j0ta Posted 1 hour ago Posted 1 hour ago Connecting a usb keyboard doesn't seem to work with 7.1 .. [ 2.836541] usb 7-1: new full-speed USB device number 2 using ohci-platform [ 3.024538] usb 7-1: device descriptor read/64, error -62 [ 3.304535] usb 7-1: device descriptor read/64, error -62 [ 3.596542] usb 7-1: new full-speed USB device number 3 using ohci-platform [ 3.780527] usb 7-1: device descriptor read/64, error -62 [ 4.076543] usb 7-1: device descriptor read/64, error -62 [ 4.180566] usb usb7-port1: attempt power cycle [ 4.372529] usb 7-1: new full-speed USB device number 4 using ohci-platform [ 4.780541] usb 7-1: device not accepting address 4, error -62 [ 4.964529] usb 7-1: new full-speed USB device number 5 using ohci-platform [ 5.372526] usb 7-1: device not accepting address 5, error -62 [ 5.372569] usb usb7-port1: unable to enumerate USB device 0 Quote
Werner Posted 55 minutes ago Posted 55 minutes ago must be specific to this board. rock-3a which also uses RK3568 is not affected. btw. bleedingedge is intended to be used by developers only since breakage just like you noticed, is very much expected. 0 Quote
j0ta Posted 46 minutes ago Author Posted 46 minutes ago No problem, just to let you guys know Everything else is working Cheers ! 1 Quote
Werner Posted 40 minutes ago Posted 40 minutes ago Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
