stretto Posted March 23, 2018 Posted March 23, 2018 Hello, I've flashed my SD card with Armbian_5.41_Orangepiwin_Ubuntu_xenial_default_3.10.107_desktop and after booting the system everything works like a charm except my sound which I've tried to get through the 3.5mm jack. I've done upgrade && update but that doesn't seem to help. I've tried several headphones and speakers and none of them worked. On top of that I've tried flashing this image file on one other microSD card and I've tried running it on another Opi Win Plus board since I have several of them lying around my house. Regarding my power supply, it's 5V 3A which I've read is the appropriate one. I'm fairly new to Linux with really limited knowledge of how everything works here, so I would really appreciate some help in solving this issue. Also, if it gives you any clues what could be the cause of problem, when playing videos on YT on Chromium all of them seem to lag a lot. They just don't have that fluidness you need to watch any video. On Firefox is a different story - videos play ok there but there is still no sound there either. When I type aplay -l I get this **** List of PLAYBACK Hardware Devices **** card 0: sndhdmi [sndhdmi], device 0: SUNXI-HDMIAUDIO sndhdmi-0 [] Subdevices: 1/1 Subdevice #0: subdevice #0 and aplay -L gives me this output null Discard all samples (playback) or generate zero samples (capture) pulse PulseAudio Sound Server default Playback/recording through the PulseAudio sound server sysdefault:CARD=sndhdmi sndhdmi, Default Audio Device dmix:CARD=sndhdmi,DEV=0 sndhdmi, Direct sample mixing device dsnoop:CARD=sndhdmi,DEV=0 sndhdmi, Direct sample snooping device hw:CARD=sndhdmi,DEV=0 sndhdmi, Direct hardware device without any conversions plughw:CARD=sndhdmi,DEV=0 sndhdmi, Hardware device with all software conversions Help, please!
stretto Posted April 5, 2018 Author Posted April 5, 2018 Nobody have any idea how to solve this issue?
chwe Posted April 5, 2018 Posted April 5, 2018 (edited) https://github.com/armbian/sunxi-DT-overlays/blob/master/sun50i-h5/sun50i-h5-analog-codec.dts from: https://github.com/armbian/sunxi-DT-overlays/tree/master/sun50i-h5 might be a starting point Edit: And probably this one too: https://docs.armbian.com/Hardware_Allwinner_overlays/ Edited April 5, 2018 by chwe overseen legacy kernel
zador.blood.stained Posted April 5, 2018 Posted April 5, 2018 13 minutes ago, chwe said: might be a starting point Not for the legacy kernel 1
chwe Posted April 5, 2018 Posted April 5, 2018 Shame on me, I completely missed that we provide legacy kernels for A64 boards and overseen that @stretto uses a legacy image... Maybe read through this one: https://forum.pine64.org/showthread.php?tid=2309 Could therefore be a starting point...
zador.blood.stained Posted April 5, 2018 Posted April 5, 2018 Since it's not listed in /proc/asound/cards most likely something is wrong with the DT (assuming sound currently works on other A64 devices with the same kernel version).
lemonahmas Posted September 30, 2018 Posted September 30, 2018 and...this build won't work too, as my board is orangepi win plus. sad, the DT do need some help. Linux orangepiwin 3.10.107-pine64 #33 SMP PREEMPT Wed Sep 19 13:03:51 CEST 2018 aarch64 aarch64 aarch64 GNU/Linux
