ironclad Posted August 11 Posted August 11 Reference: https://armbian.com/boards/x96q Needed: a way to add a secure patch to the referred image (may be building through git). Thank you. 0 Quote
ironclad Posted August 11 Author Posted August 11 My TV Box (x96q) has a secure image (Android) installed. Because of this, I cannot install any Armbian image. My question: is it possible to compile an Armbian image with the inclusion of a secure-boot.patch ? 0 Quote
ironclad Posted August 12 Author Posted August 12 (edited) Hi, +CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y @@ -0,0 +1,32 @@ was added to /build/userpatches/u-boot/v2026.07-sunxi64/0001-add-x96q-lpddr3-dt-and-defconfig.patch secure-boot.patch (created as per examples in this forum) was added to /build/userpatches/u-boot/v2026.07-sunxi64 ./compile.sh build BOARD=x96q BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=yes KERNEL_CONFIGURE=no RELEASE=trixie note:: compilation defaults to v2026.07-sunxi64 Armbian-unofficial_26.08.0-trunk_X96q_trixie_current_6.18.44_minimal.img generated without errors output from less -RS output/logs/log-build-d35da0cb-8215-486c-b8d4-515a190d281e.log.ans Generated image (booted by SD card) still not capable of bypassing the TV Box secure lock. Any suggestions? Edited August 12 by ironclad clarification 0 Quote
Nick A Posted August 13 Posted August 13 You need to add a TTL-to-USB device to your UART. Can you find the GND, TX, and RX pads on your board? 0 Quote
ironclad Posted August 13 Author Posted August 13 Yes, I can. I will connect the TTL-to-USB device and record the TV Box boot sequence. Note: just for the sake of the challenge, I tested the Armbian Framework 20241125 (NickAlilovic released this Nov 25, 2024) and it compiles OK (bookworm, X96Q plus secure-boot.patch and "+CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y" ) The TV Box boots OK,. ethernet adapter is recognized and, apparently, everything is fine. Caveat: no Armbian-config and ethernet adapter is lost if command apt upgrade is issued. 0 Quote
Nick A Posted August 14 Posted August 14 Don’t upgrade it’s a custom kernel.. you will need to freeze kernel updates in the config. 0 Quote
ironclad Posted August 14 Author Posted August 14 Conditions: Armbian Framework=current TV Box: X96Q Compile: full run (no options)/Trixie/ v2026.07-sunxi64 plus conditions described early Selection: manually through app (X96Q/Trixie/Server image minimal) Without SD card [01.199]CPU: Allwinner Family [01.202]Model: sun50iw9 I2C: ready [01.207]Relocation Offset is: 75ebe000 [01.252]secure enable bit: 1 [01.255]pmu_axp152_probe pmic_bus_read fail [01.259]PMU: AXP1530 [01.264]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz [01.272]drv_disp_init [01.302]__clk_enable: clk is null. [01.308]drv_disp_init finish [01.310]gic: sec monitor mode [01.339]flash init start [01.341]workmode = 0,storage type = 2 [01.344]MMC: 2 [01.346][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00 [01.352][mmc]: get sdc_type fail and use default host:tm4. [01.363][mmc]: SUNXI SDMMC Controller Version:0x40502 [01.480][mmc]: Best spd md: 3-HS200/SDR104, freq: 4-150000000, Bus width: 8 [01.486]sunxi flash init ok [fd650] show_string: 8888 8 [01.496]Loading Environment from SUNXI_FLASH... OK [01.506]Item0 (Map) magic is bad [01.509]the secure storage item0 copy0 magic is bad [01.513]Item0 (Map) magic is bad [01.516]the secure storage item0 copy1 magic is bad [01.521]Item0 (Map) magic is bad secure storage read hdcpkey fail [01.527]secure storage read hdcpkey fail with:-1 secure storage read widevine fail [01.534]secure storage read widevine fail with:-1 [01.539]probe MP tools from boot delay time 0 weak:otg_phy_config [01.553]usb init ok [02.056]usb overtime [02.061]usb burn from boot delay time 0 weak:otg_phy_config [02.075]usb prepare ok [02.878]overtime [02.882]do_burn_from_boot usb : no usb exist [02.886]boot_gui_init:start ** Unable to read file disp_rsl.fex ** tcon_de_attach:de=0,tcon=2[03.171]boot_gui_init:finish [03.174]bmp_name=bootlogo.bmp 2764854 bytes read in 22 ms (119.9 MiB/s) [03.219][mmc]: delete mmc-hs400-1_8v from dtb [03.227]update dts ** Unrecognized filesystem type ** [03.239]load file(ULI/factory/rootwait init.txt) error. ** Unrecognized filesystem type ** [03.254]load file(ULI/factory/snum.txt) error. ** Unrecognized filesystem type ** [03.269]load file(ULI/factory/mac.txt) error. ** Unrecognized filesystem type ** [03.284]load file(ULI/factory/wifi_mac.txt) error. ** Unrecognized filesystem type ** [03.299]load file(ULI/factory/bt_mac.txt) error. ** Unrecognized filesystem type ** [03.314]load file(ULI/factory/selinux.txt) error. ** Unrecognized filesystem type ** [03.329]load file(ULI/factory/specialstr.txt) error. [03.342]update part info [03.440]update bootcmd [03.442]No ethernet found. Hit any key to stop autoboot: 0 [03.694]not supported key [03.697]actual n size:1000, e:10001 [03.700]exptect n size:800, e:10001 show hash of file f0 2c 0a e4 44 f7 cc 7f 39 ca ff 4b 50 55 36 a0 c8 d1 41 56 ad 8c 60 26 ef d4 d9 19 bc a7 ef 7a image vbmeta hash valid CACHE: Misaligned operation at range [44ffffe0, 462a6800] [03.873]Starting kernel ... [03.876][mmc]: mmc exit start [04.007][mmc]: mmc 2 exit ok [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.9.170 (chenzanchao@ubuntu11) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #280 SMP PREEMPT Tue Jun 17 17:24:17 CST 2025 [ 0.000000] Boot CPU: AArch64 Processor [410fd034] [ 0.000000] bootconsole [earlycon0] enabled console:/ $ Gatekeeper_TA_CreateEntryPoint With SD card (one line only) U-Boot SPL 2026.07_armbian-2026.07-Sece3-P0207-H8076-V4771-B5da4-R448a (Aug 14 2026 - 09:04:47 -0300) DRAM: 0 Quote
ironclad Posted August 19 Author Posted August 19 Any ideas? Note: is there a repository of previous Armbian Frameworks? May be I can try with an older version. Herzlichen Dank. 0 Quote
