Hi there,
as already discussed here,
https://forum.armbian.com/topic/5318-looking-for-an-enclosure-for-espressobin/?do=findComment&comment=49396
it seems that this 4-sata mini pci express card is supposed to be supported by armbian.
As I wrote in that post, it doesn't work for me.
I've tried Armbian default and next.
The cards work, since I got them running with espressobin's Ubuntu distribution.
Also, I've compiled a 4.4.52 Kernel according to:
http://wiki.espressobin.net/tiki-index.php?page=Build+From+Source+-+Kernel
It also works just fine with Armbian.
So, my guess is that there's something different in the kernel config provided by linux-marvel and armbian when it comes to this chipset.
For reference, I've attached the screen output from a boot with the sata card.
I can not seem to find the kernel-config in the armbian-buildroot. Where do I find that?
I've already set *KERNEL_KEEP_CONFIG="yes"* in default-config.conf
Any help is aprreciated.
Cheers!
udo,
screenlog.0.defauft
Have you changed/updated u-boot on SPI flash? If not, this is the first thing to do.
Yes, I have U-Boot 2017.03-armada-17.06.3-ga33ecb8 (Jul 05 2017 - 14:30:47 +0800)
25 minutes ago, Igor said:
You need latest which is 2017.03-armada-17.10 https://dl.armbian.com/espressobin/u-boot/
Thanks for that.
Unfortunatly something is fishy now, and the machine is bricked :(
i took the 1g-1200_750  - which might have been too much. Time to find out how to unbrick it... Any hints?
TIM-1.0
WTMI-armada-17.10.1-4809244
ENTER init_ddrgen
DDR_TOPOLOGY is 2 :     DDR3, 2CS 512M + 512M
WTMI_CLOCK=3
Fill memory before self refresh...done
Now in Self-refresh Mode
Restore CAS Read and Write Latency
Restore termination values to original values
Exited self-refresh ...
DLL TUNING
   DLL 0xc0001050[21:16]: [1,26,13]
   DLL 0xc0001050[29:24]: [f,34,21]
   DLL 0xc0001054[21:16]: [4,25,14]
   DLL 0xc0001054[29:24]: [e,2f,1e]
   DLL 0xc0001074[21:16]: [0,3f,1f]
   DLL 0xc0001074[29:24]: [0,3f,1f]
 DLL: pass
Thanks for the help.
My device doesn't work with the flash-image-1g-1200_750_boot_sd_and_usb.bin image, but the 1000_800 does work just fine.
Even the SATA-Card works now. Thanks again! Cheers!
