hardvk0 Posted February 13, 2016 Posted February 13, 2016 I have a "Banana PRO"One USB disk, 2TB with three partitions in ext4, the first partition is mounted (hdb1), the other two are not mounted.One USB disk, 4TB with a single ext4 partition mounted (hdc1).One SATA SSD disk with a single ext4 partition unmounted (hda1).Several aesthetic considerations:After the upgrade, reboot and login, the welcome screen and 100% battery!!! Hurrah!!!It seems that the MMC is 9% occupancy and ... oh! my hdb disk has only one partition? ah no, only reads hdb1. And the other two disks? I have two mounted partitions but only shows one.Turn off the system with the poweroff order and boot from the power button again, the battery is down to 97%? 30 minutes later still 97% ... I think we will have to discharge the battery to calibrate.It is a bit ugly to show the battery charge on two lines. ____| __ ) __ _ _ __ __ _ _ __ __ _| _ \ / _` | '_ \ / _` | '_ \ / _` || |_) | (_| | | | | (_| | | | | (_| ||____/ \__,_|_| |_|\__,_|_| |_|\__,_|Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 4.4.1-sunxiSystem load: 0.10 Up time: 2 minMemory usage: 4 % of 997Mb IP: 192.168.187.89CPU temp: 38°CUsage of /: 9% of 15G storage/: 88% of 1.8T Battery: 97% chargingLast login: Sat Feb 13 01:49:50 2016 from remote.intranetroot@mybanana:~#
Igor Posted February 13, 2016 Posted February 13, 2016 Well, storage monitoring was meant to be a choice - to monitor one / two mounts. I'll develop a user config for next, since this file is overwritten on every upgrade. It is a bit ugly to show the battery charge on two lines. Who uses 80 column mode ? OK, Will be fixed in next. Battery.
hardvk0 Posted February 13, 2016 Author Posted February 13, 2016 Well, I do not know exactly how the script works. I propose an idea, find out first mounted partitions and display the data later.df -l excluding tmpfs, for example, do that.I do not know programming, I'm too old for that but certainly with your magic you know how. A query, how do I show the data with the session already started?
Igor Posted February 13, 2016 Posted February 13, 2016 This is the script. It's not complicated ... https://github.com/igorpecovnik/lib/blob/master/scripts/update-motd.d/30-sysinfo No need to fix it by yourself. We will find a way to make this as simple as possible to adjust to user desires. I made the basics, design and beauty of the output is a subjective manner. Always An idea / txt output how to shape date is enough, perhaps here where those changes begin: http://forum.armbian.com/index.php/topic/602-new-motd-for-ubuntudebian/
