kris777 Posted April 21 Posted April 21 Is it possible to enable the I2S service (for audio) on BananaPim2pro? In the program configuration: armbian-config / manage device tree overlays...there are no entries for: I2S. Maybe someone already knows what to enter or how to enable it 🙂 0 Quote
Igor Posted April 21 Posted April 21 1 hour ago, kris777 said: there are no entries for: I2S This likely means the I2S overlay doesn’t exist yet. Someone would need to implement it and add it upstream (or just here to Armbian build framework). You can try enabling it manually via the Device Tree editor: https://docs.armbian.com/User-Guide_Armbian-Config/System/#device-tree-editor No guarantees it will work — hardware descriptions are often incomplete or inaccurate, and that’s outside our control. 0 Quote
kris777 Posted April 22 Author Posted April 22 Thank you for any information... when I have more time I will try with the help of AI... because I don't have enough knowledge myself 🙂 regards 0 Quote
kris777 Posted May 3 Author Posted May 3 I tried to enable the I2S / PCM5102 service with AI, but unfortunately, despite numerous attempts, I couldn't. But anyone can use a USB audio card. Maybe someone else will figure out how to enable it 🙂 Best regards 0 Quote
