just bought a HC1 and tryin to setup Armbian. I installed Armbian_5.37_Odroidxu4_Ubuntu_xenial_next_4.9.71, works with SDHC. Now I put in my ADATA SP550 (480GB) SSD, but something fails, see dmesg:
[    5.096332] r8152 6-1:1.0 eth0: v1.08.8
[    5.118014] r8152 6-1:1.0 enx001e06326386: renamed from eth0
[    5.207225] usb 4-1: new SuperSpeed USB device number 2 using xhci-hcd
[    5.228766] usb 4-1: New USB device found, idVendor=152d, idProduct=0578
[    5.228786] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    5.228802] usb 4-1: Product: USB to SATA bridge
[    5.228817] usb 4-1: Manufacturer: JMicron
[    5.228831] usb 4-1: SerialNumber: DB00000000013B
[    5.273348] scsi host0: uas
[    5.275764] scsi 0:0:0:0: Direct-Access     JMicron                   3101 PQ: 0 ANSI: 6
[    5.322900] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    5.323056] sd 0:0:0:0: [sda] 937703088 512-byte logical blocks: (480 GB/447 GiB)
[    5.323064] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    5.323514] usbcore: registered new interface driver uas
[    5.324347] sd 0:0:0:0: [sda] Write Protect is off
[    5.324357] sd 0:0:0:0: [sda] Mode Sense: 53 00 00 08
[    5.324785] sd 0:0:0:0: [sda] Disabling FUA
[    5.324793] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    5.331160]  sda: sda1
[    5.334111] sd 0:0:0:0: [sda] Attached SCSI disk
[    5.758357] random: crng init done
[    7.360460] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null)
[    7.610620] systemd[1]: System time before build time, advancing clock.
[   11.742404] r8152 6-1:1.0 enx001e06326386: carrier on
[   11.742490] IPv6: ADDRCONF(NETDEV_CHANGE): enx001e06326386: link becomes ready
[   27.691905] sd 0:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
[   27.691914] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x85 85 08 0e 00 00 00 01 00 00 00 00 00 00 40 ec 00
[   49.115485] sd 0:0:0:0: tag#1 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD
[   49.115495] sd 0:0:0:0: tag#1 CDB: opcode=0x0 00 00 00 00 00 00
[   49.115510] scsi host0: uas_eh_bus_reset_handler start
[   49.235138] usb 4-1: reset SuperSpeed USB device number 2 using xhci-hcd
[   49.257848] scsi host0: uas_eh_bus_reset_handler success
[   64.488972] sd 0:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
[   64.488981] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x85 85 08 0e 00 00 00 01 00 00 00 00 00 00 40 a1 00
[   64.489068] scsi host0: uas_eh_bus_reset_handler start
[   66.078913] usb usb4-port1: Cannot enable. Maybe the USB cable is bad?
[   66.078923] xhci-hcd xhci-hcd.2.auto: Cannot set link state.
[   66.078949] usb usb4-port1: cannot disable (err = -32)
[   67.878822] usb usb4-port1: Cannot enable. Maybe the USB cable is bad?
[   67.878831] xhci-hcd xhci-hcd.2.auto: Cannot set link state.
[   67.878856] usb usb4-port1: cannot disable (err = -32)
[   69.888724] usb usb4-port1: Cannot enable. Maybe the USB cable is bad?
[   69.888735] xhci-hcd xhci-hcd.2.auto: Cannot set link state.
[   69.888762] usb usb4-port1: cannot disable (err = -32)
[   71.693639] usb usb4-port1: Cannot enable. Maybe the USB cable is bad?
[   71.693653] xhci-hcd xhci-hcd.2.auto: Cannot set link state.
[   71.693686] usb usb4-port1: cannot disable (err = -32)
[   71.693699] xhci-hcd xhci-hcd.2.auto: Cannot set link state.
[   71.693722] usb usb4-port1: cannot disable (err = -32)
[   71.693737] scsi host0: uas_post_reset: alloc streams error -19 after reset
[   71.693853] usb 4-1: USB disconnect, device number 2
[   71.695774] sd 0:0:0:0: [sda] Synchronizing SCSI cache
There is no device for the SSD, therefor no installation to SATA possible.
Any suggestions?? Power is ok (5V, 4A), SSD works fine on my desktop, without any hassles.
UPDATE: I've tried another SSD (WD Green, 120GB) which seems to work without problems. Only a little bit too small... Are there any known issues with HC1+Armbian+ADATA?
I did the FW-update mentioned at https://wiki.odroid.com/odroid-xu4/software/jms578_fw_update (with WD-Green attached), but after switching back to the ADATA SP550 dmesg shows this two messages over and over again:
[  559.347071] scsi 0:0:0:1: tag#0 sense submit err -19 uas-tag 1 inflight: s-st a-in s-in a-cmd s-cmd
[  559.347077] scsi 0:0:0:1: tag#0 CDB: opcode=0x12 12 00 00 00 24 00
And CPU-Load is ~12%, wtih nothing running.
Replacing the ADATA with the WD-Green and everything is ok again.
25 minutes ago, tkaiser said:
In case you can measure/monitor voltage available to HC1/SSD you should do this. Most probably just the usual 'powered with 5V' sh*t show almost all SBC are affected with.
I did, 5.14V directly at SATA-Connector. Just installed original Odroid Ubuntu 16.04.3 LTS  with 4.14 kernel and my ADATA works!  Kernel issue?
Maybe. There's one change wrt UAS between 4.9 and 4.14 but shouldn't apply here. Can you provide debug output please?
sudo armbianmonitor -u
OK, tried  Armbian_5.38_Odroidxu4_Ubuntu_xenial_next_4.14.15 from archive/wrongf,  gave me same errors as Armbian 5.37 with Kernel 4.9: with ADATA SP550 no device found.
debug: http://ix.io/Xae
On 14.3.2018 at 11:16 PM, alex996 said:
So ganz nebenbei: Danke für deine Hilfe. Ich nehme an auf Deutsch unterhalten ist hier nicht gern gesehen?
IMO depends on topic, for off-topic stuff, german is fine (even @TonyMac32 understands now what a 'Eierlegende Wollmilchsau' is... :D )... It doesn't make sense for stuff related to the topic cause not everyone will understand it and the information is probably lost for those not able to understand 'ze germans'... :P
;-) A joke of course. I do not mind some German, of course I can read it, so that makes it less distracting.
