Mikec Posted January 14, 2016 Share Posted January 14, 2016 I wanted to try 3.4 to see if I could build FFmpeg with the legacy Kernel. When I run any of the three (Trusty, Jessie, Wheezy) as soon as the script says starting Kernel, I get a few blue and green noise lines on the screen and then the screen disappears. I can use SSH and.the system is booting up and running. The one thing that I noticed is that when I log on, the name of the machine is LIME instead of MICRO. I'm running an Olimex Olinuxino Micro. Is there a config file that I need to tweek, or is the Kernel setup for a LIME? thanks MikeC Link to comment Share on other sites More sharing options...
Mikec Posted January 15, 2016 Author Share Posted January 15, 2016 Did I make a mistake and download the wrong files.... When I open the xorg.conf file I find this Section "Device" Identifier "Allwinner A10/A13 FBDEV" Driver "fbturbo" Option "fbdev" "/dev/fb0" Option "SwapbuffersWait" "true" EndSection when I log on from SSH I get the LIME stencil instead of the MICRO stencil... I am running a Olimex Olinuxino Micro not the Lime Link to comment Share on other sites More sharing options...
Igor Posted January 15, 2016 Share Posted January 15, 2016 When I run any of the three (Trusty, Jessie, Wheezy) as soon as the script says starting Kernel, I get a few blue and green noise lines on the screen and then the screen disappears. That's normal. The only diff between micro and lime is a config. Check where your /boot/script.bin points to ... if it's not pointing to proper one, change. So you get nothing on the screen but you can login via SSH? Link to comment Share on other sites More sharing options...
Mikec Posted January 16, 2016 Author Share Posted January 16, 2016 Yes it is a newer ASuS, and it is running at 1920X1080P60 is that too high for the 3.4? There are a couple of lines in dmesg that says that it can't match up the frequency with a mode. it there a way to mount the monitor after the system boots? Link to comment Share on other sites More sharing options...
Igor Posted January 16, 2016 Share Posted January 16, 2016 Later Uboot auto detect monitor via EDID but if you got those green lines, that's ok ... as long as it's not UHD monitor 1440p-2160p .. In that case no picture is a normal (bug) behavior. Yes, try to boot without and attach it later ... next check if your script.bin, section for video output is having correct numbers. Correct = HDMI, not correct anything else. http://linux-sunxi.org/Display script.bin/fex file Link to comment Share on other sites More sharing options...
