Skip to content
View in the app
Armbian Community Forums
armbian-config + docker - upgrade container image.
Featured Replies
Hello everyone.
I am sorry if this is a silly question but I can't find a good answer.
I am running `Armbian 26.8.3 trixie` in a radxa e52.
I deployed AdGuard using `armbian-config`, as in `sudo armbian-config --cmd ADG001`, back in 2026/07
I was hoping to find a docker compose file at /armbian/adguardhome but there is none.
It looks like armbian-config does a docker run to start the container, without docker compose.
How I am expected to update the image and the container? Usually I just docker compose pull and then docker compose up -d,
but without it, I should docker stop <container id>, docker rm <container id>, and docker run it again, with the same options.
I have already docker pull adguard/adguardhome:latest which downloaded a new version, but I can't find a good way to update the container with the new image.
¿Is that expected?
¿Is there a place to get the same docker options used when starting the container?
¿Am I missing something?
Thank you in advance.
Edited by Dolape
Solved by Dolape
  • Author
  • Solution
Found a solution to automatically create a docker-compose.yml file and bring it under compose control.
I created it using this tool: https://github.com/Red5d/docker-autocompose
Ran: $ docker run --rm -v /var/run/docker.sock:/var/run/docker.sock ghcr.io/red5d/docker-autocompose <container_id> > /armbian/adguardhome/docker-compose.yml
Modified the image stanza to pull latest: image: "adguard/adguardhome:latest"
Then docker stop and docker rm the old container, and start the new version with docker compose up -d
It is now running fine:
user@host:/armbian/adguardhome$ docker compose ps
NAME IMAGE COMMAND SERVICE CREATED STATUS PORTS
adguardhome adguard/adguardhome:latest "/opt/adguardhome/Ad…" adguardhome 6 minutes ago Up 6 minutes
Thanks!
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
