alright thanks @edupv
Oh, and one another problem that bugs me once every one or two week in armbian 5.27, but in 5.40 it's almost everyday,
The UASP stopped responding requests, it freeze entire system for several minutes, and every I/O to my hard drive makes the OS unresponsive.
I was using ASMedia ASM1153E a years ago, and it show much problem. So I switch to JMicron JMS578, which doesn't error as often like ASMedia 1153E.
I already read here (http://linux-sunxi.org/USB/UAS) and found out both ASM1153E and JMS578 is listed as OK right now.
below is dmesg output when it started to freeze when I'm copying a file from my PC to OrangePi via Windows 10 SMB. Most of the time, I'm just unplug & plug it again, followed by reboot if the problem still occured.
[47768.032826] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[47768.032841] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 58 3d e0 00 00 20 00
[47768.032871] scsi host1: uas_eh_device_reset_handler start
[47768.160815] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[47768.317930] scsi host1: uas_eh_device_reset_handler success
[50330.163432] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[50330.163447] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 6b 33 a0 00 00 20 00
[50330.163479] scsi host1: uas_eh_device_reset_handler start
[50330.291422] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[50330.448545] scsi host1: uas_eh_device_reset_handler success
[50526.777755] sd 1:0:0:0: [sda] tag#1 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD
[50526.777769] sd 1:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 03 6c d9 c0 00 00 20 00
[50526.777801] scsi host1: uas_eh_device_reset_handler start
[50526.905758] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[50527.062920] scsi host1: uas_eh_device_reset_handler success
[51663.454466] sd 1:0:0:0: [sda] tag#2 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD
[51663.454481] sd 1:0:0:0: [sda] tag#2 CDB: opcode=0x28 28 00 03 75 30 e0 00 00 20 00
[51663.454493] sd 1:0:0:0: [sda] tag#1 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD
[51663.454499] sd 1:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 03 75 30 c0 00 00 20 00
[51663.454509] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[51663.454515] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 75 30 a0 00 00 20 00
[51663.454546] scsi host1: uas_eh_device_reset_handler start
[51663.590458] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[51663.747660] scsi host1: uas_eh_device_reset_handler success
[51845.732387] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[51845.732402] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 76 72 60 00 00 20 00
[51845.732432] scsi host1: uas_eh_device_reset_handler start
[51845.860374] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[51846.017539] scsi host1: uas_eh_device_reset_handler success
[51894.886013] sd 1:0:0:0: [sda] tag#1 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD
[51894.886029] sd 1:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 03 76 c3 00 00 00 20 00
[51894.886042] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[51894.886048] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 76 c2 e0 00 00 20 00
[51894.886077] scsi host1: uas_eh_device_reset_handler start
[51895.018012] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[51895.175164] scsi host1: uas_eh_device_reset_handler success
[52292.211152] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[52292.211167] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 79 32 40 00 00 20 00
[52292.211198] scsi host1: uas_eh_device_reset_handler start
[52292.339142] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[52292.496285] scsi host1: uas_eh_device_reset_handler success
[52404.854865] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[52404.854879] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 7a f4 a0 00 00 20 00
[52404.854911] scsi host1: uas_eh_device_reset_handler start
[52404.982872] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[52405.140037] scsi host1: uas_eh_device_reset_handler success
[54092.463588] sd 1:0:0:0: [sda] tag#1 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD
[54092.463602] sd 1:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 03 8c 92 a0 00 00 20 00
[54092.463615] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[54092.463621] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 8c 92 00 00 00 20 00
[54092.463651] scsi host1: uas_eh_device_reset_handler start
[54092.595592] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[54092.752780] scsi host1: uas_eh_device_reset_handler success
[54538.942597] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[54538.942612] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 8f 2d c0 00 00 20 00
[54538.942644] scsi host1: uas_eh_device_reset_handler start
[54539.070600] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[54539.227780] scsi host1: uas_eh_device_reset_handler success
[55057.103819] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[55057.103834] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 91 fa 20 00 00 20 00
[55057.103865] scsi host1: uas_eh_device_reset_handler start
[55057.231835] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[55057.389024] scsi host1: uas_eh_device_reset_handler success
[55653.090860] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[55653.090874] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 96 59 80 00 00 20 00
[55653.090906] scsi host1: uas_eh_device_reset_handler start
[55653.218859] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[55653.376021] scsi host1: uas_eh_device_reset_handler success
[56503.038029] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[56503.038044] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 9b eb e0 00 00 20 00
[56503.038074] scsi host1: uas_eh_device_reset_handler start
[56503.166015] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[56503.323149] scsi host1: uas_eh_device_reset_handler success
[56711.940696] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[56711.940711] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 9d 57 20 00 00 20 00
[56711.940743] scsi host1: uas_eh_device_reset_handler start
[56712.068695] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[56712.225894] scsi host1: uas_eh_device_reset_handler success
[56845.065067] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[56845.065081] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 9e 28 c0 00 00 20 00
[56845.065113] scsi host1: uas_eh_device_reset_handler start
[56845.193056] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[56845.350268] scsi host1: uas_eh_device_reset_handler success
[56945.420365] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[56945.420379] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 9e ca 60 00 00 20 00
[56945.420410] scsi host1: uas_eh_device_reset_handler start
[56945.548357] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[56945.705523] scsi host1: uas_eh_device_reset_handler success
[57299.736002] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[57299.736016] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 a1 59 80 00 00 20 00
[57299.736048] scsi host1: uas_eh_device_reset_handler start
[57299.863990] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[57300.021139] scsi host1: uas_eh_device_reset_handler success
[57723.685896] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[57723.685910] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 a4 37 20 00 00 20 00
[57723.685941] scsi host1: uas_eh_device_reset_handler start
[57723.813885] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[57723.971011] scsi host1: uas_eh_device_reset_handler success
[57890.349013] sd 1:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[57890.349040] sd 1:0:0:0: [sda] tag#0 Sense Key : 0xb [current]
[57890.349047] sd 1:0:0:0: [sda] tag#0 ASC=0x47 ASCQ=0x3
[57890.349058] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 a5 bb c0 00 00 20 00
[57890.349065] print_req_error: I/O error, dev sda, sector 61193152
[57938.732871] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[57938.732885] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 a6 03 60 00 00 20 00
[57938.732916] scsi host1: uas_eh_device_reset_handler start
[57938.860865] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[57939.018019] scsi host1: uas_eh_device_reset_handler success
[92577.642693] EXT4-fs (sda1): error count since last fsck: 1
[92577.642712] EXT4-fs (sda1): initial error at time 1517862148: ext4_find_entry:1436: inode 2113537
[92577.642729] EXT4-fs (sda1): last error at time 1517862148: ext4_find_entry:1436: inode 2113537
[97339.405484] sd 1:0:0:0: [sda] tag#4 uas_eh_abort_handler 0 uas-tag 5 inflight: CMD
[97339.405498] sd 1:0:0:0: [sda] tag#4 CDB: opcode=0x2a 2a 00 03 f2 f8 00 00 04 00 00
[97339.405512] sd 1:0:0:0: [sda] tag#3 uas_eh_abort_handler 0 uas-tag 4 inflight: CMD
[97339.405518] sd 1:0:0:0: [sda] tag#3 CDB: opcode=0x2a 2a 00 03 f2 f4 00 00 04 00 00
[97339.405527] sd 1:0:0:0: [sda] tag#2 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD
[97339.405533] sd 1:0:0:0: [sda] tag#2 CDB: opcode=0x2a 2a 00 03 f2 f0 00 00 04 00 00
[97339.405543] sd 1:0:0:0: [sda] tag#1 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD
[97339.405549] sd 1:0:0:0: [sda] tag#1 CDB: opcode=0x2a 2a 00 03 f2 ec 00 00 04 00 00
[97339.405558] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[97339.405564] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 03 f2 e8 00 00 04 00 00
[97339.405576] sd 1:0:0:0: [sda] tag#27 uas_eh_abort_handler 0 uas-tag 28 inflight: CMD
[97339.405582] sd 1:0:0:0: [sda] tag#27 CDB: opcode=0x2a 2a 00 03 f2 e4 00 00 04 00 00
[97339.405591] sd 1:0:0:0: [sda] tag#26 uas_eh_abort_handler 0 uas-tag 27 inflight: CMD
[97339.405597] sd 1:0:0:0: [sda] tag#26 CDB: opcode=0x2a 2a 00 03 f2 e0 00 00 04 00 00
[97339.405606] sd 1:0:0:0: [sda] tag#25 uas_eh_abort_handler 0 uas-tag 26 inflight: CMD
[97339.405612] sd 1:0:0:0: [sda] tag#25 CDB: opcode=0x2a 2a 00 03 f2 dc 00 00 04 00 00
[97339.405621] sd 1:0:0:0: [sda] tag#24 uas_eh_abort_handler 0 uas-tag 25 inflight: CMD
[97339.405627] sd 1:0:0:0: [sda] tag#24 CDB: opcode=0x2a 2a 00 03 f2 d8 00 00 04 00 00
[97339.405637] sd 1:0:0:0: [sda] tag#23 uas_eh_abort_handler 0 uas-tag 24 inflight: CMD
[97339.405642] sd 1:0:0:0: [sda] tag#23 CDB: opcode=0x2a 2a 00 03 f2 d4 00 00 04 00 00
[97339.405652] sd 1:0:0:0: [sda] tag#22 uas_eh_abort_handler 0 uas-tag 23 inflight: CMD OUT
[97339.405658] sd 1:0:0:0: [sda] tag#22 CDB: opcode=0x2a 2a 00 03 f2 d0 00 00 04 00 00
[97366.030292] sd 1:0:0:0: tag#5 uas_eh_abort_handler 0 uas-tag 6 inflight: CMD
[97366.030305] sd 1:0:0:0: tag#5 CDB: opcode=0x0 00 00 00 00 00 00
[97366.030341] scsi host1: uas_eh_device_reset_handler start
[97366.194294] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[97366.351493] scsi host1: uas_eh_device_reset_handler success
[97374.990566] sd 1:0:0:0: [sda] tag#22 uas_eh_abort_handler 0 uas-tag 23 inflight: CMD
[97374.990581] sd 1:0:0:0: [sda] tag#22 CDB: opcode=0x12 12 00 00 00 24 00
[97398.799307] sd 1:0:0:0: [sda] tag#28 uas_eh_abort_handler 0 uas-tag 29 inflight: CMD
[97398.799322] sd 1:0:0:0: [sda] tag#28 CDB: opcode=0x28 28 00 03 c0 08 68 00 00 08 00
[97398.799337] sd 1:0:0:0: [sda] tag#21 uas_eh_abort_handler 0 uas-tag 22 inflight: CMD
[97398.799343] sd 1:0:0:0: [sda] tag#21 CDB: opcode=0x2a 2a 00 03 f4 04 00 00 04 00 00
[97398.799353] sd 1:0:0:0: [sda] tag#20 uas_eh_abort_handler 0 uas-tag 21 inflight: CMD
[97398.799359] sd 1:0:0:0: [sda] tag#20 CDB: opcode=0x2a 2a 00 03 f4 00 00 00 04 00 00
[97398.799368] sd 1:0:0:0: [sda] tag#19 uas_eh_abort_handler 0 uas-tag 20 inflight: CMD
[97398.799374] sd 1:0:0:0: [sda] tag#19 CDB: opcode=0x2a 2a 00 03 f3 fc 00 00 04 00 00
[97398.799384] sd 1:0:0:0: [sda] tag#18 uas_eh_abort_handler 0 uas-tag 19 inflight: CMD
[97398.799389] sd 1:0:0:0: [sda] tag#18 CDB: opcode=0x2a 2a 00 03 f3 f8 00 00 04 00 00
[97398.799398] sd 1:0:0:0: [sda] tag#17 uas_eh_abort_handler 0 uas-tag 18 inflight: CMD
[97398.799404] sd 1:0:0:0: [sda] tag#17 CDB: opcode=0x2a 2a 00 03 f3 f4 00 00 04 00 00
[97398.799414] sd 1:0:0:0: [sda] tag#16 uas_eh_abort_handler 0 uas-tag 17 inflight: CMD
[97398.799419] sd 1:0:0:0: [sda] tag#16 CDB: opcode=0x2a 2a 00 03 f3 f0 00 00 04 00 00
[97398.799452] scsi host1: uas_eh_device_reset_handler start
[97398.951299] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[97399.108489] scsi host1: uas_eh_device_reset_handler success
[97406.927546] sd 1:0:0:0: [sda] tag#7 uas_eh_abort_handler 0 uas-tag 8 inflight: CMD
[97406.927560] sd 1:0:0:0: [sda] tag#7 CDB: opcode=0x12 12 00 00 00 24 00
[97431.568309] sd 1:0:0:0: tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[97431.568323] sd 1:0:0:0: tag#0 CDB: opcode=0x0 00 00 00 00 00 00
[97431.568353] scsi host1: uas_eh_device_reset_handler start
[97431.583653] sd 1:0:0:0: [sda] tag#5 uas_zap_pending 0 uas-tag 6 inflight: CMD
[97431.583665] sd 1:0:0:0: [sda] tag#5 CDB: opcode=0x2a 2a 00 03 f4 04 00 00 04 00 00
[97431.583674] sd 1:0:0:0: [sda] tag#6 uas_zap_pending 0 uas-tag 7 inflight: CMD
[97431.583680] sd 1:0:0:0: [sda] tag#6 CDB: opcode=0x28 28 00 03 c0 08 68 00 00 08 00
[97431.708296] usb 5-1: reset high-speed USB device number 2 using ehci-platform
[97431.865490] scsi host1: uas_eh_device_reset_handler success
______@orangepipc2:~$
@lukasb please use spoiler tags to avoid such walls of text and answer the question whether your drives are powered by the board or by an own PSU.
In case it's the board can a moderator please split off these two posts and create a thread in the appropriate sub forum called 'UAS or undervoltage?'. Thank you.
alright thanks@edupv
[47768.032826] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD [47768.032841] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 58 3d e0 00 00 20 00[47768.032871] scsi host1: uas_eh_device_reset_handler start[47768.160815] usb 5-1: reset high-speed USB device number 2 using ehci-platform[47768.317930] scsi host1: uas_eh_device_reset_handler success[50330.163432] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD [50330.163447] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 6b 33 a0 00 00 20 00[50330.163479] scsi host1: uas_eh_device_reset_handler start[50330.291422] usb 5-1: reset high-speed USB device number 2 using ehci-platform[50330.448545] scsi host1: uas_eh_device_reset_handler success[50526.777755] sd 1:0:0:0: [sda] tag#1 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD [50526.777769] sd 1:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 03 6c d9 c0 00 00 20 00[50526.777801] scsi host1: uas_eh_device_reset_handler start[50526.905758] usb 5-1: reset high-speed USB device number 2 using ehci-platform[50527.062920] scsi host1: uas_eh_device_reset_handler success[51663.454466] sd 1:0:0:0: [sda] tag#2 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD [51663.454481] sd 1:0:0:0: [sda] tag#2 CDB: opcode=0x28 28 00 03 75 30 e0 00 00 20 00[51663.454493] sd 1:0:0:0: [sda] tag#1 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD [51663.454499] sd 1:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 03 75 30 c0 00 00 20 00[51663.454509] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD [51663.454515] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 75 30 a0 00 00 20 00[51663.454546] scsi host1: uas_eh_device_reset_handler start[51663.590458] usb 5-1: reset high-speed USB device number 2 using ehci-platform[51663.747660] scsi host1: uas_eh_device_reset_handler success[51845.732387] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD [51845.732402] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 76 72 60 00 00 20 00[51845.732432] scsi host1: uas_eh_device_reset_handler start[51845.860374] usb 5-1: reset high-speed USB device number 2 using ehci-platform[51846.017539] scsi host1: uas_eh_device_reset_handler success[51894.886013] sd 1:0:0:0: [sda] tag#1 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD [51894.886029] sd 1:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 03 76 c3 00 00 00 20 00[51894.886042] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD [51894.886048] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 76 c2 e0 00 00 20 00[51894.886077] scsi host1: uas_eh_device_reset_handler start[51895.018012] usb 5-1: reset high-speed USB device number 2 using ehci-platform[51895.175164] scsi host1: uas_eh_device_reset_handler success[52292.211152] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD [52292.211167] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 79 32 40 00 00 20 00[52292.211198] scsi host1: uas_eh_device_reset_handler start[52292.339142] usb 5-1: reset high-speed USB device number 2 using ehci-platform[52292.496285] scsi host1: uas_eh_device_reset_handler success[52404.854865] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD [52404.854879] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 7a f4 a0 00 00 20 00[52404.854911] scsi host1: uas_eh_device_reset_handler start[52404.982872] usb 5-1: reset high-speed USB device number 2 using ehci-platform[52405.140037] scsi host1: uas_eh_device_reset_handler success[54092.463588] sd 1:0:0:0: [sda] tag#1 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD [54092.463602] sd 1:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 03 8c 92 a0 00 00 20 00[54092.463615] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD [54092.463621] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 8c 92 00 00 00 20 00[54092.463651] scsi host1: uas_eh_device_reset_handler start[54092.595592] usb 5-1: reset high-speed USB device number 2 using ehci-platform[54092.752780] scsi host1: uas_eh_device_reset_handler success[54538.942597] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD [54538.942612] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 8f 2d c0 00 00 20 00[54538.942644] scsi host1: uas_eh_device_reset_handler start[54539.070600] usb 5-1: reset high-speed USB device number 2 using ehci-platform[54539.227780] scsi host1: uas_eh_device_reset_handler success[55057.103819] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD [55057.103834] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 91 fa 20 00 00 20 00[55057.103865] scsi host1: uas_eh_device_reset_handler start[55057.231835] usb 5-1: reset high-speed USB device number 2 using ehci-platform[55057.389024] scsi host1: uas_eh_device_reset_handler success[55653.090860] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD [55653.090874] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 96 59 80 00 00 20 00[55653.090906] scsi host1: uas_eh_device_reset_handler start[55653.218859] usb 5-1: reset high-speed USB device number 2 using ehci-platform[55653.376021] scsi host1: uas_eh_device_reset_handler success[56503.038029] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD [56503.038044] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 9b eb e0 00 00 20 00[56503.038074] scsi host1: uas_eh_device_reset_handler start[56503.166015] usb 5-1: reset high-speed USB device number 2 using ehci-platform[56503.323149] scsi host1: uas_eh_device_reset_handler success[56711.940696] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD [56711.940711] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 9d 57 20 00 00 20 00[56711.940743] scsi host1: uas_eh_device_reset_handler start[56712.068695] usb 5-1: reset high-speed USB device number 2 using ehci-platform[56712.225894] scsi host1: uas_eh_device_reset_handler success[56845.065067] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD [56845.065081] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 9e 28 c0 00 00 20 00[56845.065113] scsi host1: uas_eh_device_reset_handler start[56845.193056] usb 5-1: reset high-speed USB device number 2 using ehci-platform[56845.350268] scsi host1: uas_eh_device_reset_handler success[56945.420365] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD [56945.420379] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 9e ca 60 00 00 20 00[56945.420410] scsi host1: uas_eh_device_reset_handler start[56945.548357] usb 5-1: reset high-speed USB device number 2 using ehci-platform[56945.705523] scsi host1: uas_eh_device_reset_handler success[57299.736002] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD [57299.736016] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 a1 59 80 00 00 20 00[57299.736048] scsi host1: uas_eh_device_reset_handler start[57299.863990] usb 5-1: reset high-speed USB device number 2 using ehci-platform[57300.021139] scsi host1: uas_eh_device_reset_handler success[57723.685896] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD [57723.685910] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 a4 37 20 00 00 20 00[57723.685941] scsi host1: uas_eh_device_reset_handler start[57723.813885] usb 5-1: reset high-speed USB device number 2 using ehci-platform[57723.971011] scsi host1: uas_eh_device_reset_handler success[57890.349013] sd 1:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08[57890.349040] sd 1:0:0:0: [sda] tag#0 Sense Key : 0xb [current] [57890.349047] sd 1:0:0:0: [sda] tag#0 ASC=0x47 ASCQ=0x3 [57890.349058] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 a5 bb c0 00 00 20 00[57890.349065] print_req_error: I/O error, dev sda, sector 61193152[57938.732871] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD [57938.732885] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 03 a6 03 60 00 00 20 00[57938.732916] scsi host1: uas_eh_device_reset_handler start[57938.860865] usb 5-1: reset high-speed USB device number 2 using ehci-platform[57939.018019] scsi host1: uas_eh_device_reset_handler success[92577.642693] EXT4-fs (sda1): error count since last fsck: 1[92577.642712] EXT4-fs (sda1): initial error at time 1517862148: ext4_find_entry:1436: inode 2113537[92577.642729] EXT4-fs (sda1): last error at time 1517862148: ext4_find_entry:1436: inode 2113537[97339.405484] sd 1:0:0:0: [sda] tag#4 uas_eh_abort_handler 0 uas-tag 5 inflight: CMD [97339.405498] sd 1:0:0:0: [sda] tag#4 CDB: opcode=0x2a 2a 00 03 f2 f8 00 00 04 00 00[97339.405512] sd 1:0:0:0: [sda] tag#3 uas_eh_abort_handler 0 uas-tag 4 inflight: CMD [97339.405518] sd 1:0:0:0: [sda] tag#3 CDB: opcode=0x2a 2a 00 03 f2 f4 00 00 04 00 00[97339.405527] sd 1:0:0:0: [sda] tag#2 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD [97339.405533] sd 1:0:0:0: [sda] tag#2 CDB: opcode=0x2a 2a 00 03 f2 f0 00 00 04 00 00[97339.405543] sd 1:0:0:0: [sda] tag#1 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD [97339.405549] sd 1:0:0:0: [sda] tag#1 CDB: opcode=0x2a 2a 00 03 f2 ec 00 00 04 00 00[97339.405558] sd 1:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD [97339.405564] sd 1:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 03 f2 e8 00 00 04 00 00[97339.405576] sd 1:0:0:0: [sda] tag#27 uas_eh_abort_handler 0 uas-tag 28 inflight: CMD [97339.405582] sd 1:0:0:0: [sda] tag#27 CDB: opcode=0x2a 2a 00 03 f2 e4 00 00 04 00 00[97339.405591] sd 1:0:0:0: [sda] tag#26 uas_eh_abort_handler 0 uas-tag 27 inflight: CMD [97339.405597] sd 1:0:0:0: [sda] tag#26 CDB: opcode=0x2a 2a 00 03 f2 e0 00 00 04 00 00[97339.405606] sd 1:0:0:0: [sda] tag#25 uas_eh_abort_handler 0 uas-tag 26 inflight: CMD [97339.405612] sd 1:0:0:0: [sda] tag#25 CDB: opcode=0x2a 2a 00 03 f2 dc 00 00 04 00 00[97339.405621] sd 1:0:0:0: [sda] tag#24 uas_eh_abort_handler 0 uas-tag 25 inflight: CMD [97339.405627] sd 1:0:0:0: [sda] tag#24 CDB: opcode=0x2a 2a 00 03 f2 d8 00 00 04 00 00[97339.405637] sd 1:0:0:0: [sda] tag#23 uas_eh_abort_handler 0 uas-tag 24 inflight: CMD [97339.405642] sd 1:0:0:0: [sda] tag#23 CDB: opcode=0x2a 2a 00 03 f2 d4 00 00 04 00 00[97339.405652] sd 1:0:0:0: [sda] tag#22 uas_eh_abort_handler 0 uas-tag 23 inflight: CMD OUT [97339.405658] sd 1:0:0:0: [sda] tag#22 CDB: opcode=0x2a 2a 00 03 f2 d0 00 00 04 00 00[97366.030292] sd 1:0:0:0: tag#5 uas_eh_abort_handler 0 uas-tag 6 inflight: CMD [97366.030305] sd 1:0:0:0: tag#5 CDB: opcode=0x0 00 00 00 00 00 00[97366.030341] scsi host1: uas_eh_device_reset_handler start[97366.194294] usb 5-1: reset high-speed USB device number 2 using ehci-platform[97366.351493] scsi host1: uas_eh_device_reset_handler success[97374.990566] sd 1:0:0:0: [sda] tag#22 uas_eh_abort_handler 0 uas-tag 23 inflight: CMD [97374.990581] sd 1:0:0:0: [sda] tag#22 CDB: opcode=0x12 12 00 00 00 24 00[97398.799307] sd 1:0:0:0: [sda] tag#28 uas_eh_abort_handler 0 uas-tag 29 inflight: CMD [97398.799322] sd 1:0:0:0: [sda] tag#28 CDB: opcode=0x28 28 00 03 c0 08 68 00 00 08 00[97398.799337] sd 1:0:0:0: [sda] tag#21 uas_eh_abort_handler 0 uas-tag 22 inflight: CMD [97398.799343] sd 1:0:0:0: [sda] tag#21 CDB: opcode=0x2a 2a 00 03 f4 04 00 00 04 00 00[97398.799353] sd 1:0:0:0: [sda] tag#20 uas_eh_abort_handler 0 uas-tag 21 inflight: CMD [97398.799359] sd 1:0:0:0: [sda] tag#20 CDB: opcode=0x2a 2a 00 03 f4 00 00 00 04 00 00[97398.799368] sd 1:0:0:0: [sda] tag#19 uas_eh_abort_handler 0 uas-tag 20 inflight: CMD [97398.799374] sd 1:0:0:0: [sda] tag#19 CDB: opcode=0x2a 2a 00 03 f3 fc 00 00 04 00 00[97398.799384] sd 1:0:0:0: [sda] tag#18 uas_eh_abort_handler 0 uas-tag 19 inflight: CMD [97398.799389] sd 1:0:0:0: [sda] tag#18 CDB: opcode=0x2a 2a 00 03 f3 f8 00 00 04 00 00[97398.799398] sd 1:0:0:0: [sda] tag#17 uas_eh_abort_handler 0 uas-tag 18 inflight: CMD [97398.799404] sd 1:0:0:0: [sda] tag#17 CDB: opcode=0x2a 2a 00 03 f3 f4 00 00 04 00 00[97398.799414] sd 1:0:0:0: [sda] tag#16 uas_eh_abort_handler 0 uas-tag 17 inflight: CMD [97398.799419] sd 1:0:0:0: [sda] tag#16 CDB: opcode=0x2a 2a 00 03 f3 f0 00 00 04 00 00[97398.799452] scsi host1: uas_eh_device_reset_handler start[97398.951299] usb 5-1: reset high-speed USB device number 2 using ehci-platform[97399.108489] scsi host1: uas_eh_device_reset_handler success[97406.927546] sd 1:0:0:0: [sda] tag#7 uas_eh_abort_handler 0 uas-tag 8 inflight: CMD [97406.927560] sd 1:0:0:0: [sda] tag#7 CDB: opcode=0x12 12 00 00 00 24 00[97431.568309] sd 1:0:0:0: tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD [97431.568323] sd 1:0:0:0: tag#0 CDB: opcode=0x0 00 00 00 00 00 00[97431.568353] scsi host1: uas_eh_device_reset_handler start[97431.583653] sd 1:0:0:0: [sda] tag#5 uas_zap_pending 0 uas-tag 6 inflight: CMD [97431.583665] sd 1:0:0:0: [sda] tag#5 CDB: opcode=0x2a 2a 00 03 f4 04 00 00 04 00 00[97431.583674] sd 1:0:0:0: [sda] tag#6 uas_zap_pending 0 uas-tag 7 inflight: CMD [97431.583680] sd 1:0:0:0: [sda] tag#6 CDB: opcode=0x28 28 00 03 c0 08 68 00 00 08 00[97431.708296] usb 5-1: reset high-speed USB device number 2 using ehci-platform[97431.865490] scsi host1: uas_eh_device_reset_handler success______@orangepipc2:~$
I have the same problem with a multi bay enclosure with JMS567 and Intel Atom running Ubuntu 16.04 with any kind of kernels. It is not a problem with armbian or power, the UAS just have several problems with some chipsets
Inviato dal mio SM-G955F utilizzando Tapatalk
JMS567 should not be amongst them so in your situation most probably you should check the cable and USB3-A receptacle which is known to be utter crap (the low end storage world will be a better place once we have USB-C everywhere).
Folks, if you see 'uas' in your logs then it's often just the uas driver reporting problems happening one layer below. Don't shoot the messenger even if it seems 'fun' to blame software and a protocol for hardware issues.
It is not the cable. In BOT mode (with quirks in modules.d) works perfectly
The here mentioned chipsets are all known to be fully UAS compliant when using a recent enough kernel: JMS567, JMS578 and eg. ASM1153E (with original firmware! Seagate also uses this ASMedia chip but combines it with a broken firmware in their USB3 storage products)
Then there's this issue (fixed in Armbian, most probably a problem with the majority of x86 Linux distros):
And then there are fake products. I bought last summer two JMS578 USB SATA adapters that showed strange behavior with UAS. Understandable since they were fakes using Norelsys 1068 instead (needing UAS blacklisting). Upstream fix arrived just recently in kernel 14.$something thanks to @Icenowybut unfortunately only Norelsys 1608 affected not the similarly broken 1066 :(
I didn't blacklist NS1066 because my NS1066 HDD case doesn't report UAS at all (with Ivy Bridge PC's USB3).
P.S. NS106X will only report UAS at USB3 ports.
