.sh choose "Do not change kernel configuration" choose "Show CSC/WIP/EOS/TVB" choose "I understand and agree" choose "X98H" choose "edge" rest is up to you. Your image should be in output/images directory. Edited yesterday at 12:55 PM by Nick A 0 Quote
Mohammad Adel Posted 23 hours ago Author Posted 23 hours ago (edited) X98H Pro FIRMWARE OFICIAL secure image Edited 23 hours ago by Mohammad Adel 0 Quote
Werner Posted 23 hours ago Posted 23 hours ago We don't deal with other OS than Armbian. If you need Android, I suggest to ask at xda developers or similar place. 0 Quote
Mohammad Adel Posted 23 hours ago Author Posted 23 hours ago i need rom work linux on x98h pro with secure image 0 Quote
Werner Posted 22 hours ago Posted 22 hours ago Nick explained above how to create such an image on your own. 0 Quote
Mohammad Adel Posted 3 hours ago Author Posted 3 hours ago The x98h pro device is not the same as the x98h 0 Quote
Mohammad Adel Posted 1 hour ago Author Posted 1 hour ago I need a Linux system that runs on an x98h device Anything that does not work is not booted by the device 0 Quote
