Hi all,
I just downloaded the Armbian(5.36 xenial-next)-based image for BPI M2 Zero, that comes with kernel 4.14.3-sunxi.
I'm looking for kernel headers for this kernel, but I can't find it in armbian's repo.
Could you help me to retrive them?
Thank you!
Switch to the beta repository, update and install them. H3 is testing in any case.
Thank you for you help!
I updated to nightly and downlaod the headers from the beta repo (http://beta.armbian.com/pool/main/l/linux-4.14.13-sunxi/), but if I run "make headers_check" I get
make[1]: *** No rule to make target 'arch/arm/tools/syscall.tbl', needed by 'arch/arm/include/generated/uapi/asm/unistd-common.h'. Stop.
PS: I noticed that the SoC temperature, even in idle, is insanely high (70°C) and it causes throttling when loaded. From what I read this is cuased by a bad voltage regulation in mfr's implementation. Is there any quick fix to mitigate this?
