Cubox-i 4x4 crash after updating to Kernel 4.4.1
the system in my cubox-i 4x4 crashes after updating to kernel 4.4.1. I did the update in the system and after rebooting it doesn't work.
I upload the screenshot of the only thing I get, after that the screen goes off, nothing else happens.
If the problem is the new kernel it means I can't upgrade it, is it right?
I also try new images 5.0 Vanilla and I get the same screen.
That's normal. Kernel 4.4.1 does not have video driver yet - @download page this is noted with bold under bugs and limitation: Serial console only
Kernel 4.4.x is useful for server scenarios. For now.
is it any way to downgrade the system to the previous version instead of reinstall? and even if I reinstall the system, could I update the system without updating the kernel? because I will have again the same problem then....
Yes, login via SSH and install default kernel (with DTB).
1. Remove current
dpkg -r linux-dtb-next-cubox linux-image-next-cubox
2. Install default kernel
apt-get install linux-image-cubox linux-dtb-cubox
3. Reboot
Thanks, but the system wasn't online in the network. I did ping from one laptop searching for all possible devices online and cubox wasn't.
Anyway I used this opportunity to reinstall the system in another HD and I made better partitions for the system and swap space and I took note of all this.
  • Igor unpinned this topic
