devrus Posted January 7, 2018 Posted January 7, 2018 Want to know if some one succeded compiling ffmpeg with hw acceleration? Actually I'm looking for board which is good for Home Media Server with support for transcoding 1080p(4k? if any can) with good fps (24+) Already tried rpi3 results are not that good as i want 13fps for 720p x264 Hi10 5Mb/s bitrate=> 720p x264 5Mb/s bitrate So i think 1080p will be much slower. Do you think orange pi prime can handle this type of tasks well? 1
chwe Posted January 8, 2018 Posted January 8, 2018 pi prime = H5 = mainline only (armbian) = no hw acceleration
manuti Posted January 8, 2018 Posted January 8, 2018 The info is in Spanish https://raspberryparatorpes.net/proyectos/optimizar-videos-para-ipad-en-plex/ But in short the numbers are: In the Banana PRO that is dual core and running the entire OMV server with Samba, torrent and Plex I have achieved a speed of about 0.15x, that is, to convert a 1h video it takes 6h40. Then I tried the Raspberry Pi 2 with the same video and conversion reaches about 0.40x. We move to the newer model, the Raspberry Pi 3 also reaches about 0.75x Testing with the Orange Pi PC gives us 0.58x And finally the Orange Pi PC2 same SoC reaches 0.9x As a final test, I compared it with a normal laptop, a Lenova Yoga 2 with an intel Core 1.6GHz Intel Core i5 4200U is achieved to 2.85x This number are only an example it may vary depending your case.
Tido Posted January 8, 2018 Posted January 8, 2018 58 minutes ago, manuti said: Lenova Yoga 2 with an intel Core 1.6GHz Intel Core i5 4200U Did you make use of: Intel Quick Sync Video? Intel Quick Sync Video uses the dedicated media processing capabilities of Intel Graphics Technology to decode and encode fast, enabling the processor to complete other tasks and improving system responsiveness.
manuti Posted January 8, 2018 Posted January 8, 2018 I don't know if I use or not, I use the same instruction en every machine: ffmpeg -i input.mkv -vcodec libx264 -profile:v main -level 3.1 -preset medium -crf 23 -x264-params ref=4 -acodec copy -movflags +faststart output.mp4 Usually the ffmpeg detects the processor capabilities like you can see on the OPiPC2 with H5 with ARMv8 and NEON
Tido Posted January 8, 2018 Posted January 8, 2018 It would have been interesting how much faster Intel Quick Sync Video is versus ffmpeg.
devrus Posted January 8, 2018 Author Posted January 8, 2018 Yesterday I've finaly fixed problems with my rpi3 and achived x2.86 transcoding speed on rpi3 for 720p video Here is log file from Emby Spoiler 2018-01-08 21:25:20.984 Application version: 3.2.60.0 http://192.168.1.166:8096/emby/videos/603ca3579c66c739dc474c5a9d8faa61/hls1/main/0.ts?DeviceId=f3f59edb98f7568ede27193c757b6c9418951356&MediaSourceId=603ca3579c66c739dc474c5a9d8faa61&VideoCodec=h264&AudioCodec=ac3,eac3,aac,mp3&AudioStreamIndex=1&VideoBitrate=9808000&AudioBitrate=192000&PlaySessionId=e8b499b8384e4118ac892789f5aafb1e&api_key=9f196ee35e0b4905945c0ecd8da1dc69&CopyTimestamps=false&TranscodingMaxAudioChannels=6&EnableSubtitlesInManifest=false&Tag=6edf546b25b41ca85a9afd7710ecb4ae&RequireAvc=false&RequireNonAnamorphic=false&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=False&TranscodeReasons=VideoProfileNotSupported&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51 {"Protocol":"File","Id":"603ca3579c66c739dc474c5a9d8faa61","Path":"/mnt/library/Torrent/Anime/movie.mkv","Type":"Default","Container":"mkv,webm","Name":"movie.mkv","IsRemote":false,"ETag":"6edf546b25b41ca85a9afd7710ecb4ae","RunTimeTicks":14224480256,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"RequiresLooping":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","TimeBase":"1/1000","CodecTimeBase":"1001/48000","DisplayTitle":"720P H264","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":4375014,"BitDepth":10,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":720,"Width":1280,"AverageFrameRate":23.9760246,"RealFrameRate":23.9760246,"Profile":"High 10","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p10le","Level":41,"IsAnamorphic":false},{"Codec":"ac3","Language":"rus","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Ancord & Nika_Lenina","DisplayTitle":"Rus Dolby Digital stereo Default","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"vorbis","Language":"jpn","TimeBase":"1/1000","CodecTimeBase":"1/48000","DisplayTitle":"Jpn VORBIS stereo","IsInterlaced":false,"ChannelLayout":"stereo","Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false}],"Formats":[],"Bitrate":4375014,"RequiredHttpHeaders":{}} User policy for devrus: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True /usr/local/bin/ffmpeg -c:v h264_mmal -i file:"/mnt/library/Torrent/Anime/movie.mkv" -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_omx -vf "scale=trunc(min(max(iw\,ih*dar)\,1920)/2)*2:trunc(ow/dar/2)*2" -b:v 4375014 -maxrate 4375014 -bufsize 8750028 -force_key_frames "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -copyts -vsync -1 -codec:a:0 copy -f segment -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8" -y "/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc%d.ts" ffmpeg version git-2018-01-07-476665d Copyright (c) 2000-2018 the FFmpeg developers built with gcc 4.9.2 (Raspbian 4.9.2-10) configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --disable-ffplay --disable-indev=sndio --disable-outdev=sndio --enable-fontconfig --enable-frei0r --enable-gnutls --enable-gray --enable-libfribidi --enable-libass --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-librubberband --enable-librtmp --enable-libsoxr --enable-libspeex --enable-libvorbis --enable-libopus --enable-libtheora --enable-libvidstab --enable-libvo-amrwbenc --enable-libvpx --enable-libwebp --enable-libx264 --enable-libxvid --enable-omx-rpi --enable-omx --enable-mmal libavutil 56. 7.100 / 56. 7.100 libavcodec 58. 9.100 / 58. 9.100 libavformat 58. 3.100 / 58. 3.100 libavdevice 58. 0.100 / 58. 0.100 libavfilter 7. 11.101 / 7. 11.101 libswscale 5. 0.101 / 5. 0.101 libswresample 3. 0.101 / 3. 0.101 libpostproc 55. 0.100 / 55. 0.100 Input #0, matroska,webm, from 'file:/mnt/library/Torrent/Anime/movie.mkv': Metadata: encoder : libebml v1.0.0 + libmatroska v1.0.0 creation_time : 2013-07-01T09:12:58.000000Z Duration: 00:23:42.45, start: 0.000000, bitrate: 4375 kb/s Stream #0:0: Video: h264 (High 10), yuv420p10le(progressive), 1280x720 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc Stream #0:1(rus): Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s (default) Metadata: title : Ancord & Nika_Lenina Stream #0:2(jpn): Audio: vorbis, 48000 Hz, stereo, fltp Stream mapping: Stream #0:0 -> #0:0 (h264 (h264_mmal) -> h264 (h264_omx)) Stream #0:1 -> #0:1 (copy) Press [q] to stop, [?] for help [h264_omx @ 0x362fda0] Using OMX.broadcom.video_encode [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc0.ts' for writing Output #0, segment, to '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc%d.ts': Metadata: encoder : Lavf58.3.100 Stream #0:0: Video: h264 (h264_omx), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=2-31, 4375 kb/s, 23.98 fps, 90k tbn, 23.98 tbc Metadata: encoder : Lavc58.9.100 h264_omx Stream #0:1: Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s (default) frame= 25 fps=0.0 q=-0.0 size=N/A time=00:00:02.81 bitrate=N/A speed=5.44x frame= 56 fps= 55 q=-0.0 size=N/A time=00:00:04.00 bitrate=N/A speed=3.92x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc1.ts' for writing frame= 86 fps= 56 q=-0.0 size=N/A time=00:00:05.28 bitrate=N/A speed=3.45x frame= 117 fps= 58 q=-0.0 size=N/A time=00:00:06.56 bitrate=N/A speed=3.22x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc2.ts' for writing frame= 149 fps= 59 q=-0.0 size=N/A time=00:00:07.84 bitrate=N/A speed=3.09x frame= 180 fps= 59 q=-0.0 size=N/A time=00:00:09.37 bitrate=N/A speed=3.08x frame= 212 fps= 60 q=-0.0 size=N/A time=00:00:10.36 bitrate=N/A speed=2.92x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc3.ts' for writing frame= 242 fps= 60 q=-0.0 size=N/A time=00:00:11.68 bitrate=N/A speed=2.88x frame= 275 fps= 60 q=-0.0 size=N/A time=00:00:13.15 bitrate=N/A speed=2.88x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc4.ts' for writing frame= 306 fps= 60 q=-0.0 size=N/A time=00:00:14.43 bitrate=N/A speed=2.84x frame= 337 fps= 60 q=-0.0 size=N/A time=00:00:15.74 bitrate=N/A speed=2.82x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc5.ts' for writing frame= 369 fps= 61 q=-0.0 size=N/A time=00:00:17.02 bitrate=N/A speed=2.79x frame= 399 fps= 60 q=-0.0 size=N/A time=00:00:18.27 bitrate=N/A speed=2.76x frame= 431 fps= 61 q=-0.0 size=N/A time=00:00:19.68 bitrate=N/A speed=2.76x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc6.ts' for writing frame= 460 fps= 60 q=-0.0 size=N/A time=00:00:20.73 bitrate=N/A speed=2.72x frame= 492 fps= 60 q=-0.0 size=N/A time=00:00:22.04 bitrate=N/A speed=2.71x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc7.ts' for writing frame= 522 fps= 60 q=-0.0 size=N/A time=00:00:23.29 bitrate=N/A speed=2.69x frame= 554 fps= 60 q=-0.0 size=N/A time=00:00:24.60 bitrate=N/A speed=2.69x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc8.ts' for writing frame= 584 fps= 60 q=-0.0 size=N/A time=00:00:26.01 bitrate=N/A speed=2.69x frame= 613 fps= 60 q=-0.0 size=N/A time=00:00:27.16 bitrate=N/A speed=2.67x frame= 627 fps= 59 q=-0.0 size=N/A time=00:00:27.68 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc9.ts' for writing frame= 657 fps= 59 q=-0.0 size=N/A time=00:00:29.12 bitrate=N/A speed= 2.6x frame= 689 fps= 59 q=-0.0 size=N/A time=00:00:30.43 bitrate=N/A speed= 2.6x frame= 720 fps= 59 q=-0.0 size=N/A time=00:00:31.96 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc10.ts' for writing frame= 751 fps= 59 q=-0.0 size=N/A time=00:00:32.92 bitrate=N/A speed=2.59x frame= 782 fps= 59 q=-0.0 size=N/A time=00:00:34.24 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc11.ts' for writing frame= 814 fps= 59 q=-0.0 size=N/A time=00:00:35.87 bitrate=N/A speed=2.61x frame= 845 fps= 59 q=-0.0 size=N/A time=00:00:36.89 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc12.ts' for writing frame= 875 fps= 59 q=-0.0 size=N/A time=00:00:38.36 bitrate=N/A speed= 2.6x frame= 906 fps= 59 q=-0.0 size=N/A time=00:00:39.39 bitrate=N/A speed=2.58x frame= 938 fps= 60 q=-0.0 size=N/A time=00:00:40.92 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc13.ts' for writing frame= 970 fps= 60 q=-0.0 size=N/A time=00:00:42.27 bitrate=N/A speed= 2.6x frame= 1001 fps= 60 q=-0.0 size=N/A time=00:00:43.55 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc14.ts' for writing frame= 1032 fps= 60 q=-0.0 size=N/A time=00:00:44.60 bitrate=N/A speed=2.58x frame= 1066 fps= 60 q=-0.0 size=N/A time=00:00:46.14 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc15.ts' for writing frame= 1096 fps= 60 q=-0.0 size=N/A time=00:00:47.23 bitrate=N/A speed=2.58x frame= 1128 fps= 60 q=-0.0 size=N/A time=00:00:48.76 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc16.ts' for writing frame= 1160 fps= 60 q=-0.0 size=N/A time=00:00:49.88 bitrate=N/A speed=2.58x frame= 1192 fps= 60 q=-0.0 size=N/A time=00:00:51.23 bitrate=N/A speed=2.58x frame= 1225 fps= 60 q=-0.0 size=N/A time=00:00:52.99 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc17.ts' for writing frame= 1256 fps= 60 q=-0.0 size=N/A time=00:00:54.27 bitrate=N/A speed=2.61x frame= 1287 fps= 60 q=-0.0 size=N/A time=00:00:55.26 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc18.ts' for writing frame= 1318 fps= 60 q=-0.0 size=N/A time=00:00:56.54 bitrate=N/A speed=2.59x frame= 1351 fps= 60 q=-0.0 size=N/A time=00:00:58.20 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc19.ts' for writing frame= 1382 fps= 60 q=-0.0 size=N/A time=00:00:59.23 bitrate=N/A speed=2.59x frame= 1413 fps= 60 q=-0.0 size=N/A time=00:01:00.54 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc20.ts' for writing frame= 1444 fps= 60 q=-0.0 size=N/A time=00:01:01.72 bitrate=N/A speed=2.59x frame= 1474 fps= 60 q=-0.0 size=N/A time=00:01:03.16 bitrate=N/A speed=2.59x frame= 1504 fps= 60 q=-0.0 size=N/A time=00:01:04.51 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc21.ts' for writing frame= 1533 fps= 60 q=-0.0 size=N/A time=00:01:05.79 bitrate=N/A speed=2.59x frame= 1565 fps= 60 q=-0.0 size=N/A time=00:01:07.07 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc22.ts' for writing frame= 1595 fps= 60 q=-0.0 size=N/A time=00:01:08.12 bitrate=N/A speed=2.58x frame= 1627 fps= 60 q=-0.0 size=N/A time=00:01:09.63 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc23.ts' for writing frame= 1659 fps= 61 q=-0.0 size=N/A time=00:01:10.97 bitrate=N/A speed=2.59x frame= 1691 fps= 61 q=-0.0 size=N/A time=00:01:12.25 bitrate=N/A speed=2.59x frame= 1723 fps= 61 q=-0.0 size=N/A time=00:01:13.56 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc24.ts' for writing frame= 1756 fps= 61 q=-0.0 size=N/A time=00:01:14.94 bitrate=N/A speed=2.59x frame= 1789 fps= 61 q=-0.0 size=N/A time=00:01:16.48 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc25.ts' for writing frame= 1822 fps= 61 q=-0.0 size=N/A time=00:01:17.60 bitrate=N/A speed=2.59x frame= 1854 fps= 61 q=-0.0 size=N/A time=00:01:19.04 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc26.ts' for writing frame= 1886 fps= 61 q=-0.0 size=N/A time=00:01:20.57 bitrate=N/A speed= 2.6x frame= 1918 fps= 61 q=-0.0 size=N/A time=00:01:21.72 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc27.ts' for writing frame= 1950 fps= 61 q=-0.0 size=N/A time=00:01:22.94 bitrate=N/A speed=2.59x frame= 1981 fps= 61 q=-0.0 size=N/A time=00:01:24.25 bitrate=N/A speed=2.59x frame= 2013 fps= 61 q=-0.0 size=N/A time=00:01:25.69 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc28.ts' for writing frame= 2045 fps= 61 q=-0.0 size=N/A time=00:01:26.97 bitrate=N/A speed=2.59x frame= 2077 fps= 61 q=-0.0 size=N/A time=00:01:28.19 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc29.ts' for writing frame= 2108 fps= 61 q=-0.0 size=N/A time=00:01:29.72 bitrate=N/A speed= 2.6x frame= 2140 fps= 61 q=-0.0 size=N/A time=00:01:31.00 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc30.ts' for writing frame= 2172 fps= 61 q=-0.0 size=N/A time=00:01:32.22 bitrate=N/A speed=2.59x frame= 2203 fps= 61 q=-0.0 size=N/A time=00:01:33.56 bitrate=N/A speed= 2.6x frame= 2233 fps= 61 q=-0.0 size=N/A time=00:01:34.88 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc31.ts' for writing frame= 2265 fps= 61 q=-0.0 size=N/A time=00:01:36.22 bitrate=N/A speed=2.59x frame= 2297 fps= 61 q=-0.0 size=N/A time=00:01:37.37 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc32.ts' for writing frame= 2327 fps= 61 q=-0.0 size=N/A time=00:01:38.52 bitrate=N/A speed=2.59x frame= 2358 fps= 61 q=-0.0 size=N/A time=00:01:39.93 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc33.ts' for writing frame= 2388 fps= 61 q=-0.0 size=N/A time=00:01:41.28 bitrate=N/A speed=2.59x frame= 2419 fps= 61 q=-0.0 size=N/A time=00:01:42.40 bitrate=N/A speed=2.58x frame= 2450 fps= 61 q=-0.0 size=N/A time=00:01:43.87 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc34.ts' for writing frame= 2479 fps= 61 q=-0.0 size=N/A time=00:01:44.89 bitrate=N/A speed=2.58x frame= 2510 fps= 61 q=-0.0 size=N/A time=00:01:46.30 bitrate=N/A speed=2.58x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc35.ts' for writing frame= 2539 fps= 61 q=-0.0 size=N/A time=00:01:47.58 bitrate=N/A speed=2.58x frame= 2569 fps= 61 q=-0.0 size=N/A time=00:01:48.76 bitrate=N/A speed=2.58x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc36.ts' for writing frame= 2600 fps= 61 q=-0.0 size=N/A time=00:01:50.08 bitrate=N/A speed=2.58x frame= 2630 fps= 61 q=-0.0 size=N/A time=00:01:51.26 bitrate=N/A speed=2.58x frame= 2663 fps= 61 q=-0.0 size=N/A time=00:01:52.64 bitrate=N/A speed=2.58x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc37.ts' for writing frame= 2693 fps= 61 q=-0.0 size=N/A time=00:01:53.92 bitrate=N/A speed=2.58x frame= 2723 fps= 61 q=-0.0 size=N/A time=00:01:55.10 bitrate=N/A speed=2.58x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc38.ts' for writing frame= 2753 fps= 61 q=-0.0 size=N/A time=00:01:56.38 bitrate=N/A speed=2.58x frame= 2782 fps= 61 q=-0.0 size=N/A time=00:01:57.76 bitrate=N/A speed=2.58x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc39.ts' for writing frame= 2812 fps= 61 q=-0.0 size=N/A time=00:01:58.94 bitrate=N/A speed=2.57x frame= 2842 fps= 61 q=-0.0 size=N/A time=00:02:00.06 bitrate=N/A speed=2.57x frame= 2874 fps= 61 q=-0.0 size=N/A time=00:02:01.56 bitrate=N/A speed=2.57x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc40.ts' for writing frame= 2903 fps= 61 q=-0.0 size=N/A time=00:02:02.59 bitrate=N/A speed=2.57x frame= 2935 fps= 61 q=-0.0 size=N/A time=00:02:04.03 bitrate=N/A speed=2.57x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc41.ts' for writing frame= 2966 fps= 61 q=-0.0 size=N/A time=00:02:05.31 bitrate=N/A speed=2.57x frame= 2996 fps= 61 q=-0.0 size=N/A time=00:02:06.52 bitrate=N/A speed=2.57x frame= 3026 fps= 61 q=-0.0 size=N/A time=00:02:07.74 bitrate=N/A speed=2.57x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc42.ts' for writing frame= 3058 fps= 61 q=-0.0 size=N/A time=00:02:09.15 bitrate=N/A speed=2.57x frame= 3091 fps= 61 q=-0.0 size=N/A time=00:02:10.40 bitrate=N/A speed=2.57x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc43.ts' for writing frame= 3117 fps= 61 q=-0.0 size=N/A time=00:02:11.55 bitrate=N/A speed=2.56x frame= 3148 fps= 61 q=-0.0 size=N/A time=00:02:12.80 bitrate=N/A speed=2.56x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc44.ts' for writing frame= 3180 fps= 61 q=-0.0 size=N/A time=00:02:14.30 bitrate=N/A speed=2.57x frame= 3211 fps= 61 q=-0.0 size=N/A time=00:02:15.68 bitrate=N/A speed=2.57x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc45.ts' for writing frame= 3243 fps= 61 q=-0.0 size=N/A time=00:02:17.08 bitrate=N/A speed=2.57x frame= 3275 fps= 61 q=-0.0 size=N/A time=00:02:18.36 bitrate=N/A speed=2.57x frame= 3307 fps= 61 q=-0.0 size=N/A time=00:02:19.55 bitrate=N/A speed=2.57x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc46.ts' for writing frame= 3340 fps= 61 q=-0.0 size=N/A time=00:02:20.83 bitrate=N/A speed=2.57x frame= 3373 fps= 61 q=-0.0 size=N/A time=00:02:22.43 bitrate=N/A speed=2.57x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc47.ts' for writing frame= 3404 fps= 61 q=-0.0 size=N/A time=00:02:23.52 bitrate=N/A speed=2.57x frame= 3426 fps= 61 q=-0.0 size=N/A time=00:02:24.41 bitrate=N/A speed=2.56x frame= 3458 fps= 61 q=-0.0 size=N/A time=00:02:25.98 bitrate=N/A speed=2.56x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc48.ts' for writing frame= 3489 fps= 61 q=-0.0 size=N/A time=00:02:27.16 bitrate=N/A speed=2.56x frame= 3519 fps= 61 q=-0.0 size=N/A time=00:02:28.32 bitrate=N/A speed=2.56x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc49.ts' for writing frame= 3550 fps= 61 q=-0.0 size=N/A time=00:02:29.69 bitrate=N/A speed=2.56x frame= 3581 fps= 61 q=-0.0 size=N/A time=00:02:30.88 bitrate=N/A speed=2.56x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc50.ts' for writing frame= 3613 fps= 61 q=-0.0 size=N/A time=00:02:32.28 bitrate=N/A speed=2.56x frame= 3645 fps= 61 q=-0.0 size=N/A time=00:02:33.56 bitrate=N/A speed=2.56x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc51.ts' for writing frame= 3676 fps= 61 q=-0.0 size=N/A time=00:02:34.81 bitrate=N/A speed=2.56x frame= 3708 fps= 61 q=-0.0 size=N/A time=00:02:36.25 bitrate=N/A speed=2.56x frame= 3740 fps= 61 q=-0.0 size=N/A time=00:02:37.79 bitrate=N/A speed=2.56x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc52.ts' for writing frame= 3773 fps= 61 q=-0.0 size=N/A time=00:02:38.94 bitrate=N/A speed=2.56x frame= 3805 fps= 61 q=-0.0 size=N/A time=00:02:40.38 bitrate=N/A speed=2.56x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc53.ts' for writing frame= 3837 fps= 61 q=-0.0 size=N/A time=00:02:41.79 bitrate=N/A speed=2.57x frame= 3869 fps= 61 q=-0.0 size=N/A time=00:02:43.04 bitrate=N/A speed=2.56x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc54.ts' for writing frame= 3901 fps= 61 q=-0.0 size=N/A time=00:02:44.28 bitrate=N/A speed=2.56x frame= 3932 fps= 61 q=-0.0 size=N/A time=00:02:45.72 bitrate=N/A speed=2.57x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc55.ts' for writing frame= 3963 fps= 61 q=-0.0 size=N/A time=00:02:47.00 bitrate=N/A speed=2.57x frame= 3993 fps= 61 q=-0.0 size=N/A time=00:02:48.44 bitrate=N/A speed=2.57x frame= 4025 fps= 61 q=-0.0 size=N/A time=00:02:49.72 bitrate=N/A speed=2.57x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc56.ts' for writing frame= 4058 fps= 61 q=-0.0 size=N/A time=00:02:50.91 bitrate=N/A speed=2.57x frame= 4090 fps= 61 q=-0.0 size=N/A time=00:02:52.22 bitrate=N/A speed=2.57x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc57.ts' for writing frame= 4123 fps= 61 q=-0.0 size=N/A time=00:02:53.60 bitrate=N/A speed=2.57x frame= 4154 fps= 61 q=-0.0 size=N/A time=00:02:54.88 bitrate=N/A speed=2.57x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc58.ts' for writing frame= 4184 fps= 61 q=-0.0 size=N/A time=00:02:56.03 bitrate=N/A speed=2.56x frame= 4216 fps= 61 q=-0.0 size=N/A time=00:02:57.53 bitrate=N/A speed=2.57x frame= 4247 fps= 61 q=-0.0 size=N/A time=00:02:58.91 bitrate=N/A speed=2.57x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc59.ts' for writing frame= 4279 fps= 61 q=-0.0 size=N/A time=00:03:00.19 bitrate=N/A speed=2.57x frame= 4310 fps= 61 q=-0.0 size=N/A time=00:03:01.53 bitrate=N/A speed=2.57x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc60.ts' for writing frame= 4343 fps= 61 q=-0.0 size=N/A time=00:03:02.81 bitrate=N/A speed=2.57x frame= 4375 fps= 61 q=-0.0 size=N/A time=00:03:04.09 bitrate=N/A speed=2.57x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc61.ts' for writing frame= 4405 fps= 61 q=-0.0 size=N/A time=00:03:05.34 bitrate=N/A speed=2.57x frame= 4438 fps= 61 q=-0.0 size=N/A time=00:03:06.84 bitrate=N/A speed=2.57x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc62.ts' for writing frame= 4471 fps= 61 q=-0.0 size=N/A time=00:03:08.03 bitrate=N/A speed=2.57x frame= 4503 fps= 61 q=-0.0 size=N/A time=00:03:09.34 bitrate=N/A speed=2.57x frame= 4537 fps= 61 q=-0.0 size=N/A time=00:03:10.81 bitrate=N/A speed=2.57x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc63.ts' for writing frame= 4570 fps= 61 q=-0.0 size=N/A time=00:03:12.35 bitrate=N/A speed=2.57x frame= 4602 fps= 61 q=-0.0 size=N/A time=00:03:13.56 bitrate=N/A speed=2.57x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc64.ts' for writing frame= 4635 fps= 61 q=-0.0 size=N/A time=00:03:15.10 bitrate=N/A speed=2.58x frame= 4668 fps= 61 q=-0.0 size=N/A time=00:03:16.38 bitrate=N/A speed=2.58x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc65.ts' for writing frame= 4702 fps= 61 q=-0.0 size=N/A time=00:03:17.76 bitrate=N/A speed=2.58x frame= 4733 fps= 61 q=-0.0 size=N/A time=00:03:19.07 bitrate=N/A speed=2.58x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc66.ts' for writing frame= 4766 fps= 61 q=-0.0 size=N/A time=00:03:20.35 bitrate=N/A speed=2.58x frame= 4801 fps= 61 q=-0.0 size=N/A time=00:03:21.85 bitrate=N/A speed=2.58x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc67.ts' for writing frame= 4835 fps= 61 q=-0.0 size=N/A time=00:03:23.58 bitrate=N/A speed=2.58x frame= 4868 fps= 61 q=-0.0 size=N/A time=00:03:24.73 bitrate=N/A speed=2.58x frame= 4898 fps= 61 q=-0.0 size=N/A time=00:03:25.98 bitrate=N/A speed=2.58x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc68.ts' for writing frame= 4931 fps= 61 q=-0.0 size=N/A time=00:03:27.26 bitrate=N/A speed=2.58x frame= 4963 fps= 61 q=-0.0 size=N/A time=00:03:28.73 bitrate=N/A speed=2.58x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc69.ts' for writing frame= 4996 fps= 61 q=-0.0 size=N/A time=00:03:30.01 bitrate=N/A speed=2.58x frame= 5027 fps= 61 q=-0.0 size=N/A time=00:03:31.32 bitrate=N/A speed=2.58x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc70.ts' for writing frame= 5061 fps= 61 q=-0.0 size=N/A time=00:03:32.99 bitrate=N/A speed=2.59x frame= 5095 fps= 62 q=-0.0 size=N/A time=00:03:34.01 bitrate=N/A speed=2.58x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc71.ts' for writing frame= 5128 fps= 62 q=-0.0 size=N/A time=00:03:35.58 bitrate=N/A speed=2.59x frame= 5163 fps= 62 q=-0.0 size=N/A time=00:03:36.83 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc72.ts' for writing frame= 5196 fps= 62 q=-0.0 size=N/A time=00:03:38.40 bitrate=N/A speed=2.59x frame= 5229 fps= 62 q=-0.0 size=N/A time=00:03:39.68 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc73.ts' for writing frame= 5261 fps= 62 q=-0.0 size=N/A time=00:03:41.02 bitrate=N/A speed=2.59x frame= 5292 fps= 62 q=-0.0 size=N/A time=00:03:42.33 bitrate=N/A speed=2.59x frame= 5325 fps= 62 q=-0.0 size=N/A time=00:03:43.77 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc74.ts' for writing frame= 5332 fps= 61 q=-0.0 size=N/A time=00:03:44.03 bitrate=N/A speed=2.57x frame= 5363 fps= 61 q=-0.0 size=N/A time=00:03:45.37 bitrate=N/A speed=2.57x frame= 5396 fps= 61 q=-0.0 size=N/A time=00:03:46.65 bitrate=N/A speed=2.57x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc75.ts' for writing frame= 5428 fps= 61 q=-0.0 size=N/A time=00:03:48.09 bitrate=N/A speed=2.57x frame= 5462 fps= 61 q=-0.0 size=N/A time=00:03:49.56 bitrate=N/A speed=2.57x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc76.ts' for writing frame= 5495 fps= 61 q=-0.0 size=N/A time=00:03:50.84 bitrate=N/A speed=2.57x frame= 5528 fps= 61 q=-0.0 size=N/A time=00:03:52.09 bitrate=N/A speed=2.57x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc77.ts' for writing frame= 5561 fps= 61 q=-0.0 size=N/A time=00:03:53.66 bitrate=N/A speed=2.58x frame= 5595 fps= 61 q=-0.0 size=N/A time=00:03:54.91 bitrate=N/A speed=2.58x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc78.ts' for writing frame= 5628 fps= 61 q=-0.0 size=N/A time=00:03:56.35 bitrate=N/A speed=2.58x frame= 5661 fps= 61 q=-0.0 size=N/A time=00:03:57.63 bitrate=N/A speed=2.58x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc79.ts' for writing frame= 5695 fps= 61 q=-0.0 size=N/A time=00:03:59.42 bitrate=N/A speed=2.58x frame= 5729 fps= 61 q=-0.0 size=N/A time=00:04:00.54 bitrate=N/A speed=2.58x frame= 5759 fps= 61 q=-0.0 size=N/A time=00:04:01.82 bitrate=N/A speed=2.58x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc80.ts' for writing frame= 5793 fps= 61 q=-0.0 size=N/A time=00:04:03.32 bitrate=N/A speed=2.58x frame= 5825 fps= 61 q=-0.0 size=N/A time=00:04:04.64 bitrate=N/A speed=2.58x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc81.ts' for writing frame= 5859 fps= 62 q=-0.0 size=N/A time=00:04:05.98 bitrate=N/A speed=2.58x frame= 5891 fps= 62 q=-0.0 size=N/A time=00:04:07.23 bitrate=N/A speed=2.58x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc82.ts' for writing frame= 5925 fps= 62 q=-0.0 size=N/A time=00:04:08.73 bitrate=N/A speed=2.58x frame= 5959 fps= 62 q=-0.0 size=N/A time=00:04:10.20 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc83.ts' for writing frame= 5992 fps= 62 q=-0.0 size=N/A time=00:04:11.74 bitrate=N/A speed=2.59x frame= 6024 fps= 62 q=-0.0 size=N/A time=00:04:12.96 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc84.ts' for writing frame= 6057 fps= 62 q=-0.0 size=N/A time=00:04:14.27 bitrate=N/A speed=2.59x frame= 6089 fps= 62 q=-0.0 size=N/A time=00:04:15.58 bitrate=N/A speed=2.59x frame= 6119 fps= 62 q=-0.0 size=N/A time=00:04:16.86 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc85.ts' for writing frame= 6150 fps= 62 q=-0.0 size=N/A time=00:04:18.08 bitrate=N/A speed=2.58x frame= 6181 fps= 62 q=-0.0 size=N/A time=00:04:19.61 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc86.ts' for writing frame= 6214 fps= 62 q=-0.0 size=N/A time=00:04:20.89 bitrate=N/A speed=2.59x frame= 6244 fps= 62 q=-0.0 size=N/A time=00:04:22.17 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc87.ts' for writing frame= 6274 fps= 62 q=-0.0 size=N/A time=00:04:23.32 bitrate=N/A speed=2.59x frame= 6303 fps= 62 q=-0.0 size=N/A time=00:04:24.64 bitrate=N/A speed=2.58x frame= 6334 fps= 62 q=-0.0 size=N/A time=00:04:25.88 bitrate=N/A speed=2.58x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc88.ts' for writing frame= 6363 fps= 62 q=-0.0 size=N/A time=00:04:26.94 bitrate=N/A speed=2.58x frame= 6396 fps= 62 q=-0.0 size=N/A time=00:04:28.38 bitrate=N/A speed=2.58x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc89.ts' for writing frame= 6427 fps= 62 q=-0.0 size=N/A time=00:04:29.69 bitrate=N/A speed=2.58x frame= 6461 fps= 62 q=-0.0 size=N/A time=00:04:31.39 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc90.ts' for writing frame= 6494 fps= 62 q=-0.0 size=N/A time=00:04:32.41 bitrate=N/A speed=2.58x frame= 6526 fps= 62 q=-0.0 size=N/A time=00:04:33.72 bitrate=N/A speed=2.58x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc91.ts' for writing frame= 6559 fps= 62 q=-0.0 size=N/A time=00:04:35.23 bitrate=N/A speed=2.59x frame= 6590 fps= 62 q=-0.0 size=N/A time=00:04:36.48 bitrate=N/A speed=2.59x frame= 6622 fps= 62 q=-0.0 size=N/A time=00:04:37.76 bitrate=N/A speed=2.58x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc92.ts' for writing frame= 6653 fps= 62 q=-0.0 size=N/A time=00:04:39.04 bitrate=N/A speed=2.58x frame= 6684 fps= 62 q=-0.0 size=N/A time=00:04:40.41 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc93.ts' for writing frame= 6717 fps= 62 q=-0.0 size=N/A time=00:04:41.95 bitrate=N/A speed=2.59x frame= 6749 fps= 62 q=-0.0 size=N/A time=00:04:43.23 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc94.ts' for writing frame= 6781 fps= 62 q=-0.0 size=N/A time=00:04:44.51 bitrate=N/A speed=2.59x frame= 6814 fps= 62 q=-0.0 size=N/A time=00:04:45.98 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc95.ts' for writing frame= 6847 fps= 62 q=-0.0 size=N/A time=00:04:47.26 bitrate=N/A speed=2.59x frame= 6878 fps= 62 q=-0.0 size=N/A time=00:04:48.80 bitrate=N/A speed=2.59x frame= 6910 fps= 62 q=-0.0 size=N/A time=00:04:49.88 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc96.ts' for writing frame= 6943 fps= 62 q=-0.0 size=N/A time=00:04:51.36 bitrate=N/A speed=2.59x frame= 6974 fps= 62 q=-0.0 size=N/A time=00:04:52.64 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc97.ts' for writing frame= 7005 fps= 62 q=-0.0 size=N/A time=00:04:53.98 bitrate=N/A speed=2.59x frame= 7038 fps= 62 q=-0.0 size=N/A time=00:04:55.26 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc98.ts' for writing frame= 7070 fps= 62 q=-0.0 size=N/A time=00:04:56.64 bitrate=N/A speed=2.59x frame= 7102 fps= 62 q=-0.0 size=N/A time=00:04:57.92 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc99.ts' for writing frame= 7133 fps= 62 q=-0.0 size=N/A time=00:04:59.16 bitrate=N/A speed=2.59x frame= 7165 fps= 62 q=-0.0 size=N/A time=00:05:00.64 bitrate=N/A speed=2.59x frame= 7198 fps= 62 q=-0.0 size=N/A time=00:05:01.92 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc100.ts' for writing frame= 7230 fps= 62 q=-0.0 size=N/A time=00:05:03.20 bitrate=N/A speed=2.59x frame= 7263 fps= 62 q=-0.0 size=N/A time=00:05:04.60 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc101.ts' for writing frame= 7294 fps= 62 q=-0.0 size=N/A time=00:05:05.88 bitrate=N/A speed=2.59x frame= 7325 fps= 62 q=-0.0 size=N/A time=00:05:07.13 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc102.ts' for writing frame= 7356 fps= 62 q=-0.0 size=N/A time=00:05:08.41 bitrate=N/A speed=2.59x frame= 7386 fps= 62 q=-0.0 size=N/A time=00:05:09.63 bitrate=N/A speed=2.59x frame= 7418 fps= 62 q=-0.0 size=N/A time=00:05:11.16 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc103.ts' for writing frame= 7450 fps= 62 q=-0.0 size=N/A time=00:05:12.44 bitrate=N/A speed=2.59x frame= 7482 fps= 62 q=-0.0 size=N/A time=00:05:13.88 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc104.ts' for writing frame= 7514 fps= 62 q=-0.0 size=N/A time=00:05:15.16 bitrate=N/A speed=2.59x frame= 7546 fps= 62 q=-0.0 size=N/A time=00:05:16.44 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc105.ts' for writing frame= 7577 fps= 62 q=-0.0 size=N/A time=00:05:17.63 bitrate=N/A speed=2.59x frame= 7608 fps= 62 q=-0.0 size=N/A time=00:05:18.94 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc106.ts' for writing frame= 7642 fps= 62 q=-0.0 size=N/A time=00:05:20.38 bitrate=N/A speed=2.59x frame= 7672 fps= 62 q=-0.0 size=N/A time=00:05:21.66 bitrate=N/A speed=2.59x frame= 7703 fps= 62 q=-0.0 size=N/A time=00:05:22.94 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc107.ts' for writing frame= 7733 fps= 62 q=-0.0 size=N/A time=00:05:24.35 bitrate=N/A speed=2.59x frame= 7765 fps= 62 q=-0.0 size=N/A time=00:05:25.37 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc108.ts' for writing frame= 7795 fps= 62 q=-0.0 size=N/A time=00:05:26.68 bitrate=N/A speed=2.59x frame= 7827 fps= 62 q=-0.0 size=N/A time=00:05:27.96 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc109.ts' for writing frame= 7859 fps= 62 q=-0.0 size=N/A time=00:05:29.50 bitrate=N/A speed=2.59x frame= 7890 fps= 62 q=-0.0 size=N/A time=00:05:30.65 bitrate=N/A speed=2.59x frame= 7922 fps= 62 q=-0.0 size=N/A time=00:05:32.16 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc110.ts' for writing frame= 7952 fps= 62 q=-0.0 size=N/A time=00:05:33.21 bitrate=N/A speed=2.59x frame= 7986 fps= 62 q=-0.0 size=N/A time=00:05:35.00 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc111.ts' for writing frame= 8016 fps= 62 q=-0.0 size=N/A time=00:05:36.06 bitrate=N/A speed=2.59x frame= 8048 fps= 62 q=-0.0 size=N/A time=00:05:37.34 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc112.ts' for writing frame= 8080 fps= 62 q=-0.0 size=N/A time=00:05:38.62 bitrate=N/A speed=2.59x frame= 8113 fps= 62 q=-0.0 size=N/A time=00:05:40.12 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc113.ts' for writing frame= 8146 fps= 62 q=-0.0 size=N/A time=00:05:41.44 bitrate=N/A speed=2.59x frame= 8177 fps= 62 q=-0.0 size=N/A time=00:05:42.97 bitrate=N/A speed=2.59x frame= 8210 fps= 62 q=-0.0 size=N/A time=00:05:44.00 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc114.ts' for writing frame= 8243 fps= 62 q=-0.0 size=N/A time=00:05:45.56 bitrate=N/A speed=2.59x frame= 8277 fps= 62 q=-0.0 size=N/A time=00:05:46.84 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc115.ts' for writing frame= 8310 fps= 62 q=-0.0 size=N/A time=00:05:48.12 bitrate=N/A speed=2.59x frame= 8343 fps= 62 q=-0.0 size=N/A time=00:05:49.66 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc116.ts' for writing frame= 8376 fps= 62 q=-0.0 size=N/A time=00:05:50.94 bitrate=N/A speed=2.59x frame= 8408 fps= 62 q=-0.0 size=N/A time=00:05:52.35 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc117.ts' for writing frame= 8439 fps= 62 q=-0.0 size=N/A time=00:05:53.63 bitrate=N/A speed=2.59x frame= 8470 fps= 62 q=-0.0 size=N/A time=00:05:54.94 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc118.ts' for writing frame= 8503 fps= 62 q=-0.0 size=N/A time=00:05:56.44 bitrate=N/A speed=2.59x frame= 8536 fps= 62 q=-0.0 size=N/A time=00:05:57.72 bitrate=N/A speed=2.59x frame= 8568 fps= 62 q=-0.0 size=N/A time=00:05:59.20 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc119.ts' for writing frame= 8600 fps= 62 q=-0.0 size=N/A time=00:06:00.22 bitrate=N/A speed=2.59x frame= 8632 fps= 62 q=-0.0 size=N/A time=00:06:01.72 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc120.ts' for writing frame= 8665 fps= 62 q=-0.0 size=N/A time=00:06:03.26 bitrate=N/A speed= 2.6x frame= 8698 fps= 62 q=-0.0 size=N/A time=00:06:04.28 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc121.ts' for writing frame= 8732 fps= 62 q=-0.0 size=N/A time=00:06:06.08 bitrate=N/A speed= 2.6x frame= 8764 fps= 62 q=-0.0 size=N/A time=00:06:07.29 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc122.ts' for writing frame= 8795 fps= 62 q=-0.0 size=N/A time=00:06:08.54 bitrate=N/A speed= 2.6x frame= 8826 fps= 62 q=-0.0 size=N/A time=00:06:09.69 bitrate=N/A speed=2.59x frame= 8858 fps= 62 q=-0.0 size=N/A time=00:06:10.97 bitrate=N/A speed=2.59x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc123.ts' for writing frame= 8890 fps= 62 q=-0.0 size=N/A time=00:06:12.38 bitrate=N/A speed= 2.6x frame= 8921 fps= 62 q=-0.0 size=N/A time=00:06:13.79 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc124.ts' for writing frame= 8952 fps= 62 q=-0.0 size=N/A time=00:06:15.10 bitrate=N/A speed= 2.6x frame= 8985 fps= 62 q=-0.0 size=N/A time=00:06:16.35 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc125.ts' for writing frame= 9018 fps= 62 q=-0.0 size=N/A time=00:06:17.66 bitrate=N/A speed= 2.6x frame= 9051 fps= 62 q=-0.0 size=N/A time=00:06:19.20 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc126.ts' for writing frame= 9082 fps= 62 q=-0.0 size=N/A time=00:06:20.48 bitrate=N/A speed= 2.6x frame= 9113 fps= 62 q=-0.0 size=N/A time=00:06:21.63 bitrate=N/A speed= 2.6x frame= 9145 fps= 62 q=-0.0 size=N/A time=00:06:23.13 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc127.ts' for writing frame= 9177 fps= 62 q=-0.0 size=N/A time=00:06:24.48 bitrate=N/A speed= 2.6x frame= 9208 fps= 62 q=-0.0 size=N/A time=00:06:25.60 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc128.ts' for writing frame= 9239 fps= 62 q=-0.0 size=N/A time=00:06:27.13 bitrate=N/A speed= 2.6x frame= 9271 fps= 62 q=-0.0 size=N/A time=00:06:28.35 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc129.ts' for writing frame= 9303 fps= 62 q=-0.0 size=N/A time=00:06:29.63 bitrate=N/A speed= 2.6x frame= 9333 fps= 62 q=-0.0 size=N/A time=00:06:30.88 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc130.ts' for writing frame= 9367 fps= 62 q=-0.0 size=N/A time=00:06:32.38 bitrate=N/A speed= 2.6x frame= 9399 fps= 62 q=-0.0 size=N/A time=00:06:33.85 bitrate=N/A speed= 2.6x frame= 9431 fps= 62 q=-0.0 size=N/A time=00:06:35.07 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc131.ts' for writing frame= 9463 fps= 62 q=-0.0 size=N/A time=00:06:36.60 bitrate=N/A speed= 2.6x frame= 9495 fps= 62 q=-0.0 size=N/A time=00:06:37.63 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc132.ts' for writing frame= 9527 fps= 62 q=-0.0 size=N/A time=00:06:38.91 bitrate=N/A speed= 2.6x frame= 9559 fps= 62 q=-0.0 size=N/A time=00:06:40.38 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc133.ts' for writing frame= 9592 fps= 62 q=-0.0 size=N/A time=00:06:41.92 bitrate=N/A speed= 2.6x frame= 9623 fps= 62 q=-0.0 size=N/A time=00:06:43.10 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc134.ts' for writing frame= 9655 fps= 62 q=-0.0 size=N/A time=00:06:44.38 bitrate=N/A speed= 2.6x frame= 9688 fps= 62 q=-0.0 size=N/A time=00:06:45.92 bitrate=N/A speed= 2.6x frame= 9720 fps= 62 q=-0.0 size=N/A time=00:06:47.23 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc135.ts' for writing frame= 9753 fps= 62 q=-0.0 size=N/A time=00:06:48.51 bitrate=N/A speed= 2.6x frame= 9785 fps= 62 q=-0.0 size=N/A time=00:06:49.82 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc136.ts' for writing frame= 9817 fps= 62 q=-0.0 size=N/A time=00:06:51.36 bitrate=N/A speed= 2.6x frame= 9848 fps= 62 q=-0.0 size=N/A time=00:06:52.38 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc137.ts' for writing frame= 9880 fps= 62 q=-0.0 size=N/A time=00:06:53.72 bitrate=N/A speed= 2.6x frame= 9912 fps= 62 q=-0.0 size=N/A time=00:06:55.26 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc138.ts' for writing frame= 9944 fps= 62 q=-0.0 size=N/A time=00:06:56.54 bitrate=N/A speed= 2.6x frame= 9976 fps= 62 q=-0.0 size=N/A time=00:06:57.76 bitrate=N/A speed= 2.6x frame=10010 fps= 62 q=-0.0 size=N/A time=00:06:59.23 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc139.ts' for writing frame=10043 fps= 62 q=-0.0 size=N/A time=00:07:00.76 bitrate=N/A speed= 2.6x frame=10073 fps= 62 q=-0.0 size=N/A time=00:07:01.72 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc140.ts' for writing frame=10104 fps= 62 q=-0.0 size=N/A time=00:07:03.26 bitrate=N/A speed= 2.6x frame=10135 fps= 62 q=-0.0 size=N/A time=00:07:04.32 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc141.ts' for writing frame=10167 fps= 62 q=-0.0 size=N/A time=00:07:05.72 bitrate=N/A speed= 2.6x frame=10199 fps= 62 q=-0.0 size=N/A time=00:07:07.26 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc142.ts' for writing frame=10229 fps= 62 q=-0.0 size=N/A time=00:07:08.28 bitrate=N/A speed= 2.6x frame=10261 fps= 62 q=-0.0 size=N/A time=00:07:09.63 bitrate=N/A speed= 2.6x frame=10293 fps= 62 q=-0.0 size=N/A time=00:07:11.16 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc143.ts' for writing frame=10326 fps= 62 q=-0.0 size=N/A time=00:07:12.19 bitrate=N/A speed= 2.6x frame=10357 fps= 62 q=-0.0 size=N/A time=00:07:13.56 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc144.ts' for writing frame=10387 fps= 62 q=-0.0 size=N/A time=00:07:14.84 bitrate=N/A speed= 2.6x frame=10417 fps= 62 q=-0.0 size=N/A time=00:07:16.00 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc145.ts' for writing frame=10448 fps= 62 q=-0.0 size=N/A time=00:07:17.53 bitrate=N/A speed= 2.6x frame=10479 fps= 62 q=-0.0 size=N/A time=00:07:18.59 bitrate=N/A speed= 2.6x frame=10510 fps= 62 q=-0.0 size=N/A time=00:07:20.12 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc146.ts' for writing frame=10542 fps= 62 q=-0.0 size=N/A time=00:07:21.24 bitrate=N/A speed= 2.6x frame=10574 fps= 62 q=-0.0 size=N/A time=00:07:22.91 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc147.ts' for writing frame=10607 fps= 62 q=-0.0 size=N/A time=00:07:24.19 bitrate=N/A speed= 2.6x frame=10639 fps= 62 q=-0.0 size=N/A time=00:07:25.47 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc148.ts' for writing frame=10672 fps= 62 q=-0.0 size=N/A time=00:07:26.75 bitrate=N/A speed= 2.6x frame=10703 fps= 62 q=-0.0 size=N/A time=00:07:28.03 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc149.ts' for writing frame=10735 fps= 62 q=-0.0 size=N/A time=00:07:29.34 bitrate=N/A speed= 2.6x frame=10766 fps= 62 q=-0.0 size=N/A time=00:07:30.65 bitrate=N/A speed= 2.6x frame=10797 fps= 62 q=-0.0 size=N/A time=00:07:31.90 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc150.ts' for writing frame=10829 fps= 62 q=-0.0 size=N/A time=00:07:33.44 bitrate=N/A speed= 2.6x frame=10862 fps= 62 q=-0.0 size=N/A time=00:07:34.65 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc151.ts' for writing frame=10895 fps= 62 q=-0.0 size=N/A time=00:07:35.90 bitrate=N/A speed= 2.6x frame=10927 fps= 62 q=-0.0 size=N/A time=00:07:37.44 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc152.ts' for writing frame=10960 fps= 62 q=-0.0 size=N/A time=00:07:38.72 bitrate=N/A speed= 2.6x frame=10991 fps= 62 q=-0.0 size=N/A time=00:07:40.00 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc153.ts' for writing frame=11023 fps= 62 q=-0.0 size=N/A time=00:07:41.50 bitrate=N/A speed= 2.6x frame=11056 fps= 62 q=-0.0 size=N/A time=00:07:42.78 bitrate=N/A speed= 2.6x frame=11089 fps= 62 q=-0.0 size=N/A time=00:07:44.00 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc154.ts' for writing frame=11122 fps= 62 q=-0.0 size=N/A time=00:07:45.79 bitrate=N/A speed= 2.6x frame=11155 fps= 62 q=-0.0 size=N/A time=00:07:46.81 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc155.ts' for writing frame=11187 fps= 62 q=-0.0 size=N/A time=00:07:48.35 bitrate=N/A speed= 2.6x frame=11220 fps= 62 q=-0.0 size=N/A time=00:07:49.60 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc156.ts' for writing frame=11253 fps= 62 q=-0.0 size=N/A time=00:07:51.16 bitrate=N/A speed= 2.6x frame=11285 fps= 62 q=-0.0 size=N/A time=00:07:52.22 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc157.ts' for writing frame=11319 fps= 62 q=-0.0 size=N/A time=00:07:53.72 bitrate=N/A speed= 2.6x frame=11352 fps= 62 q=-0.0 size=N/A time=00:07:55.00 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc158.ts' for writing frame=11385 fps= 62 q=-0.0 size=N/A time=00:07:56.54 bitrate=N/A speed= 2.6x frame=11417 fps= 62 q=-0.0 size=N/A time=00:07:57.85 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc159.ts' for writing frame=11451 fps= 62 q=-0.0 size=N/A time=00:07:59.32 bitrate=N/A speed= 2.6x frame=11483 fps= 62 q=-0.0 size=N/A time=00:08:00.86 bitrate=N/A speed= 2.6x frame=11515 fps= 62 q=-0.0 size=N/A time=00:08:01.85 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc160.ts' for writing frame=11546 fps= 62 q=-0.0 size=N/A time=00:08:03.23 bitrate=N/A speed= 2.6x frame=11579 fps= 62 q=-0.0 size=N/A time=00:08:04.51 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc161.ts' for writing frame=11613 fps= 62 q=-0.0 size=N/A time=00:08:06.08 bitrate=N/A speed= 2.6x frame=11646 fps= 62 q=-0.0 size=N/A time=00:08:07.36 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc162.ts' for writing frame=11678 fps= 62 q=-0.0 size=N/A time=00:08:08.76 bitrate=N/A speed= 2.6x frame=11709 fps= 62 q=-0.0 size=N/A time=00:08:10.04 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc163.ts' for writing frame=11740 fps= 62 q=-0.0 size=N/A time=00:08:11.16 bitrate=N/A speed= 2.6x frame=11771 fps= 62 q=-0.0 size=N/A time=00:08:12.44 bitrate=N/A speed= 2.6x frame=11803 fps= 62 q=-0.0 size=N/A time=00:08:14.04 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc164.ts' for writing frame=11835 fps= 62 q=-0.0 size=N/A time=00:08:15.45 bitrate=N/A speed= 2.6x frame=11867 fps= 62 q=-0.0 size=N/A time=00:08:16.48 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc165.ts' for writing frame=11901 fps= 62 q=-0.0 size=N/A time=00:08:18.24 bitrate=N/A speed=2.61x frame=11934 fps= 62 q=-0.0 size=N/A time=00:08:19.26 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc166.ts' for writing frame=11965 fps= 62 q=-0.0 size=N/A time=00:08:20.70 bitrate=N/A speed= 2.6x frame=11997 fps= 62 q=-0.0 size=N/A time=00:08:22.24 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc167.ts' for writing frame=12030 fps= 62 q=-0.0 size=N/A time=00:08:23.52 bitrate=N/A speed=2.61x frame=12063 fps= 62 q=-0.0 size=N/A time=00:08:24.64 bitrate=N/A speed= 2.6x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc168.ts' for writing frame=12095 fps= 62 q=-0.0 size=N/A time=00:08:26.01 bitrate=N/A speed= 2.6x frame=12129 fps= 62 q=-0.0 size=N/A time=00:08:27.64 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc169.ts' for writing frame=12162 fps= 62 q=-0.0 size=N/A time=00:08:28.89 bitrate=N/A speed=2.61x frame=12195 fps= 62 q=-0.0 size=N/A time=00:08:30.43 bitrate=N/A speed=2.61x frame=12226 fps= 62 q=-0.0 size=N/A time=00:08:31.64 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc170.ts' for writing frame=12259 fps= 62 q=-0.0 size=N/A time=00:08:32.92 bitrate=N/A speed=2.61x frame=12291 fps= 62 q=-0.0 size=N/A time=00:08:34.20 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc171.ts' for writing frame=12323 fps= 62 q=-0.0 size=N/A time=00:08:35.48 bitrate=N/A speed=2.61x frame=12355 fps= 62 q=-0.0 size=N/A time=00:08:36.99 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc172.ts' for writing frame=12387 fps= 62 q=-0.0 size=N/A time=00:08:38.27 bitrate=N/A speed=2.61x frame=12422 fps= 62 q=-0.0 size=N/A time=00:08:39.77 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc173.ts' for writing frame=12454 fps= 62 q=-0.0 size=N/A time=00:08:41.05 bitrate=N/A speed=2.61x frame=12488 fps= 62 q=-0.0 size=N/A time=00:08:42.46 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc174.ts' for writing frame=12520 fps= 62 q=-0.0 size=N/A time=00:08:44.00 bitrate=N/A speed=2.61x frame=12553 fps= 62 q=-0.0 size=N/A time=00:08:45.12 bitrate=N/A speed=2.61x frame=12584 fps= 62 q=-0.0 size=N/A time=00:08:46.40 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc175.ts' for writing frame=12616 fps= 62 q=-0.0 size=N/A time=00:08:48.09 bitrate=N/A speed=2.61x frame=12648 fps= 62 q=-0.0 size=N/A time=00:08:49.37 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc176.ts' for writing frame=12680 fps= 62 q=-0.0 size=N/A time=00:08:50.62 bitrate=N/A speed=2.61x frame=12713 fps= 62 q=-0.0 size=N/A time=00:08:51.90 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc177.ts' for writing frame=12745 fps= 62 q=-0.0 size=N/A time=00:08:53.47 bitrate=N/A speed=2.61x frame=12778 fps= 62 q=-0.0 size=N/A time=00:08:54.52 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc178.ts' for writing frame=12811 fps= 62 q=-0.0 size=N/A time=00:08:55.90 bitrate=N/A speed=2.61x frame=12843 fps= 62 q=-0.0 size=N/A time=00:08:57.44 bitrate=N/A speed=2.61x frame=12875 fps= 62 q=-0.0 size=N/A time=00:08:58.68 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc179.ts' for writing frame=12908 fps= 62 q=-0.0 size=N/A time=00:09:00.22 bitrate=N/A speed=2.61x frame=12940 fps= 62 q=-0.0 size=N/A time=00:09:01.24 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc180.ts' for writing frame=12970 fps= 62 q=-0.0 size=N/A time=00:09:02.78 bitrate=N/A speed=2.61x frame=13001 fps= 62 q=-0.0 size=N/A time=00:09:04.06 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc181.ts' for writing frame=13033 fps= 62 q=-0.0 size=N/A time=00:09:05.47 bitrate=N/A speed=2.61x frame=13066 fps= 62 q=-0.0 size=N/A time=00:09:06.75 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc182.ts' for writing frame=13098 fps= 62 q=-0.0 size=N/A time=00:09:07.80 bitrate=N/A speed=2.61x frame=13133 fps= 62 q=-0.0 size=N/A time=00:09:09.56 bitrate=N/A speed=2.61x frame=13166 fps= 62 q=-0.0 size=N/A time=00:09:10.75 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc183.ts' for writing frame=13198 fps= 62 q=-0.0 size=N/A time=00:09:12.28 bitrate=N/A speed=2.61x frame=13231 fps= 62 q=-0.0 size=N/A time=00:09:13.53 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc184.ts' for writing frame=13262 fps= 62 q=-0.0 size=N/A time=00:09:14.75 bitrate=N/A speed=2.61x frame=13294 fps= 62 q=-0.0 size=N/A time=00:09:16.28 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc185.ts' for writing frame=13327 fps= 62 q=-0.0 size=N/A time=00:09:17.56 bitrate=N/A speed=2.61x frame=13360 fps= 62 q=-0.0 size=N/A time=00:09:18.78 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc186.ts' for writing frame=13392 fps= 62 q=-0.0 size=N/A time=00:09:20.16 bitrate=N/A speed=2.61x frame=13424 fps= 62 q=-0.0 size=N/A time=00:09:21.44 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc187.ts' for writing frame=13455 fps= 62 q=-0.0 size=N/A time=00:09:22.81 bitrate=N/A speed=2.61x frame=13488 fps= 62 q=-0.0 size=N/A time=00:09:24.32 bitrate=N/A speed=2.61x frame=13521 fps= 62 q=-0.0 size=N/A time=00:09:25.69 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc188.ts' for writing frame=13553 fps= 62 q=-0.0 size=N/A time=00:09:26.97 bitrate=N/A speed=2.61x frame=13586 fps= 62 q=-0.0 size=N/A time=00:09:28.44 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc189.ts' for writing frame=13618 fps= 62 q=-0.0 size=N/A time=00:09:29.72 bitrate=N/A speed=2.61x frame=13649 fps= 62 q=-0.0 size=N/A time=00:09:30.78 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc190.ts' for writing frame=13682 fps= 62 q=-0.0 size=N/A time=00:09:32.28 bitrate=N/A speed=2.61x frame=13714 fps= 62 q=-0.0 size=N/A time=00:09:33.50 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc191.ts' for writing frame=13745 fps= 62 q=-0.0 size=N/A time=00:09:34.88 bitrate=N/A speed=2.61x frame=13776 fps= 62 q=-0.0 size=N/A time=00:09:36.19 bitrate=N/A speed=2.61x frame=13809 fps= 62 q=-0.0 size=N/A time=00:09:37.47 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc192.ts' for writing frame=13841 fps= 62 q=-0.0 size=N/A time=00:09:39.00 bitrate=N/A speed=2.61x frame=13872 fps= 62 q=-0.0 size=N/A time=00:09:40.35 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc193.ts' for writing frame=13904 fps= 62 q=-0.0 size=N/A time=00:09:41.72 bitrate=N/A speed=2.61x frame=13937 fps= 62 q=-0.0 size=N/A time=00:09:43.00 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc194.ts' for writing frame=13968 fps= 62 q=-0.0 size=N/A time=00:09:44.22 bitrate=N/A speed=2.61x frame=13999 fps= 62 q=-0.0 size=N/A time=00:09:45.56 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc195.ts' for writing frame=14032 fps= 62 q=-0.0 size=N/A time=00:09:46.88 bitrate=N/A speed=2.61x frame=14065 fps= 62 q=-0.0 size=N/A time=00:09:48.16 bitrate=N/A speed=2.61x frame=14099 fps= 62 q=-0.0 size=N/A time=00:09:49.79 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc196.ts' for writing frame=14131 fps= 62 q=-0.0 size=N/A time=00:09:51.07 bitrate=N/A speed=2.61x frame=14162 fps= 62 q=-0.0 size=N/A time=00:09:52.16 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc197.ts' for writing frame=14192 fps= 62 q=-0.0 size=N/A time=00:09:53.44 bitrate=N/A speed=2.61x frame=14224 fps= 62 q=-0.0 size=N/A time=00:09:55.00 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc198.ts' for writing frame=14255 fps= 62 q=-0.0 size=N/A time=00:09:56.28 bitrate=N/A speed=2.61x frame=14285 fps= 62 q=-0.0 size=N/A time=00:09:57.56 bitrate=N/A speed=2.61x frame=14317 fps= 62 q=-0.0 size=N/A time=00:09:59.10 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc199.ts' for writing frame=14351 fps= 62 q=-0.0 size=N/A time=00:10:00.12 bitrate=N/A speed=2.61x frame=14384 fps= 62 q=-0.0 size=N/A time=00:10:01.53 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc200.ts' for writing frame=14417 fps= 62 q=-0.0 size=N/A time=00:10:03.07 bitrate=N/A speed=2.61x frame=14450 fps= 62 q=-0.0 size=N/A time=00:10:04.35 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc201.ts' for writing frame=14482 fps= 62 q=-0.0 size=N/A time=00:10:05.56 bitrate=N/A speed=2.61x frame=14514 fps= 62 q=-0.0 size=N/A time=00:10:07.10 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc202.ts' for writing frame=14544 fps= 62 q=-0.0 size=N/A time=00:10:08.12 bitrate=N/A speed=2.61x frame=14577 fps= 62 q=-0.0 size=N/A time=00:10:09.66 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc203.ts' for writing frame=14610 fps= 62 q=-0.0 size=N/A time=00:10:11.20 bitrate=N/A speed=2.61x frame=14642 fps= 62 q=-0.0 size=N/A time=00:10:12.25 bitrate=N/A speed=2.61x frame=14676 fps= 62 q=-0.0 size=N/A time=00:10:13.76 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc204.ts' for writing frame=14707 fps= 62 q=-0.0 size=N/A time=00:10:15.00 bitrate=N/A speed=2.61x frame=14740 fps= 62 q=-0.0 size=N/A time=00:10:16.54 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc205.ts' for writing frame=14772 fps= 62 q=-0.0 size=N/A time=00:10:17.66 bitrate=N/A speed=2.61x frame=14805 fps= 62 q=-0.0 size=N/A time=00:10:19.20 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc206.ts' for writing frame=14838 fps= 62 q=-0.0 size=N/A time=00:10:20.64 bitrate=N/A speed=2.61x frame=14871 fps= 62 q=-0.0 size=N/A time=00:10:21.92 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc207.ts' for writing frame=14904 fps= 62 q=-0.0 size=N/A time=00:10:23.29 bitrate=N/A speed=2.61x frame=14935 fps= 62 q=-0.0 size=N/A time=00:10:24.70 bitrate=N/A speed=2.61x frame=14966 fps= 62 q=-0.0 size=N/A time=00:10:26.01 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc208.ts' for writing frame=14998 fps= 62 q=-0.0 size=N/A time=00:10:27.23 bitrate=N/A speed=2.61x frame=15031 fps= 62 q=-0.0 size=N/A time=00:10:28.64 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc209.ts' for writing frame=15064 fps= 62 q=-0.0 size=N/A time=00:10:30.11 bitrate=N/A speed=2.61x frame=15098 fps= 63 q=-0.0 size=N/A time=00:10:31.39 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc210.ts' for writing frame=15131 fps= 63 q=-0.0 size=N/A time=00:10:32.92 bitrate=N/A speed=2.61x frame=15163 fps= 63 q=-0.0 size=N/A time=00:10:34.14 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc211.ts' for writing frame=15196 fps= 63 q=-0.0 size=N/A time=00:10:35.42 bitrate=N/A speed=2.61x frame=15229 fps= 63 q=-0.0 size=N/A time=00:10:36.89 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc212.ts' for writing frame=15261 fps= 63 q=-0.0 size=N/A time=00:10:38.17 bitrate=N/A speed=2.61x frame=15293 fps= 63 q=-0.0 size=N/A time=00:10:39.36 bitrate=N/A speed=2.61x frame=15325 fps= 63 q=-0.0 size=N/A time=00:10:40.89 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc213.ts' for writing frame=15357 fps= 63 q=-0.0 size=N/A time=00:10:42.17 bitrate=N/A speed=2.61x frame=15390 fps= 63 q=-0.0 size=N/A time=00:10:43.64 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc214.ts' for writing frame=15423 fps= 63 q=-0.0 size=N/A time=00:10:44.92 bitrate=N/A speed=2.61x frame=15456 fps= 63 q=-0.0 size=N/A time=00:10:46.33 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc215.ts' for writing frame=15487 fps= 63 q=-0.0 size=N/A time=00:10:47.45 bitrate=N/A speed=2.61x frame=15519 fps= 63 q=-0.0 size=N/A time=00:10:48.96 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc216.ts' for writing frame=15550 fps= 63 q=-0.0 size=N/A time=00:10:50.30 bitrate=N/A speed=2.61x frame=15581 fps= 63 q=-0.0 size=N/A time=00:10:51.32 bitrate=N/A speed=2.61x frame=15612 fps= 63 q=-0.0 size=N/A time=00:10:52.67 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc217.ts' for writing frame=15644 fps= 63 q=-0.0 size=N/A time=00:10:54.30 bitrate=N/A speed=2.61x frame=15678 fps= 63 q=-0.0 size=N/A time=00:10:55.58 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc218.ts' for writing frame=15711 fps= 63 q=-0.0 size=N/A time=00:10:56.92 bitrate=N/A speed=2.61x frame=15745 fps= 63 q=-0.0 size=N/A time=00:10:58.46 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc219.ts' for writing frame=15776 fps= 63 q=-0.0 size=N/A time=00:10:59.58 bitrate=N/A speed=2.61x frame=15808 fps= 63 q=-0.0 size=N/A time=00:11:00.86 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc220.ts' for writing frame=15840 fps= 63 q=-0.0 size=N/A time=00:11:02.40 bitrate=N/A speed=2.62x frame=15874 fps= 63 q=-0.0 size=N/A time=00:11:03.74 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc221.ts' for writing frame=15907 fps= 63 q=-0.0 size=N/A time=00:11:05.28 bitrate=N/A speed=2.62x frame=15940 fps= 63 q=-0.0 size=N/A time=00:11:06.40 bitrate=N/A speed=2.62x frame=15971 fps= 63 q=-0.0 size=N/A time=00:11:07.71 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc222.ts' for writing frame=16003 fps= 63 q=-0.0 size=N/A time=00:11:09.18 bitrate=N/A speed=2.62x frame=16036 fps= 63 q=-0.0 size=N/A time=00:11:10.46 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc223.ts' for writing frame=16068 fps= 63 q=-0.0 size=N/A time=00:11:11.93 bitrate=N/A speed=2.62x frame=16101 fps= 63 q=-0.0 size=N/A time=00:11:13.21 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc224.ts' for writing frame=16132 fps= 63 q=-0.0 size=N/A time=00:11:14.36 bitrate=N/A speed=2.62x frame=16166 fps= 63 q=-0.0 size=N/A time=00:11:15.93 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc225.ts' for writing frame=16200 fps= 63 q=-0.0 size=N/A time=00:11:17.47 bitrate=N/A speed=2.62x frame=16233 fps= 63 q=-0.0 size=N/A time=00:11:18.65 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc226.ts' for writing frame=16264 fps= 63 q=-0.0 size=N/A time=00:11:19.90 bitrate=N/A speed=2.62x frame=16295 fps= 63 q=-0.0 size=N/A time=00:11:21.44 bitrate=N/A speed=2.62x frame=16328 fps= 63 q=-0.0 size=N/A time=00:11:22.62 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc227.ts' for writing frame=16360 fps= 63 q=-0.0 size=N/A time=00:11:23.90 bitrate=N/A speed=2.62x frame=16392 fps= 63 q=-0.0 size=N/A time=00:11:25.21 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc228.ts' for writing frame=16424 fps= 63 q=-0.0 size=N/A time=00:11:26.72 bitrate=N/A speed=2.62x frame=16458 fps= 63 q=-0.0 size=N/A time=00:11:27.96 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc229.ts' for writing frame=16490 fps= 63 q=-0.0 size=N/A time=00:11:29.44 bitrate=N/A speed=2.62x frame=16522 fps= 63 q=-0.0 size=N/A time=00:11:30.72 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc230.ts' for writing frame=16555 fps= 63 q=-0.0 size=N/A time=00:11:32.16 bitrate=N/A speed=2.62x frame=16588 fps= 63 q=-0.0 size=N/A time=00:11:33.60 bitrate=N/A speed=2.62x frame=16620 fps= 63 q=-0.0 size=N/A time=00:11:34.88 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc231.ts' for writing frame=16651 fps= 63 q=-0.0 size=N/A time=00:11:35.96 bitrate=N/A speed=2.62x frame=16680 fps= 63 q=-0.0 size=N/A time=00:11:37.28 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc232.ts' for writing frame=16712 fps= 63 q=-0.0 size=N/A time=00:11:38.62 bitrate=N/A speed=2.62x frame=16743 fps= 63 q=-0.0 size=N/A time=00:11:39.93 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc233.ts' for writing frame=16774 fps= 63 q=-0.0 size=N/A time=00:11:41.24 bitrate=N/A speed=2.62x frame=16807 fps= 63 q=-0.0 size=N/A time=00:11:42.46 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc234.ts' for writing frame=16840 fps= 63 q=-0.0 size=N/A time=00:11:44.00 bitrate=N/A speed=2.62x frame=16871 fps= 63 q=-0.0 size=N/A time=00:11:45.31 bitrate=N/A speed=2.62x frame=16905 fps= 63 q=-0.0 size=N/A time=00:11:46.72 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc235.ts' for writing frame=16937 fps= 63 q=-0.0 size=N/A time=00:11:48.09 bitrate=N/A speed=2.62x frame=16969 fps= 63 q=-0.0 size=N/A time=00:11:49.34 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc236.ts' for writing frame=17001 fps= 63 q=-0.0 size=N/A time=00:11:50.88 bitrate=N/A speed=2.62x frame=17032 fps= 63 q=-0.0 size=N/A time=00:11:52.12 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc237.ts' for writing frame=17065 fps= 63 q=-0.0 size=N/A time=00:11:53.66 bitrate=N/A speed=2.62x frame=17097 fps= 63 q=-0.0 size=N/A time=00:11:54.78 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc238.ts' for writing frame=17130 fps= 63 q=-0.0 size=N/A time=00:11:56.12 bitrate=N/A speed=2.62x frame=17161 fps= 63 q=-0.0 size=N/A time=00:11:57.37 bitrate=N/A speed=2.62x frame=17195 fps= 63 q=-0.0 size=N/A time=00:11:58.81 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc239.ts' for writing frame=17226 fps= 63 q=-0.0 size=N/A time=00:12:00.06 bitrate=N/A speed=2.62x frame=17258 fps= 63 q=-0.0 size=N/A time=00:12:01.34 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc240.ts' for writing frame=17291 fps= 63 q=-0.0 size=N/A time=00:12:02.91 bitrate=N/A speed=2.62x frame=17322 fps= 63 q=-0.0 size=N/A time=00:12:04.00 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc241.ts' for writing frame=17354 fps= 63 q=-0.0 size=N/A time=00:12:05.37 bitrate=N/A speed=2.62x frame=17387 fps= 63 q=-0.0 size=N/A time=00:12:06.91 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc242.ts' for writing frame=17420 fps= 63 q=-0.0 size=N/A time=00:12:08.16 bitrate=N/A speed=2.62x frame=17453 fps= 63 q=-0.0 size=N/A time=00:12:09.47 bitrate=N/A speed=2.62x frame=17485 fps= 63 q=-0.0 size=N/A time=00:12:11.00 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc243.ts' for writing frame=17516 fps= 63 q=-0.0 size=N/A time=00:12:12.09 bitrate=N/A speed=2.62x frame=17547 fps= 63 q=-0.0 size=N/A time=00:12:13.44 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc244.ts' for writing frame=17578 fps= 63 q=-0.0 size=N/A time=00:12:14.81 bitrate=N/A speed=2.62x frame=17609 fps= 63 q=-0.0 size=N/A time=00:12:16.06 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc245.ts' for writing frame=17639 fps= 63 q=-0.0 size=N/A time=00:12:17.40 bitrate=N/A speed=2.62x frame=17667 fps= 63 q=-0.0 size=N/A time=00:12:18.46 bitrate=N/A speed=2.62x frame=17697 fps= 63 q=-0.0 size=N/A time=00:12:19.68 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc246.ts' for writing frame=17730 fps= 63 q=-0.0 size=N/A time=00:12:21.18 bitrate=N/A speed=2.62x frame=17763 fps= 63 q=-0.0 size=N/A time=00:12:22.59 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc247.ts' for writing frame=17795 fps= 63 q=-0.0 size=N/A time=00:12:23.87 bitrate=N/A speed=2.62x frame=17827 fps= 63 q=-0.0 size=N/A time=00:12:25.28 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc248.ts' for writing frame=17860 fps= 63 q=-0.0 size=N/A time=00:12:26.59 bitrate=N/A speed=2.62x frame=17893 fps= 63 q=-0.0 size=N/A time=00:12:27.90 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc249.ts' for writing frame=17923 fps= 63 q=-0.0 size=N/A time=00:12:29.28 bitrate=N/A speed=2.62x frame=17956 fps= 63 q=-0.0 size=N/A time=00:12:30.52 bitrate=N/A speed=2.62x frame=17988 fps= 63 q=-0.0 size=N/A time=00:12:31.84 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc250.ts' for writing frame=18020 fps= 63 q=-0.0 size=N/A time=00:12:33.12 bitrate=N/A speed=2.62x frame=18050 fps= 63 q=-0.0 size=N/A time=00:12:34.36 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc251.ts' for writing frame=18080 fps= 63 q=-0.0 size=N/A time=00:12:35.74 bitrate=N/A speed=2.62x frame=18110 fps= 63 q=-0.0 size=N/A time=00:12:37.02 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc252.ts' for writing frame=18142 fps= 63 q=-0.0 size=N/A time=00:12:38.30 bitrate=N/A speed=2.62x frame=18175 fps= 63 q=-0.0 size=N/A time=00:12:39.58 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc253.ts' for writing frame=18207 fps= 63 q=-0.0 size=N/A time=00:12:40.89 bitrate=N/A speed=2.62x frame=18239 fps= 63 q=-0.0 size=N/A time=00:12:42.56 bitrate=N/A speed=2.62x frame=18271 fps= 63 q=-0.0 size=N/A time=00:12:43.96 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc254.ts' for writing frame=18303 fps= 63 q=-0.0 size=N/A time=00:12:45.24 bitrate=N/A speed=2.62x frame=18335 fps= 63 q=-0.0 size=N/A time=00:12:46.52 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc255.ts' for writing frame=18367 fps= 63 q=-0.0 size=N/A time=00:12:47.96 bitrate=N/A speed=2.62x frame=18400 fps= 63 q=-0.0 size=N/A time=00:12:49.24 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc256.ts' for writing frame=18431 fps= 63 q=-0.0 size=N/A time=00:12:50.30 bitrate=N/A speed=2.62x frame=18465 fps= 63 q=-0.0 size=N/A time=00:12:51.77 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc257.ts' for writing frame=18496 fps= 63 q=-0.0 size=N/A time=00:12:53.34 bitrate=N/A speed=2.62x frame=18526 fps= 63 q=-0.0 size=N/A time=00:12:54.36 bitrate=N/A speed=2.62x frame=18558 fps= 63 q=-0.0 size=N/A time=00:12:55.64 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc258.ts' for writing frame=18588 fps= 63 q=-0.0 size=N/A time=00:12:56.89 bitrate=N/A speed=2.62x frame=18622 fps= 63 q=-0.0 size=N/A time=00:12:58.36 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc259.ts' for writing frame=18654 fps= 63 q=-0.0 size=N/A time=00:12:59.68 bitrate=N/A speed=2.62x frame=18687 fps= 63 q=-0.0 size=N/A time=00:13:01.12 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc260.ts' for writing frame=18720 fps= 63 q=-0.0 size=N/A time=00:13:02.65 bitrate=N/A speed=2.62x frame=18753 fps= 63 q=-0.0 size=N/A time=00:13:03.93 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc261.ts' for writing frame=18786 fps= 63 q=-0.0 size=N/A time=00:13:05.21 bitrate=N/A speed=2.62x frame=18818 fps= 63 q=-0.0 size=N/A time=00:13:06.40 bitrate=N/A speed=2.62x frame=18851 fps= 63 q=-0.0 size=N/A time=00:13:08.19 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc262.ts' for writing frame=18883 fps= 63 q=-0.0 size=N/A time=00:13:09.21 bitrate=N/A speed=2.62x frame=18915 fps= 63 q=-0.0 size=N/A time=00:13:10.56 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc263.ts' for writing frame=18948 fps= 63 q=-0.0 size=N/A time=00:13:12.03 bitrate=N/A speed=2.62x frame=18979 fps= 63 q=-0.0 size=N/A time=00:13:13.31 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc264.ts' for writing frame=19011 fps= 63 q=-0.0 size=N/A time=00:13:14.59 bitrate=N/A speed=2.62x frame=19044 fps= 63 q=-0.0 size=N/A time=00:13:16.09 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc265.ts' for writing frame=19077 fps= 63 q=-0.0 size=N/A time=00:13:17.24 bitrate=N/A speed=2.62x frame=19109 fps= 63 q=-0.0 size=N/A time=00:13:18.78 bitrate=N/A speed=2.62x frame=19141 fps= 63 q=-0.0 size=N/A time=00:13:20.00 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc266.ts' for writing frame=19173 fps= 63 q=-0.0 size=N/A time=00:13:21.24 bitrate=N/A speed=2.62x frame=19204 fps= 63 q=-0.0 size=N/A time=00:13:22.52 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc267.ts' for writing frame=19235 fps= 63 q=-0.0 size=N/A time=00:13:23.80 bitrate=N/A speed=2.62x frame=19266 fps= 63 q=-0.0 size=N/A time=00:13:25.05 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc268.ts' for writing frame=19299 fps= 63 q=-0.0 size=N/A time=00:13:26.81 bitrate=N/A speed=2.62x frame=19331 fps= 63 q=-0.0 size=N/A time=00:13:28.00 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc269.ts' for writing frame=19361 fps= 63 q=-0.0 size=N/A time=00:13:29.02 bitrate=N/A speed=2.62x frame=19393 fps= 63 q=-0.0 size=N/A time=00:13:30.56 bitrate=N/A speed=2.62x frame=19425 fps= 63 q=-0.0 size=N/A time=00:13:32.00 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc270.ts' for writing frame=19457 fps= 63 q=-0.0 size=N/A time=00:13:33.28 bitrate=N/A speed=2.62x frame=19489 fps= 63 q=-0.0 size=N/A time=00:13:34.56 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc271.ts' for writing frame=19520 fps= 63 q=-0.0 size=N/A time=00:13:35.87 bitrate=N/A speed=2.62x frame=19550 fps= 63 q=-0.0 size=N/A time=00:13:37.15 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc272.ts' for writing frame=19582 fps= 63 q=-0.0 size=N/A time=00:13:38.43 bitrate=N/A speed=2.62x frame=19612 fps= 63 q=-0.0 size=N/A time=00:13:39.64 bitrate=N/A speed=2.62x frame=19644 fps= 63 q=-0.0 size=N/A time=00:13:40.99 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc273.ts' for writing frame=19676 fps= 63 q=-0.0 size=N/A time=00:13:42.14 bitrate=N/A speed=2.62x frame=19706 fps= 63 q=-0.0 size=N/A time=00:13:43.42 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc274.ts' for writing frame=19739 fps= 63 q=-0.0 size=N/A time=00:13:44.92 bitrate=N/A speed=2.62x frame=19770 fps= 63 q=-0.0 size=N/A time=00:13:46.20 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc275.ts' for writing frame=19802 fps= 63 q=-0.0 size=N/A time=00:13:47.64 bitrate=N/A speed=2.62x frame=19835 fps= 63 q=-0.0 size=N/A time=00:13:48.92 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc276.ts' for writing frame=19867 fps= 63 q=-0.0 size=N/A time=00:13:50.20 bitrate=N/A speed=2.62x frame=19899 fps= 63 q=-0.0 size=N/A time=00:13:51.68 bitrate=N/A speed=2.62x frame=19930 fps= 63 q=-0.0 size=N/A time=00:13:52.96 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc277.ts' for writing frame=19960 fps= 63 q=-0.0 size=N/A time=00:13:54.27 bitrate=N/A speed=2.62x frame=19992 fps= 63 q=-0.0 size=N/A time=00:13:55.42 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc278.ts' for writing frame=20024 fps= 63 q=-0.0 size=N/A time=00:13:56.96 bitrate=N/A speed=2.62x frame=20056 fps= 63 q=-0.0 size=N/A time=00:13:58.27 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc279.ts' for writing frame=20086 fps= 63 q=-0.0 size=N/A time=00:13:59.45 bitrate=N/A speed=2.62x frame=20118 fps= 63 q=-0.0 size=N/A time=00:14:00.73 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc280.ts' for writing frame=20151 fps= 63 q=-0.0 size=N/A time=00:14:02.24 bitrate=N/A speed=2.62x frame=20183 fps= 63 q=-0.0 size=N/A time=00:14:03.52 bitrate=N/A speed=2.62x frame=20216 fps= 63 q=-0.0 size=N/A time=00:14:04.80 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc281.ts' for writing frame=20248 fps= 63 q=-0.0 size=N/A time=00:14:06.04 bitrate=N/A speed=2.62x frame=20281 fps= 63 q=-0.0 size=N/A time=00:14:07.55 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc282.ts' for writing frame=20312 fps= 63 q=-0.0 size=N/A time=00:14:08.83 bitrate=N/A speed=2.62x frame=20344 fps= 63 q=-0.0 size=N/A time=00:14:10.11 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc283.ts' for writing frame=20376 fps= 63 q=-0.0 size=N/A time=00:14:11.42 bitrate=N/A speed=2.62x frame=20407 fps= 63 q=-0.0 size=N/A time=00:14:12.80 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc284.ts' for writing frame=20440 fps= 63 q=-0.0 size=N/A time=00:14:14.33 bitrate=N/A speed=2.62x frame=20471 fps= 63 q=-0.0 size=N/A time=00:14:15.39 bitrate=N/A speed=2.62x frame=20503 fps= 63 q=-0.0 size=N/A time=00:14:16.67 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc285.ts' for writing frame=20536 fps= 63 q=-0.0 size=N/A time=00:14:18.14 bitrate=N/A speed=2.62x frame=20567 fps= 63 q=-0.0 size=N/A time=00:14:19.45 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc286.ts' for writing frame=20599 fps= 63 q=-0.0 size=N/A time=00:14:20.89 bitrate=N/A speed=2.62x frame=20630 fps= 63 q=-0.0 size=N/A time=00:14:21.92 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc287.ts' for writing frame=20661 fps= 63 q=-0.0 size=N/A time=00:14:23.29 bitrate=N/A speed=2.62x frame=20692 fps= 63 q=-0.0 size=N/A time=00:14:24.57 bitrate=N/A speed=2.62x frame=20723 fps= 63 q=-0.0 size=N/A time=00:14:26.04 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc288.ts' for writing frame=20754 fps= 63 q=-0.0 size=N/A time=00:14:27.32 bitrate=N/A speed=2.62x frame=20786 fps= 63 q=-0.0 size=N/A time=00:14:28.57 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc289.ts' for writing frame=20817 fps= 63 q=-0.0 size=N/A time=00:14:29.92 bitrate=N/A speed=2.62x frame=20847 fps= 63 q=-0.0 size=N/A time=00:14:31.20 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc290.ts' for writing frame=20877 fps= 63 q=-0.0 size=N/A time=00:14:32.44 bitrate=N/A speed=2.62x frame=20907 fps= 63 q=-0.0 size=N/A time=00:14:33.69 bitrate=N/A speed=2.62x frame=20940 fps= 63 q=-0.0 size=N/A time=00:14:35.20 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc291.ts' for writing frame=20972 fps= 63 q=-0.0 size=N/A time=00:14:36.41 bitrate=N/A speed=2.62x frame=21005 fps= 63 q=-0.0 size=N/A time=00:14:37.88 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc292.ts' for writing frame=21037 fps= 63 q=-0.0 size=N/A time=00:14:39.16 bitrate=N/A speed=2.62x frame=21070 fps= 63 q=-0.0 size=N/A time=00:14:40.44 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc293.ts' for writing frame=21102 fps= 63 q=-0.0 size=N/A time=00:14:41.92 bitrate=N/A speed=2.62x frame=21133 fps= 63 q=-0.0 size=N/A time=00:14:43.10 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc294.ts' for writing frame=21165 fps= 63 q=-0.0 size=N/A time=00:14:44.35 bitrate=N/A speed=2.62x frame=21197 fps= 63 q=-0.0 size=N/A time=00:14:45.82 bitrate=N/A speed=2.62x frame=21229 fps= 63 q=-0.0 size=N/A time=00:14:47.10 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc295.ts' for writing frame=21259 fps= 63 q=-0.0 size=N/A time=00:14:48.41 bitrate=N/A speed=2.62x frame=21292 fps= 63 q=-0.0 size=N/A time=00:14:49.72 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc296.ts' for writing frame=21324 fps= 63 q=-0.0 size=N/A time=00:14:51.04 bitrate=N/A speed=2.62x frame=21357 fps= 63 q=-0.0 size=N/A time=00:14:52.32 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc297.ts' for writing frame=21388 fps= 63 q=-0.0 size=N/A time=00:14:53.63 bitrate=N/A speed=2.62x frame=21420 fps= 63 q=-0.0 size=N/A time=00:14:55.07 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc298.ts' for writing frame=21451 fps= 63 q=-0.0 size=N/A time=00:14:56.25 bitrate=N/A speed=2.62x frame=21483 fps= 63 q=-0.0 size=N/A time=00:14:57.53 bitrate=N/A speed=2.62x frame=21513 fps= 63 q=-0.0 size=N/A time=00:14:58.81 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc299.ts' for writing frame=21543 fps= 63 q=-0.0 size=N/A time=00:15:00.19 bitrate=N/A speed=2.62x frame=21575 fps= 63 q=-0.0 size=N/A time=00:15:01.47 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc300.ts' for writing frame=21607 fps= 63 q=-0.0 size=N/A time=00:15:02.81 bitrate=N/A speed=2.62x frame=21640 fps= 63 q=-0.0 size=N/A time=00:15:04.22 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc301.ts' for writing frame=21671 fps= 63 q=-0.0 size=N/A time=00:15:05.37 bitrate=N/A speed=2.62x frame=21705 fps= 63 q=-0.0 size=N/A time=00:15:06.91 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc302.ts' for writing frame=21736 fps= 63 q=-0.0 size=N/A time=00:15:08.19 bitrate=N/A speed=2.62x frame=21769 fps= 63 q=-0.0 size=N/A time=00:15:09.72 bitrate=N/A speed=2.62x frame=21800 fps= 63 q=-0.0 size=N/A time=00:15:10.88 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc303.ts' for writing frame=21833 fps= 63 q=-0.0 size=N/A time=00:15:12.16 bitrate=N/A speed=2.62x frame=21863 fps= 63 q=-0.0 size=N/A time=00:15:13.63 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc304.ts' for writing frame=21895 fps= 63 q=-0.0 size=N/A time=00:15:14.91 bitrate=N/A speed=2.62x frame=21928 fps= 63 q=-0.0 size=N/A time=00:15:16.19 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc305.ts' for writing frame=21960 fps= 63 q=-0.0 size=N/A time=00:15:17.50 bitrate=N/A speed=2.62x frame=21992 fps= 63 q=-0.0 size=N/A time=00:15:18.78 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc306.ts' for writing frame=22025 fps= 63 q=-0.0 size=N/A time=00:15:20.25 bitrate=N/A speed=2.62x frame=22058 fps= 63 q=-0.0 size=N/A time=00:15:21.56 bitrate=N/A speed=2.62x frame=22093 fps= 63 q=-0.0 size=N/A time=00:15:23.32 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc307.ts' for writing frame=22126 fps= 63 q=-0.0 size=N/A time=00:15:24.48 bitrate=N/A speed=2.62x frame=22159 fps= 63 q=-0.0 size=N/A time=00:15:26.01 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc308.ts' for writing frame=22192 fps= 63 q=-0.0 size=N/A time=00:15:27.29 bitrate=N/A speed=2.62x frame=22226 fps= 63 q=-0.0 size=N/A time=00:15:28.57 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc309.ts' for writing frame=22259 fps= 63 q=-0.0 size=N/A time=00:15:29.85 bitrate=N/A speed=2.62x frame=22292 fps= 63 q=-0.0 size=N/A time=00:15:31.32 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc310.ts' for writing frame=22324 fps= 63 q=-0.0 size=N/A time=00:15:32.60 bitrate=N/A speed=2.62x frame=22356 fps= 63 q=-0.0 size=N/A time=00:15:34.11 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc311.ts' for writing frame=22388 fps= 63 q=-0.0 size=N/A time=00:15:35.26 bitrate=N/A speed=2.62x frame=22421 fps= 63 q=-0.0 size=N/A time=00:15:36.80 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc312.ts' for writing frame=22455 fps= 63 q=-0.0 size=N/A time=00:15:38.08 bitrate=N/A speed=2.62x frame=22488 fps= 63 q=-0.0 size=N/A time=00:15:39.61 bitrate=N/A speed=2.62x frame=22521 fps= 63 q=-0.0 size=N/A time=00:15:41.08 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc313.ts' for writing frame=22554 fps= 63 q=-0.0 size=N/A time=00:15:42.36 bitrate=N/A speed=2.62x frame=22586 fps= 63 q=-0.0 size=N/A time=00:15:43.61 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc314.ts' for writing frame=22618 fps= 63 q=-0.0 size=N/A time=00:15:45.12 bitrate=N/A speed=2.62x frame=22651 fps= 63 q=-0.0 size=N/A time=00:15:46.40 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc315.ts' for writing frame=22684 fps= 63 q=-0.0 size=N/A time=00:15:47.68 bitrate=N/A speed=2.62x frame=22717 fps= 63 q=-0.0 size=N/A time=00:15:49.12 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc316.ts' for writing frame=22750 fps= 63 q=-0.0 size=N/A time=00:15:50.36 bitrate=N/A speed=2.62x frame=22782 fps= 63 q=-0.0 size=N/A time=00:15:51.90 bitrate=N/A speed=2.62x frame=22814 fps= 63 q=-0.0 size=N/A time=00:15:53.24 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc317.ts' for writing frame=22845 fps= 63 q=-0.0 size=N/A time=00:15:54.52 bitrate=N/A speed=2.62x frame=22876 fps= 63 q=-0.0 size=N/A time=00:15:55.77 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc318.ts' for writing frame=22908 fps= 63 q=-0.0 size=N/A time=00:15:57.31 bitrate=N/A speed=2.62x frame=22940 fps= 63 q=-0.0 size=N/A time=00:15:58.30 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc319.ts' for writing frame=22972 fps= 63 q=-0.0 size=N/A time=00:15:59.80 bitrate=N/A speed=2.62x frame=23003 fps= 63 q=-0.0 size=N/A time=00:16:01.21 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc320.ts' for writing frame=23033 fps= 63 q=-0.0 size=N/A time=00:16:02.20 bitrate=N/A speed=2.62x frame=23066 fps= 63 q=-0.0 size=N/A time=00:16:03.80 bitrate=N/A speed=2.62x frame=23098 fps= 63 q=-0.0 size=N/A time=00:16:04.99 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc321.ts' for writing frame=23129 fps= 63 q=-0.0 size=N/A time=00:16:06.27 bitrate=N/A speed=2.62x frame=23159 fps= 63 q=-0.0 size=N/A time=00:16:07.52 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc322.ts' for writing frame=23189 fps= 63 q=-0.0 size=N/A time=00:16:08.73 bitrate=N/A speed=2.62x frame=23221 fps= 63 q=-0.0 size=N/A time=00:16:10.27 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc323.ts' for writing frame=23253 fps= 63 q=-0.0 size=N/A time=00:16:11.36 bitrate=N/A speed=2.62x frame=23285 fps= 63 q=-0.0 size=N/A time=00:16:12.70 bitrate=N/A speed=2.62x frame=23317 fps= 63 q=-0.0 size=N/A time=00:16:14.20 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc324.ts' for writing frame=23348 fps= 63 q=-0.0 size=N/A time=00:16:15.42 bitrate=N/A speed=2.62x frame=23381 fps= 63 q=-0.0 size=N/A time=00:16:16.92 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc325.ts' for writing frame=23413 fps= 63 q=-0.0 size=N/A time=00:16:18.20 bitrate=N/A speed=2.62x frame=23445 fps= 63 q=-0.0 size=N/A time=00:16:19.39 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc326.ts' for writing frame=23476 fps= 63 q=-0.0 size=N/A time=00:16:20.70 bitrate=N/A speed=2.62x frame=23507 fps= 63 q=-0.0 size=N/A time=00:16:22.24 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc327.ts' for writing frame=23539 fps= 63 q=-0.0 size=N/A time=00:16:23.29 bitrate=N/A speed=2.62x frame=23572 fps= 63 q=-0.0 size=N/A time=00:16:24.80 bitrate=N/A speed=2.62x frame=23605 fps= 63 q=-0.0 size=N/A time=00:16:26.20 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc328.ts' for writing frame=23637 fps= 63 q=-0.0 size=N/A time=00:16:27.48 bitrate=N/A speed=2.62x frame=23670 fps= 63 q=-0.0 size=N/A time=00:16:28.76 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc329.ts' for writing frame=23701 fps= 63 q=-0.0 size=N/A time=00:16:30.14 bitrate=N/A speed=2.62x frame=23735 fps= 63 q=-0.0 size=N/A time=00:16:31.64 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc330.ts' for writing frame=23767 fps= 63 q=-0.0 size=N/A time=00:16:32.86 bitrate=N/A speed=2.62x frame=23799 fps= 63 q=-0.0 size=N/A time=00:16:34.14 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc331.ts' for writing frame=23829 fps= 63 q=-0.0 size=N/A time=00:16:35.42 bitrate=N/A speed=2.62x frame=23861 fps= 63 q=-0.0 size=N/A time=00:16:36.73 bitrate=N/A speed=2.62x frame=23892 fps= 63 q=-0.0 size=N/A time=00:16:38.36 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc332.ts' for writing frame=23924 fps= 63 q=-0.0 size=N/A time=00:16:39.64 bitrate=N/A speed=2.62x frame=23959 fps= 63 q=-0.0 size=N/A time=00:16:40.92 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc333.ts' for writing frame=23991 fps= 63 q=-0.0 size=N/A time=00:16:42.30 bitrate=N/A speed=2.62x frame=24023 fps= 63 q=-0.0 size=N/A time=00:16:43.45 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc334.ts' for writing frame=24054 fps= 63 q=-0.0 size=N/A time=00:16:44.73 bitrate=N/A speed=2.62x frame=24087 fps= 63 q=-0.0 size=N/A time=00:16:46.11 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc335.ts' for writing frame=24119 fps= 63 q=-0.0 size=N/A time=00:16:47.64 bitrate=N/A speed=2.62x frame=24152 fps= 63 q=-0.0 size=N/A time=00:16:48.86 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc336.ts' for writing frame=24185 fps= 63 q=-0.0 size=N/A time=00:16:50.40 bitrate=N/A speed=2.62x frame=24215 fps= 63 q=-0.0 size=N/A time=00:16:51.55 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc337.ts' for writing frame=24248 fps= 63 q=-0.0 size=N/A time=00:16:53.05 bitrate=N/A speed=2.62x frame=24279 fps= 63 q=-0.0 size=N/A time=00:16:54.33 bitrate=N/A speed=2.62x frame=24309 fps= 63 q=-0.0 size=N/A time=00:16:55.42 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc338.ts' for writing frame=24341 fps= 63 q=-0.0 size=N/A time=00:16:56.86 bitrate=N/A speed=2.62x frame=24373 fps= 63 q=-0.0 size=N/A time=00:16:58.14 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc339.ts' for writing frame=24405 fps= 63 q=-0.0 size=N/A time=00:16:59.52 bitrate=N/A speed=2.62x frame=24437 fps= 63 q=-0.0 size=N/A time=00:17:01.02 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc340.ts' for writing frame=24470 fps= 63 q=-0.0 size=N/A time=00:17:02.30 bitrate=N/A speed=2.62x frame=24503 fps= 63 q=-0.0 size=N/A time=00:17:03.61 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc341.ts' for writing frame=24536 fps= 63 q=-0.0 size=N/A time=00:17:04.99 bitrate=N/A speed=2.62x frame=24569 fps= 63 q=-0.0 size=N/A time=00:17:06.27 bitrate=N/A speed=2.62x frame=24601 fps= 63 q=-0.0 size=N/A time=00:17:07.96 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc342.ts' for writing frame=24633 fps= 63 q=-0.0 size=N/A time=00:17:08.99 bitrate=N/A speed=2.62x frame=24663 fps= 63 q=-0.0 size=N/A time=00:17:10.27 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc343.ts' for writing frame=24695 fps= 63 q=-0.0 size=N/A time=00:17:11.74 bitrate=N/A speed=2.62x frame=24727 fps= 63 q=-0.0 size=N/A time=00:17:13.02 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc344.ts' for writing frame=24750 fps= 63 q=-0.0 size=N/A time=00:17:13.79 bitrate=N/A speed=2.62x frame=24781 fps= 63 q=-0.0 size=N/A time=00:17:15.10 bitrate=N/A speed=2.62x frame=24814 fps= 63 q=-0.0 size=N/A time=00:17:16.51 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc345.ts' for writing frame=24847 fps= 63 q=-0.0 size=N/A time=00:17:17.85 bitrate=N/A speed=2.62x frame=24878 fps= 63 q=-0.0 size=N/A time=00:17:19.16 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc346.ts' for writing frame=24911 fps= 63 q=-0.0 size=N/A time=00:17:20.80 bitrate=N/A speed=2.62x frame=24943 fps= 63 q=-0.0 size=N/A time=00:17:22.08 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc347.ts' for writing frame=24976 fps= 63 q=-0.0 size=N/A time=00:17:23.32 bitrate=N/A speed=2.62x frame=25007 fps= 63 q=-0.0 size=N/A time=00:17:24.60 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc348.ts' for writing frame=25037 fps= 63 q=-0.0 size=N/A time=00:17:26.01 bitrate=N/A speed=2.62x frame=25064 fps= 63 q=-0.0 size=N/A time=00:17:27.04 bitrate=N/A speed=2.62x frame=25096 fps= 63 q=-0.0 size=N/A time=00:17:28.38 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc349.ts' for writing frame=25130 fps= 63 q=-0.0 size=N/A time=00:17:29.88 bitrate=N/A speed=2.62x frame=25163 fps= 63 q=-0.0 size=N/A time=00:17:31.07 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc350.ts' for writing frame=25195 fps= 63 q=-0.0 size=N/A time=00:17:32.35 bitrate=N/A speed=2.62x frame=25227 fps= 63 q=-0.0 size=N/A time=00:17:33.88 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc351.ts' for writing frame=25259 fps= 63 q=-0.0 size=N/A time=00:17:35.29 bitrate=N/A speed=2.62x frame=25291 fps= 63 q=-0.0 size=N/A time=00:17:36.32 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc352.ts' for writing frame=25324 fps= 63 q=-0.0 size=N/A time=00:17:37.88 bitrate=N/A speed=2.62x frame=25357 fps= 63 q=-0.0 size=N/A time=00:17:39.16 bitrate=N/A speed=2.62x frame=25389 fps= 63 q=-0.0 size=N/A time=00:17:40.64 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc353.ts' for writing frame=25420 fps= 63 q=-0.0 size=N/A time=00:17:41.92 bitrate=N/A speed=2.62x frame=25453 fps= 63 q=-0.0 size=N/A time=00:17:43.20 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc354.ts' for writing frame=25485 fps= 63 q=-0.0 size=N/A time=00:17:44.57 bitrate=N/A speed=2.62x frame=25517 fps= 63 q=-0.0 size=N/A time=00:17:45.82 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc355.ts' for writing frame=25548 fps= 63 q=-0.0 size=N/A time=00:17:47.10 bitrate=N/A speed=2.62x frame=25580 fps= 63 q=-0.0 size=N/A time=00:17:48.51 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc356.ts' for writing frame=25613 fps= 63 q=-0.0 size=N/A time=00:17:50.04 bitrate=N/A speed=2.62x frame=25644 fps= 63 q=-0.0 size=N/A time=00:17:51.23 bitrate=N/A speed=2.62x frame=25677 fps= 63 q=-0.0 size=N/A time=00:17:52.51 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc357.ts' for writing frame=25709 fps= 63 q=-0.0 size=N/A time=00:17:53.92 bitrate=N/A speed=2.62x frame=25741 fps= 63 q=-0.0 size=N/A time=00:17:55.23 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc358.ts' for writing frame=25772 fps= 63 q=-0.0 size=N/A time=00:17:56.51 bitrate=N/A speed=2.62x frame=25805 fps= 63 q=-0.0 size=N/A time=00:17:58.01 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc359.ts' for writing frame=25838 fps= 63 q=-0.0 size=N/A time=00:17:59.29 bitrate=N/A speed=2.62x frame=25870 fps= 63 q=-0.0 size=N/A time=00:18:00.57 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc360.ts' for writing frame=25902 fps= 63 q=-0.0 size=N/A time=00:18:01.92 bitrate=N/A speed=2.62x frame=25934 fps= 63 q=-0.0 size=N/A time=00:18:03.45 bitrate=N/A speed=2.62x frame=25965 fps= 63 q=-0.0 size=N/A time=00:18:04.60 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc361.ts' for writing frame=25996 fps= 63 q=-0.0 size=N/A time=00:18:05.92 bitrate=N/A speed=2.62x frame=26028 fps= 63 q=-0.0 size=N/A time=00:18:07.10 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc362.ts' for writing frame=26058 fps= 63 q=-0.0 size=N/A time=00:18:08.38 bitrate=N/A speed=2.62x frame=26091 fps= 63 q=-0.0 size=N/A time=00:18:09.88 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc363.ts' for writing frame=26124 fps= 63 q=-0.0 size=N/A time=00:18:11.16 bitrate=N/A speed=2.62x frame=26157 fps= 63 q=-0.0 size=N/A time=00:18:12.64 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc364.ts' for writing frame=26191 fps= 63 q=-0.0 size=N/A time=00:18:13.85 bitrate=N/A speed=2.62x frame=26224 fps= 63 q=-0.0 size=N/A time=00:18:15.39 bitrate=N/A speed=2.62x frame=26257 fps= 63 q=-0.0 size=N/A time=00:18:16.89 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc365.ts' for writing frame=26289 fps= 63 q=-0.0 size=N/A time=00:18:18.20 bitrate=N/A speed=2.62x frame=26323 fps= 63 q=-0.0 size=N/A time=00:18:19.64 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc366.ts' for writing frame=26354 fps= 63 q=-0.0 size=N/A time=00:18:20.92 bitrate=N/A speed=2.62x frame=26387 fps= 63 q=-0.0 size=N/A time=00:18:22.11 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc367.ts' for writing frame=26419 fps= 63 q=-0.0 size=N/A time=00:18:23.42 bitrate=N/A speed=2.62x frame=26451 fps= 63 q=-0.0 size=N/A time=00:18:24.92 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc368.ts' for writing frame=26483 fps= 63 q=-0.0 size=N/A time=00:18:26.08 bitrate=N/A speed=2.62x frame=26514 fps= 63 q=-0.0 size=N/A time=00:18:27.42 bitrate=N/A speed=2.62x frame=26545 fps= 63 q=-0.0 size=N/A time=00:18:28.64 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc369.ts' for writing frame=26575 fps= 63 q=-0.0 size=N/A time=00:18:30.30 bitrate=N/A speed=2.62x frame=26607 fps= 63 q=-0.0 size=N/A time=00:18:31.32 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc370.ts' for writing frame=26638 fps= 63 q=-0.0 size=N/A time=00:18:32.73 bitrate=N/A speed=2.62x frame=26668 fps= 63 q=-0.0 size=N/A time=00:18:33.79 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc371.ts' for writing frame=26700 fps= 63 q=-0.0 size=N/A time=00:18:35.29 bitrate=N/A speed=2.62x frame=26732 fps= 63 q=-0.0 size=N/A time=00:18:36.83 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc372.ts' for writing frame=26764 fps= 63 q=-0.0 size=N/A time=00:18:38.11 bitrate=N/A speed=2.62x frame=26796 fps= 63 q=-0.0 size=N/A time=00:18:39.32 bitrate=N/A speed=2.62x frame=26829 fps= 63 q=-0.0 size=N/A time=00:18:40.60 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc373.ts' for writing frame=26861 fps= 63 q=-0.0 size=N/A time=00:18:42.01 bitrate=N/A speed=2.62x frame=26891 fps= 63 q=-0.0 size=N/A time=00:18:43.16 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc374.ts' for writing frame=26921 fps= 63 q=-0.0 size=N/A time=00:18:44.51 bitrate=N/A speed=2.62x frame=26955 fps= 63 q=-0.0 size=N/A time=00:18:45.76 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc375.ts' for writing frame=26981 fps= 63 q=-0.0 size=N/A time=00:18:47.04 bitrate=N/A speed=2.62x frame=27014 fps= 63 q=-0.0 size=N/A time=00:18:48.32 bitrate=N/A speed=2.62x frame=27048 fps= 63 q=-0.0 size=N/A time=00:18:49.85 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc376.ts' for writing frame=27079 fps= 63 q=-0.0 size=N/A time=00:18:50.97 bitrate=N/A speed=2.62x frame=27111 fps= 63 q=-0.0 size=N/A time=00:18:52.51 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc377.ts' for writing frame=27141 fps= 63 q=-0.0 size=N/A time=00:18:53.56 bitrate=N/A speed=2.62x frame=27174 fps= 63 q=-0.0 size=N/A time=00:18:55.16 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc378.ts' for writing frame=27205 fps= 63 q=-0.0 size=N/A time=00:18:56.44 bitrate=N/A speed=2.62x frame=27236 fps= 63 q=-0.0 size=N/A time=00:18:57.72 bitrate=N/A speed=2.62x frame=27266 fps= 63 q=-0.0 size=N/A time=00:18:58.72 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc379.ts' for writing frame=27294 fps= 63 q=-0.0 size=N/A time=00:18:59.96 bitrate=N/A speed=2.62x frame=27325 fps= 63 q=-0.0 size=N/A time=00:19:01.34 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc380.ts' for writing frame=27354 fps= 63 q=-0.0 size=N/A time=00:19:02.46 bitrate=N/A speed=2.62x frame=27383 fps= 63 q=-0.0 size=N/A time=00:19:03.61 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc381.ts' for writing frame=27415 fps= 63 q=-0.0 size=N/A time=00:19:05.05 bitrate=N/A speed=2.62x frame=27446 fps= 63 q=-0.0 size=N/A time=00:19:06.33 bitrate=N/A speed=2.62x frame=27477 fps= 63 q=-0.0 size=N/A time=00:19:07.61 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc382.ts' for writing frame=27508 fps= 63 q=-0.0 size=N/A time=00:19:08.96 bitrate=N/A speed=2.62x frame=27539 fps= 63 q=-0.0 size=N/A time=00:19:10.08 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc383.ts' for writing frame=27569 fps= 63 q=-0.0 size=N/A time=00:19:11.42 bitrate=N/A speed=2.62x frame=27598 fps= 63 q=-0.0 size=N/A time=00:19:12.60 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc384.ts' for writing frame=27629 fps= 63 q=-0.0 size=N/A time=00:19:13.98 bitrate=N/A speed=2.62x frame=27661 fps= 63 q=-0.0 size=N/A time=00:19:15.26 bitrate=N/A speed=2.62x frame=27694 fps= 63 q=-0.0 size=N/A time=00:19:16.73 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc385.ts' for writing frame=27725 fps= 63 q=-0.0 size=N/A time=00:19:18.01 bitrate=N/A speed=2.62x frame=27757 fps= 63 q=-0.0 size=N/A time=00:19:19.29 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc386.ts' for writing frame=27789 fps= 63 q=-0.0 size=N/A time=00:19:20.73 bitrate=N/A speed=2.62x frame=27820 fps= 63 q=-0.0 size=N/A time=00:19:22.01 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc387.ts' for writing frame=27850 fps= 63 q=-0.0 size=N/A time=00:19:23.20 bitrate=N/A speed=2.62x frame=27882 fps= 63 q=-0.0 size=N/A time=00:19:24.51 bitrate=N/A speed=2.62x frame=27912 fps= 63 q=-0.0 size=N/A time=00:19:25.82 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc388.ts' for writing frame=27944 fps= 63 q=-0.0 size=N/A time=00:19:27.13 bitrate=N/A speed=2.62x frame=27975 fps= 63 q=-0.0 size=N/A time=00:19:28.41 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc389.ts' for writing frame=28008 fps= 63 q=-0.0 size=N/A time=00:19:29.69 bitrate=N/A speed=2.62x frame=28041 fps= 63 q=-0.0 size=N/A time=00:19:31.13 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc390.ts' for writing frame=28073 fps= 63 q=-0.0 size=N/A time=00:19:32.41 bitrate=N/A speed=2.62x frame=28105 fps= 63 q=-0.0 size=N/A time=00:19:33.76 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc391.ts' for writing frame=28136 fps= 63 q=-0.0 size=N/A time=00:19:35.29 bitrate=N/A speed=2.62x frame=28168 fps= 63 q=-0.0 size=N/A time=00:19:36.54 bitrate=N/A speed=2.62x frame=28201 fps= 63 q=-0.0 size=N/A time=00:19:37.72 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc392.ts' for writing frame=28232 fps= 63 q=-0.0 size=N/A time=00:19:39.04 bitrate=N/A speed=2.62x frame=28264 fps= 63 q=-0.0 size=N/A time=00:19:40.54 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc393.ts' for writing frame=28294 fps= 63 q=-0.0 size=N/A time=00:19:41.79 bitrate=N/A speed=2.62x frame=28326 fps= 63 q=-0.0 size=N/A time=00:19:43.07 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc394.ts' for writing frame=28358 fps= 63 q=-0.0 size=N/A time=00:19:44.35 bitrate=N/A speed=2.62x frame=28390 fps= 63 q=-0.0 size=N/A time=00:19:45.72 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc395.ts' for writing frame=28423 fps= 63 q=-0.0 size=N/A time=00:19:47.13 bitrate=N/A speed=2.62x frame=28454 fps= 63 q=-0.0 size=N/A time=00:19:48.41 bitrate=N/A speed=2.62x frame=28485 fps= 63 q=-0.0 size=N/A time=00:19:49.56 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc396.ts' for writing frame=28518 fps= 63 q=-0.0 size=N/A time=00:19:51.10 bitrate=N/A speed=2.62x frame=28544 fps= 63 q=-0.0 size=N/A time=00:19:52.41 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc397.ts' for writing frame=28576 fps= 63 q=-0.0 size=N/A time=00:19:53.40 bitrate=N/A speed=2.61x frame=28607 fps= 63 q=-0.0 size=N/A time=00:19:54.68 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc398.ts' for writing frame=28639 fps= 63 q=-0.0 size=N/A time=00:19:56.22 bitrate=N/A speed=2.62x frame=28670 fps= 63 q=-0.0 size=N/A time=00:19:57.40 bitrate=N/A speed=2.61x frame=28703 fps= 63 q=-0.0 size=N/A time=00:19:58.91 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc399.ts' for writing frame=28733 fps= 63 q=-0.0 size=N/A time=00:20:00.19 bitrate=N/A speed=2.62x frame=28766 fps= 63 q=-0.0 size=N/A time=00:20:01.47 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc400.ts' for writing frame=28800 fps= 63 q=-0.0 size=N/A time=00:20:02.94 bitrate=N/A speed=2.62x frame=28833 fps= 63 q=-0.0 size=N/A time=00:20:04.22 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc401.ts' for writing frame=28863 fps= 63 q=-0.0 size=N/A time=00:20:05.44 bitrate=N/A speed=2.62x frame=28896 fps= 63 q=-0.0 size=N/A time=00:20:06.97 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc402.ts' for writing frame=28929 fps= 63 q=-0.0 size=N/A time=00:20:08.25 bitrate=N/A speed=2.62x frame=28961 fps= 63 q=-0.0 size=N/A time=00:20:09.69 bitrate=N/A speed=2.62x frame=28994 fps= 63 q=-0.0 size=N/A time=00:20:10.97 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc403.ts' for writing frame=29027 fps= 63 q=-0.0 size=N/A time=00:20:12.51 bitrate=N/A speed=2.62x frame=29060 fps= 63 q=-0.0 size=N/A time=00:20:13.88 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc404.ts' for writing frame=29092 fps= 63 q=-0.0 size=N/A time=00:20:15.16 bitrate=N/A speed=2.62x frame=29122 fps= 63 q=-0.0 size=N/A time=00:20:16.25 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc405.ts' for writing frame=29157 fps= 63 q=-0.0 size=N/A time=00:20:18.01 bitrate=N/A speed=2.62x frame=29188 fps= 63 q=-0.0 size=N/A time=00:20:19.00 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc406.ts' for writing frame=29220 fps= 63 q=-0.0 size=N/A time=00:20:20.28 bitrate=N/A speed=2.62x frame=29252 fps= 63 q=-0.0 size=N/A time=00:20:21.72 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc407.ts' for writing frame=29285 fps= 63 q=-0.0 size=N/A time=00:20:23.00 bitrate=N/A speed=2.62x frame=29316 fps= 63 q=-0.0 size=N/A time=00:20:24.28 bitrate=N/A speed=2.62x frame=29348 fps= 63 q=-0.0 size=N/A time=00:20:25.72 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc408.ts' for writing frame=29380 fps= 63 q=-0.0 size=N/A time=00:20:27.26 bitrate=N/A speed=2.62x frame=29410 fps= 63 q=-0.0 size=N/A time=00:20:28.48 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc409.ts' for writing frame=29442 fps= 63 q=-0.0 size=N/A time=00:20:29.76 bitrate=N/A speed=2.62x frame=29475 fps= 63 q=-0.0 size=N/A time=00:20:31.04 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc410.ts' for writing frame=29504 fps= 63 q=-0.0 size=N/A time=00:20:32.25 bitrate=N/A speed=2.62x frame=29536 fps= 63 q=-0.0 size=N/A time=00:20:33.53 bitrate=N/A speed=2.62x frame=29568 fps= 63 q=-0.0 size=N/A time=00:20:34.81 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc411.ts' for writing frame=29600 fps= 63 q=-0.0 size=N/A time=00:20:36.19 bitrate=N/A speed=2.62x frame=29632 fps= 63 q=-0.0 size=N/A time=00:20:37.47 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc412.ts' for writing frame=29664 fps= 63 q=-0.0 size=N/A time=00:20:38.97 bitrate=N/A speed=2.62x frame=29695 fps= 63 q=-0.0 size=N/A time=00:20:40.00 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc413.ts' for writing frame=29727 fps= 63 q=-0.0 size=N/A time=00:20:41.50 bitrate=N/A speed=2.62x frame=29758 fps= 63 q=-0.0 size=N/A time=00:20:42.88 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc414.ts' for writing frame=29790 fps= 63 q=-0.0 size=N/A time=00:20:44.16 bitrate=N/A speed=2.62x frame=29819 fps= 63 q=-0.0 size=N/A time=00:20:45.50 bitrate=N/A speed=2.62x frame=29850 fps= 63 q=-0.0 size=N/A time=00:20:46.78 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc415.ts' for writing frame=29881 fps= 63 q=-0.0 size=N/A time=00:20:47.84 bitrate=N/A speed=2.61x frame=29913 fps= 63 q=-0.0 size=N/A time=00:20:49.18 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc416.ts' for writing frame=29945 fps= 63 q=-0.0 size=N/A time=00:20:50.72 bitrate=N/A speed=2.62x frame=29976 fps= 63 q=-0.0 size=N/A time=00:20:52.00 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc417.ts' for writing frame=30008 fps= 63 q=-0.0 size=N/A time=00:20:53.28 bitrate=N/A speed=2.62x frame=30040 fps= 63 q=-0.0 size=N/A time=00:20:54.49 bitrate=N/A speed=2.61x frame=30073 fps= 63 q=-0.0 size=N/A time=00:20:56.03 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc418.ts' for writing frame=30104 fps= 63 q=-0.0 size=N/A time=00:20:57.34 bitrate=N/A speed=2.62x frame=30136 fps= 63 q=-0.0 size=N/A time=00:20:58.43 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc419.ts' for writing frame=30168 fps= 63 q=-0.0 size=N/A time=00:20:59.96 bitrate=N/A speed=2.62x frame=30199 fps= 63 q=-0.0 size=N/A time=00:21:01.28 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc420.ts' for writing frame=30231 fps= 63 q=-0.0 size=N/A time=00:21:02.49 bitrate=N/A speed=2.61x frame=30265 fps= 63 q=-0.0 size=N/A time=00:21:04.00 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc421.ts' for writing frame=30297 fps= 63 q=-0.0 size=N/A time=00:21:05.15 bitrate=N/A speed=2.61x frame=30331 fps= 63 q=-0.0 size=N/A time=00:21:06.65 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc422.ts' for writing frame=30363 fps= 63 q=-0.0 size=N/A time=00:21:08.19 bitrate=N/A speed=2.62x frame=30395 fps= 63 q=-0.0 size=N/A time=00:21:09.37 bitrate=N/A speed=2.62x frame=30427 fps= 63 q=-0.0 size=N/A time=00:21:10.62 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc423.ts' for writing frame=30458 fps= 63 q=-0.0 size=N/A time=00:21:12.16 bitrate=N/A speed=2.62x frame=30491 fps= 63 q=-0.0 size=N/A time=00:21:13.69 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc424.ts' for writing frame=30524 fps= 63 q=-0.0 size=N/A time=00:21:14.81 bitrate=N/A speed=2.62x frame=30554 fps= 63 q=-0.0 size=N/A time=00:21:15.87 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc425.ts' for writing frame=30587 fps= 63 q=-0.0 size=N/A time=00:21:17.37 bitrate=N/A speed=2.62x frame=30618 fps= 63 q=-0.0 size=N/A time=00:21:18.52 bitrate=N/A speed=2.61x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc426.ts' for writing frame=30652 fps= 63 q=-0.0 size=N/A time=00:21:20.03 bitrate=N/A speed=2.62x frame=30684 fps= 63 q=-0.0 size=N/A time=00:21:21.56 bitrate=N/A speed=2.62x frame=30716 fps= 63 q=-0.0 size=N/A time=00:21:22.59 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc427.ts' for writing frame=30747 fps= 63 q=-0.0 size=N/A time=00:21:24.28 bitrate=N/A speed=2.62x frame=30779 fps= 63 q=-0.0 size=N/A time=00:21:25.31 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc428.ts' for writing frame=30812 fps= 63 q=-0.0 size=N/A time=00:21:26.59 bitrate=N/A speed=2.62x frame=30843 fps= 63 q=-0.0 size=N/A time=00:21:28.03 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc429.ts' for writing frame=30875 fps= 63 q=-0.0 size=N/A time=00:21:29.56 bitrate=N/A speed=2.62x frame=30908 fps= 63 q=-0.0 size=N/A time=00:21:30.84 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc430.ts' for writing frame=30941 fps= 63 q=-0.0 size=N/A time=00:21:32.28 bitrate=N/A speed=2.62x frame=30974 fps= 63 q=-0.0 size=N/A time=00:21:33.56 bitrate=N/A speed=2.62x frame=31006 fps= 63 q=-0.0 size=N/A time=00:21:34.84 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc431.ts' for writing frame=31039 fps= 63 q=-0.0 size=N/A time=00:21:36.28 bitrate=N/A speed=2.62x frame=31072 fps= 63 q=-0.0 size=N/A time=00:21:37.56 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc432.ts' for writing frame=31104 fps= 63 q=-0.0 size=N/A time=00:21:39.10 bitrate=N/A speed=2.62x frame=31137 fps= 63 q=-0.0 size=N/A time=00:21:40.51 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc433.ts' for writing frame=31171 fps= 63 q=-0.0 size=N/A time=00:21:41.76 bitrate=N/A speed=2.62x frame=31204 fps= 63 q=-0.0 size=N/A time=00:21:43.04 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc434.ts' for writing frame=31237 fps= 63 q=-0.0 size=N/A time=00:21:44.64 bitrate=N/A speed=2.62x frame=31269 fps= 63 q=-0.0 size=N/A time=00:21:45.76 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc435.ts' for writing frame=31302 fps= 63 q=-0.0 size=N/A time=00:21:47.29 bitrate=N/A speed=2.62x frame=31335 fps= 63 q=-0.0 size=N/A time=00:21:48.57 bitrate=N/A speed=2.62x frame=31367 fps= 63 q=-0.0 size=N/A time=00:21:49.76 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc436.ts' for writing frame=31398 fps= 63 q=-0.0 size=N/A time=00:21:51.07 bitrate=N/A speed=2.62x frame=31430 fps= 63 q=-0.0 size=N/A time=00:21:52.51 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc437.ts' for writing frame=31462 fps= 63 q=-0.0 size=N/A time=00:21:53.79 bitrate=N/A speed=2.62x frame=31494 fps= 63 q=-0.0 size=N/A time=00:21:55.16 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc438.ts' for writing frame=31525 fps= 63 q=-0.0 size=N/A time=00:21:56.38 bitrate=N/A speed=2.62x frame=31557 fps= 63 q=-0.0 size=N/A time=00:21:57.88 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc439.ts' for writing frame=31588 fps= 63 q=-0.0 size=N/A time=00:21:59.00 bitrate=N/A speed=2.62x frame=31619 fps= 63 q=-0.0 size=N/A time=00:22:00.54 bitrate=N/A speed=2.62x frame=31650 fps= 63 q=-0.0 size=N/A time=00:22:01.76 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc440.ts' for writing frame=31681 fps= 63 q=-0.0 size=N/A time=00:22:03.07 bitrate=N/A speed=2.62x frame=31711 fps= 63 q=-0.0 size=N/A time=00:22:04.12 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc441.ts' for writing frame=31743 fps= 63 q=-0.0 size=N/A time=00:22:05.56 bitrate=N/A speed=2.62x frame=31774 fps= 63 q=-0.0 size=N/A time=00:22:06.88 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc442.ts' for writing frame=31806 fps= 63 q=-0.0 size=N/A time=00:22:08.22 bitrate=N/A speed=2.62x frame=31838 fps= 63 q=-0.0 size=N/A time=00:22:09.50 bitrate=N/A speed=2.62x frame=31869 fps= 63 q=-0.0 size=N/A time=00:22:10.81 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc443.ts' for writing frame=31900 fps= 63 q=-0.0 size=N/A time=00:22:12.09 bitrate=N/A speed=2.62x frame=31931 fps= 63 q=-0.0 size=N/A time=00:22:13.34 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc444.ts' for writing frame=31962 fps= 63 q=-0.0 size=N/A time=00:22:14.72 bitrate=N/A speed=2.62x frame=31995 fps= 63 q=-0.0 size=N/A time=00:22:16.22 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc445.ts' for writing frame=32027 fps= 63 q=-0.0 size=N/A time=00:22:17.37 bitrate=N/A speed=2.62x frame=32060 fps= 63 q=-0.0 size=N/A time=00:22:18.81 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc446.ts' for writing frame=32091 fps= 63 q=-0.0 size=N/A time=00:22:20.12 bitrate=N/A speed=2.62x frame=32123 fps= 63 q=-0.0 size=N/A time=00:22:21.40 bitrate=N/A speed=2.62x frame=32157 fps= 63 q=-0.0 size=N/A time=00:22:22.84 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc447.ts' for writing frame=32189 fps= 63 q=-0.0 size=N/A time=00:22:24.19 bitrate=N/A speed=2.62x frame=32221 fps= 63 q=-0.0 size=N/A time=00:22:25.72 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc448.ts' for writing frame=32252 fps= 63 q=-0.0 size=N/A time=00:22:26.81 bitrate=N/A speed=2.62x frame=32284 fps= 63 q=-0.0 size=N/A time=00:22:28.35 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc449.ts' for writing frame=32317 fps= 63 q=-0.0 size=N/A time=00:22:29.56 bitrate=N/A speed=2.62x frame=32350 fps= 63 q=-0.0 size=N/A time=00:22:30.84 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc450.ts' for writing frame=32382 fps= 63 q=-0.0 size=N/A time=00:22:32.16 bitrate=N/A speed=2.62x frame=32416 fps= 63 q=-0.0 size=N/A time=00:22:33.53 bitrate=N/A speed=2.62x frame=32449 fps= 63 q=-0.0 size=N/A time=00:22:35.07 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc451.ts' for writing frame=32481 fps= 63 q=-0.0 size=N/A time=00:22:36.35 bitrate=N/A speed=2.62x frame=32514 fps= 63 q=-0.0 size=N/A time=00:22:37.88 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc452.ts' for writing frame=32546 fps= 63 q=-0.0 size=N/A time=00:22:39.04 bitrate=N/A speed=2.62x frame=32578 fps= 63 q=-0.0 size=N/A time=00:22:40.57 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc453.ts' for writing frame=32611 fps= 63 q=-0.0 size=N/A time=00:22:41.85 bitrate=N/A speed=2.62x frame=32644 fps= 63 q=-0.0 size=N/A time=00:22:43.39 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc454.ts' for writing frame=32677 fps= 63 q=-0.0 size=N/A time=00:22:44.54 bitrate=N/A speed=2.62x frame=32709 fps= 63 q=-0.0 size=N/A time=00:22:46.08 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc455.ts' for writing frame=32741 fps= 63 q=-0.0 size=N/A time=00:22:47.10 bitrate=N/A speed=2.62x frame=32772 fps= 63 q=-0.0 size=N/A time=00:22:48.64 bitrate=N/A speed=2.62x frame=32804 fps= 63 q=-0.0 size=N/A time=00:22:49.76 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc456.ts' for writing frame=32836 fps= 63 q=-0.0 size=N/A time=00:22:51.16 bitrate=N/A speed=2.62x frame=32868 fps= 63 q=-0.0 size=N/A time=00:22:52.44 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc457.ts' for writing frame=32902 fps= 63 q=-0.0 size=N/A time=00:22:53.95 bitrate=N/A speed=2.62x frame=32934 fps= 63 q=-0.0 size=N/A time=00:22:55.36 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc458.ts' for writing frame=32968 fps= 63 q=-0.0 size=N/A time=00:22:56.80 bitrate=N/A speed=2.62x frame=33001 fps= 63 q=-0.0 size=N/A time=00:22:58.08 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc459.ts' for writing frame=33032 fps= 63 q=-0.0 size=N/A time=00:22:59.36 bitrate=N/A speed=2.62x frame=33062 fps= 63 q=-0.0 size=N/A time=00:23:00.64 bitrate=N/A speed=2.62x frame=33091 fps= 63 q=-0.0 size=N/A time=00:23:01.69 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc460.ts' for writing frame=33122 fps= 63 q=-0.0 size=N/A time=00:23:03.20 bitrate=N/A speed=2.62x frame=33153 fps= 63 q=-0.0 size=N/A time=00:23:04.48 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc461.ts' for writing frame=33185 fps= 63 q=-0.0 size=N/A time=00:23:05.76 bitrate=N/A speed=2.62x frame=33217 fps= 63 q=-0.0 size=N/A time=00:23:07.04 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc462.ts' for writing frame=33250 fps= 63 q=-0.0 size=N/A time=00:23:08.32 bitrate=N/A speed=2.62x frame=33282 fps= 63 q=-0.0 size=N/A time=00:23:09.92 bitrate=N/A speed=2.62x frame=33313 fps= 63 q=-0.0 size=N/A time=00:23:10.94 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc463.ts' for writing frame=33334 fps= 63 q=-0.0 size=N/A time=00:23:12.00 bitrate=N/A speed=2.62x frame=33367 fps= 63 q=-0.0 size=N/A time=00:23:13.40 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc464.ts' for writing frame=33398 fps= 63 q=-0.0 size=N/A time=00:23:14.94 bitrate=N/A speed=2.62x frame=33428 fps= 63 q=-0.0 size=N/A time=00:23:15.93 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc465.ts' for writing frame=33460 fps= 63 q=-0.0 size=N/A time=00:23:17.44 bitrate=N/A speed=2.62x frame=33493 fps= 63 q=-0.0 size=N/A time=00:23:18.46 bitrate=N/A speed=2.62x frame=33527 fps= 63 q=-0.0 size=N/A time=00:23:20.06 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc466.ts' for writing frame=33561 fps= 63 q=-0.0 size=N/A time=00:23:21.34 bitrate=N/A speed=2.62x frame=33594 fps= 63 q=-0.0 size=N/A time=00:23:22.88 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc467.ts' for writing frame=33627 fps= 63 q=-0.0 size=N/A time=00:23:24.19 bitrate=N/A speed=2.62x frame=33659 fps= 63 q=-0.0 size=N/A time=00:23:25.76 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc468.ts' for writing frame=33685 fps= 63 q=-0.0 size=N/A time=00:23:26.52 bitrate=N/A speed=2.62x frame=33716 fps= 63 q=-0.0 size=N/A time=00:23:28.09 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc469.ts' for writing frame=33748 fps= 63 q=-0.0 size=N/A time=00:23:29.18 bitrate=N/A speed=2.62x frame=33781 fps= 63 q=-0.0 size=N/A time=00:23:30.72 bitrate=N/A speed=2.62x frame=33814 fps= 63 q=-0.0 size=N/A time=00:23:32.00 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc470.ts' for writing frame=33847 fps= 63 q=-0.0 size=N/A time=00:23:33.24 bitrate=N/A speed=2.62x frame=33879 fps= 63 q=-0.0 size=N/A time=00:23:34.78 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc471.ts' for writing frame=33911 fps= 63 q=-0.0 size=N/A time=00:23:36.03 bitrate=N/A speed=2.62x frame=33944 fps= 63 q=-0.0 size=N/A time=00:23:37.37 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc472.ts' for writing frame=33977 fps= 63 q=-0.0 size=N/A time=00:23:38.65 bitrate=N/A speed=2.62x frame=34009 fps= 63 q=-0.0 size=N/A time=00:23:39.93 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc473.ts' for writing frame=34040 fps= 63 q=-0.0 size=N/A time=00:23:41.47 bitrate=N/A speed=2.62x frame=34073 fps= 63 q=-0.0 size=N/A time=00:23:42.40 bitrate=N/A speed=2.62x [segment @ 0x365aed0] Opening '/mnt/library/tmp/transcoding-temp/b6ce9178696288402418acebd27699cc.m3u8.tmp' for writing frame=34104 fps= 63 q=-0.0 Lsize=N/A time=00:23:42.40 bitrate=N/A speed=2.61x video:447798kB audio:33338kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
devrus Posted January 8, 2018 Author Posted January 8, 2018 Here is example for 1080p speed=1.22 Spoiler 2018-01-08 22:03:57.419 Application version: 3.2.60.0 http://192.168.1.166:8096/emby/videos/c37ff1a2108d51e7f2c8b23c7998f0c3/hls1/main/0.ts?DeviceId=f3f59edb98f7568ede27193c757b6c9418951356&MediaSourceId=c37ff1a2108d51e7f2c8b23c7998f0c3&VideoCodec=h264&AudioCodec=ac3,eac3,aac,mp3&AudioStreamIndex=1&VideoBitrate=9808000&AudioBitrate=192000&PlaySessionId=3a5f69e6361244d9956a129f91e9fcd8&api_key=9f196ee35e0b4905945c0ecd8da1dc69&CopyTimestamps=false&TranscodingMaxAudioChannels=6&EnableSubtitlesInManifest=false&Tag=d01fd9f067e79ef3f8282004820287f2&RequireAvc=false&RequireNonAnamorphic=false&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=False&TranscodeReasons=VideoProfileNotSupported,ContainerBitrateExceedsLimit&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51 {"Protocol":"File","Id":"c37ff1a2108d51e7f2c8b23c7998f0c3","Path":"/mnt/library/Torrent/Anime/Movee BD Rip 1080p.mkv","Type":"Default","Container":"mkv,webm","Name":"Movee BD Rip 1080p.mkv","IsRemote":false,"ETag":"d01fd9f067e79ef3f8282004820287f2","RunTimeTicks":14311680000,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"RequiresLooping":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","TimeBase":"1/1000","CodecTimeBase":"1001/48000","DisplayTitle":"1080P H264","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":11981925,"BitDepth":10,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":23.9760246,"RealFrameRate":23.9760246,"Profile":"High 10","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p10le","Level":41,"IsAnamorphic":false},{"Codec":"aac","Language":"rus","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Marclail & NikaLenina","DisplayTitle":"Rus AAC stereo Default","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"LC","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"flac","Language":"jpn","TimeBase":"1/1000","CodecTimeBase":"1/48000","DisplayTitle":"Jpn FLAC stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitDepth":24,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false}],"Formats":[],"Bitrate":11981925,"RequiredHttpHeaders":{}} User policy for devrus: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True /usr/local/bin/ffmpeg -c:v h264_mmal -i file:"/mnt/library/Torrent/Anime/Movee BD Rip 1080p.mkv" -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_omx -vf "scale=trunc(min(max(iw\,ih*dar)\,1920)/2)*2:trunc(ow/dar/2)*2" -b:v 9808000 -maxrate 9808000 -bufsize 19616000 -force_key_frames "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -copyts -vsync -1 -codec:a:0 copy -f segment -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8" -y "/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45%d.ts" ffmpeg version git-2018-01-07-476665d Copyright (c) 2000-2018 the FFmpeg developers built with gcc 4.9.2 (Raspbian 4.9.2-10) configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --disable-ffplay --disable-indev=sndio --disable-outdev=sndio --enable-fontconfig --enable-frei0r --enable-gnutls --enable-gray --enable-libfribidi --enable-libass --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-librubberband --enable-librtmp --enable-libsoxr --enable-libspeex --enable-libvorbis --enable-libopus --enable-libtheora --enable-libvidstab --enable-libvo-amrwbenc --enable-libvpx --enable-libwebp --enable-libx264 --enable-libxvid --enable-omx-rpi --enable-omx --enable-mmal libavutil 56. 7.100 / 56. 7.100 libavcodec 58. 9.100 / 58. 9.100 libavformat 58. 3.100 / 58. 3.100 libavdevice 58. 0.100 / 58. 0.100 libavfilter 7. 11.101 / 7. 11.101 libswscale 5. 0.101 / 5. 0.101 libswresample 3. 0.101 / 3. 0.101 libpostproc 55. 0.100 / 55. 0.100 Input #0, matroska,webm, from 'file:/mnt/library/Torrent/Anime/Movee BD Rip 1080p.mkv': Metadata: encoder : libebml v1.0.0 + libmatroska v1.0.0 creation_time : 2012-05-15T06:18:57.000000Z Duration: 00:23:51.17, start: 0.000000, bitrate: 11981 kb/s Stream #0:0: Video: h264 (High 10), yuv420p10le(progressive), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) Stream #0:1(rus): Audio: aac (LC), 48000 Hz, stereo, fltp (default) Metadata: title : Marclail & NikaLenina Stream #0:2(jpn): Audio: flac, 48000 Hz, stereo, s32 (24 bit) Stream mapping: Stream #0:0 -> #0:0 (h264 (h264_mmal) -> h264 (h264_omx)) Stream #0:1 -> #0:1 (copy) Press [q] to stop, [?] for help [h264_omx @ 0x26c2520] Using OMX.broadcom.video_encode [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d450.ts' for writing Output #0, segment, to '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45%d.ts': Metadata: encoder : Lavf58.3.100 Stream #0:0: Video: h264 (h264_omx), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 9808 kb/s, 23.98 fps, 90k tbn, 23.98 tbc (default) Metadata: encoder : Lavc58.9.100 h264_omx Stream #0:1: Audio: aac (LC), 48000 Hz, stereo, fltp (default) frame= 8 fps=0.0 q=-0.0 size=N/A time=00:00:01.85 bitrate=N/A speed=3.66x frame= 24 fps= 23 q=-0.0 size=N/A time=00:00:02.36 bitrate=N/A speed= 2.3x frame= 39 fps= 25 q=-0.0 size=N/A time=00:00:03.09 bitrate=N/A speed=1.99x frame= 55 fps= 27 q=-0.0 size=N/A time=00:00:03.60 bitrate=N/A speed=1.74x frame= 70 fps= 27 q=-0.0 size=N/A time=00:00:04.28 bitrate=N/A speed=1.65x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d451.ts' for writing frame= 83 fps= 27 q=-0.0 size=N/A time=00:00:04.84 bitrate=N/A speed=1.56x frame= 97 fps= 27 q=-0.0 size=N/A time=00:00:05.37 bitrate=N/A speed=1.48x frame= 113 fps= 27 q=-0.0 size=N/A time=00:00:06.14 bitrate=N/A speed=1.48x frame= 127 fps= 27 q=-0.0 size=N/A time=00:00:06.67 bitrate=N/A speed=1.43x frame= 142 fps= 27 q=-0.0 size=N/A time=00:00:07.23 bitrate=N/A speed= 1.4x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d452.ts' for writing frame= 156 fps= 27 q=-0.0 size=N/A time=00:00:07.87 bitrate=N/A speed=1.39x frame= 172 fps= 28 q=-0.0 size=N/A time=00:00:08.55 bitrate=N/A speed=1.38x frame= 187 fps= 28 q=-0.0 size=N/A time=00:00:09.23 bitrate=N/A speed=1.37x frame= 202 fps= 28 q=-0.0 size=N/A time=00:00:09.79 bitrate=N/A speed=1.35x frame= 216 fps= 28 q=-0.0 size=N/A time=00:00:10.47 bitrate=N/A speed=1.35x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d453.ts' for writing frame= 231 fps= 28 q=-0.0 size=N/A time=00:00:11.09 bitrate=N/A speed=1.34x frame= 246 fps= 28 q=-0.0 size=N/A time=00:00:11.60 bitrate=N/A speed=1.32x frame= 262 fps= 28 q=-0.0 size=N/A time=00:00:12.24 bitrate=N/A speed=1.31x frame= 277 fps= 28 q=-0.0 size=N/A time=00:00:12.96 bitrate=N/A speed=1.31x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d454.ts' for writing frame= 292 fps= 28 q=-0.0 size=N/A time=00:00:13.65 bitrate=N/A speed=1.32x frame= 306 fps= 28 q=-0.0 size=N/A time=00:00:14.12 bitrate=N/A speed= 1.3x frame= 319 fps= 28 q=-0.0 size=N/A time=00:00:14.65 bitrate=N/A speed=1.28x frame= 333 fps= 28 q=-0.0 size=N/A time=00:00:15.42 bitrate=N/A speed=1.29x frame= 349 fps= 28 q=-0.0 size=N/A time=00:00:15.91 bitrate=N/A speed=1.28x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d455.ts' for writing frame= 363 fps= 28 q=-0.0 size=N/A time=00:00:16.59 bitrate=N/A speed=1.28x frame= 377 fps= 28 q=-0.0 size=N/A time=00:00:17.08 bitrate=N/A speed=1.27x frame= 392 fps= 28 q=-0.0 size=N/A time=00:00:17.76 bitrate=N/A speed=1.27x frame= 406 fps= 28 q=-0.0 size=N/A time=00:00:18.30 bitrate=N/A speed=1.26x frame= 420 fps= 28 q=-0.0 size=N/A time=00:00:18.83 bitrate=N/A speed=1.26x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d456.ts' for writing frame= 436 fps= 28 q=-0.0 size=N/A time=00:00:19.56 bitrate=N/A speed=1.26x frame= 448 fps= 28 q=-0.0 size=N/A time=00:00:19.98 bitrate=N/A speed=1.25x frame= 464 fps= 28 q=-0.0 size=N/A time=00:00:20.64 bitrate=N/A speed=1.25x frame= 478 fps= 28 q=-0.0 size=N/A time=00:00:21.31 bitrate=N/A speed=1.25x frame= 493 fps= 28 q=-0.0 size=N/A time=00:00:22.01 bitrate=N/A speed=1.25x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d457.ts' for writing frame= 507 fps= 28 q=-0.0 size=N/A time=00:00:22.42 bitrate=N/A speed=1.24x frame= 521 fps= 28 q=-0.0 size=N/A time=00:00:23.10 bitrate=N/A speed=1.24x frame= 535 fps= 28 q=-0.0 size=N/A time=00:00:23.80 bitrate=N/A speed=1.25x frame= 550 fps= 28 q=-0.0 size=N/A time=00:00:24.31 bitrate=N/A speed=1.24x frame= 564 fps= 28 q=-0.0 size=N/A time=00:00:24.80 bitrate=N/A speed=1.23x frame= 578 fps= 28 q=-0.0 size=N/A time=00:00:25.40 bitrate=N/A speed=1.23x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d458.ts' for writing frame= 591 fps= 28 q=-0.0 size=N/A time=00:00:26.09 bitrate=N/A speed=1.23x frame= 606 fps= 28 q=-0.0 size=N/A time=00:00:26.60 bitrate=N/A speed=1.23x frame= 621 fps= 28 q=-0.0 size=N/A time=00:00:27.28 bitrate=N/A speed=1.23x frame= 636 fps= 28 q=-0.0 size=N/A time=00:00:27.96 bitrate=N/A speed=1.23x frame= 650 fps= 28 q=-0.0 size=N/A time=00:00:28.43 bitrate=N/A speed=1.22x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d459.ts' for writing frame= 664 fps= 28 q=-0.0 size=N/A time=00:00:29.11 bitrate=N/A speed=1.23x frame= 679 fps= 28 q=-0.0 size=N/A time=00:00:29.61 bitrate=N/A speed=1.22x frame= 693 fps= 28 q=-0.0 size=N/A time=00:00:30.18 bitrate=N/A speed=1.22x frame= 708 fps= 28 q=-0.0 size=N/A time=00:00:30.86 bitrate=N/A speed=1.22x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d4510.ts' for writing frame= 723 fps= 28 q=-0.0 size=N/A time=00:00:31.57 bitrate=N/A speed=1.22x frame= 735 fps= 28 q=-0.0 size=N/A time=00:00:32.00 bitrate=N/A speed=1.22x frame= 750 fps= 28 q=-0.0 size=N/A time=00:00:32.59 bitrate=N/A speed=1.22x frame= 766 fps= 28 q=-0.0 size=N/A time=00:00:33.42 bitrate=N/A speed=1.22x frame= 780 fps= 28 q=-0.0 size=N/A time=00:00:33.92 bitrate=N/A speed=1.22x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d4511.ts' for writing frame= 796 fps= 28 q=-0.0 size=N/A time=00:00:34.58 bitrate=N/A speed=1.22x frame= 811 fps= 28 q=-0.0 size=N/A time=00:00:35.26 bitrate=N/A speed=1.22x frame= 826 fps= 28 q=-0.0 size=N/A time=00:00:35.94 bitrate=N/A speed=1.22x frame= 841 fps= 28 q=-0.0 size=N/A time=00:00:36.62 bitrate=N/A speed=1.22x frame= 856 fps= 28 q=-0.0 size=N/A time=00:00:37.14 bitrate=N/A speed=1.22x frame= 861 fps= 28 q=-0.0 size=N/A time=00:00:37.31 bitrate=N/A speed= 1.2x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d4512.ts' for writing frame= 874 fps= 28 q=-0.0 size=N/A time=00:00:37.86 bitrate=N/A speed= 1.2x frame= 889 fps= 28 q=-0.0 size=N/A time=00:00:38.37 bitrate=N/A speed=1.19x frame= 903 fps= 28 q=-0.0 size=N/A time=00:00:39.08 bitrate=N/A speed= 1.2x frame= 918 fps= 28 q=-0.0 size=N/A time=00:00:39.65 bitrate=N/A speed= 1.2x frame= 932 fps= 28 q=-0.0 size=N/A time=00:00:40.19 bitrate=N/A speed=1.19x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d4513.ts' for writing frame= 948 fps= 28 q=-0.0 size=N/A time=00:00:40.89 bitrate=N/A speed=1.19x frame= 961 fps= 28 q=-0.0 size=N/A time=00:00:41.42 bitrate=N/A speed=1.19x frame= 976 fps= 28 q=-0.0 size=N/A time=00:00:42.04 bitrate=N/A speed=1.19x frame= 990 fps= 28 q=-0.0 size=N/A time=00:00:42.73 bitrate=N/A speed=1.19x frame= 1005 fps= 28 q=-0.0 size=N/A time=00:00:43.22 bitrate=N/A speed=1.19x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d4514.ts' for writing frame= 1019 fps= 28 q=-0.0 size=N/A time=00:00:43.88 bitrate=N/A speed=1.19x frame= 1034 fps= 28 q=-0.0 size=N/A time=00:00:44.41 bitrate=N/A speed=1.19x frame= 1048 fps= 28 q=-0.0 size=N/A time=00:00:45.03 bitrate=N/A speed=1.19x frame= 1063 fps= 28 q=-0.0 size=N/A time=00:00:45.71 bitrate=N/A speed=1.19x frame= 1077 fps= 28 q=-0.0 size=N/A time=00:00:46.29 bitrate=N/A speed=1.19x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d4515.ts' for writing frame= 1092 fps= 28 q=-0.0 size=N/A time=00:00:46.97 bitrate=N/A speed=1.19x frame= 1106 fps= 28 q=-0.0 size=N/A time=00:00:47.48 bitrate=N/A speed=1.19x frame= 1120 fps= 28 q=-0.0 size=N/A time=00:00:48.06 bitrate=N/A speed=1.19x frame= 1135 fps= 28 q=-0.0 size=N/A time=00:00:48.74 bitrate=N/A speed=1.19x frame= 1150 fps= 28 q=-0.0 size=N/A time=00:00:49.23 bitrate=N/A speed=1.19x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d4516.ts' for writing frame= 1164 fps= 28 q=-0.0 size=N/A time=00:00:50.04 bitrate=N/A speed=1.19x frame= 1180 fps= 28 q=-0.0 size=N/A time=00:00:50.55 bitrate=N/A speed=1.19x frame= 1195 fps= 28 q=-0.0 size=N/A time=00:00:51.39 bitrate=N/A speed=1.19x frame= 1210 fps= 28 q=-0.0 size=N/A time=00:00:51.92 bitrate=N/A speed=1.19x frame= 1226 fps= 28 q=-0.0 size=N/A time=00:00:52.58 bitrate=N/A speed=1.19x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d4517.ts' for writing frame= 1241 fps= 28 q=-0.0 size=N/A time=00:00:53.03 bitrate=N/A speed=1.19x frame= 1255 fps= 28 q=-0.0 size=N/A time=00:00:53.71 bitrate=N/A speed=1.19x frame= 1270 fps= 28 q=-0.0 size=N/A time=00:00:54.42 bitrate=N/A speed=1.19x frame= 1285 fps= 28 q=-0.0 size=N/A time=00:00:55.10 bitrate=N/A speed=1.19x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d4518.ts' for writing frame= 1300 fps= 28 q=-0.0 size=N/A time=00:00:55.70 bitrate=N/A speed=1.19x frame= 1313 fps= 28 q=-0.0 size=N/A time=00:00:56.06 bitrate=N/A speed=1.19x frame= 1329 fps= 28 q=-0.0 size=N/A time=00:00:56.72 bitrate=N/A speed=1.19x frame= 1344 fps= 28 q=-0.0 size=N/A time=00:00:57.51 bitrate=N/A speed=1.19x frame= 1359 fps= 28 q=-0.0 size=N/A time=00:00:58.00 bitrate=N/A speed=1.19x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d4519.ts' for writing frame= 1373 fps= 28 q=-0.0 size=N/A time=00:00:58.68 bitrate=N/A speed=1.19x frame= 1388 fps= 28 q=-0.0 size=N/A time=00:00:59.17 bitrate=N/A speed=1.19x frame= 1401 fps= 28 q=-0.0 size=N/A time=00:00:59.84 bitrate=N/A speed=1.19x frame= 1416 fps= 28 q=-0.0 size=N/A time=00:01:00.50 bitrate=N/A speed=1.19x frame= 1431 fps= 28 q=-0.0 size=N/A time=00:01:01.14 bitrate=N/A speed=1.19x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d4520.ts' for writing frame= 1446 fps= 28 q=-0.0 size=N/A time=00:01:01.63 bitrate=N/A speed=1.19x frame= 1460 fps= 28 q=-0.0 size=N/A time=00:01:02.31 bitrate=N/A speed=1.19x frame= 1476 fps= 28 q=-0.0 size=N/A time=00:01:02.84 bitrate=N/A speed=1.19x frame= 1491 fps= 28 q=-0.0 size=N/A time=00:01:03.52 bitrate=N/A speed=1.19x frame= 1506 fps= 28 q=-0.0 size=N/A time=00:01:04.14 bitrate=N/A speed=1.19x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d4521.ts' for writing frame= 1519 fps= 28 q=-0.0 size=N/A time=00:01:04.66 bitrate=N/A speed=1.19x frame= 1534 fps= 28 q=-0.0 size=N/A time=00:01:05.34 bitrate=N/A speed=1.19x frame= 1549 fps= 28 q=-0.0 size=N/A time=00:01:05.98 bitrate=N/A speed=1.19x frame= 1565 fps= 28 q=-0.0 size=N/A time=00:01:06.66 bitrate=N/A speed=1.19x frame= 1580 fps= 28 q=-0.0 size=N/A time=00:01:07.17 bitrate=N/A speed=1.19x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d4522.ts' for writing frame= 1594 fps= 28 q=-0.0 size=N/A time=00:01:07.88 bitrate=N/A speed=1.19x frame= 1609 fps= 28 q=-0.0 size=N/A time=00:01:08.43 bitrate=N/A speed=1.19x frame= 1625 fps= 28 q=-0.0 size=N/A time=00:01:09.11 bitrate=N/A speed=1.19x frame= 1638 fps= 28 q=-0.0 size=N/A time=00:01:09.63 bitrate=N/A speed=1.19x frame= 1655 fps= 28 q=-0.0 size=N/A time=00:01:10.46 bitrate=N/A speed=1.19x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d4523.ts' for writing frame= 1669 fps= 28 q=-0.0 size=N/A time=00:01:10.89 bitrate=N/A speed=1.19x frame= 1683 fps= 28 q=-0.0 size=N/A time=00:01:11.50 bitrate=N/A speed=1.19x frame= 1699 fps= 28 q=-0.0 size=N/A time=00:01:12.34 bitrate=N/A speed=1.19x frame= 1715 fps= 28 q=-0.0 size=N/A time=00:01:12.85 bitrate=N/A speed=1.19x frame= 1722 fps= 28 q=-0.0 size=N/A time=00:01:13.19 bitrate=N/A speed=1.19x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d4524.ts' for writing frame= 1736 fps= 28 q=-0.0 size=N/A time=00:01:13.79 bitrate=N/A speed=1.19x frame= 1751 fps= 28 q=-0.0 size=N/A time=00:01:14.45 bitrate=N/A speed=1.19x frame= 1766 fps= 28 q=-0.0 size=N/A time=00:01:15.13 bitrate=N/A speed=1.19x frame= 1779 fps= 28 q=-0.0 size=N/A time=00:01:15.49 bitrate=N/A speed=1.19x frame= 1795 fps= 28 q=-0.0 size=N/A time=00:01:16.32 bitrate=N/A speed=1.19x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d4525.ts' for writing frame= 1810 fps= 28 q=-0.0 size=N/A time=00:01:16.82 bitrate=N/A speed=1.19x frame= 1825 fps= 28 q=-0.0 size=N/A time=00:01:17.54 bitrate=N/A speed=1.19x frame= 1838 fps= 28 q=-0.0 size=N/A time=00:01:18.05 bitrate=N/A speed=1.19x frame= 1852 fps= 28 q=-0.0 size=N/A time=00:01:18.59 bitrate=N/A speed=1.19x frame= 1866 fps= 28 q=-0.0 size=N/A time=00:01:19.27 bitrate=N/A speed=1.19x [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d45.m3u8.tmp' for writing [segment @ 0x26e0190] Opening '/mnt/library/tmp/transcoding-temp/e044beb3688f2b6b00cf51499a9c4d4526.ts' for writing Currenly problems are heat and Emby - Plex is much better... I will buy a small fan i think becasue for after long video tempreture is pretty high(80+)
manuti Posted January 8, 2018 Posted January 8, 2018 Impressive numbers. How do you manage to achieve this performance? Thanks
devrus Posted January 8, 2018 Author Posted January 8, 2018 I've build ffmpeg from sources with suport for hw acceleration for h264 for rpi3 It is not possible to achive same for plex because their Plex Transcoder is modified ffmpeg. And sources are closed... I've created topic on a plex forums maybe they can give their sources https://forums.plex.tv/discussion/302965/plex-transcoder-actual-sources 1
Jingzhao Liu Posted November 19, 2019 Posted November 19, 2019 On 1/9/2018 at 6:12 AM, devrus said: I've build ffmpeg from sources with suport for hw acceleration for h264 for rpi3 It is not possible to achive same for plex because their Plex Transcoder is modified ffmpeg. And sources are closed... I've created topic on a plex forums maybe they can give their sources https://forums.plex.tv/discussion/302965/plex-transcoder-actual-sources Hello, I want use hw acceleration for s905d vpu(mali 450), I want to use jellyfin ffmpeg transcode, do you have some suggestion? 1
