smurfx Posted 2 hours ago Posted 2 hours ago Armbianmonitor: https://paste.armbian.com/nubeniduko Hi everyone, I just installed Armbian on my OrangePi 5, but I can't get it to recognize the NVMe drive. I've tried the official OrangePi Ubuntu distro, and it detects the NVMe without any issues. However, when using Armbian, it simply doesn't show up. I'm not sure what to do at this point. I would really like to use Armbian, but it seems unable to detect the NVMe on this particular device. Interestingly, I have another OrangePi 5 Pro where I installed Armbian, and it recognizes the NVMe and works perfectly fine — but not on the standard OrangePi 5. Does anyone know how to fix this issue, or can you recommend a good alternative? Quote root@orangepi5:~# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS mtdblock0 31:0 0 16M 0 disk mmcblk0 179:0 0 238.8G 0 disk └─mmcblk0p1 179:1 0 236.3G 0 part /var/log.hdd / zram0 252:0 0 7.8G 0 disk [SWAP] zram1 252:1 0 50M 0 disk /var/log zram2 252:2 0 0B 0 disk Thank you in advance. 0 Quote
eselarm Posted 2 hours ago Posted 2 hours ago (edited) 43 minutes ago, smurfx said: https://paste.armbian.com/nubeniduko Log shows nothing about PCIE when 6.19.0-edge-rockchip64, it does when 6.18.8-current-rockchip64 If you just upgraded the kernel via apt, then this might be the point where an older U-Boot is incompatible with newer kernel. This is the case for all Rockchip devices I have and not strange. It is like it is, so if you want edge or newest or even standard Debian sid/unstable/testing kernel, you will need to look at that in more detail. I have been spending a lot of time on it, it is simply what you want or need. If you want all RK3588 silicon HW support, so like video encoders, stick to vendor based U-Boot and kernel. I you want a generic computer that is good enough for server tasks and web-browsing etc, use mainline based U-Boot and kernel. Of course something else might be wrong, but reporting U-Boot version would be needed and helpful first I think. Edited 2 hours ago by eselarm 0 Quote
smurfx Posted 1 hour ago Author Posted 1 hour ago Hey @eselarm, Thanks for the quick answer. My goal is indeed having a more generic computer for server tasks. The version of the u-boot is: Quote root@orangepi5:~# dpkg -l | grep u-boot ii linux-u-boot-orangepi5-current 26.2.1 arm64 Das U-Boot for orangepi5 ii u-boot-tools 2025.10-0ubuntu0.24.04.2 arm64 companion tools for Das U-Boot bootloader root@orangepi5:~# uname -a Linux orangepi5 6.18.10-current-rockchip64 #2 SMP PREEMPT Wed Feb 11 12:42:01 UTC 2026 aarch64 aarch64 aarch64 GNU/Linux I have switched again to the orangepi5 6.18.10-current-rockchip64 kernel but still not showing nothing. Thank you. 0 Quote
eselarm Posted 1 hour ago Posted 1 hour ago (edited) 10 minutes ago, smurfx said: linux-u-boot-orangepi5-current 26.2.1 You need the U-Boot source-code version; I at least cannot conclude on it; You can watch the start-up via serial console, then you will see. Or like this: root@rock3a:~# strings /dev/mtdblock0 | grep "U-Boot SPL 20" U-Boot SPL 2017.09-armbian (May 20 2024 - 00:46:51) I see you have 2 options: which U-Boot is used: mtdblock0 (the SPI-flash) or mmcblk0 (SD-card) ?? Edited 1 hour ago by eselarm 0 Quote
smurfx Posted 1 hour ago Author Posted 1 hour ago Strangely I can't get any outcome from that command: Quote root@orangepi5:~# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS mtdblock0 31:0 0 16M 0 disk mmcblk0 179:0 0 238.8G 0 disk └─mmcblk0p1 179:1 0 236.3G 0 part /var/log.hdd / zram0 252:0 0 7.8G 0 disk [SWAP] zram1 252:1 0 50M 0 disk /var/log zram2 252:2 0 0B 0 disk root@orangepi5:~# strings /dev/mtdblock0 | grep "U-Boot SPL 20" root@orangepi5:~# strings /dev/mtdblock0 | grep "U-Boot" root@orangepi5:~# strings /dev/mtdblock0 root@orangepi5:~# grep -a --null-data "U-Boot" /dev/mtdblock0 root@orangepi5:~# Now I am confused if there is something else going on, however, the OrangePi official distro recognised the nvme disk. 0 Quote
smurfx Posted 1 hour ago Author Posted 1 hour ago (edited) The only thing I could manage to get information from was this: Quote root@orangepi5:~# dd if=/dev/mmcblk0 bs=1M count=4 2>/dev/null | strings | grep -i "u-boot" | head -1 u-boot,spl-boot-order I had to rewrite the SPI-flash and now I see: Quote root@orangepi5:~# strings /dev/mtdblock0 | grep "U-Boot SPL 20" U-Boot SPL 2025.10_armbian-2025.10-Se50b-P4b2d-Hd43a-Va0a8-B2eb2-R448a (Feb 01 2026 - 04:51:01 +0000) Btw, this is the output when I was using the official OrangePI Ubuntu distro: Quote ubuntu@ubuntu:~$ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS loop0 7:0 0 69.2M 1 loop /snap/core22/1624 loop1 7:1 0 94.4M 1 loop /snap/lxd/30134 loop2 7:2 0 33.7M 1 loop /snap/snapd/21761 loop3 7:3 0 41.8M 1 loop /snap/snapd/26383 sda 8:0 0 1.8T 0 disk └─sda1 8:1 0 1.8T 0 part mmcblk1 179:0 0 238.8G 0 disk ├─mmcblk1p1 179:1 0 4M 0 part └─mmcblk1p2 179:2 0 238.7G 0 part / nvme0n1 259:0 0 238.5G 0 disk Edited 1 hour ago by smurfx 0 Quote
