Hello.
Thank you for your great effort.
I'm using CubieTruck, and I installed Debian Jessie(Armbian, of course), and make it boot from Nand. It was successful.
However, if I insert sd card into the slot, CubieTruck won't boot.
Isn't it possible to boot from nand while sd card is inserted?
I want mount the SD card to /home directory. (Using USB slot works.)
Thanks in advance!
I can prove, that your intended setup is working on my CubieTruck and also on the CubieBoard2:
I'm booting Armbian from NAND and a SDCARD, a HDD and USB drives can be mounted as expected.
