I want to boot Hummingboard Edge with Armbian (Jessie - kernel 3.14.54) , but I'm experiencing problems during the booting procedure.
Bootloader is searching for some files then it gives up. I have copied two files (imx6q-hummingboard2.dtb to imx6q-hummingboard.dtb) to /boot/dtb/ folder. It looks like it starts with the kernel, but it never loads completely. Below are the steps:
U-Boot SPL 2013.10-rc4-sun7i (Oct 11 2015 - 20:45:45)
Boot Device: SD1
spl: error reading image u-boot.img, err - -1
Load image from RAW...
U-Boot 2013.10-rc4-sun7i (Oct 11 2015 - 20:45:45)
CPU:   Freescale i.MX6Q rev1.5 at 792 MHz
Reset cause: POR
Board: MX6-HummingBoard2
DRAM:  2 GiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
In:    serial
Out:   serial
Err:   serial
Net:   FEC [PRIME]
mmc0 is current device
** File not found /boot.scr **
** File not found /uEnv.txt **
** File not found /zImage **
** File not found /uImage **
437 bytes read in 130 ms (2.9 KiB/s)
Running bootscript from mmc ...
## Executing script at 10800000
40257 bytes read in 421 ms (92.8 KiB/s)
6015384 bytes read in 584 ms (9.8 MiB/s)
Kernel image @ 0x12000000 [ 0x000000 - 0x5bc998 ]
## Flattened Device Tree blob at 18000000
   Booting using the fdt blob at 0x18000000
   Using Device Tree in place at 18000000, end 1800cd40
Starting kernel ...
I would be happy, if you can give me some pointers on how to solve this problem.
With Solidrun linux port it works normally.
Thank you.
Hello Igor,
no I use stock u-boot which came with the device. Should it be patched if I want to use Armbian for Hummingboard?
Thank you for your time.
Yes, better.
My u-boot loads boot.scr script and there you can set console output to serial, enlarge debug level to see what's going on, ...
Edit: even this uboot loads script so you need to edit /boot/boot.cmd, set console output and debug level = 7, recompile to boo.scr and reboot.
Hello to everyone,
I am having a similar problem, but with a hummingboard we bought recently. I downloaded the armbian image with ubuntu (server) and we put this image in two hummingboards:
one "I4P" (marked with a sticker on the back) and another one that we recently bought.
On the first one the image works perfectly, but on the second one it stops during boot; We are attaching here a screenshot of the boot sequence. Given that it says it does not find the file "/boot/dtb/imx6-..." we found on the solidrun forum that the different u-boot version would check for dtb files into /boot instead of /boot/dtb/ and so we copied all dtbs into /boot/ but we obtained the same screenshot.
Do you know what would be the issue? Initially we thought that it was a problem of only one of the boards but then we reproduced the problem on all 3 hummingboards we bought.
Best regards and many thanks in advance.
Which kernel version you are trying to boot?
