bholland Posted March 28, 2018 Share Posted March 28, 2018 Hello all, I wrote up this documentation mostly as notes to myself about how I successfully built a kernel and ubuntu core rootfs. If you could let me know how to improve it, please let me know. I don't generally write documentation. I focused on the roc-rk3328-cc but it should work okay for a variety of the Firefly chips. Thanks, ~Ben barebone_to_ubunutu.md Link to comment Share on other sites More sharing options...
gspillman Posted March 28, 2018 Share Posted March 28, 2018 Thanks for the docs. But have run into some issues trying to use it. mk_kernel.sh got an error because of missing "mmd" command. Installed it using "sudo apt install mtools". mk_uboot.sh got error for because of missing u-boot folder. Created it manually using "mkdir u-boot". Finally got stuck with another error in mk_uboot.sh. It complains of missing rule for target "roc-rk3328-cc_defconfig" I am unable to locate this file anywhere on my system. Below is what I attempted, step by step. Thanks for any help you can provide. Guy ###################################### # Created VirtualBox VM with: # 4 processosors, 2 GB Memory, 20 GB Storage # Installed Kubuntu 16.04 ###################################### sudo apt update sudo apt upgrade ############## # Rebooted VM ############## sudo apt install git gcc-arm-linux-gnueabihf gcc-aarch64-linux-gnu device-tree-compiler lzop libncurses5-dev libssl1.0.0 libssl-dev qemu qemu-user-static binfmt-support debootstrap mkdir ~/temp/firefly_build cd ~/temp/firefly_build git clone https://github.com/FireflyTeam/kernel.git git clone https://github.com/FireflyTeam/build.git git clone https://github.com/FireflyTeam/rkbin.git cd kernel make menuconfig ######################################################## # Added settings for built-in TUN/TAP: ### Device Drivers --> Network Device Support ---> Universal TUN/TAP device driver support # Added settings for built-in Xtables ### Networking Support ---> Networking Options ---> Network packet filtering framework (Netfilter) ---> Core Netfilter Configuration ---> Netfilter Xtables support # Added settings for built-in IP Tables ### Networking Support ---> Networking Options ---> Network packet filtering framework (Netfilter) ---> Network packet filtering framework ######################################################## cd .. ./build/mk-kernel.sh roc-rk3328-cc ##################################################################### # This caused an ERROR to be generated: ### Generate Boot image start ###mkfs.fat 3.0.28 (2015-05-16) ###mkfs.fat: warning - lowercase labels might not work properly with DOS or Windows ###./build/mk-image.sh: line 59: mmd: command not found ### MAKE KERNEL IMAGE FAILED. # Found the "mmd" command in the mtools package: ##################################################################### sudo apt install mtools ./build/mk-kernel.sh roc-rk3328-cc ##################################################################### # Now I get success messages: ### Generate Boot image start ###mkfs.fat 3.0.28 (2015-05-16) ###mkfs.fat: warning - lowercase labels might not work properly with DOS or Windows ### Generate Boot image : /home/gspillman/temp/firefly_build/out/boot.img success! ### Kernel build success! ##################################################################### ./build/mk-uboot.sh roc-rk3328-cc ################################################################################## # This caused another ERROR: ### Building U-boot for roc-rk3328-cc board! ### Using roc-rk3328-cc_defconfig ###./build/mk-uboot.sh: line 35: cd: /home/gspillman/temp/firefly_build/u-boot: No such file or directory ### MAKE UBOOT IMAGE FAILED. # OK, lets manually create the u-boot directory ################################################################################## mkdir u-boot ./build/mk-uboot.sh roc-rk3328-cc ####################################################### # Now get different ERROR: ### Building U-boot for roc-rk3328-cc board! ### Using roc-rk3328-cc_defconfig ###make: *** No rule to make target 'roc-rk3328-cc_defconfig'. Stop. ### MAKE UBOOT IMAGE FAILED. # Using the following returns no results: ### find -iname roc-rk3328-cc_defconfig ####################################################### Link to comment Share on other sites More sharing options...
Cameron Ross Posted April 9, 2018 Share Posted April 9, 2018 (edited) @gspillman You need to git clone https://github.com/FireflyTeam/u-boot.git too. The .defconfig file is in there. Edited April 9, 2018 by Cameron Ross Link to comment Share on other sites More sharing options...
gspillman Posted April 11, 2018 Share Posted April 11, 2018 Finally got a bootable image file, and have OpenVPN running on the FireFly Renegade (ROC-3328-CC). I'm now getting around 90 megabit per second throughput, as opposed to 30 megabit with the Raspberry Pi 3. I think the Renegade could probably do more, as I am hitting the limits of my ISP. The one major change I made was to use Ubuntu 16.04.4, which only needed about a dozen packages upgraded. When you did an "apt upgrade" with 16.04.1, it effectively brought you up to 16.04.4 by upgrading 300+ packages. Thank you to bholland, who's instructions got me most of the way, and Cameron Ross, who provided the last missing piece to the puzzle. Below is what I did to create my bootable image file. You should still read bholland's instructions as it has more in-depth descriptions for each step. Make sure to replace <new user> and <hostname> with meaningful values. Guy #------- # Created VirtualBox VM with: # 4 processosors # 2 GB Memory # 30 GB Storage # Installed Kubuntu 16.04.4 #------- sudo apt update sudo apt upgrade #------- # Reboot VM #------- sudo apt install git gcc-arm-linux-gnueabihf gcc-aarch64-linux-gnu device-tree-compiler lzop libncurses5-dev libssl1.0.0 libssl-dev qemu qemu-user-static binfmt-support debootstrap swig libpython-dev mtools pv mkdir ~/temp mkdir ~/temp/firefly_build git clone https://github.com/FireflyTeam/kernel.git git clone https://github.com/FireflyTeam/build.git git clone https://github.com/FireflyTeam/rkbin.git git clone https://github.com/FireflyTeam/u-boot.git cd kernel make menuconfig #------- # Load Config from "arch/arm64/configs/fireflyrk3328_linux_defconfig" # # Device Drivers --> # Network Device Support ---> # Universal TUN/TAP device driver support <Mark with an asterisk(*)> # # Networking Support ---> # Networking Options ---> # Network packet filtering framework (Netfilter) ---> # Core Netfilter Configuration ---> # <Mark all options with an asterisk (*)> # # Networking Support ---> # Networking Options ---> # Network packet filtering framework (Netfilter) ---> # IP: Net Filter configurations --> # <Mark all options with an asterisk (*)> # # Save Config to "arch/arm64/configs/fireflyrk3328_linux_defconfig" #------- cd .. ./build/mk-kernel.sh roc-rk3328-cc ./build/mk-uboot.sh roc-rk3328-cc mkdir ubuntu_core install -d ./ubuntu_core/{linux,rootfs,archives/{ubuntu-base,debs,hwpacks},images,scripts} cd ubuntu_core wget -P archives/ubuntu-base -c http://cdimage.ubuntu.com/ubuntu-base/releases/16.04.4/release/ubuntu-base-16.04.4-base-arm64.tar.gz dd if=/dev/zero of=images/rootfs.img bs=1M count=0 seek=1000 sudo mkfs.ext4 -F -L ROOTFS images/rootfs.img # <enter user password> rm -rf rootfs && install -d rootfs sudo mount -o loop images/rootfs.img rootfs sudo rm -rf rootfs/lost+found sudo tar -xzf archives/ubuntu-base/ubuntu-base-16.04.4-base-arm64.tar.gz -C rootfs/ sudo cp -a /usr/bin/qemu-aarch64-static rootfs/usr/bin/ sudo chroot rootfs/ passwd root # <enter new root password> # <re-enter new root password> useradd -G sudo -m -s /bin/bash <new user> passwd <new user> # <enter new user password> # <re-enter new user password> echo "<hostname>" > /etc/hostname echo "127.0.0.1 localhost.localdomain localhost" > /etc/hosts echo "127.0.0.1 <hostname>" >> /etc/hosts mkdir /etc/network mkdir /etc/network/interfaces.d echo "auto eth0" > /etc/network/interfaces.d/eth0 echo "iface eth0 inet dhcp" >> /etc/network/interfaces.d/eth0 echo "nameserver 127.0.1.1" > /etc/resolv.conf apt update apt upgrade apt install ifupdown net-tools sudo ssh iptables openvpn nano unzip exit sudo sync # <enter user password> sudo umount rootfs/ cd .. build/mk-image.sh -c rk3328 -t system -r ubuntu_core/images/rootfs.img build/flash_tool.sh -c rk3328 -d ubuntu_16.04.4_roc-rk3328-cc_arch64_$(date +%Y%m%d).img -p system -i out/system.img Link to comment Share on other sites More sharing options...
Joseluis Posted June 5, 2019 Share Posted June 5, 2019 On 4/11/2018 at 1:57 AM, gspillman said: # # Save Config to "arch/arm64/configs/fireflyrk3328_linux_defconfig" #------- cd .. ./build/mk-kernel.sh roc-rk3328-cc Making the kernel I got: CC fs/nfs/dir.o CC drivers/gpu/drm/drm_panel.o drivers/gpu/arm/midgard/ipa/mali_kbase_ipa.c:582:22: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types] error, forbidden warning:mali_kbase_ipa.c:582 .get_static_power = &kbase_get_static_power, ^ drivers/gpu/arm/midgard/ipa/mali_kbase_ipa.c:582:22: note: (near initialization for 'kbase_ipa_power_model_ops.get_static_power') drivers/gpu/arm/midgard/ipa/mali_kbase_ipa.c:583:23: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types] error, forbidden warning:mali_kbase_ipa.c:583 .get_dynamic_power = &kbase_get_dynamic_power, ^ drivers/gpu/arm/midgard/ipa/mali_kbase_ipa.c:583:23: note: (near initialization for 'kbase_ipa_power_model_ops.get_dynamic_power') scripts/Makefile.build:277: recipe for target 'drivers/gpu/arm/midgard/ipa/mali_kbase_ipa.o' failed make[4]: *** [drivers/gpu/arm/midgard/ipa/mali_kbase_ipa.o] Error 1 scripts/Makefile.build:484: recipe for target 'drivers/gpu/arm/midgard' failed make[3]: *** [drivers/gpu/arm/midgard] Error 2 scripts/Makefile.build:484: recipe for target 'drivers/gpu/arm' failed make[2]: *** [drivers/gpu/arm] Error 2 make[2]: *** Waiting for unfinished jobs.... CC drivers/gpu/drm/drm_of.o ...... LD drivers/gpu/drm/built-in.o scripts/Makefile.build:484: recipe for target 'drivers/gpu' failed make[1]: *** [drivers/gpu] Error 2 Makefile:1031: recipe for target 'drivers' failed make: *** [drivers] Error 2 make: *** Waiting for unfinished jobs.... CC lib/fonts/font_8x8.o .... LD net/built-in.o MAKE KERNEL IMAGE FAILED. Link to comment Share on other sites More sharing options...
Igor Posted June 8, 2019 Share Posted June 8, 2019 7 minutes ago, lanefu said: Hi. Once the kinks have been ironed out, would you be willing to submit it as a PR to our documentation repo? https://github.com/armbian/documentation This doesn't seems to be compiling using our tools nor sources we use. Link to comment Share on other sites More sharing options...
lanefu Posted June 8, 2019 Share Posted June 8, 2019 6 minutes ago, Igor said: This doesn't seems to be compiling using our tools nor sources we use. Ooopps! Just kidding then! 1 Link to comment Share on other sites More sharing options...
