Hi to you all. I've had a functional boot from USB flash drive on my OrangePi Zero and when I've updated kernel yesterday from main repository and reboot_ed boot stoped working. I've tried on another fully functional OrangePi Zero with same rom on it and still not working. I've tried to put new "virgin" image to USB flash drive and still nothing. Tried to erase spi and write it againe and still nothing.  Any idea what could happened. I'll try today to get serial console to see what is going on during the boot proces.
Which kernel? NEXT 4.y is still experimental/testing.
Edit: I just checked DT bits for Zero - SPI is disabled.
/* Disable SPI NOR by default: it optional on Orange Pi Zero boards */
Linux orangepizero 3.4.113-sun8i #4 SMP PREEMPT Wed Nov 22 13:45:28 CET 2017 armv7l armv7l armv7l GNU/Linux
When I leave sd card in Orange Pi Zero boot from USB Flash. What can cause this?
/usr/lib/linux-u-boot-orangepizero_5.35_armhf/u-boot-sunxi-with-spl.bin
I've followed instructions from here:
This is output of spi-flash writing
root@orangepizero:~# flashrom -p linux_spi:dev=/dev/spidev0.0 -c MX25L1605 -w spi.img
flashrom v0.9.9-rc1-r1942 on Linux 3.4.113-sun8i (armv7l)
flashrom is free software, get the source code at https://flashrom.org
Calibrating delay loop... OK.
Found Macronix flash chip "MX25L1605" (2048 kB, SPI) on linux_spi.
Reading old flash chip contents... done.
Erasing and writing flash chip... Erase/write done.
Verifying flash... VERIFIED.
Everything worked fine since last upgrade where I've upgraded initramfs-tools...
