How to disable HDMI and CODEC in system where is ne kernel 6.18.25
cat /proc/asound/cards
 0 [Codec          ]: sun4i-codec - H616 Audio Codec
                      h616-audio-codec
 1 [HDMI           ]: HDMI - HDMI
                      HDMI
 2 [Device         ]: USB-Audio - USB PnP Sound Device
                      C-Media Electronics Inc. USB PnP Sound Device at usb-5200400.usb-1, full speed
I need an always USB sound card with the number of 0
After updating the system, when the 6.12.x kernel was updated to 6.18.25, the audio codec and HDMI codecs appeared in the list, which caused the USB sound card to be renumbered from 0 to 2. I know I can change the number from 0 to 2, but there's a system image that users use with their configuration, which previously had the card number set to 0. As a result of the system update, everyone lost communication with the sound card in the application. I'm looking for a solution to restore the system so that the USB sound card remains number 0.
If anyone has any good advice on how to make the USB sound card permanently have number 0 in the list or how to block Codec and HDMI audio in the system so that they are not present?
Ok tried:
/dts-v1/;
/plugin/;
    compatible = "allwinner,sun50i-h616";
    fragment@0 {
        target = <&codec>;
        __overlay__ {
            status = "disabled";
    fragment@1 {
        target = <&hdmi_sound>;
        __overlay__ {
and run
armbian-add-overlay disable-internal-audio.dts
But after reboot, still Codec and HDMI exist in the list of cards
Maybe I wrote the overlay file?
Unfortunately, there's no technical way to connect to the UART to see. I'm not sure if I got the names right. Maybe the HDMI and audio codecs have different names in the tree devices ? Is there any way to find them?
I don't know the names either. I suggest to look at the original device tree by decompiling it:
dtc -I dtb -O dts /boot/dtb/allwinner/whateverthenameofthezero3devicetreewas.dtb
Ok I check via
ls /proc/device-tree/__symbols__/
addr_mgt           hdmi_con_in                 name             r_i2c_pins                     tcon_tv0
ahub1_codec        hdmi_in                     nmi_intc         rmii_pins                      tcon_tv0_in
ahub1_cpu          hdmi_in_tcon_top            ohci0            r_pio                          tcon_tv0_in_tcon_top_mixer0
ahub1_mach         hdmi_out                    ohci1            r_rsb                          tcon_tv0_in_tcon_top_mixer1
ahub1_plat         hdmi_out_con                ohci2            r_rsb_pins                     tcon_tv0_out
ahub_dam_mach      hdmi_phy                    ohci3            rtc                            tcon_tv0_out_tcon_top
ahub_dam_plat      i2c0                        osc24M           sid                            ths
axp313             i2c0_pins                   pio              spdif                          ths_calibration
ccu                i2c1                        planes           spdif_tx_pin                   uart0
codec              i2c1_pi_pins                prcm_ppu         spi0                           uart0_ph_pins
cpu0               i2c2                        pwm              spi0_cs0_pin                   uart1
cpu1               i2c2_ph_pins                pwm0             spi0_pins                      uart1_pins
cpu2               i2c2_pi_pins                pwm0_pin         spi1                           uart1_rts_cts_pins
cpu3               i2c3                        pwm1             spi1_cs0_pin                   uart2
cpu_critical       i2c3_pa_pins                pwm1_pg_pin      spi1_cs1_pin                   uart2_pg_pins
cpu_opp_table      i2c3_pg_pins                pwm1_ph_pin      spi1_pins                      uart2_pg_rts_cts_pins
cpu_speed_grade    i2c3_ph_pins                pwm1_pi_pin      sram_c                         uart2_ph_pins
cpu_target         i2c4                        pwm2             sram_c1                        uart2_ph_rts_cts_pins
cpu_threshold      i2c4_pg_pins                pwm2_ph_pin      syscon                         uart2_pi_pins
crypto             i2c4_ph_pins                pwm2_pi_pin      tcon_lcd0                      uart2_pi_rts_cts_pins
ddr_temp_critical  iommu                       pwm3             tcon_lcd0_in                   uart3
de                 ir                          pwm3_ph_pin      tcon_lcd0_in_tcon_top_mixer0   uart3_pi_pins
de3_sram           ir_rx_pin                   pwm3_pi_pin      tcon_lcd0_in_tcon_top_mixer1   uart3_pi_rts_cts_pins
display_clocks     l2_cache                    pwm4             tcon_lcd0_out                  uart4
dma                lradc                       pwm4_ph_pin      tcon_top                       uart4_pi_pins
dump_reg           mdio0                       pwm4_pi_pin      tcon_top_hdmi_in               uart4_pi_rts_cts_pins
ehci0              mdio1                       pwm5             tcon_top_hdmi_in_tcon_tv0      uart5
ehci1              mixer0                      pwm5_pin         tcon_top_hdmi_out              uart5_pins
ehci2              mixer0_out                  r_ccu            tcon_top_hdmi_out_hdmi         usbotg
ehci3              mixer0_out_tcon_top_mixer0  reg_aldo1        tcon_top_mixer0_in             usbphy
emac0              mixer1                      reg_dcdc1        tcon_top_mixer0_in_mixer0      ve_sram
emac1              mixer1_out                  reg_dcdc2        tcon_top_mixer0_out            ve_temp_critical
ext_rgmii_phy      mixer1_out_tcon_top_mixer1  reg_dcdc3        tcon_top_mixer0_out_tcon_lcd0  watchdog
ext_rgmii_pins     mmc0                        reg_dldo1        tcon_top_mixer0_out_tcon_tv0   wifi_pwrseq
gic                mmc0_pins                   reg_usb1_vbus    tcon_top_mixer1_in             x32clk_fanout_pin
gpadc              mmc1                        reg_vcc33_wifi   tcon_top_mixer1_in_mixer1
gpu                mmc1_pins                   reg_vcc5v        tcon_top_mixer1_out
gpu_temp_critical  mmc2                        reg_vcc_wifi_io  tcon_top_mixer1_out_tcon_lcd0
hdmi               mmc2_pins                   r_i2c            tcon_top_mixer1_out_tcon_tv0
After decompiling the DTS image (H618):
grep -A 15 "codec {" /tmp/extracted_tree.dts
			soundcard-mach,codec {
		ahub1_plat {
			#sound-dai-cells = <0x00>;
			compatible = "allwinner,sunxi-snd-plat-ahub";
			apb_num = <0x01>;
			dmas = <0x25 0x04 0x25 0x04>;
			dma-names = "tx\0rx";
			playback_cma = <0x80>;
			capture_cma = <0x80>;
			tx_fifo_size = <0x80>;
			rx_fifo_size = <0x80>;
			tdm_num = <0x01>;
			tx_pin = <0x00>;
				sound-dai = <0x33>;
				phandle = <0x98>;
		usb@5100000 {
			compatible = "allwinner,sun50i-h616-musb\0allwinner,sun8i-h3-musb";
			reg = <0x5100000 0x400>;
			clocks = <0x02 0x70>;
			resets = <0x02 0x32>;
			interrupts = <0x00 0x19 0x04>;
			interrupt-names = "mc";
			phys = <0x34 0x00>;
			phy-names = "usb";
			extcon = <0x34 0x00>;
root@host:/tmp# grep -A 15 "hdmi_sound {" /tmp/extracted_tree.dts
root@host:/tmp# grep -A 10 "ahub1_mach {" /tmp/extracted_tree.dts
		ahub1_mach {
			compatible = "allwinner,sunxi-snd-mach";
			soundcard-mach,name = "HDMI";
			soundcard-mach,format = "i2s";
			soundcard-mach,frame-master = <0x31>;
			soundcard-mach,bitclock-master = <0x31>;
			soundcard-mach,slot-num = <0x02>;
			soundcard-mach,slot-width = <0x20>;
			status = "okay";
			phandle = <0x97>;
HDMI Audio is located under the label: ahub1_mach Analog Codec is associated with: ahub1_plat and codec
These nodes have a default status of "okay," which causes them to occupy slots 0 and 1.
and use
/dts-v1/;
/plugin/;
    fragment@0 {
        target = <&codec>;
        __overlay__ {
    fragment@1 {
        target = <&ahub1_codec>;
        __overlay__ {
    fragment@2 {
        target = <&hdmi>;
        __overlay__ {
    fragment@3 {
        target = <&spdif>;
        __overlay__ {
    fragment@4 {
        target = <&ahub1_mach>;
        __overlay__ {
and after reboot not show HDMI and Codec audio and USB sound card has 0 number
By the way, it's a shame the old method of forcing the bit card number via /etc/modprobe.d/alsa.conf didn't work on Armbian.
options snd_usb_audio index=0
options sun4i_codec index=1
options snd_hdmi_audio index=2
alias snd-card-0 snd_usb_audio
alias snd-card-1 sun4i_codec
alias snd-card-2 snd_hdmi_audio
That's why I was looking for a way to disable these additional audio codecs and HDMI, but maybe it's because snd_usb_audio, etc., aren't loaded as modules in the new kerne
Another interesting thing is that snd_usb_audio is not loaded as a module and seems to be compiled. I tried in /boot/armbianEnv.tx in extrargs=   put
snd_usb_audio.index=0
but that didn't work either, unless a different name should be provided instead of snd_usb_audio.
