freak Posted March 26, 2018 Posted March 26, 2018 Is there a way to upgrade from an earlier version to 5.41?
chwe Posted March 26, 2018 Posted March 26, 2018 https://docs.armbian.com Quote Upgrades are done via standard apt-get upgrade method I don't know if 5.41 is available through apt.armbian.com or only via beta.armbian.com (which means change to nightly...).
freak Posted March 27, 2018 Author Posted March 27, 2018 I'm talking about a version upgrade like do-release-upgrade does. I have a tinker running 5.33 and nothing I do will make it go to anything higher.
Igor Posted March 27, 2018 Posted March 27, 2018 3 hours ago, freak said: I have a tinker running 5.33 and nothing I do will make it go to anything higher. Hmm. Perhaps you have frozen kernel upgrade? Type this: apt-mark showhold
freak Posted March 27, 2018 Author Posted March 27, 2018 Spoiler |_ _(_)_ __ | | _____ _ __| |__ ___ __ _ _ __ __| | | | | | '_ \| |/ / _ \ '__| '_ \ / _ \ / _` | '__/ _` | | | | | | | | < __/ | | |_) | (_) | (_| | | | (_| | |_| |_|_| |_|_|\_\___|_| |_.__/ \___/ \__,_|_| \__,_| Welcome to ARMBIAN 5.40 user-built Ubuntu 16.04.3 LTS 4.4.115-rockchip System load: 0.08 0.06 0.01 Up time: 3:43 hours Memory usage: 15 % of 2011MB IP: 169.254.8.77 10.0.1.236 CPU temp: 55°C Usage of /: 8% of 29G [ 0 security updates available, 40 updates total: apt upgrade ] Last check: 2018-03-27 08:49 Last login: Tue Mar 6 12:58:20 2018 from 10.0.1.217 armbian@term69:~$ apt-mark showhold armbian@term69:~$ sudo -i [sudo] password for armbian: root@term69:~# apt-mark showhold root@term69:~# apt upgrade Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done The following packages were automatically installed and are no longer required: dnsmasq-base libmm-glib0 libndp0 libnetfilter-conntrack3 Use 'sudo apt autoremove' to remove them. The following packages will be upgraded: apt apt-transport-https apt-utils base-files dpkg dpkg-dev initramfs-tools initramfs-tools-bin initramfs-tools-core isc-dhcp-client isc-dhcp-common libapparmor1 libapt-inst2.0 libapt-pkg5.0 libdpkg-perl libgcrypt20 libnss-myhostname libpam-systemd libpci3 libpulse-mainloop-glib0 libpulse0 libpulsedsp libsystemd0 libudev1 linux-dtb-rockchip linux-firmware linux-image-rockchip ntp numix-gtk-theme pciutils pulseaudio pulseaudio-module-bluetooth pulseaudio-module-gconf pulseaudio-module-zeroconf pulseaudio-utils python-apt-common python3-apt systemd systemd-sysv udev 40 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 70.1 MB of archives. After this operation, 2,841 kB of additional disk space will be used. Do you want to continue? [Y/n] Get:1 http://ports.ubuntu.com xenial-updates/main armhf base-files armhf 9.4ubuntu4.6 [66.7 kB] Get:2 http://apt.armbian.com xenial/main armhf linux-dtb-rockchip armhf 5.41 [111 kB] Get:3 http://ports.ubuntu.com xenial-updates/main armhf dpkg armhf 1.18.4ubuntu1.4 [1,984 kB] Get:4 http://apt.armbian.com xenial/main armhf linux-image-rockchip armhf 5.41 [12.4 MB] Get:5 http://ports.ubuntu.com xenial-updates/main armhf libapt-pkg5.0 armhf 1.2.26 [649 kB] Get:6 http://ports.ubuntu.com xenial-updates/main armhf libapt-inst2.0 armhf 1.2.26 [53.3 kB] Get:7 http://ports.ubuntu.com xenial-updates/main armhf apt armhf 1.2.26 [1,015 kB] Get:8 http://ports.ubuntu.com xenial-updates/main armhf apt-utils armhf 1.2.26 [186 kB] Get:9 http://apt.armbian.com xenial/main armhf numix-gtk-theme all 2.6.7+670~201710270712~ubuntu17.10.1 [129 kB] Get:10 http://ports.ubuntu.com xenial-updates/main armhf libsystemd0 armhf 229-4ubuntu21.2 [187 kB] Get:11 http://ports.ubuntu.com xenial-updates/main armhf libpam-systemd armhf 229-4ubuntu21.2 [104 kB] Get:12 http://ports.ubuntu.com xenial-updates/main armhf libnss-myhostname armhf 229-4ubuntu21.2 [32.5 kB] Get:13 http://ports.ubuntu.com xenial-updates/main armhf systemd armhf 229-4ubuntu21.2 [3,227 kB] Get:14 http://ports.ubuntu.com xenial-updates/main armhf udev armhf 229-4ubuntu21.2 [963 kB] Get:15 http://ports.ubuntu.com xenial-updates/main armhf libudev1 armhf 229-4ubuntu21.2 [49.1 kB] Get:16 http://ports.ubuntu.com xenial-updates/main armhf initramfs-tools all 0.122ubuntu8.11 [8,590 B] Get:17 http://ports.ubuntu.com xenial-updates/main armhf initramfs-tools-core all 0.122ubuntu8.11 [42.9 kB] Get:18 http://ports.ubuntu.com xenial-updates/main armhf initramfs-tools-bin armhf 0.122ubuntu8.11 [9,288 B] Get:19 http://ports.ubuntu.com xenial-updates/main armhf systemd-sysv armhf 229-4ubuntu21.2 [11.9 kB] Get:20 http://ports.ubuntu.com xenial-updates/main armhf libapparmor1 armhf 2.10.95-0ubuntu2.9 [26.2 kB] Get:21 http://ports.ubuntu.com xenial-updates/main armhf ntp armhf 1:4.2.8p4+dfsg-3ubuntu5.8 [464 kB] Get:22 http://ports.ubuntu.com xenial-updates/main armhf libgcrypt20 armhf 1.6.5-2ubuntu0.4 [305 kB] Get:23 http://ports.ubuntu.com xenial-updates/main armhf isc-dhcp-client armhf 4.3.3-5ubuntu12.10 [202 kB] Get:24 http://ports.ubuntu.com xenial-updates/main armhf isc-dhcp-common armhf 4.3.3-5ubuntu12.10 [105 kB] Get:25 http://ports.ubuntu.com xenial-updates/main armhf apt-transport-https armhf 1.2.26 [23.3 kB] Get:26 http://ports.ubuntu.com xenial-updates/main armhf pciutils armhf 1:3.3.1-1.1ubuntu1.2 [229 kB] Get:27 http://ports.ubuntu.com xenial-updates/main armhf libpci3 armhf 1:3.3.1-1.1ubuntu1.2 [18.6 kB] Get:28 http://ports.ubuntu.com xenial-updates/main armhf python-apt-common all 1.1.0~beta1ubuntu0.16.04.1 [16.0 kB] Get:29 http://ports.ubuntu.com xenial-updates/main armhf python3-apt armhf 1.1.0~beta1ubuntu0.16.04.1 [125 kB] Get:30 http://ports.ubuntu.com xenial-updates/main armhf dpkg-dev all 1.18.4ubuntu1.4 [584 kB] Get:31 http://ports.ubuntu.com xenial-updates/main armhf libdpkg-perl all 1.18.4ubuntu1.4 [195 kB] Get:32 http://ports.ubuntu.com xenial-updates/main armhf pulseaudio-module-bluetooth armhf 1:8.0-0ubuntu3.8 [55.4 kB] Get:33 http://ports.ubuntu.com xenial-updates/universe armhf pulseaudio-module-gconf armhf 1:8.0-0ubuntu3.8 [11.5 kB] Get:34 http://ports.ubuntu.com xenial-updates/universe armhf pulseaudio-module-zeroconf armhf 1:8.0-0ubuntu3.8 [18.7 kB] Get:35 http://ports.ubuntu.com xenial-updates/main armhf libpulsedsp armhf 1:8.0-0ubuntu3.8 [19.5 kB] Get:36 http://ports.ubuntu.com xenial-updates/main armhf pulseaudio-utils armhf 1:8.0-0ubuntu3.8 [49.7 kB] Get:37 http://ports.ubuntu.com xenial-updates/main armhf pulseaudio armhf 1:8.0-0ubuntu3.8 [699 kB] Get:38 http://ports.ubuntu.com xenial-updates/main armhf libpulse-mainloop-glib0 armhf 1:8.0-0ubuntu3.8 [11.0 kB] Get:39 http://ports.ubuntu.com xenial-updates/main armhf libpulse0 armhf 1:8.0-0ubuntu3.8 [215 kB] Get:40 http://ports.ubuntu.com xenial-updates/main armhf linux-firmware all 1.157.17 [45.5 MB] Fetched 70.1 MB in 1min 41s (693 kB/s) Extracting templates from packages: 100% (Reading database ... 70333 files and directories currently installed.) Preparing to unpack .../base-files_9.4ubuntu4.6_armhf.deb ... Unpacking base-files (9.4ubuntu4.6) over (9.4ubuntu4.5) ... Processing triggers for man-db (2.7.5-1) ... Setting up base-files (9.4ubuntu4.6) ... Installing new version of config file /etc/issue ... Installing new version of config file /etc/issue.net ... Installing new version of config file /etc/lsb-release ... (Reading database ... 70333 files and directories currently installed.) Preparing to unpack .../dpkg_1.18.4ubuntu1.4_armhf.deb ... Unpacking dpkg (1.18.4ubuntu1.4) over (1.18.4ubuntu1.3) ... Setting up dpkg (1.18.4ubuntu1.4) ... Processing triggers for man-db (2.7.5-1) ... (Reading database ... 70333 files and directories currently installed.) Preparing to unpack .../libapt-pkg5.0_1.2.26_armhf.deb ... Unpacking libapt-pkg5.0:armhf (1.2.26) over (1.2.25) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... Setting up libapt-pkg5.0:armhf (1.2.26) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... (Reading database ... 70333 files and directories currently installed.) Preparing to unpack .../libapt-inst2.0_1.2.26_armhf.deb ... Unpacking libapt-inst2.0:armhf (1.2.26) over (1.2.25) ... Preparing to unpack .../archives/apt_1.2.26_armhf.deb ... Unpacking apt (1.2.26) over (1.2.25) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... Processing triggers for man-db (2.7.5-1) ... Setting up apt (1.2.26) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... (Reading database ... 70333 files and directories currently installed.) Preparing to unpack .../apt-utils_1.2.26_armhf.deb ... Unpacking apt-utils (1.2.26) over (1.2.25) ... Preparing to unpack .../libsystemd0_229-4ubuntu21.2_armhf.deb ... Unpacking libsystemd0:armhf (229-4ubuntu21.2) over (229-4ubuntu21.1) ... Processing triggers for man-db (2.7.5-1) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... Setting up libsystemd0:armhf (229-4ubuntu21.2) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... (Reading database ... 70333 files and directories currently installed.) Preparing to unpack .../libpam-systemd_229-4ubuntu21.2_armhf.deb ... Unpacking libpam-systemd:armhf (229-4ubuntu21.2) over (229-4ubuntu21.1) ... Preparing to unpack .../libnss-myhostname_229-4ubuntu21.2_armhf.deb ... Unpacking libnss-myhostname:armhf (229-4ubuntu21.2) over (229-4ubuntu21.1) ... Preparing to unpack .../systemd_229-4ubuntu21.2_armhf.deb ... Unpacking systemd (229-4ubuntu21.2) over (229-4ubuntu21.1) ... Processing triggers for man-db (2.7.5-1) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... Processing triggers for ureadahead (0.100.0-19) ... Processing triggers for dbus (1.10.6-1ubuntu3.3) ... Setting up systemd (229-4ubuntu21.2) ... addgroup: The group `systemd-journal' already exists as a system group. Exiting. (Reading database ... 70333 files and directories currently installed.) Preparing to unpack .../udev_229-4ubuntu21.2_armhf.deb ... Unpacking udev (229-4ubuntu21.2) over (229-4ubuntu21.1) ... Preparing to unpack .../libudev1_229-4ubuntu21.2_armhf.deb ... Unpacking libudev1:armhf (229-4ubuntu21.2) over (229-4ubuntu21.1) ... Processing triggers for systemd (229-4ubuntu21.2) ... Processing triggers for ureadahead (0.100.0-19) ... Processing triggers for man-db (2.7.5-1) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... Setting up libudev1:armhf (229-4ubuntu21.2) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... (Reading database ... 70333 files and directories currently installed.) Preparing to unpack .../initramfs-tools_0.122ubuntu8.11_all.deb ... Unpacking initramfs-tools (0.122ubuntu8.11) over (0.122ubuntu8.10) ... Preparing to unpack .../initramfs-tools-core_0.122ubuntu8.11_all.deb ... Unpacking initramfs-tools-core (0.122ubuntu8.11) over (0.122ubuntu8.10) ... Preparing to unpack .../initramfs-tools-bin_0.122ubuntu8.11_armhf.deb ... Unpacking initramfs-tools-bin (0.122ubuntu8.11) over (0.122ubuntu8.10) ... Preparing to unpack .../systemd-sysv_229-4ubuntu21.2_armhf.deb ... Unpacking systemd-sysv (229-4ubuntu21.2) over (229-4ubuntu21.1) ... Processing triggers for man-db (2.7.5-1) ... Setting up systemd-sysv (229-4ubuntu21.2) ... (Reading database ... 70333 files and directories currently installed.) Preparing to unpack .../libapparmor1_2.10.95-0ubuntu2.9_armhf.deb ... Unpacking libapparmor1:armhf (2.10.95-0ubuntu2.9) over (2.10.95-0ubuntu2.8) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... Setting up libapparmor1:armhf (2.10.95-0ubuntu2.9) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... (Reading database ... 70333 files and directories currently installed.) Preparing to unpack .../ntp_1%3a4.2.8p4+dfsg-3ubuntu5.8_armhf.deb ... Unpacking ntp (1:4.2.8p4+dfsg-3ubuntu5.8) over (1:4.2.8p4+dfsg-3ubuntu5.7) ... Preparing to unpack .../libgcrypt20_1.6.5-2ubuntu0.4_armhf.deb ... Unpacking libgcrypt20:armhf (1.6.5-2ubuntu0.4) over (1.6.5-2ubuntu0.3) ... Processing triggers for ureadahead (0.100.0-19) ... Processing triggers for man-db (2.7.5-1) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... Setting up libgcrypt20:armhf (1.6.5-2ubuntu0.4) ... Processing triggers for systemd (229-4ubuntu21.2) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... (Reading database ... 70333 files and directories currently installed.) Preparing to unpack .../isc-dhcp-client_4.3.3-5ubuntu12.10_armhf.deb ... Unpacking isc-dhcp-client (4.3.3-5ubuntu12.10) over (4.3.3-5ubuntu12.9) ... Preparing to unpack .../isc-dhcp-common_4.3.3-5ubuntu12.10_armhf.deb ... Unpacking isc-dhcp-common (4.3.3-5ubuntu12.10) over (4.3.3-5ubuntu12.9) ... Preparing to unpack .../apt-transport-https_1.2.26_armhf.deb ... Unpacking apt-transport-https (1.2.26) over (1.2.25) ... Preparing to unpack .../pciutils_1%3a3.3.1-1.1ubuntu1.2_armhf.deb ... Unpacking pciutils (1:3.3.1-1.1ubuntu1.2) over (1:3.3.1-1.1ubuntu1.1) ... Preparing to unpack .../libpci3_1%3a3.3.1-1.1ubuntu1.2_armhf.deb ... Unpacking libpci3:armhf (1:3.3.1-1.1ubuntu1.2) over (1:3.3.1-1.1ubuntu1.1) ... Preparing to unpack .../python-apt-common_1.1.0~beta1ubuntu0.16.04.1_all.deb ... Unpacking python-apt-common (1.1.0~beta1ubuntu0.16.04.1) over (1.1.0~beta1build1) ... Preparing to unpack .../python3-apt_1.1.0~beta1ubuntu0.16.04.1_armhf.deb ... Unpacking python3-apt (1.1.0~beta1ubuntu0.16.04.1) over (1.1.0~beta1build1) ... Preparing to unpack .../dpkg-dev_1.18.4ubuntu1.4_all.deb ... Unpacking dpkg-dev (1.18.4ubuntu1.4) over (1.18.4ubuntu1.3) ... Preparing to unpack .../libdpkg-perl_1.18.4ubuntu1.4_all.deb ... Unpacking libdpkg-perl (1.18.4ubuntu1.4) over (1.18.4ubuntu1.3) ... Preparing to unpack .../pulseaudio-module-bluetooth_1%3a8.0-0ubuntu3.8_armhf.deb ... Unpacking pulseaudio-module-bluetooth (1:8.0-0ubuntu3.8) over (1:8.0-0ubuntu3.7) ... Preparing to unpack .../pulseaudio-module-gconf_1%3a8.0-0ubuntu3.8_armhf.deb ... Unpacking pulseaudio-module-gconf (1:8.0-0ubuntu3.8) over (1:8.0-0ubuntu3.7) ... Preparing to unpack .../pulseaudio-module-zeroconf_1%3a8.0-0ubuntu3.8_armhf.deb ... Unpacking pulseaudio-module-zeroconf (1:8.0-0ubuntu3.8) over (1:8.0-0ubuntu3.7) ... Preparing to unpack .../libpulsedsp_1%3a8.0-0ubuntu3.8_armhf.deb ... Unpacking libpulsedsp:armhf (1:8.0-0ubuntu3.8) over (1:8.0-0ubuntu3.7) ... Preparing to unpack .../pulseaudio-utils_1%3a8.0-0ubuntu3.8_armhf.deb ... Unpacking pulseaudio-utils (1:8.0-0ubuntu3.8) over (1:8.0-0ubuntu3.7) ... Preparing to unpack .../pulseaudio_1%3a8.0-0ubuntu3.8_armhf.deb ... Unpacking pulseaudio (1:8.0-0ubuntu3.8) over (1:8.0-0ubuntu3.7) ... Preparing to unpack .../libpulse-mainloop-glib0_1%3a8.0-0ubuntu3.8_armhf.deb ... Unpacking libpulse-mainloop-glib0:armhf (1:8.0-0ubuntu3.8) over (1:8.0-0ubuntu3.7) ... Preparing to unpack .../libpulse0_1%3a8.0-0ubuntu3.8_armhf.deb ... Unpacking libpulse0:armhf (1:8.0-0ubuntu3.8) over (1:8.0-0ubuntu3.7) ... Preparing to unpack .../linux-dtb-rockchip_5.41_armhf.deb ... Unpacking linux-dtb-rockchip (5.41) over (5.40) ... Preparing to unpack .../linux-firmware_1.157.17_all.deb ... Unpacking linux-firmware (1.157.17) over (1.157.16) ... Replaced by files in installed package armbian-firmware (5.40) ... Preparing to unpack .../linux-image-rockchip_5.41_armhf.deb ... update-initramfs: Deleting /boot/initrd.img-4.4.115-rockchip Removing obsolete file uInitrd-4.4.115-rockchip Unpacking linux-image-rockchip (5.41) over (5.40) ... Preparing to unpack .../numix-gtk-theme_2.6.7+670~201710270712~ubuntu17.10.1_all.deb ... Unpacking numix-gtk-theme (2.6.7+670~201710270712~ubuntu17.10.1) over (2.1.2-0ubuntu1) ... Processing triggers for man-db (2.7.5-1) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... Processing triggers for dbus (1.10.6-1ubuntu3.3) ... Setting up libapt-inst2.0:armhf (1.2.26) ... Setting up apt-utils (1.2.26) ... Setting up libpam-systemd:armhf (229-4ubuntu21.2) ... Setting up libnss-myhostname:armhf (229-4ubuntu21.2) ... Setting up udev (229-4ubuntu21.2) ... addgroup: The group `input' already exists as a system group. Exiting. update-initramfs: deferring update (trigger activated) Setting up initramfs-tools-bin (0.122ubuntu8.11) ... Setting up initramfs-tools-core (0.122ubuntu8.11) ... Setting up initramfs-tools (0.122ubuntu8.11) ... update-initramfs: deferring update (trigger activated) Setting up ntp (1:4.2.8p4+dfsg-3ubuntu5.8) ... Installing new version of config file /etc/apparmor.d/usr.sbin.ntpd ... Setting up isc-dhcp-client (4.3.3-5ubuntu12.10) ... Setting up isc-dhcp-common (4.3.3-5ubuntu12.10) ... Setting up apt-transport-https (1.2.26) ... Setting up libpci3:armhf (1:3.3.1-1.1ubuntu1.2) ... Setting up pciutils (1:3.3.1-1.1ubuntu1.2) ... Setting up python-apt-common (1.1.0~beta1ubuntu0.16.04.1) ... Setting up python3-apt (1.1.0~beta1ubuntu0.16.04.1) ... Setting up libdpkg-perl (1.18.4ubuntu1.4) ... Setting up dpkg-dev (1.18.4ubuntu1.4) ... Setting up libpulse0:armhf (1:8.0-0ubuntu3.8) ... Setting up libpulsedsp:armhf (1:8.0-0ubuntu3.8) ... Setting up pulseaudio-utils (1:8.0-0ubuntu3.8) ... Setting up pulseaudio (1:8.0-0ubuntu3.8) ... Setting up pulseaudio-module-bluetooth (1:8.0-0ubuntu3.8) ... Setting up pulseaudio-module-gconf (1:8.0-0ubuntu3.8) ... Setting up pulseaudio-module-zeroconf (1:8.0-0ubuntu3.8) ... Setting up libpulse-mainloop-glib0:armhf (1:8.0-0ubuntu3.8) ... Setting up linux-dtb-rockchip (5.41) ... Setting up linux-firmware (1.157.17) ... Setting up linux-image-rockchip (5.41) ... update-initramfs: Generating /boot/initrd.img-4.4.120-rockchip update-initramfs: Converting to u-boot format Setting up numix-gtk-theme (2.6.7+670~201710270712~ubuntu17.10.1) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... Processing triggers for initramfs-tools (0.122ubuntu8.11) ... update-initramfs: Generating /boot/initrd.img-4.4.120-rockchip update-initramfs: Converting to u-boot format root@term69:~# cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=tinkerboard BOARD_NAME="Tinkerboard" BOARDFAMILY=rockchip VERSION=5.40 LINUXFAMILY=rockchip BRANCH=default ARCH=arm IMAGE_TYPE=user-built BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=zImage root@term69:~# reboot Connection to term69 closed by remote host. Connection to term69 closed. _____ _ _ _ _ |_ _(_)_ __ | | _____ _ __| |__ ___ __ _ _ __ __| | | | | | '_ \| |/ / _ \ '__| '_ \ / _ \ / _` | '__/ _` | | | | | | | | < __/ | | |_) | (_) | (_| | | | (_| | |_| |_|_| |_|_|\_\___|_| |_.__/ \___/ \__,_|_| \__,_| Welcome to ARMBIAN 5.40 user-built Ubuntu 16.04.4 LTS 4.4.120-rockchip System load: 0.91 0.40 0.15 Up time: 1 min Memory usage: 13 % of 2010MB IP: 10.0.1.118 CPU temp: 61°C Usage of /: 8% of 29G Last login: Tue Mar 27 12:33:18 2018 from 10.0.0.88 armbian@term69:~$
Igor Posted March 27, 2018 Posted March 27, 2018 That's ok. This is latest in the stable repository ... if you need more recent, you need to switch to (warranty free) beta.armbian.com
Jose Deras Posted March 28, 2018 Posted March 28, 2018 Humm this should be somehow documented but I cannot find a way either. I'm on 5.38 and I can get updates via apt upgrade but not a full distribution upgrade. Is this then just cosmetic: Welcome to ARMBIAN 5.38 stable Ubuntu 16.04.4 LTS 4.4.120-rockchip System load: 0.06 0.05 0.00 Up time: 13 min Memory usage: 3 % of 2010MB IP: 192.168.1.63 CPU temp: 42°C Usage of /: 5% of 59G Last login: Wed Mar 28 10:29:05 2018 from 192.168.1.19
