bedna Posted April 20 Posted April 20 (edited) Maybe you already know, but to be sure (you guys are most likely always swamped), the keyrings workflow has failed the last two runs with the same error, on April 8 & April 15... https://github.com/armbian/armbian.github.io/actions/workflows/generate-keyring-data.yaml ERROR: Unable to find debian-archive-keyring package URL from https://packages.debian.org/sid/all/debian-archive-keyring/download Thanks for all you do! Edit With the limited understanding I have of this, I extracted relevant code and just ran a check on my local machine, and it returned: % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 3012 100 3012 0 0 509 0 00:05 00:05 509 Debian debian-archive-keyring URL: http://ftp.debian.org/debian/pool/main/d/debian-archive-keyring/debian-archive-keyring_2025.1_all.deb % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 3021 100 3021 0 0 532 0 00:05 00:05 532 Debian debian-ports-archive-keyring URL: http://ftp.debian.org/debian/pool/main/d/debian-ports-archive-keyring/debian-ports-archive-keyring_2026.02.04_all.deb (the reason it took 5s was due to the time it took me to press "allow" on the outgoing curl connection in my firewall) So maybe it was just a fluke, and it was just really unlucky failing resolving to packages.debian.org instead of ftp.debian.org those two times. Idk, just wanted to make sure everything was correctly configured. Ignore this if all is ok. Edited April 20 by bedna
Solution Igor Posted April 20 Solution Posted April 20 https://actions.armbian.com/?repo=armbian.github.io Here anyone can monitor ... but the real problem is capacity to fix problems. Not knowning them. We have too many problems on the to do list 2 hours ago, bedna said: Ignore this if all is ok. It is not O.K., but also not a critical problem. This script is making a cache for this package which is needed in critical operations. Where it can't fail. This is why this was made in 1st place. We can't rely on upstream infrastructure.
bedna Posted April 20 Author Posted April 20 I see. I actually tried to educate myself to see if I could help out, that is why I extracted the code in the first place. I would love to be able to help, but it seems outside of my capabilities. But I'll keep reading trying to learn, and maybe some day I will be able to make a pr rather than just a post on the forum. Thank you AGAIN for ALL you do!!
