I would like to put ip cameras into the grid as you can see here: omx cctv
Does the armbian support omx player?
Or is there another solution for grid view ?
Hardware: Orange pi One
If you want hardware accelerated decoding you need to use mpv or mplayer. I'm not sure if you can run multiple instances and all use VDPAU
edit: mpv segfaults if you open 2 instances
Main problem now is related to Motion... mjpeg is not multithreaded, only one core (per camera) work into flow mjpeg->RAW->motion analisys->display output. H264/X264 is multithreaded (but still a low quality approach). Final output (movie) can be accelerated by (a future) version of FFmpeg. A good hw for a cctv project is an A17/A57/A72 ARM (out of order, fast single core performance compared to a A7/A53) or a low power Intel N3350 (Gigabyte Brix with Debian 9).
