Yesterday at 03:49 AM1 day Hi everyone,I have physical access to an Orange Pi 5 Ultra with 16 GB RAM and would like to help with testing and maintenance of this board. Here is my first round of hardware testing on the current/mainline image. I am posting the working features, reproducible problems and remaining gaps separately. This is an initial test report, not a release sign-off.Image and test environmentBoard: Orange Pi 5 Ultra, RK3588, 16 GB RAM.Image: Armbian community 26.11.0-trunk.120, Ubuntu 26.04 Resolute, GNOME/Wayland, booted from microSD.Kernel: 6.18.60-current-rockchip64. Image build commit: c24ea08f8759a37aaa83a101774582c37c18eda6.Kernel, DTB and BSP packages: 26.11.0-trunk.120. Mesa: 26.0.8-1ubuntu0.3.Storage: 64 GB SDXC card using SDR104 at approximately 148.5 MHz; Samsung SSD 980 500 GB on PCIe 3.0 x4; Toshiba MQ04UBF100 1 TB USB hard disk detected at SuperSpeed 5000M.Ethernet: RTL8125B using r8169, linked to a 1 GbE LAN peer. Cooling fan present. PSU model/specification has not yet been recorded.Tests were run on 5–6 November 2026, UTC+8, using remote shell/Python automation and local hands-on cable/desktop checks.A baseline package list and boot log were saved before testing. The desktop updater subsequently updated userspace packages, including libc6 from 2.43-2ubuntu2.3 to 2.43-2ubuntu2.4. The recorded kernel/DTB packages and Mesa version remained as listed above. This should therefore not be treated as a completely untouched-image test for every later result. Additional test utilities were unpacked into a separate test directory.I do not yet have an armbianmonitor -u upload URL from this session. Redacted baseline boot, hardware and package information is included with the test evidence; a formal support report is still incomplete.Completed checksBoot and desktop: SD boot, GNOME/Wayland desktop, HDMI output, USB keyboard and mouse were usable. This covers this desktop image only, not a separate minimal/CLI image.GPU: accelerated OpenGL renderer reported Mali-G610 MC4 (Panfrost). glmark2 output validation passed. Vulkan enumeration with the Panfrost ICD and a 240-frame Wayland vkcube run completed successfully. Three short glmark2 scenes also completed; this was not the full default performance benchmark.RAM: memtester completed one full pass over 2 GiB with exit status 0 in 836.51 seconds. The highest sampled temperature during that test was 53.6°C. This is not exhaustive coverage of all 16 GB.CPU policy: three cpufreq policies were present, with observed peaks of 1.8 / 2.4 / 2.4 GHz during the memory test. The desktop tuning profile and ext4 commit=15 setting were present. A full CPU/VM soak result is still missing, as noted below.RTC: HYM8563 time reads worked. A future, minute-aligned alarm triggered the RTC hardware interrupt at the requested RTC timestamp; its IRQ counter increased from 0 to 1. This was an awake-system alarm test, not a suspend wake-up or battery-backed power-off retention test.Ethernet: TCP receive to the board was approximately 940 Mb/s and transmit from the board approximately 764 Mb/s. A bidirectional run also completed. IPv4, IPv6 and 1500-byte-MTU ping checks passed. The peer was limited to 1 GbE, so 2.5 GbE throughput was not validated.Storage checksfio 3.41 was used for bounded tests. SD and USB file tests used 1 MiB blocks, direct I/O, libaio queue depth 16 and CRC32C write/read verification. The NVMe test used direct, read-only access with a 4 GiB working set for 15 seconds. Rates below are decimal MB/s.Device / scopeWriteReadResultSD, 2 GiB file24.75 MB/s65.81 MB/sCRC32C verification passedUSB hard disk, 1 GiB file, first USB 3 port59.08 MB/s138.65 MB/sCRC32C verification passedNVMe, read-onlyNot tested1403.87 MB/sRead test passed; health queries completedThe SD and USB 4 KiB random-read tests also completed. No new storage-related kernel errors were found during this test interval. These tests do not cover the entire capacity of the media. NVMe write verification and the second USB 3 port remain untested.Open finding 1: onboard Wi-Fi interface is missingAt baseline, Ethernet and Bluetooth were present but no WLAN interface or wireless PHY appeared. The installed bcmdhd-sdio-dkms package was built for the running kernel, while the SDIO bus had no enumerated device. The live device tree contained:mmc@fe2d0000 { status = "disabled"; };Observed package/driver state:bcmdhd-sdio-dkms: 101.10.591.52.27-10 bcmdhd-sdio/101.10.591.52.27-10, 6.18.60-current-rockchip64, aarch64: installed iw dev / iw phy: no wireless interface or PHY listed /sys/bus/sdio/devices/: emptyThe vendor board DTS contains SDIO enablement and a Wi-Fi power sequence. Missing board-level SDIO/power-sequence description is a suspect; no proposed fix or overlay has been runtime-tested in this session.Open finding 2: HDMI input self-loop did not lockWith no independent HDMI source available, I connected this board's HDMI OUT to its HDMI IN. A fullscreen colour-bar pattern was generated, and the receiver was given the v4l2-ctl HDMI EDID preset. DRM state confirmed a 1920×1080 at 60 Hz RGB 8 bpc transmitter mode, with a 148.5 MHz TMDS clock.The receiver reported power_present=1, but v4l2-ctl --query-dv-timings failed with “No locks available”. The kernel logged:hdmirx_phy_register_write wait cr write done failed hdmirx_controller_init wait timer base lock failed hdmirx_query_dv_timings: signal is not lockedThe HDMI RX HDMI/DMA IRQ counters stayed at zero while the 5V-detect GPIO IRQ counter increased. Unloading/reloading synopsys_hdmirx and reapplying the test EDID reproduced the same result. The original receiver EDID and monitor connection were restored afterward.This is a reproducible self-loop observation on this setup, not proof that every external HDMI source will fail. Testing with an independent source and checking a clean cold boot remain necessary. Relevant earlier changes include #10172 and the 6.18 patch adjustment #10180.Incomplete and intentionally omitted checksA 15-minute all-CPU plus 4 GiB VM verification run was started, but no final completion record has been collected. The last collected progress line was around 58 seconds. I am not counting this soak as passed.Later, new SSH connections were closed before authentication while the board still answered LAN pings. The cause has not been established, and I am not attributing it to the load test or kernel without further evidence.Bluetooth firmware loading, discovery and three rfkill recovery cycles were observed; pairing and data transfer were not validated. Further Bluetooth testing was intentionally skipped.Actual audio playback/capture, the second USB 3 port, repeated warm/cold boot recovery, RTC power-off retention, other images/kernel branches and additional header/camera interfaces remain outside this completed test set.Maintenance interestI would like to contribute release-image testing and reproducible board reports for the Orange Pi 5 Ultra. In particular, #10673 explicitly noted missing Ultra/Linux 6.18 runtime coverage, and #11157 reported no board hardware testing for the CPU policy changes. The observations above provide some additional runtime evidence, with the limitations stated.I have saved the scripts, package inventories and logs, and can provide specific redacted excerpts. Guidance on the highest-priority follow-up tests and the board-maintainer application process would be appreciated.KingFalse orangepi5-ultra-6.18-first-round-evidence.zip
