Dmitriy Zhuk Posted January 22, 2018 Posted January 22, 2018 Hello guys. I try to build image for pine64. My OS is Ubuntu 16.04. My options: - Full OS image for flashing - Do not change the kernel configuration - pine64 - default - jessie -image with console interface. Then I see the following: 0 upgraded, 299 newly installed, 0 to remove and 0 not upgraded. Need to get 118 MB of archives. After this operation, 461 MB of additional disk space will be used. WARNING: The following packages cannot be authenticated! hostapd E: There are problems and -y was used without --force-yes [ error ] ERROR in function create_rootfs_cache [ debootstrap-ng.sh:208 ] [ error ] Installation of Armbian packages failed [ o.k. ] Process terminated [ error ] ERROR in function unmount_on_exit [ image-helpers.sh:59 ] [ error ] debootstrap-ng was interrupted [ o.k. ] Process terminated How can I resolve this problem?
Igor Posted January 23, 2018 Posted January 23, 2018 17 hours ago, Dmitriy Zhuk said: Hello guys. I try to build image for pine64. My OS is Ubuntu 16.04. My options: - Full OS image for flashing - Do not change the kernel configuration - pine64 - default - jessie -image with console interface. Then I see the following: 0 upgraded, 299 newly installed, 0 to remove and 0 not upgraded. Need to get 118 MB of archives. After this operation, 461 MB of additional disk space will be used. WARNING: The following packages cannot be authenticated! hostapd E: There are problems and -y was used without --force-yes [ error ] ERROR in function create_rootfs_cache [ debootstrap-ng.sh:208 ] [ error ] Installation of Armbian packages failed [ o.k. ] Process terminated [ error ] ERROR in function unmount_on_exit [ image-helpers.sh:59 ] [ error ] debootstrap-ng was interrupted [ o.k. ] Process terminated How can I resolve this problem? Fixed. It was a problem within our repository.
