MildaGenius Posted January 26, 2018 Share Posted January 26, 2018 Pink screen on monitor Acer AL1716. Armbian 5.35 legacy OrangePi PC HDMI with DSUB convertor new installation In previous version 5.24 works monitor fine. If I connect OPI to second monitor LG1752S and restart OPI, screen is OK. After reconnect back to AL1716, screen is still ok. But after restart with AL1716 is screen again pink. Tested some different resolutions with h3disp, but still get pink screen. Looks like problem with monitor detection at start. Is possible to disable detection after start with working monitor and set as default? Any other solution? Edit: I found simple workaround. Start OrangePi PC WITHOUT connected to monitor. After booting sequence is done, connect monitor back and screen is back. Link to comment Share on other sites More sharing options...
Igor Posted January 26, 2018 Share Posted January 26, 2018 50 minutes ago, MildaGenius said: Is possible to disable detection after start with working monitor and set as default? Check this section: https://docs.armbian.com/Hardware_Allwinner/#how-to-reconfigure-video-output Link to comment Share on other sites More sharing options...
