JSF Posted January 15, 2018 Posted January 15, 2018 I have successfully gotten Armbian to boot from a USB flash drive on the Rock64 board. Followed ayufan's instructions on how to update SPI Flash with his boot code and then wrote the Armbian Rock64 image to a USB flash drive. All worked as expected. Thanks to everyone at Armbian for all the great work! 1
Xalius Posted January 15, 2018 Posted January 15, 2018 Hi jsfrederick, glad to hear it works for you, I think ayufan did some good progress in that area...
JSF Posted January 16, 2018 Author Posted January 16, 2018 On 1/15/2018 at 10:41 AM, Xalius said: Hi jsfrederick, glad to hear it works for you, I think ayufan did some good progress in that area... Expand That he did! Hat's off to him.
Ma Tianfu Posted January 25, 2018 Posted January 25, 2018 Do you mean that the kernel and rootfs are located on USB drive and uboot (in spi flash) can load the kernel directly? Two questions: 1. is the kernel located in a separate GPT partition? or is it placed on a ext4 file system, such as /boot directory as most desktop or server distros do? 2. is usb hub supported? or the usb drive must be connected to the usb port directly? And where is the guide from ayunfan as mentioned above?
TonyMac32 Posted January 25, 2018 Posted January 25, 2018 I have seen this done with the Tinker board by adding a SPI flash to the GPIO header: https://tinkerboarding.co.uk/forum/archive/index.php/thread-415.html I would assume it is quite similar
Xalius Posted January 25, 2018 Posted January 25, 2018 On 1/25/2018 at 4:32 AM, Ma Tianfu said: Do you mean that the kernel and rootfs (including /boot with kernel image, dtbs) are located on USB drive and uboot (in spi flash) can load the kernel directly? Two questions: 1. is the kernel located in a separate GPT partition? or is it placed on a ext4 file system, such as /boot directory as most desktop or server distros do? 2. is usb hub supported? or the usb drive must be connected to the usb port directly? And where is the guide from ayunfan as mentioned above? Expand Yes firmware+u-boot are on the SPI flash, only the rootfs is on USB or network... check https://github.com/ayufan-rock64/linux-build/releases https://github.com/ayufan-rock64/linux-build/releases/download/0.6.16/u-boot-flash-spi.img.xz is a sdcard image that writes the bits to SPI https://github.com/aw/linux-build/blob/2fec6745b584c2bbc5fbe15d4cbaacd62c096b24/recipes/flash-spi.md for the how-to
Ma Tianfu Posted January 25, 2018 Posted January 25, 2018 On 1/25/2018 at 1:35 PM, Xalius said: Yes firmware+u-boot are on the SPI flash, only the rootfs is on USB or network... check https://github.com/ayufan-rock64/linux-build/releases https://github.com/ayufan-rock64/linux-build/releases/download/0.6.16/u-boot-flash-spi.img.xz is a sdcard image that writes the bits to SPI https://github.com/aw/linux-build/blob/2fec6745b584c2bbc5fbe15d4cbaacd62c096b24/recipes/flash-spi.md for the how-to Expand Thank you. I will try it this weekend.
