logicite Posted February 9, 2018 Posted February 9, 2018 Hello everyone, Looks like i have some issue after last upgrade. I'm using a Banana Pi Pro as a file server at home (with samba mainly). The system is some kind of freezing after a few hours : i'm watching a movie and cannot go to the end of it. The system disappears from the network : no more access via samba/windows network, no more ssh, no more ping... Fortunately i am logging remotly so i can see that the system is still working somehow because it goes on sending syslogs. Last syslog is (the system "froze" at 20:10) : Feb 7 20:02:01 localhost CRON[3118]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Feb 7 20:05:01 localhost CRON[3149]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1) Feb 7 20:15:01 localhost CRON[3203]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1) Feb 7 20:16:09 localhost systemd[1]: systemd-logind.service: Watchdog timeout (limit 3min)! Feb 7 20:17:39 localhost systemd[1]: systemd-logind.service: State 'stop-sigabrt' timed out. Terminating. Feb 7 20:19:10 localhost systemd[1]: systemd-logind.service: State 'stop-sigterm' timed out. Killing. Feb 7 20:20:40 localhost systemd[1]: systemd-logind.service: Processes still around after SIGKILL. Ignoring. Feb 7 20:22:10 localhost systemd[1]: systemd-logind.service: State 'stop-final-sigterm' timed out. Killing. Feb 7 20:23:40 localhost systemd[1]: systemd-logind.service: Processes still around after final SIGKILL. Entering failed mode. Feb 7 20:23:40 localhost systemd[1]: systemd-logind.service: Unit entered failed state. Feb 7 20:23:40 localhost systemd[1]: systemd-logind.service: Failed with result 'timeout'. Feb 7 20:23:41 localhost systemd[1]: systemd-logind.service: Service has no hold-off time, scheduling restart. Feb 7 20:23:41 localhost systemd[1]: Stopped Login Service. Feb 7 20:23:41 localhost systemd[1]: Starting Login Service... And nothing after... Any clue where i should be looking for a solution ?? Thank you for ideas. My config : dpkg -l | grep armbian : ii armbian-firmware 5.38 all Linux firmware ii armbian-tools-xenial 5.38 armhf Armbian tools, Cubie bt utils ii hostapd 2:2.6-4~armbian5.38+1 armhf IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator ii sunxi-tools 1.4.2-2~armbian5.38+1 armhf tools for working with Allwinner (sunxi) ARM processors
logicite Posted February 9, 2018 Author Posted February 9, 2018 Hi again, I found more in the logs today : repeting log regarding systemd-logind... I'm stil searching. If you have any idea... Thanks Feb 9 15:12:57 localhost systemd[1]: Failed to start Login Service. Feb 9 15:12:57 localhost systemd[1]: systemd-logind.service: Unit entered failed state. Feb 9 15:12:57 localhost systemd[1]: systemd-logind.service: Failed with result 'timeout'. Feb 9 15:12:57 localhost systemd[1]: systemd-logind.service: Service has no hold-off time, scheduling restart. Feb 9 15:12:57 localhost systemd[1]: Stopped Login Service. Feb 9 15:12:57 localhost systemd[1]: Starting Login Service... Feb 9 15:12:57 localhost systemd[1]: systemd-logind.service: Main process exited, code=exited, status=1/FAILURE Feb 9 15:14:36 localhost systemd[1]: systemd-logind.service: State 'stop-sigterm' timed out. Killing. Feb 9 15:16:06 localhost systemd[1]: systemd-logind.service: Processes still around after SIGKILL. Ignoring. Feb 9 15:17:45 localhost systemd[1]: systemd-logind.service: State 'stop-final-sigterm' timed out. Killing. Feb 9 15:19:15 localhost systemd[1]: systemd-logind.service: Processes still around after final SIGKILL. Entering failed mode. Feb 9 15:19:15 localhost systemd[1]: Failed to start Login Service. Feb 9 15:19:15 localhost systemd[1]: systemd-logind.service: Unit entered failed state. Feb 9 15:19:15 localhost systemd[1]: systemd-logind.service: Failed with result 'timeout'. Feb 9 15:19:16 localhost systemd[1]: systemd-logind.service: Service has no hold-off time, scheduling restart. Feb 9 15:19:16 localhost systemd[1]: Stopped Login Service. Feb 9 15:19:16 localhost systemd[1]: Starting Login Service... Feb 9 15:19:16 localhost systemd[1]: systemd-logind.service: Main process exited, code=exited, status=1/FAILURE Feb 9 15:20:54 localhost systemd[1]: systemd-logind.service: State 'stop-sigterm' timed out. Killing. Feb 9 15:22:25 localhost systemd[1]: systemd-logind.service: Processes still around after SIGKILL. Ignoring. Feb 9 15:24:04 localhost systemd[1]: systemd-logind.service: State 'stop-final-sigterm' timed out. Killing. Feb 9 15:25:34 localhost systemd[1]: systemd-logind.service: Processes still around after final SIGKILL. Entering failed mode. Feb 9 15:25:34 localhost systemd[1]: Failed to start Login Service. Feb 9 15:25:34 localhost systemd[1]: systemd-logind.service: Unit entered failed state. Feb 9 15:25:34 localhost systemd[1]: systemd-logind.service: Failed with result 'timeout'. Feb 9 15:25:34 localhost systemd[1]: systemd-logind.service: Service has no hold-off time, scheduling restart. Feb 9 15:25:34 localhost systemd[1]: Stopped Login Service. Feb 9 15:25:34 localhost systemd[1]: Starting Login Service...
logicite Posted February 9, 2018 Author Posted February 9, 2018 I tried this to get some status information : $ sudo systemctl status systemd-logind ● systemd-logind.service - Login Service Loaded: loaded (/lib/systemd/system/systemd-logind.service; static; vendor preset: enabled) Active: deactivating (final-sigterm) (Result: timeout) since ven. 2018-02-09 14:15:01 CET; 1h 27min ago Docs: man:systemd-logind.service(8) man:logind.conf(5) http://www.freedesktop.org/wiki/Software/systemd/logind http://www.freedesktop.org/wiki/Software/systemd/multiseat Process: 19171 ExecStart=/lib/systemd/systemd-logind (code=exited, status=1/FAILURE) Main PID: 19171 (code=exited, status=1/FAILURE) Status: "Shutting down..." CGroup: /system.slice/systemd-logind.service └─691 /lib/systemd/systemd-logind févr. 09 15:38:11 sharing systemd[1]: Stopped Login Service. févr. 09 15:38:11 sharing systemd[1]: Starting Login Service... févr. 09 15:38:11 sharing systemd-logind[19171]: Failed to register name: File exists févr. 09 15:38:11 sharing systemd-logind[19171]: Failed to fully start up daemon: File exists févr. 09 15:38:11 sharing systemd[1]: systemd-logind.service: Main process exited, code=exited, status=1/FAILURE févr. 09 15:39:49 sharing systemd[1]: systemd-logind.service: State 'stop-sigterm' timed out. Killing. févr. 09 15:41:19 sharing systemd[1]: systemd-logind.service: Processes still around after SIGKILL. Ignoring. And if i want to reload, it fails (probably because de "file exists" : looks like there are several 'daemons' running at the same time ?) : $ sudo systemctl reload systemd-logind Failed to reload systemd-logind.service: Job type reload is not applicable for unit systemd-logind.service. See system logs and 'systemctl status systemd-logind.service' for details. So i did not hesitate and issue a stop command : $ sudo systemctl stop systemd-logind And now nothing, no prompt ! By the way remote log shows that the OS is still working (logging the same failure again and again).
