devan Posted yesterday at 01:14 AM Posted yesterday at 01:14 AM (edited) Orange pi 5 (i dont find way hot to make it in orange pi 5 section) English is not my native, i hope you understand and sorry for mistakes I spend like 3 days on this problem and i think i am stuck I tested offisial image and Josua and there i can use my wifi normally Setup orange pi 5 v1.3.2 clened spi (i got problem like here) armbian 26.5.1 vendor 6.1.115 (from armbian imager on windows) sandisk extreme 64gb sd card after boot i runs sudo apt update sudo apt upgrade -y armbian-config (choose orange pi 5 ap6275p overlay) /boot/armbianEnv.txt verbosity=1 bootlogo=false console=both extraargs=cma=256M overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588s-orangepi-5.dtb rootdev=UUID=... rootfstype=ext4 overlays=orangepi-5-ap6275p usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u But after reboot wifi module do not works as expected ip a lspci do not show any device As i think now it is some dtbo files problems and i think key is somthing around line: [ 121.023832] rk-pcie fe190000.pcie: PCIe Link Fail, LTSSM is 0x3, hw_retries=1 there is a guy figures same error but the lines he added already included for me wifi and pcie dmesg greps (by the way armbian takes too long to boot and i fond sombody figures same problem and he syas that time depends on size of sd card) root@orangepi5:~# dmesg | grep wifi [ 116.704296] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275p [ 116.704300] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 116.704303] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 116.704340] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found ! [ 116.704348] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1 root@orangepi5:~# dmesg | grep pcie [ 19.019616] reg-fixed-voltage vcc3v3-pcie2x1l2: Looking up vin-supply from device tree [ 19.020209] vcc3v3_pcie2x1l2: supplied by vcc5v0_sys [ 19.079124] vcc3v3_pcie2x1l2: 1800 mV, enabled [ 19.085641] reg-fixed-voltage vcc3v3-pcie2x1l2: vcc3v3_pcie2x1l2 supplying 1800000uV [ 115.377859] dw-pcie fe190000.pcie: invalid resource [ 115.378688] dw-pcie fe190000.pcie: Failed to initialize host [ 115.378975] dw-pcie: probe of fe190000.pcie failed with error -22 [ 115.405440] rk-pcie fe190000.pcie: invalid prsnt-gpios property in node [ 115.405658] rk-pcie fe190000.pcie: Looking up vpcie3v3-supply from device tree [ 115.407223] rk-pcie fe190000.pcie: can't get current limit. [ 115.409940] rk-pcie fe190000.pcie: host bridge /pcie@fe190000 ranges: [ 115.410471] rk-pcie fe190000.pcie: IO 0x00f4100000..0x00f41fffff -> 0x00f4100000 [ 115.410659] rk-pcie fe190000.pcie: MEM 0x00f4200000..0x00f4ffffff -> 0x00f4200000 [ 115.410757] rk-pcie fe190000.pcie: MEM 0x0a00000000..0x0a3fffffff -> 0x0a00000000 [ 115.410961] rk-pcie fe190000.pcie: iATU unroll: enabled [ 115.410983] rk-pcie fe190000.pcie: iATU regions: 8 ob, 8 ib, align 64K, limit 8G [ 115.613333] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 115.634444] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 115.655522] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 115.676607] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 115.697683] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 115.718758] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 115.739838] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 115.760912] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 115.781986] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 115.803060] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 116.912753] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply from device tree [ 116.912767] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply property in node /power-management@fd8d8000/power-controller failed [ 117.713882] rk-pcie fe190000.pcie: PCIe Link Fail, LTSSM is 0x3, hw_retries=0 [ 120.627876] rk_pcie_establish_link: 171 callbacks suppressed [ 120.627888] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 120.648138] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 120.668247] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 120.689287] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 120.710332] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 120.731354] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 120.751458] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 120.772474] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 120.793551] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 120.814586] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 121.023832] rk-pcie fe190000.pcie: PCIe Link Fail, LTSSM is 0x3, hw_retries=1 [ 122.034993] rk-pcie fe190000.pcie: failed to initialize host Context about long boot: On 19 sec [ 19.315369] NetLabel: Initializing [ 19.315574] NetLabel: domain hash size = 128 [ 19.315819] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 19.318283] NetLabel: unlabeled traffic allowed by default [ 19.328104] vgaarb: loaded [ 19.365221] clocksource: Switched to clocksource arch_sys_counter [ 69.713069] VFS: Disk quotas dquot_6.6.0 [ 69.715555] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 69.734240] AppArmor: AppArmor Filesystem Enabled And on 73 sec [ 73.253310] NET: Registered PF_ALG protocol family [ 73.253416] Key type asymmetric registered [ 73.253451] Asymmetric key parser 'x509' registered [ 113.848019] Freeing initrd memory: 15860K [ 114.505595] alg: self-tests for CTR-KDF (hmac(sha256)) passed [ 114.508695] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 241) [ 114.512435] io scheduler mq-deadline registered So i do not know reason and where i need to look. Maybe it is broken dtbo or i need to load spesial spi because i am not spesialist at this point and i cand find sombody figured same problem. I also got full dmesg for orange pi os (where wifi works) and armbian boot with and without wifi configured if any body needs it Edited yesterday at 01:17 AM by devan 0 Quote
Werner Posted yesterday at 05:02 AM Posted yesterday at 05:02 AM attach serial console to check uboot log if the overlay is actually loaded 0 Quote
devan Posted 2 hours ago Author Posted 2 hours ago So i catch uboot log. But i dont really understand what is whrong Maybe this ## Flattened Device Tree blob at 12000000 Booting using the fdt blob at 0x12000000 Working FDT set to 12000000 Loading Ramdisk to ebc82000, end ecbff1c5 ... OK Loading Device Tree to 00000000ecdef000, end 00000000ece94fff ... OK Working FDT set to ecdef000 Also pinning full boot file (i colapsed repeading lines) a_wifi_uart_debug 0 Quote
Werner Posted 1 hour ago Posted 1 hour ago It doesn't even attempt to load which is odd. usually it tells you that it (at least) attempts to load in both success and failure cases. Everything else looks pretty normal. 0 Quote
devan Posted 22 minutes ago Author Posted 22 minutes ago (edited) You was right, i entered wrong name in /boot/armbianEnv.txt now it is: verbosity=7 bootlogo=false console=both extraargs=cma=256M overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588s-orangepi-5.dtb rootdev=UUID=... rootfstype=ext4 overlays=orangepi-5-ap6275p usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u But wifi still not working I also recorded successful launch of Joshua-Riek ubuntu Both with dtb files loading log Armbian Working FDT set to 12000000 398 bytes read in 56 ms (6.8 KiB/s) Applying kernel provided DT overlay rockchip-rk3588-orangepi-5-ap6275p.dtbo Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Ubuntu Joshua-Riek Retrieving file: /boot/initrd.img-6.1.0-1025-rockchip 16754764 bytes read in 1362 ms (11.7 MiB/s) Retrieving file: /boot/vmlinuz-6.1.0-1025-rockchip 53682688 bytes read in 4334 ms (11.8 MiB/s) append: root=UUID=... rootwait rw console=ttyS2,1500000 console=tty1 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory Retrieving file: /lib/firmware/6.1.0-1025-rockchip/device-tree/rockchip/rk3588s-orangepi-5.dtb 260529 bytes read in 287 ms (885.7 KiB/s) Retrieving file: /lib/firmware/6.1.0-1025-rockchip/device-tree/rockchip/overlay/orangepi-5-ap6275p.dtbo 398 bytes read in 329 ms (1000 Bytes/s) Fdt Ramdisk skip relocation and key differense in the end: Armbian -> [ 117.425678] rk-pcie fe190000.pcie: PCIe Link Fail, LTSSM is 0x3, hw_retries=0 Joshuas Ubuntu -> [ 20.633531] rk-pcie fe190000.pcie: PCIe Link up, LTSSM is 0x30011 Ai tolds me it is PHY problems or wrons vcc3v3_pcie2x1l2 power consumption setup but is same for Joshua-Riek and Armbian (1800000 mA) Attaching full logs u-Ubuntu a-Armbian a_wifi_uart_debug u_wifi_uart_debug Edited 13 minutes ago by devan 0 Quote
