November 7Nov 7 Just got an ODroid M1S (8GB), tried current community build, and found it wasn't working (Armbian_community_26.11.0-trunk.120_Odroidm1s_resolute_current_6.18.60_minimal.img.xz).So, a thread while I'm debugging if anyone's interested. Lets see how far I get. boot_fail.txt
November 7Nov 7 Author Found this thread by @Mortimer2003 , who probably deserves some kudos for identifying some fairly major issues, but were never submitted for PR.Looks like things have been broken for a bit in the build. So, let's take a swing at it: https://github.com/tparys/build/tree/odroid_m1sFirst up is the load address. The rk35xx family boot script loads data at 0x9000000, but doesn't seem to be valid for M1S?Adding a custom boot script that loads 0xc000000 gets us booting and to first boot login.But Ethernet isn't working (as identified). rk_gmac-dwmac fe010000.ethernet eth0: cannot attach to PHY (error: -ENODEV)
November 7Nov 7 4 hours ago, tparys said:Adding a custom boot scriptFYI. Might come handy here.@djurny made generalization / templating of boot scripts. If only loading address is different, it would be cleaner then cp whole script. In case you find time to look into. Not a blocker.
November 7Nov 7 Author generalization / templating of boot scriptsAny pointers on which boards use this? I'm sure I'll find it, but might save me reading though a few dozen family configs.In the meantime, I've integrated the above Ethernet tweak as a rockchip64 patch. I'm assuming something moved in the kernel and the M1S's .dts didn't get updated. /_\ _ _ _ __ | |__(_)__ _ _ _ ___ _ _ _ _ ___ / _|/ _(_)__(_)__ _| | / _ \| '_| ' \| '_ \ / _` | ' \___| || | ' \/ _ \ _| _| / _| / _` | | /_/ \_\_| |_|_|_|_.__/_\__,_|_||_| \_,_|_||_\___/_| |_| |_\__|_\__,_|_| v26.11 rolling for ODROID M1S running Armbian Linux 6.18.62-current-rockchip64 Packages: Ubuntu stable (noble) Updates: Kernel upgrade enabled and 7 packages available for upgrade Support: DIY (custom image) IPv4: (LAN) 10.42.0.119 (WAN) ---.---.---.---
November 7Nov 7 Author Alright, found a boot.cmd tweak in the config for dshanpi-r1, and followed that. Looks like it's working as expected, so no need for duplicate bootscript.Other basic functions appear to be working.SD CardUSBHDMINVMEInitial PR submitted to get CSC images working. Now to poke at GPIO headers.
November 13Nov 13 Author Quick update for the interested. Looks like the Armbian build for the M1S actually works as expected, but not with the boards as shipped from Hardkernel. The OEM installs an old copy of u-boot which changes the memory map, and leaves the Ethernet card in reset.Explicitly zeroing the first 1 MB of the eMMC seems to address the issue. Shorting the MASKROM pins should also work as well. A little annoying, but it's fine if you know about it.PR closed, but we should have a note on the download page for silly geese like myself who don't know better.
