JSF Posted January 15, 2018 Share Posted January 15, 2018 I have successfully gotten Armbian to boot from a USB flash drive on the Rock64 board. Followed ayufan's instructions on how to update SPI Flash with his boot code and then wrote the Armbian Rock64 image to a USB flash drive. All worked as expected. Thanks to everyone at Armbian for all the great work! 1 Link to comment Share on other sites More sharing options...
Xalius Posted January 15, 2018 Share Posted January 15, 2018 Hi jsfrederick, glad to hear it works for you, I think ayufan did some good progress in that area... Link to comment Share on other sites More sharing options...
JSF Posted January 16, 2018 Author Share Posted January 16, 2018 15 hours ago, Xalius said: Hi jsfrederick, glad to hear it works for you, I think ayufan did some good progress in that area... That he did! Hat's off to him. Link to comment Share on other sites More sharing options...
Ma Tianfu Posted January 25, 2018 Share Posted January 25, 2018 Do you mean that the kernel and rootfs are located on USB drive and uboot (in spi flash) can load the kernel directly? Two questions: 1. is the kernel located in a separate GPT partition? or is it placed on a ext4 file system, such as /boot directory as most desktop or server distros do? 2. is usb hub supported? or the usb drive must be connected to the usb port directly? And where is the guide from ayunfan as mentioned above? Link to comment Share on other sites More sharing options...
TonyMac32 Posted January 25, 2018 Share Posted January 25, 2018 I have seen this done with the Tinker board by adding a SPI flash to the GPIO header: https://tinkerboarding.co.uk/forum/archive/index.php/thread-415.html I would assume it is quite similar Link to comment Share on other sites More sharing options...
Xalius Posted January 25, 2018 Share Posted January 25, 2018 9 hours ago, Ma Tianfu said: Do you mean that the kernel and rootfs (including /boot with kernel image, dtbs) are located on USB drive and uboot (in spi flash) can load the kernel directly? Two questions: 1. is the kernel located in a separate GPT partition? or is it placed on a ext4 file system, such as /boot directory as most desktop or server distros do? 2. is usb hub supported? or the usb drive must be connected to the usb port directly? And where is the guide from ayunfan as mentioned above? Yes firmware+u-boot are on the SPI flash, only the rootfs is on USB or network... check https://github.com/ayufan-rock64/linux-build/releases https://github.com/ayufan-rock64/linux-build/releases/download/0.6.16/u-boot-flash-spi.img.xz is a sdcard image that writes the bits to SPI https://github.com/aw/linux-build/blob/2fec6745b584c2bbc5fbe15d4cbaacd62c096b24/recipes/flash-spi.md for the how-to Link to comment Share on other sites More sharing options...
Ma Tianfu Posted January 25, 2018 Share Posted January 25, 2018 2 hours ago, Xalius said: Yes firmware+u-boot are on the SPI flash, only the rootfs is on USB or network... check https://github.com/ayufan-rock64/linux-build/releases https://github.com/ayufan-rock64/linux-build/releases/download/0.6.16/u-boot-flash-spi.img.xz is a sdcard image that writes the bits to SPI https://github.com/aw/linux-build/blob/2fec6745b584c2bbc5fbe15d4cbaacd62c096b24/recipes/flash-spi.md for the how-to Thank you. I will try it this weekend. Link to comment Share on other sites More sharing options...
