edupv Posted January 19, 2018 Share Posted January 19, 2018 I have tried to set up a Banana Pi M1+ as a wireless router (installed Armbian_5.35_Bananapi_Ubuntu_xenial_next_4.13.16 ). Existing set up and testing environment are as following: Now, my android phone can access the internet and the Banana Pi works as expected. However, when I checked the file /var/log/syslog of the x86 router, I found : Jan 20 00:12:51 router86 kernel: [25688.378214] IPv4: martian source 104.17.115.27 from 10.111.103.154, on dev br0 Jan 20 00:12:51 router86 kernel: [25688.378253] ll header: 00000000: 00 e0 4c 68 12 86 02 d4 09 42 7c 37 08 00 ..Lh.....B|7.. Jan 20 00:12:51 router86 kernel: [25688.378422] IPv4: martian source 104.17.115.27 from 10.111.103.154, on dev br0 Jan 20 00:12:51 router86 kernel: [25688.378433] ll header: 00000000: 00 e0 4c 68 12 86 02 d4 09 42 7c 37 08 00 ..Lh.....B|7.. Jan 20 00:12:51 router86 kernel: [25688.379413] IPv4: martian source 104.17.115.27 from 10.111.103.154, on dev br0 Jan 20 00:12:51 router86 kernel: [25688.379426] ll header: 00000000: 00 e0 4c 68 12 86 02 d4 09 42 7c 37 08 00 ..Lh.....B|7.. Jan 20 00:12:51 router86 kernel: [25688.379573] IPv4: martian source 104.17.115.27 from 10.111.103.154, on dev br0 Jan 20 00:12:51 router86 kernel: [25688.379582] ll header: 00000000: 00 e0 4c 68 12 86 02 d4 09 42 7c 37 08 00 ..Lh.....B|7.. Jan 20 00:12:51 router86 kernel: [25688.380656] IPv4: martian source 104.17.115.27 from 10.111.103.154, on dev br0 Jan 20 00:12:51 router86 kernel: [25688.380668] ll header: 00000000: 00 e0 4c 68 12 86 02 d4 09 42 7c 37 08 00 ..Lh.....B|7.. Jan 20 00:12:51 router86 kernel: [25688.380817] IPv4: martian source 104.17.115.27 from 10.111.103.154, on dev br0 Jan 20 00:12:51 router86 kernel: [25688.380827] ll header: 00000000: 00 e0 4c 68 12 86 02 d4 09 42 7c 37 08 00 ..Lh.....B|7.. Jan 20 00:12:51 router86 kernel: [25688.382479] IPv4: martian source 104.17.115.27 from 10.111.103.154, on dev br0 Jan 20 00:12:51 router86 kernel: [25688.382489] ll header: 00000000: 00 e0 4c 68 12 86 02 d4 09 42 7c 37 08 00 ..Lh.....B|7.. Jan 20 00:12:51 router86 kernel: [25688.382693] IPv4: martian source 104.17.115.27 from 10.111.103.154, on dev br0 Jan 20 00:12:51 router86 kernel: [25688.382703] ll header: 00000000: 00 e0 4c 68 12 86 02 d4 09 42 7c 37 08 00 ..Lh.....B|7.. Jan 20 00:12:51 router86 kernel: [25688.382911] IPv4: martian source 104.17.115.27 from 10.111.103.154, on dev br0 Jan 20 00:12:51 router86 kernel: [25688.382920] ll header: 00000000: 00 e0 4c 68 12 86 02 d4 09 42 7c 37 08 00 ..Lh.....B|7.. Jan 20 00:12:51 router86 kernel: [25688.415770] IPv4: martian source 104.17.115.27 from 10.111.103.154, on dev br0 Jan 20 00:12:51 router86 kernel: [25688.415809] ll header: 00000000: 00 e0 4c 68 12 86 02 d4 09 42 7c 37 08 00 ..Lh.....B|7.. The internal IP of my phone (10.111.103.154) behind the Banana Pi leaked to the external x86 router ! How can I fix this ? Thanks. Link to comment Share on other sites More sharing options...
kukulo Posted January 20, 2018 Share Posted January 20, 2018 You have bridged two interfaces eth0 and wlan. By default armbian works as client/server where all interfaces are bridged. You need to setup eth0 and wlan on different subnets without bridging them together. Link to comment Share on other sites More sharing options...
edupv Posted January 21, 2018 Author Share Posted January 21, 2018 11 hours ago, kukulo said: You have bridged two interfaces eth0 and wlan. By default armbian works as client/server where all interfaces are bridged. You need to setup eth0 and wlan on different subnets without bridging them together. Thanks for your reply, but I have not bridged eth0 and wlan0 : root@bananapi:~# brctl show bridge name bridge id STP enabled interfaces br0 8000.983b16c7cd8d no wlan0 root@bananapi:~# I set up br0 because I have ordered an USB NIC (eth1) and I am going to add it to br0 later. Link to comment Share on other sites More sharing options...
