dlink 3g modem with nanopi due H2 allwiner ("no bulk endpoints")
dear all ,
thank you for the armbian os which is work more than great with me ,
I already bought DLINK  DWM-157 and follow the installation steps , and as i see all going fine with me , but when i connect the modem i receive this output ,
[   64.089219] usb 2-1: device descriptor read/64, error -71
[   64.579198] usb 2-1: device descriptor read/64, error -71
[   65.209195] usb 2-1: device descriptor read/64, error -71
[   66.659297] scsi 0:0:0:0: rejecting I/O to offline device
[   69.969188] scsi 0:0:0:0: rejecting I/O to offline device
[   72.924173] usbserial_generic 2-1:1.0: device has no bulk endpoints
[   72.949655] usbserial_generic 2-1:1.1: device has no bulk endpoints
[   74.052684] sd 0:0:0:0: [sda] Asking for cache data failed
[   74.058213] sd 0:0:0:0: [sda] Assuming drive cache: write through
[   89.047207] usbserial_generic 2-1:1.0: device has no bulk endpoints
[  158.137210] usbserial_generic 2-1:1.0: device has no bulk endpoints
[  195.367217] usbserial_generic 2-1:1.0: device has no bulk endpoints
this is link for the steps
http://ftp.dlink.ru/pub/usb/DWM-157/Description/D-Link DWM-157 Linux guide.pdf
please any advice will be appreciated, as also , i connect the modem to windows 10 , and work fine without any issue ...
wait for you all
regards
Please describe your setup as best as possible so we know what your operating environment is like.
  1. Name of your board with all details, version number, take a picture if you are not sure what you have
  2. Name of the image you installed or logs, when you can boot the board: armbianmonitor -u (paste URL to your forum post)
  3. If your board does not boot, provide a log from serial console (UART) or at least make and attach a picture, where it stops.
  4. Describe the problem the best you can and provide all necessary info that we can reproduce the problem.
  5. If anything is attached to the board, supply all details
  6. How do you power the board?
