I was so happy to discovery your image and to reuse my Odroid. After installing the OMV 6.18.10 image, I noticed that no plugins could be installed, and later that even an "apt list" command fails. Please see some command line logs below:
    _             _    _
   /_\  _ _ _ __ | |__(_)__ _ _ _
  / _ \| '_| '  \| '_ \ / _` | ' \
 /_/ \_\_| |_|_|_|_.__/_\__,_|_||_|
 v26.2.1 for Odroid N2 running Armbian Linux 6.18.10-current-meson64
 Packages:     Debian stable (trixie)
 IPv4:         (LAN) 192.168.1.63 (WAN) 82.137.57.14
 Performance:
 Load:         50%               Uptime:         1m
 Memory usage: 7% of 3.69G
 CPU temp:     40°C              Usage of /:   7% of 29G
 storage /:    1% of 916G
 Tips:
 What’s new in Armbian v26.5? https://tinyurl.com/5cwr7wfh
 Commands:
 Configuration: armbian-config
 Monitoring   : htop
Last login: Fri Jul 31 12:55:32 2026 from 192.168.1.58
root@nas:~# apt list
Error: Problem parsing Provides line of librust-servo-arc-dev:arm64=0.3.0-1+b1
Error: Error occurred while processing librust-servo-arc-dev (NewVersion2)
Error: Problem with MergeList /var/lib/apt/lists/deb.debian.org_debian_dists_trixie_main_binary-arm64_Packages
Error: The package lists or status file could not be parsed or opened.
root@nas:~# apt update
Ign:1 file:/var/cache/openmediavault/archives ./ InRelease
Ign:2 file:/var/cache/openmediavault/archives ./ Release
Get:3 file:/var/cache/openmediavault/archives ./ Packages
Hit:3 file:/var/cache/openmediavault/archives ./ Packages
Hit:5 http://deb.debian.org/debian trixie InRelease
Hit:6 http://deb.debian.org/debian trixie-updates InRelease
Hit:7 http://security.debian.org trixie-security InRelease
Hit:8 http://deb.debian.org/debian trixie-backports InRelease
Hit:9 http://security.debian.org/debian-security trixie-security InRelease
Hit:10 http://httpredir.debian.org/debian trixie InRelease
Hit:11 https://openmediavault.github.io/packages synchrony InRelease
Hit:12 http://httpredir.debian.org/debian trixie-updates InRelease
Hit:13 http://httpredir.debian.org/debian trixie-backports InRelease
Hit:14 https://github.armbian.com/configng stable InRelease
Hit:4 https://packages.openmediavault.org/public synchrony InRelease
Hit:15 http://fi.mirror.armbian.de/apt trixie InRelease
Traceback (most recent call last):
  File "/usr/sbin/omv-mkaptidx", line 236, in <module>
    sys.exit(main())
  File "/usr/lib/python3/dist-packages/click/core.py", line 1161, in __call__
    return self.main(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/click/core.py", line 1082, in main
    rv = self.invoke(ctx)
  File "/usr/lib/python3/dist-packages/click/core.py", line 1443, in invoke
    return ctx.invoke(self.callback, **ctx.params)
  File "/usr/lib/python3/dist-packages/click/core.py", line 788, in invoke
    return __callback(*args, **kwargs)
  File "/usr/sbin/omv-mkaptidx", line 128, in main
    cache = apt.cache.Cache()
  File "/usr/lib/python3/dist-packages/apt/cache.py", line 158, in __init__
    self.open(progress)
  File "/usr/lib/python3/dist-packages/apt/cache.py", line 217, in open
    self._cache = apt_pkg.Cache(progress)
apt_pkg.Error: E:Problem parsing Provides line of librust-servo-arc-dev:arm64=0.3.0-1+b1, E:Error occurred while processing librust-servo-arc-dev (NewVersion2), E:Problem with MergeList /var/lib/apt/lists/deb.debian.org_debian_dists_trixie_main_binary-arm64_Packages, E:The package lists or status file could not be parsed or opened.
Reading package lists... Error!
root@nas:~#
I tried to remove all the sudo rm -vf /var/lib/apt/lists/partial/*, /var/lib/apt/lists/* folders, but nothing helped.
Can you please help me out? I hope @Nico the maintainer will see this! :)
Best regards,
Adam
