lampra Posted February 27, 2018 Share Posted February 27, 2018 Hi, I updated from legacy kernel to mainline and then from jessie to stretch. Armbianmonitor -u output is further below. So far, the main issue is that after rebooting the DNS server is set to 127.0.0.1 thus loosing internet connectivity. Here is the output of resolve.conf (with manual setting the nameserver after reboot ) and the static network config. I am struggling to find how the dns server is set after reboot. I would appreciate if anyone could point me to a HOW TO. Minor issues: I can see only one cpu with htop, the ip address is not recognized at the ssh login screen, the opi pc is recognized as opi lite at the ssh login screen Spoiler # cat /etc/resolv.conf # Generated by dhcpcd from eth0.dhcp # /etc/resolv.conf.head can replace this line nameserver 8.8.8.8 # /etc/resolv.conf.tail can replace this line #cat /etc/network/interfaces.default # armbian-config created source /etc/network/interfaces.d/* # Local loopback auto lo iface lo inet loopback # Interface eth0 allow-hotplug eth0 no-auto-down eth0 iface eth0 inet static address 192.168.1.66 netmask 24 gateway 192.168.1.1 dns-nameservers 8.8.8.8 Armbianmonitor -u Spoiler Mon Feb 26 10:55:16 EET 2018 sun8i armv7l Xunlong Orange Pi PC Orange Pi Lite Linux version 4.14.18-sunxi (root@xeon) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #24 SMP Fri Feb 9 16:24:32 CET 2018 ### dmesg: [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.14.18-sunxi (root@xeon) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #24 SMP Fri Feb 9 16:24:32 CET 2018 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: Xunlong Orange Pi PC [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] Reserved memory: created CMA memory pool at 0x7c000000, size 64 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] On node 0 totalpages: 262144 [ 0.000000] free_area_init_node: node 0, pgdat c0dd8b00, node_mem_map ef6fa000 [ 0.000000] Normal zone: 1728 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 196608 pages, LIFO batch:31 [ 0.000000] HighMem zone: 65536 pages, LIFO batch:15 [ 0.000000] random: fast init done [ 0.000000] percpu: Embedded 17 pages/cpu @ef69e000 s39884 r8192 d21556 u69632 [ 0.000000] pcpu-alloc: s39884 r8192 d21556 u69632 alloc=17*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260416 [ 0.000000] Kernel command line: console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup-enable=memory swapaccount=1 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 panic=10 consoleblank=0 enforcing=0 loglevel=7 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] allocated 1048576 bytes of page_ext [ 0.000000] Memory: 957956K/1048576K available (8192K kernel code, 945K rwdata, 2344K rodata, 1024K init, 346K bss, 25084K reserved, 65536K cma-reserved, 196608K highmem) [ 0.000000] Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xffc00000 - 0xfff00000 (3072 kB) vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf800000 - 0xbfe00000 ( 6 MB) .text : 0xc0008000 - 0xc0900000 (9184 kB) .init : 0xc0c00000 - 0xc0d00000 (1024 kB) .data : 0xc0d00000 - 0xc0dec59c ( 946 kB) .bss : 0xc0df5de8 - 0xc0e4c61c ( 347 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] ftrace: allocating 37002 entries in 73 pages [ 0.000000] Hierarchical RCU implementation. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000016] Switching to timer-based delay loop, resolution 41ns [ 0.000190] Console: colour dummy device 80x30 [ 0.000601] console [tty1] enabled [ 0.000636] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.000663] pid_max: default: 32768 minimum: 301 [ 0.000849] Security Framework initialized [ 0.000872] AppArmor: AppArmor disabled by boot time parameter [ 0.000941] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000964] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001692] CPU: Testing write buffer coherency: ok [ 0.002034] /cpus/cpu@0 missing clock-frequency property [ 0.002073] /cpus/cpu@1 missing clock-frequency property [ 0.002102] /cpus/cpu@2 missing clock-frequency property [ 0.002131] /cpus/cpu@3 missing clock-frequency property [ 0.002150] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.002479] Setting up static identity map for 0x40100000 - 0x40100054 [ 0.002593] Hierarchical SRCU implementation. [ 0.003254] smp: Bringing up secondary CPUs ... [ 0.004345] smp: Brought up 1 node, 1 CPU [ 0.004367] SMP: Total of 1 processors activated (48.00 BogoMIPS). [ 0.004381] CPU: All CPU(s) started in SVC mode. [ 0.005158] devtmpfs: initialized [ 0.011584] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 [ 0.011804] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.011838] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.014250] xor: measuring software checksum speed [ 0.110055] arm4regs : 1255.200 MB/sec [ 0.210114] 8regs : 748.000 MB/sec [ 0.310171] 32regs : 765.600 MB/sec [ 0.410227] neon : 1269.600 MB/sec [ 0.410241] xor: using function: neon (1269.600 MB/sec) [ 0.410330] pinctrl core: initialized pinctrl subsystem [ 0.411196] NET: Registered protocol family 16 [ 0.413398] DMA: preallocated 2048 KiB pool for atomic coherent allocations [ 0.414107] cpuidle: using governor ladder [ 0.414126] cpuidle: using governor menu [ 0.414885] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.414910] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.590633] raid6: int32x1 gen() 189 MB/s [ 0.760678] raid6: int32x1 xor() 160 MB/s [ 0.930799] raid6: int32x2 gen() 255 MB/s [ 1.100804] raid6: int32x2 xor() 193 MB/s [ 1.271016] raid6: int32x4 gen() 258 MB/s [ 1.441149] raid6: int32x4 xor() 193 MB/s [ 1.611316] raid6: int32x8 gen() 247 MB/s [ 1.781379] raid6: int32x8 xor() 172 MB/s [ 1.951459] raid6: neonx1 gen() 494 MB/s [ 2.121533] raid6: neonx1 xor() 460 MB/s [ 2.291730] raid6: neonx2 gen() 663 MB/s [ 2.461765] raid6: neonx2 xor() 593 MB/s [ 2.631918] raid6: neonx4 gen() 798 MB/s [ 2.802030] raid6: neonx4 xor() 669 MB/s [ 2.972218] raid6: neonx8 gen() 717 MB/s [ 3.142325] raid6: neonx8 xor() 605 MB/s [ 3.142340] raid6: using algorithm neonx4 gen() 798 MB/s [ 3.142353] raid6: .... xor() 669 MB/s, rmw enabled [ 3.142366] raid6: using neon recovery algorithm [ 3.143779] SCSI subsystem initialized [ 3.144039] libata version 3.00 loaded. [ 3.144249] usbcore: registered new interface driver usbfs [ 3.144304] usbcore: registered new interface driver hub [ 3.144376] usbcore: registered new device driver usb [ 3.144547] media: Linux media interface: v0.10 [ 3.144586] Linux video capture interface: v2.00 [ 3.144655] pps_core: LinuxPPS API ver. 1 registered [ 3.144670] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 3.144701] PTP clock support registered [ 3.145943] clocksource: Switched to clocksource arch_sys_counter [ 3.236112] VFS: Disk quotas dquot_6.6.0 [ 3.236219] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 3.243352] NET: Registered protocol family 2 [ 3.243909] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 3.244010] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 3.244132] TCP: Hash tables configured (established 8192 bind 8192) [ 3.244239] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 3.244305] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 3.244526] NET: Registered protocol family 1 [ 3.245012] RPC: Registered named UNIX socket transport module. [ 3.245034] RPC: Registered udp transport module. [ 3.245046] RPC: Registered tcp transport module. [ 3.245059] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 3.246636] audit: initializing netlink subsys (disabled) [ 3.247054] Initialise system trusted keyrings [ 3.247146] audit: type=2000 audit(3.240:1): state=initialized audit_enabled=0 res=1 [ 3.247227] workingset: timestamp_bits=14 max_order=18 bucket_order=4 [ 3.251902] zbud: loaded [ 3.253972] NFS: Registering the id_resolver key type [ 3.254021] Key type id_resolver registered [ 3.254034] Key type id_legacy registered [ 3.254055] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 3.254070] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 3.254969] JFS: nTxBlock = 7996, nTxLock = 63968 [ 3.263270] SGI XFS with ACLs, security attributes, realtime, no debug enabled [ 3.270248] Key type asymmetric registered [ 3.270325] bounce: pool size: 64 pages [ 3.270414] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [ 3.270569] io scheduler noop registered [ 3.270586] io scheduler deadline registered [ 3.270836] io scheduler cfq registered (default) [ 3.270853] io scheduler mq-deadline registered [ 3.270866] io scheduler kyber registered [ 3.270988] io scheduler bfq registered [ 3.271867] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO [ 3.275414] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver [ 3.276958] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver [ 3.322764] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 3.345734] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 42, base_baud = 1500000) is a U6_16550A [ 3.348910] brd: module loaded [ 3.353885] loop: module loaded [ 3.355395] libphy: Fixed MDIO Bus: probed [ 3.355890] dwmac-sun8i 1c30000.ethernet: PTP uses main clock [ 3.356030] dwmac-sun8i 1c30000.ethernet: No regulator found [ 3.356121] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 58000) [ 3.356152] dwmac-sun8i 1c30000.ethernet: Chain mode enabled [ 3.356169] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported [ 3.356188] dwmac-sun8i 1c30000.ethernet: Normal descriptors [ 3.356204] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported [ 3.356223] dwmac-sun8i 1c30000.ethernet: COE Type 2 [ 3.356239] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported [ 3.356353] libphy: stmmac: probed [ 3.356782] dwmac-sun8i 1c30000.ethernet: Found internal PHY node [ 3.356869] libphy: mdio_mux: probed [ 3.356896] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY [ 3.356914] dwmac-sun8i 1c30000.ethernet: Powering internal PHY [ 3.357809] libphy: mdio_mux: probed [ 3.358263] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 3.358283] ehci-platform: EHCI generic platform driver [ 3.358467] ehci-platform 1c1a000.usb: EHCI Host Controller [ 3.358504] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1 [ 3.359079] ehci-platform 1c1a000.usb: irq 27, io mem 0x01c1a000 [ 3.385976] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00 [ 3.386186] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.386209] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.386229] usb usb1: Product: EHCI Host Controller [ 3.386244] usb usb1: Manufacturer: Linux 4.14.18-sunxi ehci_hcd [ 3.386260] usb usb1: SerialNumber: 1c1a000.usb [ 3.386772] hub 1-0:1.0: USB hub found [ 3.386822] hub 1-0:1.0: 1 port detected [ 3.387466] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 3.387501] ohci-platform: OHCI generic platform driver [ 3.387681] ohci-platform 1c1a400.usb: Generic Platform OHCI controller [ 3.387725] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2 [ 3.387884] ohci-platform 1c1a400.usb: irq 28, io mem 0x01c1a400 [ 3.460115] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 3.460136] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.460155] usb usb2: Product: Generic Platform OHCI controller [ 3.460171] usb usb2: Manufacturer: Linux 4.14.18-sunxi ohci_hcd [ 3.460187] usb usb2: SerialNumber: 1c1a400.usb [ 3.460602] hub 2-0:1.0: USB hub found [ 3.460646] hub 2-0:1.0: 1 port detected [ 3.461321] usbcore: registered new interface driver usb-storage [ 3.461868] mousedev: PS/2 mouse device common for all mice [ 3.462350] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0 [ 3.462375] sun6i-rtc 1f00000.rtc: RTC enabled [ 3.462565] i2c /dev entries driver [ 3.464598] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) [ 3.465845] sunxi-mmc 1c0f000.mmc: Got CD GPIO [ 3.525964] sunxi-mmc 1c0f000.mmc: base:0xf1005000 irq:25 [ 3.526906] ledtrig-cpu: registered to indicate activity on CPUs [ 3.526990] hidraw: raw HID events driver (C) Jiri Kosina [ 3.527099] usbcore: registered new interface driver usbhid [ 3.527114] usbhid: USB HID core driver [ 3.528010] NET: Registered protocol family 10 [ 3.530080] Segment Routing with IPv6 [ 3.530173] NET: Registered protocol family 17 [ 3.531408] Key type dns_resolver registered [ 3.531751] Registering SWP/SWPB emulation handler [ 3.534336] registered taskstats version 1 [ 3.534354] Loading compiled-in X.509 certificates [ 3.534426] zswap: loaded using pool lzo/zbud [ 3.535994] Btrfs loaded, crc32c=crc32c-generic [ 3.536633] Key type encrypted registered [ 3.543395] ehci-platform 1c1b000.usb: EHCI Host Controller [ 3.543459] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3 [ 3.543938] ehci-platform 1c1b000.usb: irq 29, io mem 0x01c1b000 [ 3.565967] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00 [ 3.566186] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.566206] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.566225] usb usb3: Product: EHCI Host Controller [ 3.566240] usb usb3: Manufacturer: Linux 4.14.18-sunxi ehci_hcd [ 3.566256] usb usb3: SerialNumber: 1c1b000.usb [ 3.566760] hub 3-0:1.0: USB hub found [ 3.566810] hub 3-0:1.0: 1 port detected [ 3.567490] ehci-platform 1c1c000.usb: EHCI Host Controller [ 3.567530] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4 [ 3.567764] ehci-platform 1c1c000.usb: irq 31, io mem 0x01c1c000 [ 3.583518] mmc0: host does not support reading read-only switch, assuming write-enable [ 3.585486] mmc0: new high speed SDHC card at address 1234 [ 3.586055] mmcblk0: mmc0:1234 SA04G 3.64 GiB [ 3.589037] mmcblk0: p1 [ 3.595981] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00 [ 3.596188] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.596208] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.596227] usb usb4: Product: EHCI Host Controller [ 3.596242] usb usb4: Manufacturer: Linux 4.14.18-sunxi ehci_hcd [ 3.596258] usb usb4: SerialNumber: 1c1c000.usb [ 3.596690] hub 4-0:1.0: USB hub found [ 3.596740] hub 4-0:1.0: 1 port detected [ 3.597453] ehci-platform 1c1d000.usb: EHCI Host Controller [ 3.597493] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5 [ 3.597818] ehci-platform 1c1d000.usb: irq 33, io mem 0x01c1d000 [ 3.625954] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00 [ 3.626135] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.626155] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.626174] usb usb5: Product: EHCI Host Controller [ 3.626189] usb usb5: Manufacturer: Linux 4.14.18-sunxi ehci_hcd [ 3.626205] usb usb5: SerialNumber: 1c1d000.usb [ 3.626633] hub 5-0:1.0: USB hub found [ 3.626680] hub 5-0:1.0: 1 port detected [ 3.627308] ohci-platform 1c1b400.usb: Generic Platform OHCI controller [ 3.627346] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6 [ 3.627503] ohci-platform 1c1b400.usb: irq 30, io mem 0x01c1b400 [ 3.700104] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001 [ 3.700126] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.700146] usb usb6: Product: Generic Platform OHCI controller [ 3.700162] usb usb6: Manufacturer: Linux 4.14.18-sunxi ohci_hcd [ 3.700178] usb usb6: SerialNumber: 1c1b400.usb [ 3.700593] hub 6-0:1.0: USB hub found [ 3.700639] hub 6-0:1.0: 1 port detected [ 3.701236] ohci-platform 1c1c400.usb: Generic Platform OHCI controller [ 3.701273] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7 [ 3.701452] ohci-platform 1c1c400.usb: irq 32, io mem 0x01c1c400 [ 3.770109] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001 [ 3.770131] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.770151] usb usb7: Product: Generic Platform OHCI controller [ 3.770166] usb usb7: Manufacturer: Linux 4.14.18-sunxi ohci_hcd [ 3.770182] usb usb7: SerialNumber: 1c1c400.usb [ 3.770600] hub 7-0:1.0: USB hub found [ 3.770652] hub 7-0:1.0: 1 port detected [ 3.771253] ohci-platform 1c1d400.usb: Generic Platform OHCI controller [ 3.771297] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8 [ 3.771458] ohci-platform 1c1d400.usb: irq 34, io mem 0x01c1d400 [ 3.840099] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001 [ 3.840120] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.840140] usb usb8: Product: Generic Platform OHCI controller [ 3.840156] usb usb8: Manufacturer: Linux 4.14.18-sunxi ohci_hcd [ 3.840172] usb usb8: SerialNumber: 1c1d400.usb [ 3.840606] hub 8-0:1.0: USB hub found [ 3.840654] hub 8-0:1.0: 1 port detected [ 3.841297] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator [ 3.841633] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver [ 3.841657] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 9 [ 3.841880] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.841900] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.841919] usb usb9: Product: MUSB HDRC host driver [ 3.841934] usb usb9: Manufacturer: Linux 4.14.18-sunxi musb-hcd [ 3.841950] usb usb9: SerialNumber: musb-hdrc.1.auto [ 3.842355] hub 9-0:1.0: USB hub found [ 3.842405] hub 9-0:1.0: 1 port detected [ 3.843666] of_cfs_init [ 3.843758] of_cfs_init: OK [ 3.843897] vdd-cpux-dummy: disabling [ 3.843912] vcc3v0: disabling [ 3.843926] vcc5v0: disabling [ 3.843937] usb0-vbus: disabling [ 3.856709] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) [ 3.856774] VFS: Mounted root (ext4 filesystem) readonly on device 179:1. [ 3.865046] devtmpfs: mounted [ 3.867857] Freeing unused kernel memory: 1024K [ 4.549421] systemd[1]: RTC configured in localtime, applying delta of 120 minutes to system time. [ 4.549491] systemd[1]: System time before build time, advancing clock. [ 4.581317] ip_tables: (C) 2000-2006 Netfilter Core Team [ 4.600325] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN) [ 4.600799] systemd[1]: Detected architecture arm. [ 4.611139] systemd[1]: Set hostname to <orangepipc>. [ 5.338479] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ 5.339371] systemd[1]: Listening on Journal Socket. [ 5.340522] systemd[1]: Created slice System Slice. [ 5.347430] systemd[1]: Starting Load Kernel Modules... [ 5.351275] systemd[1]: Starting Create list of required static device nodes for the current kernel... [ 5.357225] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 5.363548] systemd[1]: Listening on Journal Socket (/dev/log). [ 5.607308] EXT4-fs (mmcblk0p1): re-mounted. Opts: data=writeback,commit=600,errors=remount-ro [ 6.273030] Adding 131068k swap on /var/swap. Priority:-2 extents:1 across:131068k SSFS [ 6.627563] systemd-journald[137]: Received request to flush runtime journal from PID 1 [ 8.577871] thermal thermal_zone0: failed to read out thermal zone (-110) [ 8.601704] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 8.601733] [drm] No driver support for vblank timestamp query. [ 8.612950] sun4i-drm display-engine: bound 1100000.mixer (ops sun8i_mixer_platform_driver_exit [sun8i_mixer]) [ 8.613222] sun4i-drm display-engine: No panel or bridge found... RGB output disabled [ 8.613258] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops sun4i_tcon_platform_driver_exit [sun4i_tcon]) [ 8.791545] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17 [ 8.791598] thermal thermal_zone0: failed to read out thermal zone (-110) [ 8.927492] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy) [ 8.929094] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver [ 8.929431] sun4i-drm display-engine: bound 1ee0000.hdmi (ops sun8i_dw_hdmi_ops [sun8i_dw_hdmi]) [ 8.929486] [drm] Cannot find any crtc or sizes [ 8.929840] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0 [ 9.215371] lirc_dev: IR Remote Control driver registered, major 243 [ 9.221376] IR LIRC bridge handler initialized [ 9.221991] Registered IR keymap rc-empty [ 9.222105] rc rc0: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0 [ 9.222237] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0/input0 [ 9.237321] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-ir) registered at minor = 0 [ 9.237458] sunxi-ir 1f02000.ir: initialized sunXi IR driver [ 9.287036] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok [ 9.332154] Generic PHY 0.1:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0.1:01, irq=POLL) [ 9.333546] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available [ 9.333575] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW [ 9.846033] thermal thermal_zone0: failed to read out thermal zone (-110) [ 10.006147] [drm] Cannot find any crtc or sizes [ 11.446669] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off [ 12.184385] random: crng init done ### lsusb: Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 1.10 bDeviceClass 9 Hub bDeviceSubClass 0 Unused bDeviceProtocol 0 Full speed (or root) hub bMaxPacketSize0 64 idVendor 0x1d6b Linux Foundation idProduct 0x0001 1.1 root hub bcdDevice 4.14 iManufacturer 3 Linux 4.14.18-sunxi ohci_hcd iProduct 2 Generic Platform OHCI controller iSerial 1 1c1d400.usb bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 25 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xe0 Self Powered Remote Wakeup MaxPower 0mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 9 Hub bInterfaceSubClass 0 Unused bInterfaceProtocol 0 Full speed (or root) hub iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0002 1x 2 bytes bInterval 255 Hub Descriptor: bLength 9 bDescriptorType 41 nNbrPorts 1 wHubCharacteristic 0x0012 No power switching (usb 1.0) No overcurrent protection bPwrOn2PwrGood 2 * 2 milli seconds bHubContrCurrent 0 milli Ampere DeviceRemovable 0x00 PortPwrCtrlMask 0xff Hub Port Status: Port 1: 0000.0100 power Device Status: 0x0001 Self Powered Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 9 Hub bDeviceSubClass 0 Unused bDeviceProtocol 0 Full speed (or root) hub bMaxPacketSize0 64 idVendor 0x1d6b Linux Foundation idProduct 0x0002 2.0 root hub bcdDevice 4.14 iManufacturer 3 Linux 4.14.18-sunxi ehci_hcd iProduct 2 EHCI Host Controller iSerial 1 1c1d000.usb bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 25 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xe0 Self Powered Remote Wakeup MaxPower 0mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 9 Hub bInterfaceSubClass 0 Unused bInterfaceProtocol 0 Full speed (or root) hub iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0004 1x 4 bytes bInterval 12 Hub Descriptor: bLength 9 bDescriptorType 41 nNbrPorts 1 wHubCharacteristic 0x000a No power switching (usb 1.0) Per-port overcurrent protection bPwrOn2PwrGood 10 * 2 milli seconds bHubContrCurrent 0 milli Ampere DeviceRemovable 0x00 PortPwrCtrlMask 0xff Hub Port Status: Port 1: 0000.0100 power Device Status: 0x0001 Self Powered Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 1.10 bDeviceClass 9 Hub bDeviceSubClass 0 Unused bDeviceProtocol 0 Full speed (or root) hub bMaxPacketSize0 64 idVendor 0x1d6b Linux Foundation idProduct 0x0001 1.1 root hub bcdDevice 4.14 iManufacturer 3 Linux 4.14.18-sunxi ohci_hcd iProduct 2 Generic Platform OHCI controller iSerial 1 1c1c400.usb bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 25 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xe0 Self Powered Remote Wakeup MaxPower 0mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 9 Hub bInterfaceSubClass 0 Unused bInterfaceProtocol 0 Full speed (or root) hub iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0002 1x 2 bytes bInterval 255 Hub Descriptor: bLength 9 bDescriptorType 41 nNbrPorts 1 wHubCharacteristic 0x0012 No power switching (usb 1.0) No overcurrent protection bPwrOn2PwrGood 2 * 2 milli seconds bHubContrCurrent 0 milli Ampere DeviceRemovable 0x00 PortPwrCtrlMask 0xff Hub Port Status: Port 1: 0000.0100 power Device Status: 0x0001 Self Powered Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 9 Hub bDeviceSubClass 0 Unused bDeviceProtocol 0 Full speed (or root) hub bMaxPacketSize0 64 idVendor 0x1d6b Linux Foundation idProduct 0x0002 2.0 root hub bcdDevice 4.14 iManufacturer 3 Linux 4.14.18-sunxi ehci_hcd iProduct 2 EHCI Host Controller iSerial 1 1c1c000.usb bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 25 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xe0 Self Powered Remote Wakeup MaxPower 0mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 9 Hub bInterfaceSubClass 0 Unused bInterfaceProtocol 0 Full speed (or root) hub iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0004 1x 4 bytes bInterval 12 Hub Descriptor: bLength 9 bDescriptorType 41 nNbrPorts 1 wHubCharacteristic 0x000a No power switching (usb 1.0) Per-port overcurrent protection bPwrOn2PwrGood 10 * 2 milli seconds bHubContrCurrent 0 milli Ampere DeviceRemovable 0x00 PortPwrCtrlMask 0xff Hub Port Status: Port 1: 0000.0100 power Device Status: 0x0001 Self Powered Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 1.10 bDeviceClass 9 Hub bDeviceSubClass 0 Unused bDeviceProtocol 0 Full speed (or root) hub bMaxPacketSize0 64 idVendor 0x1d6b Linux Foundation idProduct 0x0001 1.1 root hub bcdDevice 4.14 iManufacturer 3 Linux 4.14.18-sunxi ohci_hcd iProduct 2 Generic Platform OHCI controller iSerial 1 1c1b400.usb bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 25 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xe0 Self Powered Remote Wakeup MaxPower 0mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 9 Hub bInterfaceSubClass 0 Unused bInterfaceProtocol 0 Full speed (or root) hub iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0002 1x 2 bytes bInterval 255 Hub Descriptor: bLength 9 bDescriptorType 41 nNbrPorts 1 wHubCharacteristic 0x0012 No power switching (usb 1.0) No overcurrent protection bPwrOn2PwrGood 2 * 2 milli seconds bHubContrCurrent 0 milli Ampere DeviceRemovable 0x00 PortPwrCtrlMask 0xff Hub Port Status: Port 1: 0000.0100 power Device Status: 0x0001 Self Powered Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 9 Hub bDeviceSubClass 0 Unused bDeviceProtocol 0 Full speed (or root) hub bMaxPacketSize0 64 idVendor 0x1d6b Linux Foundation idProduct 0x0002 2.0 root hub bcdDevice 4.14 iManufacturer 3 Linux 4.14.18-sunxi ehci_hcd iProduct 2 EHCI Host Controller iSerial 1 1c1b000.usb bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 25 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xe0 Self Powered Remote Wakeup MaxPower 0mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 9 Hub bInterfaceSubClass 0 Unused bInterfaceProtocol 0 Full speed (or root) hub iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0004 1x 4 bytes bInterval 12 Hub Descriptor: bLength 9 bDescriptorType 41 nNbrPorts 1 wHubCharacteristic 0x000a No power switching (usb 1.0) Per-port overcurrent protection bPwrOn2PwrGood 10 * 2 milli seconds bHubContrCurrent 0 milli Ampere DeviceRemovable 0x00 PortPwrCtrlMask 0xff Hub Port Status: Port 1: 0000.0100 power Device Status: 0x0001 Self Powered Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 1.10 bDeviceClass 9 Hub bDeviceSubClass 0 Unused bDeviceProtocol 0 Full speed (or root) hub bMaxPacketSize0 64 idVendor 0x1d6b Linux Foundation idProduct 0x0001 1.1 root hub bcdDevice 4.14 iManufacturer 3 Linux 4.14.18-sunxi ohci_hcd iProduct 2 Generic Platform OHCI controller iSerial 1 1c1a400.usb bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 25 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xe0 Self Powered Remote Wakeup MaxPower 0mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 9 Hub bInterfaceSubClass 0 Unused bInterfaceProtocol 0 Full speed (or root) hub iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0002 1x 2 bytes bInterval 255 Hub Descriptor: bLength 9 bDescriptorType 41 nNbrPorts 1 wHubCharacteristic 0x0012 No power switching (usb 1.0) No overcurrent protection bPwrOn2PwrGood 2 * 2 milli seconds bHubContrCurrent 0 milli Ampere DeviceRemovable 0x00 PortPwrCtrlMask 0xff Hub Port Status: Port 1: 0000.0100 power Device Status: 0x0001 Self Powered Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 9 Hub bDeviceSubClass 0 Unused bDeviceProtocol 0 Full speed (or root) hub bMaxPacketSize0 64 idVendor 0x1d6b Linux Foundation idProduct 0x0002 2.0 root hub bcdDevice 4.14 iManufacturer 3 Linux 4.14.18-sunxi ehci_hcd iProduct 2 EHCI Host Controller iSerial 1 1c1a000.usb bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 25 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xe0 Self Powered Remote Wakeup MaxPower 0mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 9 Hub bInterfaceSubClass 0 Unused bInterfaceProtocol 0 Full speed (or root) hub iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0004 1x 4 bytes bInterval 12 Hub Descriptor: bLength 9 bDescriptorType 41 nNbrPorts 1 wHubCharacteristic 0x000a No power switching (usb 1.0) Per-port overcurrent protection bPwrOn2PwrGood 10 * 2 milli seconds bHubContrCurrent 0 milli Ampere DeviceRemovable 0x00 PortPwrCtrlMask 0xff Hub Port Status: Port 1: 0000.0100 power Device Status: 0x0001 Self Powered Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 9 Hub bDeviceSubClass 0 Unused bDeviceProtocol 1 Single TT bMaxPacketSize0 64 idVendor 0x1d6b Linux Foundation idProduct 0x0002 2.0 root hub bcdDevice 4.14 iManufacturer 3 Linux 4.14.18-sunxi musb-hcd iProduct 2 MUSB HDRC host driver iSerial 1 musb-hdrc.1.auto bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 25 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xe0 Self Powered Remote Wakeup MaxPower 0mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 9 Hub bInterfaceSubClass 0 Unused bInterfaceProtocol 0 Full speed (or root) hub iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0004 1x 4 bytes bInterval 12 Hub Descriptor: bLength 9 bDescriptorType 41 nNbrPorts 1 wHubCharacteristic 0x0011 Per-port power switching No overcurrent protection TT think time 8 FS bits bPwrOn2PwrGood 5 * 2 milli seconds bHubContrCurrent 0 milli Ampere DeviceRemovable 0x02 PortPwrCtrlMask 0xff Hub Port Status: Port 1: 0000.0100 power Device Status: 0x0001 Self Powered ### lscpu: Architecture: armv7l Byte Order: Little Endian CPU(s): 4 On-line CPU(s) list: 0 Off-line CPU(s) list: 1-3 Thread(s) per core: 1 Core(s) per socket: 1 Socket(s): 1 Model: 5 Model name: ARMv7 Processor rev 5 (v7l) CPU max MHz: 1296.0000 CPU min MHz: 240.0000 BogoMIPS: 61.71 Flags: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm ### cpuinfo: processor : 0 model name : ARMv7 Processor rev 5 (v7l) BogoMIPS : 61.71 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x0 CPU part : 0xc07 CPU revision : 5 Hardware : Allwinner sun8i Family Revision : 0000 Serial : 02c000814730dc30 ### meminfo: MemTotal: 1024516 kB MemFree: 912940 kB MemAvailable: 946804 kB Buffers: 12708 kB Cached: 45776 kB SwapCached: 0 kB Active: 42788 kB Inactive: 28716 kB Active(anon): 13176 kB Inactive(anon): 14088 kB Active(file): 29612 kB Inactive(file): 14628 kB Unevictable: 0 kB Mlocked: 0 kB HighTotal: 262144 kB HighFree: 191588 kB LowTotal: 762372 kB LowFree: 721352 kB SwapTotal: 131068 kB SwapFree: 131068 kB Dirty: 68 kB Writeback: 0 kB AnonPages: 12992 kB Mapped: 14680 kB Shmem: 14284 kB Slab: 21580 kB SReclaimable: 11448 kB SUnreclaim: 10132 kB KernelStack: 776 kB PageTables: 660 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 643324 kB Committed_AS: 65564 kB VmallocTotal: 245760 kB VmallocUsed: 0 kB VmallocChunk: 0 kB CmaTotal: 65536 kB CmaFree: 61868 kB ### interrupts: CPU0 17: 0 GIC-0 50 Level /soc/timer@01c20c00 20: 2595 GIC-0 27 Level arch_timer 22: 0 GIC-0 120 Level 1ee0000.hdmi, dw-hdmi-cec 23: 0 GIC-0 82 Level 1c02000.dma-controller 24: 0 GIC-0 118 Level 1c0c000.lcd-controller 25: 6677 GIC-0 92 Level sunxi-mmc 26: 0 GIC-0 103 Level musb-hdrc.1.auto 27: 0 GIC-0 104 Level ehci_hcd:usb1 28: 0 GIC-0 105 Level ohci_hcd:usb2 29: 0 GIC-0 106 Level ehci_hcd:usb3 30: 0 GIC-0 107 Level ohci_hcd:usb6 31: 0 GIC-0 108 Level ehci_hcd:usb4 32: 0 GIC-0 109 Level ohci_hcd:usb7 33: 0 GIC-0 110 Level ehci_hcd:usb5 34: 0 GIC-0 111 Level ohci_hcd:usb8 38: 6 GIC-0 114 Level eth0 43: 0 GIC-0 72 Level 1f00000.rtc 45: 0 GIC-0 69 Level sunxi-ir 46: 502 GIC-0 76 Level mv64xxx_i2c 99: 1 sunxi_pio_edge 44 Edge usb0-id-det IPI0: 0 CPU wakeup interrupts IPI1: 0 Timer broadcast interrupts IPI2: 0 Rescheduling interrupts IPI3: 0 Function call interrupts IPI4: 0 CPU stop interrupts IPI5: 444 IRQ work interrupts IPI6: 0 completion interrupts Err: 0 ### ifconfig: eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.1.66 netmask 255.255.255.0 broadcast 192.168.1.255 ether 02:81:47:30:dc:30 txqueuelen 1000 (Ethernet) RX packets 6 bytes 426 (426.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 5 bytes 222 (222.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 38 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 loop txqueuelen 1000 (Local Loopback) RX packets 48 bytes 3888 (3.7 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 48 bytes 3888 (3.7 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 ### df: Filesystem Size Used Avail Use% Mounted on /dev/root 3.6G 1.9G 1.6G 56% / devtmpfs 468M 0 468M 0% /dev tmpfs 501M 0 501M 0% /dev/shm tmpfs 501M 14M 487M 3% /run tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 501M 0 501M 0% /sys/fs/cgroup tmpfs 256M 24K 256M 1% /tmp ### mmc0:1234 info: manfid: 0x000002 cid: 02544d53413034471137dfea6300db83 fwrev: 0x1 csd: 400e00325b5900001d177f800a40008d ocr: 0x00200000 type: SD date: 11/2013 hwrev: 0x1 dsr: 0x404 serial: 0x37dfea63 erase_size: 512 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SA04G MODALIAS=mmc:block ssr: 00000000020000000202900100aa0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 scr: 0235800001000000 oemid: 0x544d preferred_erase_size: 4194304 name: SA04G Link to comment Share on other sites More sharing options...
Igor Posted February 27, 2018 Share Posted February 27, 2018 Not really an Armbian issue but more a generic problem. Check this commit: https://github.com/armbian/config/commit/fad1fc34a5eccf0c64ad5636797ab658812636ad Link to comment Share on other sites More sharing options...
lampra Posted March 1, 2018 Author Share Posted March 1, 2018 Hi thank you for the answer. As a workaround for the moment, I am setting the dns server at root crontab after reboot with a delay of 60 seconds. Link to comment Share on other sites More sharing options...
