I am trying to setup a 5ghz access point on D-Link DWA-171(according to wikidevi, it's 8811au) + NanoPI NEO PLUS2. I use the testing armbian image with latest update.
The hostapd can enable the 802.11a 5ghz AP mode with ht_enabled (but it says this chip doesn't support 802.11ac)
I can see the SSID shows in the phone. If I try to connect it, it will fail and says the station is out of range.
When the phone is trying to connect this AP, hostapd doesn't output any connection log even in debug mode.
Also, although I set the channel to 40, the WIFI analyzer on the phone shows it is using 38.
dmesg
[    2.672751] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002
[    2.672760] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.672765] usb usb9: Product: MUSB HDRC host driver
[    2.672771] usb usb9: Manufacturer: Linux 4.14.8-sunxi64 musb-hcd
[    2.672776] usb usb9: SerialNumber: musb-hdrc.1.auto
[    2.673347] hub 9-0:1.0: USB hub found
[    2.673394] hub 9-0:1.0: 1 port detected
[    2.785412] usb 5-1: New USB device found, idVendor=2001, idProduct=3314
[    2.785430] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.785441] usb 5-1: Product: 802.11n WLAN Adapter
[    2.785452] usb 5-1: Manufacturer: Realtek
[    2.785462] usb 5-1: SerialNumber: 00e04c000001
[    5.347943] usbcore: registered new interface driver 8812au
[    5.359691] 8812au 5-1:1.0 wlx409bcd4c305a: renamed from wlan1
Hostapd config
# armbian hostapd configuration example
# nl80211 mode
ssid=NEOPLUS2
interface=wlx409bcd4c305a
hw_mode=g
channel=40
#bridge=br0
driver=nl80211
logger_syslog=0
logger_syslog_level=0
wmm_enabled=1
wpa=2
preamble=1
wpa_passphrase=12345678
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
auth_algs=1
macaddr_acl=0
noscan=1
## IEEE 802.11n
ieee80211n=1
ht_capab=[HT40-][SHORT-GI-40][SHORT-GI-40][DSSS_CCK-40]
country_code=US
ieee80211d=1
## IEEE 802.11n
## IEEE 802.11a
hw_mode=a
channel=40
## IEEE 802.11a
### IEEE 802.11ac
#ht_capab=[HT40+][SHORT-GI-20][SHORT-GI-40][DSSS_CCK-40]
#ieee80211ac=1
#vht_capab=[MAX-MPDU-11454][SHORT-GI-80][TX-STBC-2BY1][RX-STBC-1][MAX-A-MPDU-LEN-EXP3]
#vht_oper_chwidth=1
#vht_oper_centr_freq_seg0_idx=42
### IEEE 802.11ac
# controlling enabled
ctrl_interface=/var/run/hostapd
ctrl_interface_group=0
Hostapd log
root@route:/home/user# hostapd -d /etc/hostapd.conf
random: Trying to read entropy from /dev/random
Configuration file: /etc/hostapd.conf
nl80211: Supported cipher 00-0f-ac:1
nl80211: Supported cipher 00-0f-ac:5
nl80211: Supported cipher 00-0f-ac:2
nl80211: Supported cipher 00-0f-ac:4
nl80211: Supported cipher 00-0f-ac:6
nl80211: Supported vendor command: vendor_id=0x1018 subcmd=1
nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=4106
nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=4107
nl80211: Supported vendor event: vendor_id=0x1018 subcmd=0
nl80211: Supported vendor event: vendor_id=0x1018 subcmd=1
nl80211: interface wlx409bcd4c305a in phy phy1
nl80211: Set mode ifindex 4 iftype 3 (AP)
nl80211: Setup AP(wlx409bcd4c305a) - device_ap_sme=1 use_monitor=0
nl80211: Subscribe to mgmt frames with AP handle 0xaaaaebfa4f80 (device SME)
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaaebfa4f80 match=04
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaaebfa4f80 match=0501
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaaebfa4f80 match=0504
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaaebfa4f80 match=06
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaaebfa4f80 match=08
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaaebfa4f80 match=09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaaebfa4f80 match=0a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaaebfa4f80 match=11
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaaebfa4f80 match=7f
nl80211: Enable Probe Request reporting nl_preq=0xaaaaebfa65d0
nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0xaaaaebfa65d0 match=
rfkill: initial event: idx=1 type=1 op=0 soft=0 hard=0
nl80211: Add own interface ifindex 4 (ifidx_reason -1)
nl80211: if_indices[16]: 4(-1)
phy: phy1
BSS count 1, BSSID mask 00:00:00:00:00:00 (0 bits)
wlx409bcd4c305a: interface state UNINITIALIZED->COUNTRY_UPDATE
Previous country code US, new country code US
nl80211: Regulatory information - country=US (DFS-FCC)
nl80211: 2402-2472 @ 40 MHz 30 mBm
nl80211: 5170-5250 @ 80 MHz 23 mBm
nl80211: 5250-5330 @ 80 MHz 23 mBm (DFS)
nl80211: 5490-5730 @ 160 MHz 23 mBm (DFS)
nl80211: 5735-5835 @ 80 MHz 30 mBm
nl80211: 57240-63720 @ 2160 MHz 40 mBm
nl80211: Added 802.11b mode based on 802.11g information
Disable HT capability [DSSS_CCK-40] on 5 GHz band
hw vht capab: 0x3c03122, conf vht capab: 0x0
HT40: control channel: 40  secondary channel: 36
Completing interface initialization
Mode: IEEE 802.11a  Channel: 40  Frequency: 5200 MHz
DFS 0 channels required radar detection
nl80211: Set freq 5200 (ht_enabled=1, vht_enabled=0, bandwidth=40 MHz, cf1=5190 MHz, cf2=0 MHz)
  * freq=5200
  * vht_enabled=0
  * ht_enabled=1
  * sec_channel_offset=-1
  * channel_type=2
RATE[0] rate=60 flags=0x1
RATE[1] rate=90 flags=0x0
RATE[2] rate=120 flags=0x1
RATE[3] rate=180 flags=0x0
RATE[4] rate=240 flags=0x1
RATE[5] rate=360 flags=0x0
RATE[6] rate=480 flags=0x0
RATE[7] rate=540 flags=0x0
hostapd_setup_bss(hapd=0xaaaaebfa57f0 (wlx409bcd4c305a), first=1)
wlx409bcd4c305a: Flushing old station entries
nl80211: flush -> DEL_STATION wlx409bcd4c305a (all)
wlx409bcd4c305a: Deauthenticate all stations
nl80211: sta_remove -> DEL_STATION wlx409bcd4c305a ff:ff:ff:ff:ff:ff --> -22 (Invalid argument)
wpa_driver_nl80211_set_key: ifindex=4 (wlx409bcd4c305a) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlx409bcd4c305a) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlx409bcd4c305a) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlx409bcd4c305a) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0
Using interface wlx409bcd4c305a with hwaddr 40:9b:cd:4c:30:5a and ssid "NEOPLUS2"
Deriving WPA PSK based on passphrase
SSID - hexdump_ascii(len=8):
     4e 45 4f 50 4c 55 53 32                           NEOPLUS2
PSK (ASCII passphrase) - hexdump_ascii(len=9): [REMOVED]
PSK (from passphrase) - hexdump(len=32): [REMOVED]
random: Got 17/20 bytes from /dev/random
random: Only 17/20 bytes of strong random data available from /dev/random
random: Not enough entropy pool available for secure operations
WPA: Not enough entropy in random pool for secure operations - update keys later when the first station connects
GMK - hexdump(len=32): [REMOVED]
Key Counter - hexdump(len=32): [REMOVED]
WPA: Delay group state machine start until Beacon frames have been configured
nl80211: Set beacon (beacon_set=0)
nl80211: Beacon head - hexdump(len=59): 80 00 00 00 ff ff ff ff ff ff 40 9b cd 4c 30 5a 40 9b cd 4c 30 5a 00 00 00 00 00 00 00 00 00 00 64 00 31 00 00 08 4e 45 4f 50 4c 55 53 32 01 08 8c 12 98 24 b0 48 60 6c 03 01 28
nl80211: Beacon tail - hexdump(len=130): 07 1c 55 53 20 24 01 17 26 01 17 28 01 17 2a 01 17 2c 01 17 2e 01 17 30 01 17 95 05 1e 00 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 0c 00 2d 1a 4e 00 1f ff 00 00 00 00 00 00 00 00 00 96 00 01 00 00 00 00 00 00 00 00 00 00 3d 16 28 07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 dd 18 00 50 f2 02 01 01 00 00 03 a4 00 00 27 a4 00 00 42 43 5e 00 62 32 2f 00
nl80211: ifindex=4
nl80211: beacon_int=100
nl80211: dtim_period=2
nl80211: ssid - hexdump_ascii(len=8):
  * beacon_int=100
  * dtim_period=2
nl80211: hidden SSID not in use
nl80211: privacy=1
nl80211: auth_algs=0x1
nl80211: wpa_version=0x2
nl80211: key_mgmt_suites=0x2
nl80211: pairwise_ciphers=0x10
nl80211: group_cipher=0x10
nl80211: SMPS mode - off
WPA: Start group state machine to set initial keys
WPA: group state machine entering state GTK_INIT (VLAN-ID 0)
GTK - hexdump(len=16): [REMOVED]
WPA: group state machine entering state SETKEYSDONE (VLAN-ID 0)
wpa_driver_nl80211_set_key: ifindex=4 (wlx409bcd4c305a) alg=3 addr=0xaaaae51bc4d8 key_idx=1 set_tx=1 seq_len=0 key_len=16
nl80211: KEY_DATA - hexdump(len=16): [REMOVED]
   broadcast key
nl80211: Set wlx409bcd4c305a operstate 0->1 (UP)
netlink: Operstate: ifindex=4 linkmode=-1 (no change), operstate=6 (IF_OPER_UP)
Failed to set TX queue parameters for queue 0.
Failed to set TX queue parameters for queue 1.
Failed to set TX queue parameters for queue 2.
Failed to set TX queue parameters for queue 3.
nl80211: Set Deny ACL (num_mac_acl=0)
nl80211: Failed to set MAC ACL: -1 (Operation not permitted)
Failed to set deny acl
wlx409bcd4c305a: interface state COUNTRY_UPDATE->ENABLED
wlx409bcd4c305a: AP-ENABLED
wlx409bcd4c305a: Setup of interface done.
ctrl_iface not configured!
random: Got 3/3 bytes from /dev/random
RTM_NEWLINK: ifi_index=4 ifname= operstate=6 linkmode=0 ifi_family=0 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
nl80211: Ignored event (cmd=33) for foreign interface (ifindex 3 wdev 0x0)
nl80211: Ignored event (cmd=34) for foreign interface (ifindex 3 wdev 0x0)
RTM_NEWLINK: ifi_index=3 ifname=wlan0 wext ifi_family=0 ifi_flags=0x1003 ([UP])
Edited by Igor
added spoilers
This autodetection process needs some improvements. Such config works for me in AC mode with 8811AU:
# nl80211 mode
ssid=ARMBIAN
interface=wlx40a5ef407b3f
hw_mode=g
channel=40
#bridge=br0
driver=nl80211
logger_syslog=0
wmm_enabled=1
wpa=2
preamble=1
wpa_psk=66eb31d2b48d19ba216f2e50c6831ee11be98e2fa3a8075e30b866f4a5ccda27
wpa_pairwise=TKIP
rsn_pairwise=CCMP
auth_algs=1
macaddr_acl=0
noscan=1
## IEEE 802.11n
ieee80211n=1
country_code=US
ieee80211d=1
## IEEE 802.11n
## IEEE 802.11a
hw_mode=a
channel=44
## IEEE 802.11a
### IEEE 802.11ac
ieee80211ac=1
vht_capab=[MAX-MPDU-11454][SHORT-GI-80][RX-STBC-1][MAX-A-MPDU-LEN-EXP3]
vht_oper_chwidth=1
### IEEE 802.11ac
Still same. Can see the SSID but can not connect it. And there is no connection log by hostapd.
Also, my laptop (marvell wireless card) can't see the SSID, but several smartphones can.
May I know which WIFI 8811au dongle do you use? Maybe I can get the same one.
I changed the country_code=TW. But neither US nor TW works.
root@route:/etc# hostapd -d hostapd.conf
Configuration file: hostapd.conf
nl80211: Subscribe to mgmt frames with AP handle 0xaaaaffd09f80 (device SME)
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaaffd09f80 match=04
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaaffd09f80 match=0501
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaaffd09f80 match=0504
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaaffd09f80 match=06
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaaffd09f80 match=08
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaaffd09f80 match=09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaaffd09f80 match=0a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaaffd09f80 match=11
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaaffd09f80 match=7f
nl80211: Enable Probe Request reporting nl_preq=0xaaaaffd0b5d0
nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0xaaaaffd0b5d0 match=
phy: phy1
Previous country code US, new country code TW
Continue interface setup after channel list update
random: Got 20/20 bytes from /dev/random
nl80211: Drv Event 36 (NL80211_CMD_REG_CHANGE) received for wlx409bcd4c305a
nl80211: Regulatory domain change
 * initiator=1
 * type=0
 * alpha2=TW
wlx409bcd4c305a: Event CHANNEL_LIST_CHANGED (28) received
Channel list updated - continue setup
nl80211: Regulatory information - country=TW (DFS-FCC)
nl80211: 2400-2483 @ 40 MHz 30 mBm
nl80211: 5150-5250 @ 80 MHz 23 mBm
nl80211: 5250-5350 @ 80 MHz 23 mBm (DFS)
nl80211: 5470-5725 @ 160 MHz 23 mBm (DFS)
nl80211: 5725-5850 @ 80 MHz 30 mBm
hw vht capab: 0x3c03122, conf vht capab: 0x1800122
HT40: control channel: 44  secondary channel: 48
Mode: IEEE 802.11a  Channel: 44  Frequency: 5220 MHz
nl80211: Set freq 5220 (ht_enabled=1, vht_enabled=1, bandwidth=80 MHz, cf1=5210 MHz, cf2=0 MHz)
  * freq=5220
  * vht_enabled=1
  * ht_enabled=1
  * bandwidth=80
  * channel_width=3
  * center_freq1=5210
  * center_freq2=0
hostapd_setup_bss(hapd=0xaaaaffd0a7f0 (wlx409bcd4c305a), first=1)
Using interface wlx409bcd4c305a with hwaddr 40:9b:cd:4c:30:5a and ssid "ARMBIAN"
SSID - hexdump_ascii(len=7):
     41 52 4d 42 49 41 4e                              ARMBIAN
PSK (ASCII passphrase) - hexdump_ascii(len=8): [REMOVED]
nl80211: Beacon head - hexdump(len=58): 80 00 00 00 ff ff ff ff ff ff 40 9b cd 4c 30 5a 40 9b cd 4c 30 5a 00 00 00 00 00 00 00 00 00 00 64 00 31 00 00 07 41 52 4d 42 49 41 4e 01 08 8c 12 98 24 b0 48 60 6c 03 01 2c
nl80211: Beacon tail - hexdump(len=159): 07 1e 54 57 20 22 01 17 24 01 17 26 01 17 28 01 17 2a 01 17 2c 01 17 2e 01 17 30 01 17 95 05 1e 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 0c 00 2d 1a 6e 00 1f ff 00 00 00 00 00 00 00 00 00 96 00 01 00 00 00 00 00 00 00 00 00 00 3d 16 2c 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 bf 0c 22 01 80 01 fe ff b2 01 fe ff b2 01 c0 05 01 2a 00 fc ff c3 04 02 2e 2e 2e dd 18 00 50 f2 02 01 01 00 00 03 a4 00 00 27 a4 00 00 42 43 5e 00 62 32 2f 00
nl80211: ifindex=4
nl80211: ssid - hexdump_ascii(len=7):
  * beacon_int=100
  * dtim_period=2
nl80211: privacy=1
wpa_driver_nl80211_set_key: ifindex=4 (wlx409bcd4c305a) alg=3 addr=0xaaaac70264d8 key_idx=1 set_tx=1 seq_len=0 key_len=16
   broadcast key
Edited by Igor
added spoilers
This is normal when you don't have a properly configured network. DHCP must be configured within your subnet or you can create a bridge and use DHCP server from your router. From logs, I can see that hostapd is configured properly and it is working in AC mode.
But is 5Ghz capable? This probably means that you need to choose some other channel. IIRC not all wireless cards can make use of the complete band.
I can see other APs on that channel so maybe my laptop is OK.
Tried this driver (https://github.com/aircrack-ng/rtl8812au) on my x86 laptop and the result is same. Can see SSID on phones but can't connect it.
I think my DHCP server is configured correctly. And because there is no connection log on hostapd, I think the problem is in the driver or device.
BTW, 2.4Ghz AP mode works correctly
