berturion Posted January 24, 2016 Posted January 24, 2016 Hello, My problem is that curl tries to use ipv6 to resolve DNS entries and my home modem-router doesn't handle ipv6 so curl fails and fallbacks to ipv4. The process lasts 10 to 15 seconds because of this. For example (38s - 23s = 15s to resolve hostname): $ curl -v --trace-time https://api.owncloud.com 15:53:23.053958 * Rebuilt URL to: https://api.owncloud.com/ 15:53:23.055233 * Hostname was NOT found in DNS cache 15:53:38.583565 * Trying 85.25.74.45... 15:53:38.803420 * Connected to api.owncloud.com (85.25.74.45) port 443 (#0) And if I add '-4' option (only a few milliseconds): $ curl -4 -v --trace-time https://api.owncloud.com 15:54:43.543512 * Rebuilt URL to: https://api.owncloud.com/ 15:54:43.544649 * Hostname was NOT found in DNS cache 15:54:43.574628 * Trying 85.25.74.45... 15:54:43.792575 * Connected to api.owncloud.com (85.25.74.45) port 443 (#0) I try to make curl use ipv4 by default. I changed /etc/gai.conf and uncommented this line: precedence ::ffff:0:0/96 100 But it seems that it is ignored. So I tried to completely disable ipv6 protocol. I added to /etc/sysctl.conf these lines: net.ipv6.conf.all.disable_ipv6 = 1 net.ipv6.conf.default.disable_ipv6 = 1 net.ipv6.conf.lo.disable_ipv6 = 1 net.ipv6.conf.eth0.disable_ipv6 = 1 After reboot, same thing. Then I blacklisted ipv6 in a brand new /etc/modprobe.d/blacklist.conf file: blacklist ipv6 After reboot, same issue. I deleted all entries in /etc/hosts file relative to ipv6 address. After reboot, same issue. A method consists in disabling ipv6 with /etc/default/grub, but does Armbian uses grub ? update-grub command is not recognized. Though, it seems that ipv6 is really disabled: $ cat /proc/sys/net/ipv6/conf/all/disable_ipv6 1 $ man -k ipv6 | egrep gai | wc -l 0 $ cat /proc/net/if_inet6 (returns nothing) $ route -A inet Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface default sagembox.home 0.0.0.0 UG 0 0 0 eth0 192.168.24.0 * 255.255.255.0 U 0 0 0 eth0 $ route -A inet6 Kernel IPv6 routing table Destination Next Hop Flag Met Ref Use If ::/0 :: !n -1 1 63 lo ::/0 :: !n -1 1 63 lo I still have ipv6 connections: $ netstat -tupvnl | grep -e 'tcp6\|udp6' tcp6 0 0 :::41921 :::* LISTEN 1575/rpc.mountd tcp6 0 0 :::2049 :::* LISTEN - tcp6 0 0 :::37346 :::* LISTEN 1575/rpc.mountd tcp6 0 0 :::33253 :::* LISTEN - tcp6 0 0 :::58245 :::* LISTEN 1147/rpc.statd tcp6 0 0 :::139 :::* LISTEN 2567/smbd tcp6 0 0 :::111 :::* LISTEN 1119/rpcbind tcp6 0 0 :::44438 :::* LISTEN 1575/rpc.mountd tcp6 0 0 :::445 :::* LISTEN 2567/smbd udp6 0 0 :::52456 :::* 1575/rpc.mountd udp6 0 0 :::50925 :::* 1575/rpc.mountd udp6 0 0 :::31549 :::* 1062/dhclient udp6 0 0 :::870 :::* 1119/rpcbind udp6 0 0 :::2049 :::* - udp6 0 0 :::39428 :::* 1147/rpc.statd udp6 0 0 :::111 :::* 1119/rpcbind udp6 0 0 :::123 :::* 2108/ntpd udp6 0 0 :::42127 :::* 1575/rpc.mountd udp6 0 0 :::42153 :::* - I can't find a way to make curl using ipv4 DNS resolving only... Need help...
tkaiser Posted January 24, 2016 Posted January 24, 2016 Why not just using 'alias curl=/usr/bin/curl -4' then?
berturion Posted January 24, 2016 Author Posted January 24, 2016 Why not, I didn't know that. In which file should I write this ? Is it system wide ? Does php5-curl calls use this ?
zador.blood.stained Posted January 24, 2016 Posted January 24, 2016 @berturion If I understood your problem correctly, you already don't have IPv6 address on your network interface, but various application still request both A and AAAA DNS records, and DNS forwarder on your modem/router doesn't handle AAAA requests well. Assuming your router/modem doesn't run OpenWRT now, I would suggest using DNS proxy on your device, i.e. dnsmasq. Configuring it can be a little bit tricky, but in the end is should work. @tkaiser's solution will work, but only for curl.
tkaiser Posted January 24, 2016 Posted January 24, 2016 To be set system wide you could write this to /etc/profile (have a look in there what other files will be read out and where stuff could be defined)
berturion Posted January 24, 2016 Author Posted January 24, 2016 Thanks for your help. I added 'alias curl=/usr/bin/curl -4' in /etc/profile, logged out and logged in, but it seems that it is ignored. I also tried with 'alias curl="/usr/bin/curl -4"', also ignored. Since, my use case is a php-curl call, I am not sure that it can be achieve like that. Dnsmasq was the solution I wanted to avoid because of so much work. But if this is my only option...
zador.blood.stained Posted January 24, 2016 Posted January 24, 2016 Sorry, just checked. dnsmasq is a perfect solution for disabling per-host and per-domain AAAA queries, but there is no option to make it happen for all domains, at least without recompiling it. Since, my use case is a php-curl call, I am not sure that it can be achieve like that. If php is running as a service, then logging out and back in won't update its environment. However, quick googling shows that php-curl has some configurable options: https://secure.php.net/manual/en/function.curl-setopt.php Search there for "CURL_IPRESOLVE_V4"
berturion Posted January 25, 2016 Author Posted January 25, 2016 Ok. I re-enabled ipv6 on my machine and simply added these lines to /etc/dhcp/dhclient.conf: prepend domain-name-servers 79.133.43.124;prepend domain-name-servers 85.25.105.193; Since then, DNS resolving is done by my local server with opennic nameservers and not my modem-router which fails. Resolving lasts now 500ms long. Much better.The real problem was a bad local network configuration. I think my thread isn't so useful. Thanks for your help
