I am trying to have a serial link between an arduino and a banana pi.
As a basic test, the Arduino is sending "hello" every seconds.
I observe that the reception by the Banana pi is not good. I have tried , several baud rates, /dev/ttyS2 and FTDi adaptor.
The best result seems to be with  the FTDI adapter , at 115200 bps. But I have still a lot of errors, see below.
When I plug the FTDI adapter on my laptop, it works without issues.
Do you know what could be the cause of my issues?
Thank you
Sebastien
hell»½ýhgn·ïÏÞh»½ëèu·oÝÕýemmÍÿÿý¿¿ëÏÿÿýïï»ÿ½{í»ÿ¯nïÿý{¿ûoïÿÿÿÝÿïÏíumío^huw·oMÕhello
hello
hello
hello
hello
hello
hello
hello
hello
^hÛ·mÍïèunìïýj»û»ÿ¯ÿï{¯ÿÿïoõõooëÿÿûÿÿ÷ÿëîÿhÙ·no]Õhello
hello
hello
hello
hello
hello
hello
hello
hello
·hÝï·»íýìõímo¯ÿ~Ý··¿ÿÿ}Ý··ï½ýÿwïÿ¿ÿ×ÿÿÿÿ¿ÿûûÿÿíÿ÷ÿo¿¿ÞýlenloµhenloMNhello
hello
hello
hello
hello
hello
hello
hello
hello
hello
hello«h7ë{ë¿èåímo¯¯êõ}·»_ÿíõ»Oÿ¿óíïíïïûûëï¿ûýÿûÿÿÿïïýxu|loMÞhello
hello
hello
hello
hello
hello
hello
hello
hello
hello
hel·ë¯ÿheomïÍýèïo»ïÿîû÷mëïÿÿwûßÿÝÿÿýï¿ëê¯ÿûoÿûÿÿïïÿìo7|oÍõhullo
Is your Arduino using 5V levels? If so, you need a level shifter to not damage your Banana PI which uses 3.3V levels...
21 minutes ago, sebastien35 said:
On the FTDI USB adapter, I can select 3.3 or 5V.
With 5 V , I have the result posted previously.
With 3.3V, it is worst
Is GND securely connected at both ends? I got problems like this when my GND wasnt seated correctly and only TX,RX was connected.
And how long are the TTL-cables - maybe not enough shielding?
How does the arduino and the Babana Pi gets his power?
Thanks a lot! GND was not connected on the USB adapter! Now, with GND connected, it is perfect!
And what about the use of /dev/ttyS2? Do you confirm that I have to use 3.3 level. I can't test it for now because I haven't level adapters.
