SOLVED [TEST/sunxi/20160201] Issue while compiling / building kernel 4.3.5 / 4.4.1 (sunxi-next)
Hi there,
i try to compile a kernel via:
apt-get -y install git
git clone https://github.com/igorpecovnik/lib--depth 1
cp lib/compile.sh .
chmod +x compile.sh
./compile.sh
In compile.sh, i changed:
KERNEL_ONLY="yes"
and added
KERNELTAG="v4.3.5"
I get an error which can be seen in the attached file.
I was able to compile 4.3.4 on the same machine, so i do not expect enironment issues.
Any hint?
Thx,
A.
Thx for the quick reply - checked out lib once more an now, there is the mentioned patch in sunxi-next.
Trying to compile .....
I checked lib sources, and setting KERNELTAG manually isn't supported in current version, so resulting kernel for next branch will be 4.4.1
True. When we redesign the download part
By adding:
KERNELBRANCH="v4.3.5" and choosing NEXT will work.
And one more problem when selecting old kernel versions. Patches might break compilation. In this case they do ...
Just one more note here: when removing patches, make sure you don't remove *packaging* and *headers-packing*.patch
The rest can be missed.
