This is a FYI:
My armbian did not automount my USB-disk. Possbile reason "By default, disk drives do not auto-mount in Ubuntu Server Edition.".
Anyway: I solved it with usbmount:
First install usbmount.
Then, in /etc/usbmount/usbmount.conf change the line
#MOUNTOPTIONS="sync,noexec,nodev,noatime,nodiratime"
to
MOUNTOPTIONS="sync,noexec,nodev,noatime,nodiratime,user,umask=0000"
to make it writeable for all users.
HTH
9 hours ago, marine1988 said:
i can´t find usbmount in last version of armbian :(
$ apt search usbmount
Sorting... Done
Full Text Search... Done
usbmount/xenial,xenial,now 0.0.22 all [installed]
  automatically mount and unmount USB mass storage devices
and
sudo apt-get install usbmount
HTH
Sorting... Done
and
HTH
no luck here on orange pi prime with last beta armbian version
 pi@orangepiprime:~$ apt search usbmount
Sorting... Done
pi@orangepiprime:~$
There seems to be a bug, source: https://codeyarns.com/2019/05/18/usbmount-not-mounting-problem/
Solution:
systemd seems to be the culprit. It sets MountFlags=slave in its systemd-udevd.service file, which causes, the mount operation of usbmount mounting into the namespace of systemd and not to the user.
To change this mount option, run this command:
sudo systemctl edit systemd-udevd
Add these lines to the file:
[Service]
MountFlags=shared
This creates the file /etc/systemd/system/systemd-udevd.service.d/override.conf with the above lines.
Restart systemd on your NanoPi Neo2:
sudo systemctl daemon-reload
sudo service systemd-udevd --full-restart
Sorting... Done
pi@orangepiprime:~$
Yep. Confirm this with orange pi prime. No such package:
# cat /etc/armbian-release
# PLEASE DO NOT EDIT THIS FILE
BOARD=orangepiprime
BOARD_NAME="Orange Pi Prime"
BOARDFAMILY=sun50iw2
VERSION=5.60
LINUXFAMILY=sunxi64
BRANCH=next
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm64
KERNEL_IMAGE_TYPE=Image
BOARD=orangepiprime
VERSION=5.60
LINUXFAMILY=sunxi64
BRANCH=next
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm64
Update. Have no idea why it is not available in debian repos. But you may take and easily build it from this guy
https://github.com/nicokaiser/usbmount
or from my fork with small fix (made pull request for him also)
https://github.com/kgara/usbmount
mkdir -p /usr/src/
git clone https://github.com/kgara/usbmount/ --depth 1
cd ./ usbmount
# Install dependencies
sudo apt-get update && sudo apt-get install -y debhelper build-essential
# Build
sudo dpkg-buildpackage -us -uc -b
# Install it
dpkg -i ../usbmount_0.0.24_all.deb
# Probably first time also with
apt-get install lockfile-progs
apt --fix-broken install
# Clean
rm ../usbmount_*
Works perfect for me. Don't forget to edit config if you need permanent mount points from fstab:
    $ mcedit /etc/usbmount/usbmount.conf
    #MOUNTPOINTS="/media/usb0 /media/usb1 /media/usb2 /media/usb3
    #             /media/usb4 /media/usb5 /media/usb6 /media/usb7"
    MOUNTPOINTS=""
Guys,
Isn't it a ubuntu versus debian thing? Ubuntu has usbmount, debian hasn't.
My armbian is Ubuntu based:
"Welcome to Ubuntu Cosmic with Armbian Linux 5.1.16-cubox"
HTH
The basic difference between Armbian and Ubuntu, Debian and their releases can be decoded from here:
https://github.com/armbian/build/blob/master/lib/configuration.sh#L131-L251
Most of the packages are identical, but usually not the exact same version and dependencies could be different. Then there is a small section of strong differences where some packages are not present in one or another. Or named different. Since usbmount is not essential for us ... I wasn't even aware that it does not exists in Debian repositories while this happens from time to time. Don't know exactly why.
