July 14Jul 14 Hi ! I was trying to use SPI communication with Banana Pi M2 Pro. ย I am currently using Armbian 26.5.1 and I realized that I cannot find spidev from /boot/dev/ . ย I tried loading all dtbo files from armbian-config but still I can't get SPI. ย Is there something that I haven't check yet?
July 14Jul 14 Gemini info ๐ย ..... In the official, pure Armbian for Banana Pi M2 Pro, enabling SPI is currently extremely difficult (and even impossible for the average user) If you absolutely need the SPI bus for your project: Operating system change: SPI works without any problems on official system images provided directly by the board manufacturer (BPI-M2 Pro Debian/Ubuntu with kernel 4.9 from Amlogic). The manufacturer uses an older but fully modified kernel (Kernel BSP), where all pins are rigidly and correctly assigned. Or... Staying with Armbian: If you must stick with Armbian, it's safer to abandon SPI attempts andโif possibleโconnect the target device to a free I2C bus or UART serial communication (which work flawlessly in Armbian on this board). But ultimately, the Armbian system developer will have to decide. (Maybe there is some method to enable SPI on the latest Armbian images/firmware?)ย ๐ย Check https://docs.banana-pi.org/en/BPI-M2_Pro/BananaPi_BPI-M2_Pro Armbian olderย firmware (bananapi manufacturer's firmware) (bookworm):ย https://drive.google.com/drive/folders/1DPkc7AHEZVS7PT_yzhNH1Dfuiz99mE0p Edited July 15Jul 15 by kris777
August 9Aug 9 Am I correct in assuming this applies to similiar boards as well ? I tried a Radxa Zero board, with two SPI interfaces listed as possible options in the Radxa docs. Enabling the corresponding overlay with "armbian-config" (radxa-zero-spi-spidev) shows up correctly in theย armbianEnv.txt file, but has no effect. There is no spi<x> in /dev. ย BTW, I tried the latest release from Radxa, but it has no support for the onboard Wifi/BT module, only shared ethernet via USB-OTG. Which is why I try Armbian and DietPi. ย Could this be related to this issue ? :ย ย
