guidol Posted July 14, 2018 Posted July 14, 2018 2 hours ago, TonyMac32 said: I see that on Amazon.de, but not amazon.com for us colonists... top and bottom have no holes, but that certainly looks sharp. Add it to the "Pi-factor cases" topic? Raidsonic.de is a company in Germany, which sells the brand "ICY BOX" : https://www.raidsonic.de/en/index.php (the ebay-seller where I did buy will send it worldwide: eBay item number 362279671071 - free postage) Yes- top and bottom doesnt got holes, but at the longer sides there is grid-aluminium for "fresh air". Also the bottom plate could absorb/spread the heat. I know some time ago I did see the case-thread, but I didnt find it now while searching for some keywords [EDIT] here is the thread
guidol Posted July 15, 2018 Posted July 15, 2018 while waiting for the final (stable?) version of armbian with kernel 4.18 I did go back to armbian stable: for better hw-support ARMBIAN 5.47 stable Debian GNU/Linux 9 (stretch) 4.14.51-sunxi64 Linux npi-k1-plus 4.14.51-sunxi64 #23 SMP Sun Jun 24 12:19:01 UTC 2018 aarch64 GNU/Linux here I did miss the temperature in armbianmonitor -m So I did take a look at my Neo2 and found the missing link cd /etc/armbianmonitor/datasources/ ln -s /sys/devices/virtual/thermal/thermal_zone0/temp soctemp After creating the symbolic link I do get also the temperature from armbianmonitor: root@npi-k1-plus(192.168.6.70):/etc/armbianmonitor/datasources# armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 16:26:42: 648MHz 0.00 0% 0% 0% 0% 0% 0% 36.9°C 0/8 16:26:47: 408MHz 0.00 0% 0% 0% 0% 0% 0% 37.0°C 0/8 16:26:53: 408MHz 0.00 0% 0% 0% 0% 0% 0% 36.9°C 0/8 16:26:58: 408MHz 0.00 0% 0% 0% 0% 0% 0% 36.9°C 0/8 16:27:03: 408MHz 0.00 1% 0% 0% 0% 0% 0% 37.3°C 0/8 16:27:08: 408MHz 0.00 0% 0% 0% 0% 0% 0% 36.5°C 0/8 root@npi-k1-plus(192.168.6.70):/# cat /sys/devices/virtual/thermal/thermal_zone0/temp|awk '{printf "%.2f\n", ($1/1000)}' 37.39 after getting the temperature in armbianmonitor we also have the temperature in the welcome screen Welcome to ARMBIAN 5.47 stable Debian GNU/Linux 9 (stretch) 4.14.51-sunxi64 System load: 0.00 0.00 0.00 Up time: 3:15 hours Local users: 2 Memory usage: 3 % of 2002MB IP: 192.168.6.70 CPU temp: 37°C Usage of /: 4% of 30G PS: /sys/devices/virtual/thermal/thermal_zone0/temp is missing in the dev-image so there no temperature
tkaiser Posted July 15, 2018 Author Posted July 15, 2018 17 minutes ago, guidol said: So I did take a look at my Neo2 and found the missing link This is something that should happen automagically at boot. Can you please provide output from grep soctemp /etc/init.d/armhwinfo
guidol Posted July 15, 2018 Posted July 15, 2018 3 minutes ago, tkaiser said: This is something that should happen automagically at boot. Can you please provide output from grep soctemp /etc/init.d/armhwinfo root@npi-k1-plus(192.168.6.70):/# grep soctemp /etc/init.d/armhwinfo grep: /etc/init.d/armhwinfo: Datei oder Verzeichnis nicht gefunden
tkaiser Posted July 15, 2018 Author Posted July 15, 2018 36 minutes ago, guidol said: grep: /etc/init.d/armhwinfo: Datei oder Verzeichnis nicht gefunden Then your image already uses /usr/lib/armbian/armbian-hardware-monitor and there the symlink should be created automatically at boot. Strange.
guidol Posted July 15, 2018 Posted July 15, 2018 17 minutes ago, tkaiser said: Then your image already uses /usr/lib/armbian/armbian-hardware-monitor and there the symlink should be created automatically at boot. Strange. root@npi-k1-plus(192.168.6.70):/etc/init.d# grep soctemp /usr/lib/armbian/armbian-hardware-monitor ln -fs /sys/devices/platform/a20-tp-hwmon/temp1_input /etc/armbianmonitor/datasources/soctemp ln -fs /sys/class/hwmon/hwmon0/temp1_input /etc/armbianmonitor/datasources/soctemp ln -fs /sys/devices/virtual/thermal/${THERMAL_ZONE}/temp /etc/armbianmonitor/datasources/soctemp # remove the soctemp node on platforms where kernel support is not yet ready for thermal readouts cat /etc/armbianmonitor/datasources/soctemp >/dev/null 2>&1 || rm /etc/armbianmonitor/datasources/soctemp root@npi-k1-plus(192.168.6.70):/etc/init.d# echo ${THERMAL_ZONE} root@npi-k1-plus(192.168.6.70):/etc/init.d# Should ${THERMAL_ZONE} be set outside the script? ( as /sys/devices/virtual/thermal/thermal_zone0/temp = thermal_zone0 ) ${BOARDFAMILY} seems to be available root@npi-k1-plus(192.168.6.70):/etc/init.d# echo ${BOARDFAMILY} sun50iw2 So when ${THERMAL_ZONE} is empty it looks like the symbolic link is removed: else # all other boards/kernels use the same sysfs node except of Actions Semi S500: [[ ${BOARDFAMILY} == s500 ]] && THERMAL_ZONE="thermal_zone1" || THERMAL_ZONE="thermal_zone0" ln -fs /sys/devices/virtual/thermal/${THERMAL_ZONE}/temp /etc/armbianmonitor/datasources/soctemp fi # remove the soctemp node on platforms where kernel support is not yet ready for thermal readouts cat /etc/armbianmonitor/datasources/soctemp >/dev/null 2>&1 || rm /etc/armbianmonitor/datasources/soctemp Is sun50iw2 = s500 BoardFamily? because sun50iw2 isnt in the script....
tkaiser Posted July 15, 2018 Author Posted July 15, 2018 2 hours ago, guidol said: Should ${THERMAL_ZONE} be set outside the script? No. How does the output of the following look like? /bin/bash -x /usr/lib/armbian/armbian-hardware-monitor start
guidol Posted July 15, 2018 Posted July 15, 2018 5 minutes ago, tkaiser said: No. How does the output of the following look like? /bin/bash -x /usr/lib/armbian/armbian-hardware-monitor start here it is in the hidden box: Spoiler root@npi-k1-plus(192.168.6.70):/# /bin/bash -x /usr/lib/armbian/armbian-hardware-monitor start + . /etc/armbian-release ++ BOARD=nanopik1plus ++ BOARD_NAME='Nanopi K1 Plus' ++ BOARDFAMILY=sun50iw2 ++ VERSION=5.47 ++ LINUXFAMILY=sunxi64 ++ BRANCH=next ++ ARCH=arm64 ++ IMAGE_TYPE=stable ++ BOARD_TYPE=conf ++ INITRD_ARCH=arm64 ++ KERNEL_IMAGE_TYPE=Image + . /usr/lib/armbian/armbian-common ++ export PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++ PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++ my_name=armbian-hardware-monitor ++ Log=/var/log/armbian-services.log + case $1 in + check_sd_card_speed + collect_information + prepare_temp_monitoring + '[' -f /var/log/armbian-hardware-monitor.log ']' + '[' -d /etc/armbianmonitor/datasources ']' + [[ -f /sys/power/axp_pmu/pmu/temp ]] + ifconfig + grep -q eth0 ++ grep -c '^### df:' /var/log/armbian-hardware-monitor.log + [[ -f /sys/devices/platform/sunxi-i2c.0/i2c-0/0-0034//temp1_input ]] + [[ -f /sys/devices/b0170000.i2c/i2c-0/0-0065/atc2603c-hwmon.0/ic_temperature ]] + [[ -f /sys/class/axppower/ic_temp ]] + [[ -d /sys/devices/platform/a20-tp-hwmon ]] + [[ -f /sys/class/hwmon/hwmon0/temp1_input ]] + ln -fs /sys/class/hwmon/hwmon0/temp1_input /etc/armbianmonitor/datasources/soctemp + cat /etc/armbianmonitor/datasources/soctemp + RebootCount=8 + '[' 8 -eq 2 ']' ++ mktemp /tmp/armbian-hardware-monitor.XXXXXX + TMPFILE=/tmp/armbian-hardware-monitor.oWdHNn + trap 'sleep 1 ; rm "/tmp/armbian-hardware-monitor.oWdHNn" ; exit 0' 0 1 2 3 15 ++ lscpu ++ awk '/Architecture/ {print $2}' + CPU_ARCH=aarch64 ++ dpkg --print-architecture + DISTRO_ARCH=arm64 ++ uname -r + KERNELID=4.14.51-sunxi64 + dmesg + echo Nanopi K1 Plus + '[' 0 -ne 0 ']' + '[' -f /root/.machine.id ']' + log_hardware_info + Log=/var/log/armbian-hardware-monitor.log + '[' -f /etc/logrotate.d/armbian-hardware-monitor ']' + chmod 644 /etc/logrotate.d/armbian-hardware-monitor + '[' -f /var/log/armbian-hardware-monitor.log ']' ++ date + echo -e '\n\n\nSo 15. Jul 20:05:46 +03 2018 | Nanopi K1 Plus | 5.47 | arm64 | aarch64 | 4.14.51-sunxi64' + echo -e '\n### dmesg:\n' + cat /tmp/armbian-hardware-monitor.oWdHNn + echo -e '\n### armbian-release:\n' + cat /etc/armbian-release + echo -e '\n### boot environment:\n' + cat /boot/armbianEnv.txt + echo -e '\n### lsusb:\n' + lsusb + echo -e '\n### lscpu:\n' + lscpu + echo -e '\n### cpuinfo:\n' + cat /proc/cpuinfo + echo -e '\n### meminfo:\n' + cat /proc/meminfo + '[' -x /sbin/ip ']' + echo -e '\n### ip addr:\n' + /sbin/ip r s + /sbin/ip a + echo ' ' + echo -e '### partitions:\n' + egrep -v ' ram| zram' /proc/partitions + echo -e '\n### df:\n' + df -h + egrep '^udev|^tmpfs|^/dev/|log2ram|folder2ram' + which zpool + echo -e '\n### lsblk:\n' + lsblk -o NAME,FSTYPE,SIZE,MOUNTPOINT,UUID + grep -v '^zram' + echo -e '\n### mtab:\n' + egrep '^/dev/|\ zfs\ ' /etc/mtab + egrep -v 'log2ram|folder2ram' + sort + [[ -e /boot/script.bin ]] + get_flash_information + find /sys -name oemid + read Device + DeviceNode=/sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007 + DeviceName=mmc0:0007 + echo -e '\n### mmc0:0007 info:\n' + find /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007 -maxdepth 1 -type f + read + NodeName=fwrev ++ printf %20s fwrev ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/fwrev ++ tr '\n' ' ' + echo -e ' fwrev: 0x0 ' + read + NodeName=uevent ++ printf %20s uevent ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/uevent ++ tr '\n' ' ' + echo -e ' uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD32G MODALIAS=mmc:block ' + read + NodeName=cid ++ printf %20s cid ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/cid ++ tr '\n' ' ' + echo -e ' cid: 275048534433324730da7d50db0104b3 ' + read + NodeName=csd ++ printf %20s csd ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/csd ++ tr '\n' ' ' + echo -e ' csd: 400e00325b590000eeaf7f800a4000b9 ' + read + NodeName=manfid ++ printf %20s manfid ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/manfid ++ tr '\n' ' ' + echo -e ' manfid: 0x000027 ' + read + NodeName=ocr ++ printf %20s ocr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/ocr ++ tr '\n' ' ' + echo -e ' ocr: 0x00200000 ' + read + NodeName=preferred_erase_size ++ printf %20s preferred_erase_size ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/preferred_erase_size ++ tr '\n' ' ' + echo -e 'preferred_erase_size: 4194304 ' + read + NodeName=type ++ printf %20s type ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/type ++ tr '\n' ' ' + echo -e ' type: SD ' + read + NodeName=hwrev ++ printf %20s hwrev ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/hwrev ++ tr '\n' ' ' + echo -e ' hwrev: 0x3 ' + read + NodeName=date ++ printf %20s date ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/date ++ tr '\n' ' ' + echo -e ' date: 04/2016 ' + read + NodeName=dsr ++ printf %20s dsr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/dsr ++ tr '\n' ' ' + echo -e ' dsr: 0x404 ' + read + NodeName=erase_size ++ printf %20s erase_size ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/erase_size ++ tr '\n' ' ' + echo -e ' erase_size: 512 ' + read + NodeName=oemid ++ printf %20s oemid ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/oemid ++ tr '\n' ' ' + echo -e ' oemid: 0x5048 ' + read + NodeName=serial ++ printf %20s serial ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/serial ++ tr '\n' ' ' + echo -e ' serial: 0xda7d50db ' + read + NodeName=ssr ++ printf %20s ssr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/ssr ++ tr '\n' ' ' + echo -e ' ssr: 00000000050000000400900200ab0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 ' + read + NodeName=scr ++ printf %20s scr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/scr ++ tr '\n' ' ' + echo -e ' scr: 0235800001000000 ' + read + NodeName=name ++ printf %20s name ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/name ++ tr '\n' ' ' + echo -e ' name: SD32G ' + read + read Device + echo -e '\n### Boot system health:\n' + sleep 1 + armbianmonitor -s + egrep '^Time|^[0-9]' + rm /tmp/armbian-hardware-monitor.oWdHNn + exit 0
tkaiser Posted July 15, 2018 Author Posted July 15, 2018 16 minutes ago, guidol said: here it is in the hidden box The script uses /sys/class/hwmon/hwmon0/temp1_input since this should be the 'usual place' with modern kernels. Is reading out the temperature working now or not ('cat /etc/armbianmonitor/datasources/soctemp')
guidol Posted July 15, 2018 Posted July 15, 2018 36 minutes ago, tkaiser said: The script uses /sys/class/hwmon/hwmon0/temp1_input since this should be the 'usual place' with modern kernels. Is reading out the temperature working now or not ('cat /etc/armbianmonitor/datasources/soctemp') Now - after the script - it does use another symbolic link (as written by you above) : root@npi-k1-plus(192.168.6.70):/# cat /etc/armbianmonitor/datasources/soctemp 36905 root@npi-k1-plus(192.168.6.70):/# ls -l /etc/armbianmonitor/datasources/soctemp lrwxrwxrwx 1 root root 35 Jul 15 20:08 /etc/armbianmonitor/datasources/soctemp -> /sys/class/hwmon/hwmon0/temp1_input I used before root@npi-k1-plus(192.168.6.70):/# cat /sys/devices/virtual/thermal/thermal_zone0/temp 36542
tkaiser Posted July 15, 2018 Author Posted July 15, 2018 15 minutes ago, guidol said: root@npi-k1-plus(192.168.6.70):/# ls -l /etc/armbianmonitor/datasources/soctemp lrwxrwxrwx 1 root root 35 Jul 15 20:08 /etc/armbianmonitor/datasources/soctemp -> /sys/class/hwmon/hwmon0/temp1_input This is as expected on most recent Armbian images with mainline kernel. I still don't get it: is there a problem or not? It should be set this way after each and every reboot as long as thermal support is available in the specific kernel branch.
guidol Posted July 15, 2018 Posted July 15, 2018 12 minutes ago, tkaiser said: This is as expected on most recent Armbian images with mainline kernel. I still don't get it: is there a problem or not? It should be set this way after each and every reboot as long as thermal support is available in the specific kernel branch. I did a reboot and the symbolic link is gone So I have to do ln -s /sys/class/hwmon/hwmon0/temp1_input /etc/armbianmonitor/datasources/soctemp (prefered by the new system!?) or ln -s /sys/devices/virtual/thermal/thermal_zone0/temp /etc/armbianmonitor/datasources/soctemp Kernel 4.14.51-sunxi64 seems - for me - to have thermal support available, but on this version it doesnt seems to be recognized by the script (or the script doesnt run at startup - how could I check this?)
tkaiser Posted July 15, 2018 Author Posted July 15, 2018 2 minutes ago, guidol said: how could I check this? systemctl status armbian-hardware-monitor
guidol Posted July 15, 2018 Posted July 15, 2018 18 minutes ago, tkaiser said: systemctl status armbian-hardware-monitor Hmm - looks like it started, but without setting the link manually (or via /etc/rc.local) I didnt get a temperature readout: root@npi-k1-plus(192.168.6.70):~# systemctl status armbian-hardware-monitor ● armbian-hardware-monitor.service - Armbian hardware monitoring Loaded: loaded (/lib/systemd/system/armbian-hardware-monitor.service; enabled; vendor preset: enabled) Active: active (exited) since Sun 2018-07-15 21:59:13 +03; 1min 4s ago Process: 594 ExecStart=/usr/lib/armbian/armbian-hardware-monitor start (code=exited, status=0/SUCCESS) Main PID: 594 (code=exited, status=0/SUCCESS) Tasks: 0 (limit: 4915) CGroup: /system.slice/armbian-hardware-monitor.service Jul 15 21:59:10 npi-k1-plus systemd[1]: Starting Armbian hardware monitoring... Jul 15 21:59:13 npi-k1-plus systemd[1]: Started Armbian hardware monitoring. BUT if I stop/start armbian-hardware-monitor the temperature-readout does WORK without setting the link manually- so it seems to be like a timeout or not ready service: root@npi-k1-plus(192.168.6.70):~# systemctl stop armbian-hardware-monitor root@npi-k1-plus(192.168.6.70):~# systemctl start armbian-hardware-monitor root@npi-k1-plus(192.168.6.70):~# armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 22:05:38: 648MHz 0.29 10% 3% 4% 0% 1% 0% 38.1°C 0/8 22:05:43: 408MHz 0.26 0% 0% 0% 0% 0% 0% 37.5°C 0/8
tkaiser Posted July 15, 2018 Author Posted July 15, 2018 Weird. You could add the following just below the '#!/bin/bash' line and then post the contents of /tmp/armbian-hardware-monitor-debug.txt after a reboot, then waiting 5 minutes and then stopping/starting the service again: exec 2>>/tmp/armbian-hardware-monitor-debug.txt set -x date
guidol Posted July 15, 2018 Posted July 15, 2018 4 minutes ago, tkaiser said: Weird. You could add the following just below the '#!/bin/bash' line and then post the contents of /tmp/armbian-hardware-monitor-debug.txt after a reboot, then waiting 5 minutes and then stopping/starting the service again: exec 2>>/tmp/armbian-hardware-monitor-debug.txt set -x date I added this to /usr/lib/armbian/armbian-hardware-monitor. After reboot: Spoiler root@npi-k1-plus(192.168.6.70):~# more /tmp/armbian-hardware-monitor-debug.txt + date + . /etc/armbian-release ++ BOARD=nanopik1plus ++ BOARD_NAME='Nanopi K1 Plus' ++ BOARDFAMILY=sun50iw2 ++ VERSION=5.47 ++ LINUXFAMILY=sunxi64 ++ BRANCH=next ++ ARCH=arm64 ++ IMAGE_TYPE=stable ++ BOARD_TYPE=conf ++ INITRD_ARCH=arm64 ++ KERNEL_IMAGE_TYPE=Image + . /usr/lib/armbian/armbian-common ++ export PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++ PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++ my_name=armbian-hardware-monitor ++ Log=/var/log/armbian-services.log + case $1 in + check_sd_card_speed + collect_information + prepare_temp_monitoring + '[' -f /var/log/armbian-hardware-monitor.log ']' + '[' -d /etc/armbianmonitor/datasources ']' + ifconfig + grep -q eth0 ++ grep -c '^### df:' /var/log/armbian-hardware-monitor.log + RebootCount=22 + '[' 22 -eq 2 ']' + [[ -f /sys/power/axp_pmu/pmu/temp ]] + [[ -f /sys/devices/platform/sunxi-i2c.0/i2c-0/0-0034//temp1_input ]] + [[ -f /sys/devices/b0170000.i2c/i2c-0/0-0065/atc2603c-hwmon.0/ic_temperature ]] + [[ -f /sys/class/axppower/ic_temp ]] + [[ -d /sys/devices/platform/a20-tp-hwmon ]] + [[ -f /sys/class/hwmon/hwmon0/temp1_input ]] + ln -fs /sys/class/hwmon/hwmon0/temp1_input /etc/armbianmonitor/datasources/soctemp + cat /etc/armbianmonitor/datasources/soctemp + rm /etc/armbianmonitor/datasources/soctemp ++ mktemp /tmp/armbian-hardware-monitor.XXXXXX + TMPFILE=/tmp/armbian-hardware-monitor.ue6G4h + trap 'sleep 1 ; rm "/tmp/armbian-hardware-monitor.ue6G4h" ; exit 0' 0 1 2 3 15 ++ lscpu ++ awk '/Architecture/ {print $2}' + CPU_ARCH=aarch64 ++ dpkg --print-architecture + DISTRO_ARCH=arm64 ++ uname -r + KERNELID=4.14.51-sunxi64 + dmesg + echo Nanopi K1 Plus + '[' 0 -ne 0 ']' + '[' -f /root/.machine.id ']' + log_hardware_info + Log=/var/log/armbian-hardware-monitor.log + '[' -f /etc/logrotate.d/armbian-hardware-monitor ']' + chmod 644 /etc/logrotate.d/armbian-hardware-monitor + '[' -f /var/log/armbian-hardware-monitor.log ']' ++ date + echo -e '\n\n\nSo 15. Jul 22:42:50 +03 2018 | Nanopi K1 Plus | 5.47 | arm64 | aarch64 | 4.14.51-sunxi64' + echo -e '\n### dmesg:\n' + cat /tmp/armbian-hardware-monitor.ue6G4h + echo -e '\n### armbian-release:\n' + cat /etc/armbian-release + echo -e '\n### boot environment:\n' + cat /boot/armbianEnv.txt + echo -e '\n### lsusb:\n' + lsusb + echo -e '\n### lscpu:\n' + lscpu + echo -e '\n### cpuinfo:\n' + cat /proc/cpuinfo + echo -e '\n### meminfo:\n' + cat /proc/meminfo + '[' -x /sbin/ip ']' + echo -e '\n### ip addr:\n' + /sbin/ip r s + /sbin/ip a + echo ' ' + echo -e '### partitions:\n' + egrep -v ' ram| zram' /proc/partitions + echo -e '\n### df:\n' + df -h + egrep '^udev|^tmpfs|^/dev/|log2ram|folder2ram' + which zpool + echo -e '\n### lsblk:\n' + lsblk -o NAME,FSTYPE,SIZE,MOUNTPOINT,UUID + grep -v '^zram' + echo -e '\n### mtab:\n' + egrep '^/dev/|\ zfs\ ' /etc/mtab + sort + egrep -v 'log2ram|folder2ram' + [[ -e /boot/script.bin ]] + get_flash_information + read Device + find /sys -name oemid + DeviceNode=/sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007 + DeviceName=mmc0:0007 + echo -e '\n### mmc0:0007 info:\n' + find /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007 -maxdepth 1 -type f + read + NodeName=fwrev ++ printf %20s fwrev ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/fwrev ++ tr '\n' ' ' + echo -e ' fwrev: 0x0 ' + read + NodeName=uevent ++ printf %20s uevent ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/uevent ++ tr '\n' ' ' + echo -e ' uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD32G MODALIAS=mmc:block ' + read + NodeName=cid ++ printf %20s cid ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/cid ++ tr '\n' ' ' + echo -e ' cid: 275048534433324730da7d50db0104b3 ' + read + NodeName=csd ++ printf %20s csd ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/csd ++ tr '\n' ' ' + echo -e ' csd: 400e00325b590000eeaf7f800a4000b9 ' + read + NodeName=manfid ++ printf %20s manfid ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/manfid ++ tr '\n' ' ' + echo -e ' manfid: 0x000027 ' + read + NodeName=ocr ++ printf %20s ocr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/ocr ++ tr '\n' ' ' + echo -e ' ocr: 0x00200000 ' + read + NodeName=preferred_erase_size ++ printf %20s preferred_erase_size ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/preferred_erase_size ++ tr '\n' ' ' + echo -e 'preferred_erase_size: 4194304 ' + read + NodeName=type ++ printf %20s type ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/type ++ tr '\n' ' ' + echo -e ' type: SD ' + read + NodeName=hwrev ++ printf %20s hwrev ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/hwrev ++ tr '\n' ' ' + echo -e ' hwrev: 0x3 ' + read + NodeName=date ++ printf %20s date ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/date ++ tr '\n' ' ' + echo -e ' date: 04/2016 ' + read + NodeName=dsr ++ printf %20s dsr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/dsr ++ tr '\n' ' ' + echo -e ' dsr: 0x404 ' + read + NodeName=erase_size ++ printf %20s erase_size ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/erase_size ++ tr '\n' ' ' + echo -e ' erase_size: 512 ' + read + NodeName=oemid ++ printf %20s oemid ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/oemid ++ tr '\n' ' ' + echo -e ' oemid: 0x5048 ' + read + NodeName=serial ++ printf %20s serial ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/serial ++ tr '\n' ' ' + echo -e ' serial: 0xda7d50db ' + read + NodeName=ssr ++ printf %20s ssr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/ssr ++ tr '\n' ' ' + echo -e ' ssr: 00000000050000000400900200ab00000000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000 ' + read + NodeName=scr ++ printf %20s scr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/scr ++ tr '\n' ' ' + echo -e ' scr: 0235800001000000 ' + read + NodeName=name ++ printf %20s name ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/name ++ tr '\n' ' ' + echo -e ' name: SD32G ' + read + read Device + sleep 1 + echo -e '\n### Boot system health:\n' + armbianmonitor -s + egrep '^Time|^[0-9]' + rm /tmp/armbian-hardware-monitor.ue6G4h + exit 0 5 Minutes later and systemctl stop armbian-hardware-monitor systemctl start armbian-hardware-monitor Spoiler + date + . /etc/armbian-release ++ BOARD=nanopik1plus ++ BOARD_NAME='Nanopi K1 Plus' ++ BOARDFAMILY=sun50iw2 ++ VERSION=5.47 ++ LINUXFAMILY=sunxi64 ++ BRANCH=next ++ ARCH=arm64 ++ IMAGE_TYPE=stable ++ BOARD_TYPE=conf ++ INITRD_ARCH=arm64 ++ KERNEL_IMAGE_TYPE=Image + . /usr/lib/armbian/armbian-common ++ export PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++ PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++ my_name=armbian-hardware-monitor ++ Log=/var/log/armbian-services.log + case $1 in + check_sd_card_speed + collect_information + prepare_temp_monitoring + '[' -f /var/log/armbian-hardware-monitor.log ']' + '[' -d /etc/armbianmonitor/datasources ']' + ifconfig + grep -q eth0 ++ grep -c '^### df:' /var/log/armbian-hardware-monitor.log + RebootCount=22 + '[' 22 -eq 2 ']' + [[ -f /sys/power/axp_pmu/pmu/temp ]] + [[ -f /sys/devices/platform/sunxi-i2c.0/i2c-0/0-0034//temp1_input ]] + [[ -f /sys/devices/b0170000.i2c/i2c-0/0-0065/atc2603c-hwmon.0/ic_temperature ]] + [[ -f /sys/class/axppower/ic_temp ]] + [[ -d /sys/devices/platform/a20-tp-hwmon ]] + [[ -f /sys/class/hwmon/hwmon0/temp1_input ]] + ln -fs /sys/class/hwmon/hwmon0/temp1_input /etc/armbianmonitor/datasources/soctemp + cat /etc/armbianmonitor/datasources/soctemp + rm /etc/armbianmonitor/datasources/soctemp ++ mktemp /tmp/armbian-hardware-monitor.XXXXXX + TMPFILE=/tmp/armbian-hardware-monitor.ue6G4h + trap 'sleep 1 ; rm "/tmp/armbian-hardware-monitor.ue6G4h" ; exit 0' 0 1 2 3 15 ++ lscpu ++ awk '/Architecture/ {print $2}' + CPU_ARCH=aarch64 ++ dpkg --print-architecture + DISTRO_ARCH=arm64 ++ uname -r + KERNELID=4.14.51-sunxi64 + dmesg + echo Nanopi K1 Plus + '[' 0 -ne 0 ']' + '[' -f /root/.machine.id ']' + log_hardware_info + Log=/var/log/armbian-hardware-monitor.log + '[' -f /etc/logrotate.d/armbian-hardware-monitor ']' + chmod 644 /etc/logrotate.d/armbian-hardware-monitor + '[' -f /var/log/armbian-hardware-monitor.log ']' ++ date + echo -e '\n\n\nSo 15. Jul 22:42:50 +03 2018 | Nanopi K1 Plus | 5.47 | arm64 | aarch64 | 4.14.51-sunxi64' + echo -e '\n### dmesg:\n' + cat /tmp/armbian-hardware-monitor.ue6G4h + echo -e '\n### armbian-release:\n' + cat /etc/armbian-release + echo -e '\n### boot environment:\n' + cat /boot/armbianEnv.txt + echo -e '\n### lsusb:\n' + lsusb + echo -e '\n### lscpu:\n' + lscpu + echo -e '\n### cpuinfo:\n' + cat /proc/cpuinfo + echo -e '\n### meminfo:\n' + cat /proc/meminfo + '[' -x /sbin/ip ']' + echo -e '\n### ip addr:\n' + /sbin/ip r s + /sbin/ip a + echo ' ' + echo -e '### partitions:\n' + egrep -v ' ram| zram' /proc/partitions + echo -e '\n### df:\n' + df -h + egrep '^udev|^tmpfs|^/dev/|log2ram|folder2ram' + which zpool + echo -e '\n### lsblk:\n' + lsblk -o NAME,FSTYPE,SIZE,MOUNTPOINT,UUID + grep -v '^zram' + echo -e '\n### mtab:\n' + egrep '^/dev/|\ zfs\ ' /etc/mtab + sort + egrep -v 'log2ram|folder2ram' + [[ -e /boot/script.bin ]] + get_flash_information + read Device + find /sys -name oemid + DeviceNode=/sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007 + DeviceName=mmc0:0007 + echo -e '\n### mmc0:0007 info:\n' + find /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007 -maxdepth 1 -type f + read + NodeName=fwrev ++ printf %20s fwrev ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/fwrev ++ tr '\n' ' ' + echo -e ' fwrev: 0x0 ' + read + NodeName=uevent ++ printf %20s uevent ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/uevent ++ tr '\n' ' ' + echo -e ' uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD32G MODALIAS=mmc:block ' + read + NodeName=cid ++ printf %20s cid ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/cid ++ tr '\n' ' ' + echo -e ' cid: 275048534433324730da7d50db0104b3 ' + read + NodeName=csd ++ printf %20s csd ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/csd ++ tr '\n' ' ' + echo -e ' csd: 400e00325b590000eeaf7f800a4000b9 ' + read + NodeName=manfid ++ printf %20s manfid ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/manfid ++ tr '\n' ' ' + echo -e ' manfid: 0x000027 ' + read + NodeName=ocr ++ printf %20s ocr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/ocr ++ tr '\n' ' ' + echo -e ' ocr: 0x00200000 ' + read + NodeName=preferred_erase_size ++ printf %20s preferred_erase_size ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/preferred_erase_size ++ tr '\n' ' ' + echo -e 'preferred_erase_size: 4194304 ' + read + NodeName=type ++ printf %20s type ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/type ++ tr '\n' ' ' + echo -e ' type: SD ' + read + NodeName=hwrev ++ printf %20s hwrev ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/hwrev ++ tr '\n' ' ' + echo -e ' hwrev: 0x3 ' + read + NodeName=date ++ printf %20s date ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/date ++ tr '\n' ' ' + echo -e ' date: 04/2016 ' + read + NodeName=dsr ++ printf %20s dsr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/dsr ++ tr '\n' ' ' + echo -e ' dsr: 0x404 ' + read + NodeName=erase_size ++ printf %20s erase_size ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/erase_size ++ tr '\n' ' ' + echo -e ' erase_size: 512 ' + read + NodeName=oemid ++ printf %20s oemid ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/oemid ++ tr '\n' ' ' + echo -e ' oemid: 0x5048 ' + read + NodeName=serial ++ printf %20s serial ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/serial ++ tr '\n' ' ' + echo -e ' serial: 0xda7d50db ' + read + NodeName=ssr ++ printf %20s ssr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/ssr ++ tr '\n' ' ' + echo -e ' ssr: 00000000050000000400900200ab00000000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000 ' + read + NodeName=scr ++ printf %20s scr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/scr ++ tr '\n' ' ' + echo -e ' scr: 0235800001000000 ' + read + NodeName=name ++ printf %20s name ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/name ++ tr '\n' ' ' + echo -e ' name: SD32G ' + read + read Device + sleep 1 + echo -e '\n### Boot system health:\n' + armbianmonitor -s + egrep '^Time|^[0-9]' + rm /tmp/armbian-hardware-monitor.ue6G4h + exit 0 + date + . /etc/armbian-release ++ BOARD=nanopik1plus ++ BOARD_NAME='Nanopi K1 Plus' ++ BOARDFAMILY=sun50iw2 ++ VERSION=5.47 ++ LINUXFAMILY=sunxi64 ++ BRANCH=next ++ ARCH=arm64 ++ IMAGE_TYPE=stable ++ BOARD_TYPE=conf ++ INITRD_ARCH=arm64 ++ KERNEL_IMAGE_TYPE=Image + . /usr/lib/armbian/armbian-common ++ export PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++ PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++ my_name=armbian-hardware-monitor ++ Log=/var/log/armbian-services.log + case $1 in + case ${BOARDFAMILY} in ++ cut -f1 '-d ' + /sbin/modprobe -r snd_soc_hdmi_codec rc_cec dw_hdmi_i2s_audio dw_hdmi_cec snd_soc_simple_card sun4i_i2s sun8i_co dec_analog sun4i_codec snd_soc_simple_card_utils snd_soc_core zram ir_lirc_codec sun4i_gpadc_iio lirc_dev snd_pcm_ dmaengine sun8i_dw_hdmi snd_pcm dw_hdmi cec sunxi_cir rc_core iio_hwmon snd_timer industrialio sun4i_tcon sun4i_dr m sun8i_mixer sy8106a_regulator sunxi musb_hdrc modprobe: FATAL: Module snd_soc_hdmi_codec is in use. ++ iostat -p zram0 ++ vmstat -w ++ free -h ++ dmesg ++ tail -n 100 + echo -e '\n### shutdown:\n\nLinux 4.14.51-sunxi64 (npi-k1-plus) 15.07.2018 _aarch64_ (4 CPU) avg-cpu: %user %nice %system %iowait %steal %idle 0,94 0,01 0,68 0,34 0,00 98,02 Device: tps kB_read/s kB_wrtn/s kB_read kB_wrtn zram0 3,39 1,63 11,93 732 5372\n\nprocs -----------------------memory----- ----------------- ---swap-- -----io---- -system-- --------cpu-------- r b swpd free buff cache si so bi bo in cs us sy id wa st 0 0 0 1852644 10752 124456 0 0 68 3 123 143 1 1 98 0 0\n\n total used free shared buff/cache available Mem: 2,0G 61M 1,8G 3,0M 132M 1,8G Swap: 1,0G 0B 1,0G\n\n[ 2.403200] hub 7-0:1.0: USB hub found [ 2.403231] hub 7-0:1.0: 1 port detected [ 2.403788] ohci-platform 1c1d400.usb: Generic Platform OHCI controller [ 2.403807] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8 [ 2.404013] ohci-platform 1c1d400.usb: irq 20, io mem 0x01c1d400 [ 2.466776] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001 [ 2.466783] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.466789] usb usb8: Product: Generic Platform OHCI controller [ 2.466794] usb usb8: Manufacturer: Linux 4.14.51-sunxi64 ohci_hcd [ 2.466799] usb usb8: SerialNumber: 1c1d400.usb [ 2.467178] hub 8-0:1.0: USB hub found [ 2.467206] hub 8-0:1.0: 1 port detected [ 2.468113] input: r-gpio-keys as /devices/platform/r-gpio-keys/input/input0 [ 2.468458] of_cfs_init [ 2.468537] of_cfs_init: OK [ 2.468681] vdd-cpux-dummy: disabling [ 2.468688] usb0-vbus: disabling [ 2.468691] ALSA device list: [ 2.468694] No soundcards found. [ 2.469205] Freeing unused kernel memory: 448K [ 2.514750] random: systemd-udevd: uninitialized urandom read (16 bytes read) [ 2.515144] random: systemd-udevd: uninitialized urandom read (16 bytes read) [ 2.515185] random: systemd-udevd: uninitialized urandom read (16 bytes read) [ 2.663614] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy re gulator [ 2.664348] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver [ 2.664365] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 9 [ 2.664619] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.664626] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.664632] usb usb9: Product: MUSB HDRC host driver [ 2.664637] usb usb9: Manufacturer: Linux 4.14.51-sunxi64 musb-hcd [ 2.664643] usb usb9: SerialNumber: musb-hdrc.1.auto [ 2.665173] hub 9-0:1.0: USB hub found [ 2.665222] hub 9-0:1.0: 1 port detected [ 2.697448] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17 [ 2.846131] random: fast init done [ 3.236332] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) [ 3.901854] systemd[1]: System time before build time, advancing clock. [ 3.939887] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVIN IT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN) [ 3.940413] systemd[1]: Detected architecture arm64. [ 3.967865] systemd[1]: Set hostname to <npi-k1-plus>. [ 4.545732] systemd[1]: Listening on Syslog Socket. [ 4.562912] systemd[1]: Created slice User and Session Slice. [ 4.574815] systemd[1]: Reached target Swap. [ 4.587046] systemd[1]: Listening on udev Kernel Socket. [ 4.601194] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 4.622765] systemd[1]: Created slice System Slice. [ 4.637316] systemd[1]: Created slice system-getty.slice. [ 4.973401] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro [ 6.031190] lirc_dev: IR Remote Control driver registered, major 244 [ 6.063487] IR LIRC bridge handler initialized [ 6.064309] Registered IR keymap rc-empty [ 6.064556] rc rc0: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0 [ 6.064704] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0/input1 [ 6.073172] zram: Added device: zram0 [ 6.075330] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-ir) registered at minor = 0 [ 6.075452] zram: Added device: zram1 [ 6.075461] sunxi-ir 1f02000.ir: initialized sunXi IR driver [ 6.075806] zram: Added device: zram2 [ 6.075957] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 6.075961] [drm] No driver support for vblank timestamp query. [ 6.076156] zram: Added device: zram3 [ 6.076523] zram: Added device: zram4 [ 6.083096] sun4i-drm display-engine: bound 1100000.mixer (ops sun8i_mixer_platform_driver_exit [sun8i_mixer]) [ 6.083441] sun4i-drm display-engine: No panel or bridge found... RGB output disabled [ 6.083468] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops sun4i_tcon_platform_driver_exit [sun4i_ tcon]) [ 6.210834] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy) [ 6.211351] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver [ 6.211648] sun4i-drm display-engine: bound 1ee0000.hdmi (ops sun8i_dw_hdmi_ops [sun8i_dw_hdmi]) [ 6.211693] [drm] Cannot find any crtc or sizes [ 6.212075] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0 [ 6.212533] thermal thermal_zone0: failed to read out thermal zone (-110) [ 6.213560] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01f015c0 not registered [ 6.213571] sun4i-codec 1c22c00.codec: Failed to register our card [ 6.234427] zram1: detected capacity change from 0 to 262479872 [ 6.237722] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok [ 6.266687] Registered IR keymap rc-cec [ 6.266874] rc rc1: RC for dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc1 [ 6.267030] input: RC for dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc1/input2 [ 6.313019] Adding 256324k swap on /dev/zram1. Priority:5 extents:1 across:256324k SSFS [ 6.316119] asoc-simple-card sound: i2s-hifi <-> 1c22800.i2s mapping ok [ 6.333457] zram2: detected capacity change from 0 to 262479872 [ 6.360947] Adding 256324k swap on /dev/zram2. Priority:5 extents:1 across:256324k SSFS [ 6.363839] zram3: detected capacity change from 0 to 262479872 [ 6.388327] Adding 256324k swap on /dev/zram3. Priority:5 extents:1 across:256324k SSFS [ 6.394947] zram4: detected capacity change from 0 to 262479872 [ 6.415750] Adding 256324k swap on /dev/zram4. Priority:5 extents:1 across:256324k SSFS [ 6.439171] RTL8211E Gigabit Ethernet 0.2:07: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr =0.2:07, irq=POLL) [ 6.446869] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available [ 6.446880] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW [ 6.447249] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 6.475756] zram0: detected capacity change from 0 to 52428800 [ 6.671024] EXT4-fs (zram0): mounted filesystem without journal. Opts: (null) [ 7.234697] thermal thermal_zone0: failed to read out thermal zone (-110) [ 7.238752] [drm] Cannot find any crtc or sizes [ 7.292862] systemd-journald[585]: Received request to flush runtime journal from PID 1 [ 7.674478] random: crng init done [ 7.674489] random: 7 urandom warning(s) missed due to ratelimiting [ 8.258735] thermal thermal_zone0: failed to read out thermal zone (-110) [ 9.507505] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 9.507553] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready' + logger -i -t armbian-hardware-monitor 'Sane shutdown' + sync + date + . /etc/armbian-release ++ BOARD=nanopik1plus ++ BOARD_NAME='Nanopi K1 Plus' ++ BOARDFAMILY=sun50iw2 ++ VERSION=5.47 ++ LINUXFAMILY=sunxi64 ++ BRANCH=next ++ ARCH=arm64 ++ IMAGE_TYPE=stable ++ BOARD_TYPE=conf ++ INITRD_ARCH=arm64 ++ KERNEL_IMAGE_TYPE=Image + . /usr/lib/armbian/armbian-common ++ export PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++ PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++ my_name=armbian-hardware-monitor ++ Log=/var/log/armbian-services.log + case $1 in + check_sd_card_speed + '[' -f /var/log/armbian-hardware-monitor.log ']' + prepare_temp_monitoring + collect_information + '[' -d /etc/armbianmonitor/datasources ']' + [[ -f /sys/power/axp_pmu/pmu/temp ]] + [[ -f /sys/devices/platform/sunxi-i2c.0/i2c-0/0-0034//temp1_input ]] + [[ -f /sys/devices/b0170000.i2c/i2c-0/0-0065/atc2603c-hwmon.0/ic_temperature ]] + [[ -f /sys/class/axppower/ic_temp ]] + [[ -d /sys/devices/platform/a20-tp-hwmon ]] + [[ -f /sys/class/hwmon/hwmon0/temp1_input ]] + ln -fs /sys/class/hwmon/hwmon0/temp1_input /etc/armbianmonitor/datasources/soctemp + ifconfig ++ grep -c '^### df:' /var/log/armbian-hardware-monitor.log + grep -q eth0 + cat /etc/armbianmonitor/datasources/soctemp ++ mktemp /tmp/armbian-hardware-monitor.XXXXXX + RebootCount=23 + '[' 23 -eq 2 ']' + TMPFILE=/tmp/armbian-hardware-monitor.vWJ8QY + trap 'sleep 1 ; rm "/tmp/armbian-hardware-monitor.vWJ8QY" ; exit 0' 0 1 2 3 15 ++ lscpu ++ awk '/Architecture/ {print $2}' + CPU_ARCH=aarch64 ++ dpkg --print-architecture + DISTRO_ARCH=arm64 ++ uname -r + KERNELID=4.14.51-sunxi64 + dmesg + echo Nanopi K1 Plus + '[' 0 -ne 0 ']' + '[' -f /root/.machine.id ']' + log_hardware_info + Log=/var/log/armbian-hardware-monitor.log + '[' -f /etc/logrotate.d/armbian-hardware-monitor ']' + chmod 644 /etc/logrotate.d/armbian-hardware-monitor + '[' -f /var/log/armbian-hardware-monitor.log ']' ++ date + echo -e '\n\n\nSo 15. Jul 22:50:40 +03 2018 | Nanopi K1 Plus | 5.47 | arm64 | aarch64 | 4.14.51-sunxi64' + echo -e '\n### dmesg:\n' + cat /tmp/armbian-hardware-monitor.vWJ8QY + echo -e '\n### armbian-release:\n' + cat /etc/armbian-release + echo -e '\n### boot environment:\n' + cat /boot/armbianEnv.txt + echo -e '\n### lsusb:\n' + lsusb + echo -e '\n### lscpu:\n' + lscpu + echo -e '\n### cpuinfo:\n' + cat /proc/cpuinfo + echo -e '\n### meminfo:\n' + cat /proc/meminfo + '[' -x /sbin/ip ']' + echo -e '\n### ip addr:\n' + /sbin/ip r s + /sbin/ip a + echo ' ' + echo -e '### partitions:\n' + egrep -v ' ram| zram' /proc/partitions + echo -e '\n### df:\n' + df -h + egrep '^udev|^tmpfs|^/dev/|log2ram|folder2ram' + which zpool + echo -e '\n### lsblk:\n' + lsblk -o NAME,FSTYPE,SIZE,MOUNTPOINT,UUID + grep -v '^zram' + echo -e '\n### mtab:\n' + egrep '^/dev/|\ zfs\ ' /etc/mtab + sort + egrep -v 'log2ram|folder2ram' + [[ -e /boot/script.bin ]] + get_flash_information + find /sys -name oemid + read Device + DeviceNode=/sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007 + DeviceName=mmc0:0007 + echo -e '\n### mmc0:0007 info:\n' + find /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007 -maxdepth 1 -type f + read + NodeName=fwrev ++ printf %20s fwrev ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/fwrev ++ tr '\n' ' ' + echo -e ' fwrev: 0x0 ' + read + NodeName=uevent ++ printf %20s uevent ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/uevent ++ tr '\n' ' ' + echo -e ' uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD32G MODALIAS=mmc:block ' + read + NodeName=cid ++ printf %20s cid ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/cid ++ tr '\n' ' ' + echo -e ' cid: 275048534433324730da7d50db0104b3 ' + read + NodeName=csd ++ printf %20s csd ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/csd ++ tr '\n' ' ' + echo -e ' csd: 400e00325b590000eeaf7f800a4000b9 ' + read + NodeName=manfid ++ printf %20s manfid ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/manfid ++ tr '\n' ' ' + echo -e ' manfid: 0x000027 ' + read + NodeName=ocr ++ printf %20s ocr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/ocr ++ tr '\n' ' ' + echo -e ' ocr: 0x00200000 ' + read + NodeName=preferred_erase_size ++ printf %20s preferred_erase_size ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/preferred_erase_size ++ tr '\n' ' ' + echo -e 'preferred_erase_size: 4194304 ' + read + NodeName=type ++ printf %20s type ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/type ++ tr '\n' ' ' + echo -e ' type: SD ' + read + NodeName=hwrev ++ printf %20s hwrev ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/hwrev ++ tr '\n' ' ' + echo -e ' hwrev: 0x3 ' + read + NodeName=date ++ printf %20s date ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/date ++ tr '\n' ' ' + echo -e ' date: 04/2016 ' + read + NodeName=dsr ++ printf %20s dsr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/dsr ++ tr '\n' ' ' + echo -e ' dsr: 0x404 ' + read + NodeName=erase_size ++ printf %20s erase_size ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/erase_size ++ tr '\n' ' ' + echo -e ' erase_size: 512 ' + read + NodeName=oemid ++ printf %20s oemid ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/oemid ++ tr '\n' ' ' + echo -e ' oemid: 0x5048 ' + read + NodeName=serial ++ printf %20s serial ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/serial ++ tr '\n' ' ' + echo -e ' serial: 0xda7d50db ' + read + NodeName=ssr ++ printf %20s ssr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/ssr ++ tr '\n' ' ' + echo -e ' ssr: 00000000050000000400900200ab00000000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000 ' + read + NodeName=scr ++ printf %20s scr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/scr ++ tr '\n' ' ' + echo -e ' scr: 0235800001000000 ' + read + NodeName=name ++ printf %20s name ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/name ++ tr '\n' ' ' + echo -e ' name: SD32G ' + read + read Device + sleep 1 + echo -e '\n### Boot system health:\n' + armbianmonitor -s + egrep '^Time|^[0-9]' + rm /tmp/armbian-hardware-monitor.vWJ8QY + exit 0 My follwing little bash-script (out of the monitor-script) does work: #!/bin/bash # SoC temp: if [[ -f /sys/class/hwmon/hwmon0/temp1_input ]]; then # usual convention with modern kernels echo 'setze Link' ln -fs /sys/class/hwmon/hwmon0/temp1_input /etc/armbianmonitor/datasources/soctemp fi Thats the same source-code....
tkaiser Posted July 15, 2018 Author Posted July 15, 2018 15 minutes ago, guidol said: + ln -fs /sys/class/hwmon/hwmon0/temp1_input /etc/armbianmonitor/datasources/soctemp + cat /etc/armbianmonitor/datasources/soctemp + rm /etc/armbianmonitor/datasources/soctemp That's the culprit. The sysfs node is present at boot but can not be read out for whatever reasons. So it's some sort of a timing problem. I added removal of the /etc/armbianmonitor/datasources/soctemp symlink to get 'nicer' output with 'armbianmonitor -m' some time ago but seems like this is counterproductive. Can you try to repeat the test after commenting this line?
guidol Posted July 15, 2018 Posted July 15, 2018 7 minutes ago, tkaiser said: Can you try to repeat the test after commenting this line? Directly after the reboot (with commented rm) the link is there and temperature-readout does work out of the box! Spoiler root@npi-k1-plus(192.168.6.70):~# more /tmp/armbian-hardware-monitor-debug.txt + date + . /etc/armbian-release ++ BOARD=nanopik1plus ++ BOARD_NAME='Nanopi K1 Plus' ++ BOARDFAMILY=sun50iw2 ++ VERSION=5.47 ++ LINUXFAMILY=sunxi64 ++ BRANCH=next ++ ARCH=arm64 ++ IMAGE_TYPE=stable ++ BOARD_TYPE=conf ++ INITRD_ARCH=arm64 ++ KERNEL_IMAGE_TYPE=Image + . /usr/lib/armbian/armbian-common ++ export PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++ PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++ my_name=armbian-hardware-monitor ++ Log=/var/log/armbian-services.log + case $1 in + collect_information + check_sd_card_speed + '[' -f /var/log/armbian-hardware-monitor.log ']' + ifconfig ++ grep -c '^### df:' /var/log/armbian-hardware-monitor.log + prepare_temp_monitoring + '[' -d /etc/armbianmonitor/datasources ']' + grep -q eth0 + RebootCount=24 + '[' 24 -eq 2 ']' + [[ -f /sys/power/axp_pmu/pmu/temp ]] + [[ -f /sys/devices/platform/sunxi-i2c.0/i2c-0/0-0034//temp1_input ]] + [[ -f /sys/devices/b0170000.i2c/i2c-0/0-0065/atc2603c-hwmon.0/ic_temperature ]] + [[ -f /sys/class/axppower/ic_temp ]] + [[ -d /sys/devices/platform/a20-tp-hwmon ]] + [[ -f /sys/class/hwmon/hwmon0/temp1_input ]] + ln -fs /sys/class/hwmon/hwmon0/temp1_input /etc/armbianmonitor/datasources/soctemp ++ mktemp /tmp/armbian-hardware-monitor.XXXXXX + TMPFILE=/tmp/armbian-hardware-monitor.pcs92K + trap 'sleep 1 ; rm "/tmp/armbian-hardware-monitor.pcs92K" ; exit 0' 0 1 2 3 15 ++ lscpu ++ awk '/Architecture/ {print $2}' + CPU_ARCH=aarch64 ++ dpkg --print-architecture + DISTRO_ARCH=arm64 ++ uname -r + KERNELID=4.14.51-sunxi64 + dmesg + echo Nanopi K1 Plus + '[' 0 -ne 0 ']' + '[' -f /root/.machine.id ']' + log_hardware_info + Log=/var/log/armbian-hardware-monitor.log + '[' -f /etc/logrotate.d/armbian-hardware-monitor ']' + chmod 644 /etc/logrotate.d/armbian-hardware-monitor + '[' -f /var/log/armbian-hardware-monitor.log ']' ++ date + echo -e '\n\n\nSo 15. Jul 23:14:53 +03 2018 | Nanopi K1 Plus | 5.47 | arm64 | aarch64 | 4.14.51-sunxi64' + echo -e '\n### dmesg:\n' + cat /tmp/armbian-hardware-monitor.pcs92K + echo -e '\n### armbian-release:\n' + cat /etc/armbian-release + echo -e '\n### boot environment:\n' + cat /boot/armbianEnv.txt + echo -e '\n### lsusb:\n' + lsusb + echo -e '\n### lscpu:\n' + lscpu + echo -e '\n### cpuinfo:\n' + cat /proc/cpuinfo + echo -e '\n### meminfo:\n' + cat /proc/meminfo + '[' -x /sbin/ip ']' + echo -e '\n### ip addr:\n' + /sbin/ip r s + /sbin/ip a + echo ' ' + echo -e '### partitions:\n' + egrep -v ' ram| zram' /proc/partitions + echo -e '\n### df:\n' + df -h + egrep '^udev|^tmpfs|^/dev/|log2ram|folder2ram' + which zpool + echo -e '\n### lsblk:\n' + lsblk -o NAME,FSTYPE,SIZE,MOUNTPOINT,UUID + grep -v '^zram' + echo -e '\n### mtab:\n' + egrep '^/dev/|\ zfs\ ' /etc/mtab + sort + egrep -v 'log2ram|folder2ram' + [[ -e /boot/script.bin ]] + get_flash_information + find /sys -name oemid + read Device + DeviceNode=/sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007 + DeviceName=mmc0:0007 + echo -e '\n### mmc0:0007 info:\n' + find /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007 -maxdepth 1 -type f + read + NodeName=fwrev ++ printf %20s fwrev ++ tr '\n' ' ' ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/fwrev + echo -e ' fwrev: 0x0 ' + read + NodeName=uevent ++ printf %20s uevent ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/uevent ++ tr '\n' ' ' + echo -e ' uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD32G MODALIAS=mmc:block ' + read + NodeName=cid ++ printf %20s cid ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/cid ++ tr '\n' ' ' + echo -e ' cid: 275048534433324730da7d50db0104b3 ' + read + NodeName=csd ++ printf %20s csd ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/csd ++ tr '\n' ' ' + echo -e ' csd: 400e00325b590000eeaf7f800a4000b9 ' + read + NodeName=manfid ++ printf %20s manfid ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/manfid ++ tr '\n' ' ' + echo -e ' manfid: 0x000027 ' + read + NodeName=ocr ++ printf %20s ocr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/ocr ++ tr '\n' ' ' + echo -e ' ocr: 0x00200000 ' + read + NodeName=preferred_erase_size ++ printf %20s preferred_erase_size ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/preferred_erase_size ++ tr '\n' ' ' + echo -e 'preferred_erase_size: 4194304 ' + read + NodeName=type ++ printf %20s type ++ tr '\n' ' ' ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/type + echo -e ' type: SD ' + read + NodeName=hwrev ++ printf %20s hwrev ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/hwrev ++ tr '\n' ' ' + echo -e ' hwrev: 0x3 ' + read + NodeName=date ++ printf %20s date ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/date ++ tr '\n' ' ' + echo -e ' date: 04/2016 ' + read + NodeName=dsr ++ printf %20s dsr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/dsr ++ tr '\n' ' ' + echo -e ' dsr: 0x404 ' + read + NodeName=erase_size ++ printf %20s erase_size ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/erase_size ++ tr '\n' ' ' + echo -e ' erase_size: 512 ' + read + NodeName=oemid ++ printf %20s oemid ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/oemid ++ tr '\n' ' ' + echo -e ' oemid: 0x5048 ' + read + NodeName=serial ++ printf %20s serial ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/serial ++ tr '\n' ' ' + echo -e ' serial: 0xda7d50db ' + read + NodeName=ssr ++ printf %20s ssr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/ssr ++ tr '\n' ' ' + echo -e ' ssr: 00000000050000000400900200ab00000000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000 ' + read + NodeName=scr ++ printf %20s scr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/scr ++ tr '\n' ' ' + echo -e ' scr: 0235800001000000 ' + read + NodeName=name ++ printf %20s name ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/name ++ tr '\n' ' ' + echo -e ' name: SD32G ' + read + read Device + sleep 1 + echo -e '\n### Boot system health:\n' + armbianmonitor -s + egrep '^Time|^[0-9]' + rm /tmp/armbian-hardware-monitor.pcs92K + exit 0 5 Minutes later and systemctl stop armbian-hardware-monitor systemctl start armbian-hardware-monitor Spoiler root@npi-k1-plus(192.168.6.70):~# more /tmp/armbian-hardware-monitor-debug.txt + date + . /etc/armbian-release ++ BOARD=nanopik1plus ++ BOARD_NAME='Nanopi K1 Plus' ++ BOARDFAMILY=sun50iw2 ++ VERSION=5.47 ++ LINUXFAMILY=sunxi64 ++ BRANCH=next ++ ARCH=arm64 ++ IMAGE_TYPE=stable ++ BOARD_TYPE=conf ++ INITRD_ARCH=arm64 ++ KERNEL_IMAGE_TYPE=Image + . /usr/lib/armbian/armbian-common ++ export PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++ PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++ my_name=armbian-hardware-monitor ++ Log=/var/log/armbian-services.log + case $1 in + collect_information + check_sd_card_speed + '[' -f /var/log/armbian-hardware-monitor.log ']' + ifconfig ++ grep -c '^### df:' /var/log/armbian-hardware-monitor.log + prepare_temp_monitoring + '[' -d /etc/armbianmonitor/datasources ']' + grep -q eth0 + RebootCount=24 + '[' 24 -eq 2 ']' + [[ -f /sys/power/axp_pmu/pmu/temp ]] + [[ -f /sys/devices/platform/sunxi-i2c.0/i2c-0/0-0034//temp1_input ]] + [[ -f /sys/devices/b0170000.i2c/i2c-0/0-0065/atc2603c-hwmon.0/ic_temperature ]] + [[ -f /sys/class/axppower/ic_temp ]] + [[ -d /sys/devices/platform/a20-tp-hwmon ]] + [[ -f /sys/class/hwmon/hwmon0/temp1_input ]] + ln -fs /sys/class/hwmon/hwmon0/temp1_input /etc/armbianmonitor/datasources/soctemp ++ mktemp /tmp/armbian-hardware-monitor.XXXXXX + TMPFILE=/tmp/armbian-hardware-monitor.pcs92K + trap 'sleep 1 ; rm "/tmp/armbian-hardware-monitor.pcs92K" ; exit 0' 0 1 2 3 15 ++ lscpu ++ awk '/Architecture/ {print $2}' + CPU_ARCH=aarch64 ++ dpkg --print-architecture + DISTRO_ARCH=arm64 ++ uname -r + KERNELID=4.14.51-sunxi64 + dmesg + echo Nanopi K1 Plus + '[' 0 -ne 0 ']' + '[' -f /root/.machine.id ']' + log_hardware_info + Log=/var/log/armbian-hardware-monitor.log + '[' -f /etc/logrotate.d/armbian-hardware-monitor ']' + chmod 644 /etc/logrotate.d/armbian-hardware-monitor + '[' -f /var/log/armbian-hardware-monitor.log ']' ++ date + echo -e '\n\n\nSo 15. Jul 23:14:53 +03 2018 | Nanopi K1 Plus | 5.47 | arm64 | aarch64 | 4.14.51-sunxi64' + echo -e '\n### dmesg:\n' + cat /tmp/armbian-hardware-monitor.pcs92K + echo -e '\n### armbian-release:\n' + cat /etc/armbian-release + echo -e '\n### boot environment:\n' + cat /boot/armbianEnv.txt + echo -e '\n### lsusb:\n' + lsusb + echo -e '\n### lscpu:\n' + lscpu + echo -e '\n### cpuinfo:\n' + cat /proc/cpuinfo + echo -e '\n### meminfo:\n' + cat /proc/meminfo + '[' -x /sbin/ip ']' + echo -e '\n### ip addr:\n' + /sbin/ip r s + /sbin/ip a + echo ' ' + echo -e '### partitions:\n' + egrep -v ' ram| zram' /proc/partitions + echo -e '\n### df:\n' + df -h + egrep '^udev|^tmpfs|^/dev/|log2ram|folder2ram' + which zpool + echo -e '\n### lsblk:\n' + lsblk -o NAME,FSTYPE,SIZE,MOUNTPOINT,UUID + grep -v '^zram' + echo -e '\n### mtab:\n' + egrep '^/dev/|\ zfs\ ' /etc/mtab + sort + egrep -v 'log2ram|folder2ram' + [[ -e /boot/script.bin ]] + get_flash_information + find /sys -name oemid + read Device + DeviceNode=/sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007 + DeviceName=mmc0:0007 + echo -e '\n### mmc0:0007 info:\n' + find /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007 -maxdepth 1 -type f + read + NodeName=fwrev ++ printf %20s fwrev ++ tr '\n' ' ' ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/fwrev + echo -e ' fwrev: 0x0 ' + read + NodeName=uevent ++ printf %20s uevent ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/uevent ++ tr '\n' ' ' + echo -e ' uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD32G MODALIAS=mmc:block ' + read + NodeName=cid ++ printf %20s cid ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/cid ++ tr '\n' ' ' + echo -e ' cid: 275048534433324730da7d50db0104b3 ' + read + NodeName=csd ++ printf %20s csd ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/csd ++ tr '\n' ' ' + echo -e ' csd: 400e00325b590000eeaf7f800a4000b9 ' + read + NodeName=manfid ++ printf %20s manfid ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/manfid ++ tr '\n' ' ' + echo -e ' manfid: 0x000027 ' + read + NodeName=ocr ++ printf %20s ocr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/ocr ++ tr '\n' ' ' + echo -e ' ocr: 0x00200000 ' + read + NodeName=preferred_erase_size ++ printf %20s preferred_erase_size ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/preferred_erase_size ++ tr '\n' ' ' + echo -e 'preferred_erase_size: 4194304 ' + read + NodeName=type ++ printf %20s type ++ tr '\n' ' ' ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/type + echo -e ' type: SD ' + read + NodeName=hwrev ++ printf %20s hwrev ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/hwrev ++ tr '\n' ' ' + echo -e ' hwrev: 0x3 ' + read + NodeName=date ++ printf %20s date ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/date ++ tr '\n' ' ' + echo -e ' date: 04/2016 ' + read + NodeName=dsr ++ printf %20s dsr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/dsr ++ tr '\n' ' ' + echo -e ' dsr: 0x404 ' + read + NodeName=erase_size ++ printf %20s erase_size ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/erase_size ++ tr '\n' ' ' + echo -e ' erase_size: 512 ' + read + NodeName=oemid ++ printf %20s oemid ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/oemid ++ tr '\n' ' ' + echo -e ' oemid: 0x5048 ' + read + NodeName=serial ++ printf %20s serial ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/serial ++ tr '\n' ' ' + echo -e ' serial: 0xda7d50db ' + read + NodeName=ssr ++ printf %20s ssr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/ssr ++ tr '\n' ' ' + echo -e ' ssr: 00000000050000000400900200ab00000000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000 ' + read + NodeName=scr ++ printf %20s scr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/scr ++ tr '\n' ' ' + echo -e ' scr: 0235800001000000 ' + read + NodeName=name ++ printf %20s name ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/name ++ tr '\n' ' ' + echo -e ' name: SD32G ' + read + read Device + sleep 1 + echo -e '\n### Boot system health:\n' + armbianmonitor -s + egrep '^Time|^[0-9]' + rm /tmp/armbian-hardware-monitor.pcs92K + exit 0 + date + . /etc/armbian-release ++ BOARD=nanopik1plus ++ BOARD_NAME='Nanopi K1 Plus' ++ BOARDFAMILY=sun50iw2 ++ VERSION=5.47 ++ LINUXFAMILY=sunxi64 ++ BRANCH=next ++ ARCH=arm64 ++ IMAGE_TYPE=stable ++ BOARD_TYPE=conf ++ INITRD_ARCH=arm64 ++ KERNEL_IMAGE_TYPE=Image + . /usr/lib/armbian/armbian-common ++ export PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++ PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++ my_name=armbian-hardware-monitor ++ Log=/var/log/armbian-services.log + case $1 in + case ${BOARDFAMILY} in ++ cut -f1 '-d ' + /sbin/modprobe -r snd_soc_hdmi_codec rc_cec dw_hdmi_i2s_audio dw_hdmi_cec snd_soc_simple_card snd_soc_simple_car d_utils zram sun8i_codec_analog ir_lirc_codec sun8i_dw_hdmi sun4i_codec lirc_dev dw_hdmi sun4i_i2s sunxi_cir cec s nd_soc_core rc_core snd_pcm_dmaengine sun4i_gpadc_iio snd_pcm snd_timer iio_hwmon industrialio sun4i_drm sun8i_mix er sun4i_tcon sy8106a_regulator sunxi musb_hdrc modprobe: FATAL: Module snd_soc_hdmi_codec is in use. ++ iostat -p zram0 ++ vmstat -w ++ free -h ++ dmesg ++ tail -n 100 + echo -e '\n### shutdown:\n\nLinux 4.14.51-sunxi64 (npi-k1-plus) 15.07.2018 _aarch64_ (4 CPU) avg-cpu: %user %nice %system %iowait %steal %idle 0,94 0,01 0,70 0,33 0,00 98,03 Device: tps kB_read/s kB_wrtn/s kB_read kB_wrtn zram0 3,54 1,63 12,54 732 5640\n\nprocs -----------------------memory----- ----------------- ---swap-- -----io---- -system-- --------cpu-------- r b swpd free buff cache si so bi bo in cs us sy id wa st 0 0 0 1853368 10756 124904 0 0 68 3 120 140 1 1 98 0 0\n\n total used free shared buff/cache available Mem: 2,0G 60M 1,8G 3,0M 132M 1,8G Swap: 1,0G 0B 1,0G\n\n[ 2.403688] hub 7-0:1.0: USB hub found [ 2.403721] hub 7-0:1.0: 1 port detected [ 2.404273] ohci-platform 1c1d400.usb: Generic Platform OHCI controller [ 2.404292] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8 [ 2.404496] ohci-platform 1c1d400.usb: irq 20, io mem 0x01c1d400 [ 2.467281] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001 [ 2.467288] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.467294] usb usb8: Product: Generic Platform OHCI controller [ 2.467299] usb usb8: Manufacturer: Linux 4.14.51-sunxi64 ohci_hcd [ 2.467304] usb usb8: SerialNumber: 1c1d400.usb [ 2.467686] hub 8-0:1.0: USB hub found [ 2.467713] hub 8-0:1.0: 1 port detected [ 2.468607] input: r-gpio-keys as /devices/platform/r-gpio-keys/input/input0 [ 2.468927] of_cfs_init [ 2.469008] of_cfs_init: OK [ 2.469153] vdd-cpux-dummy: disabling [ 2.469160] usb0-vbus: disabling [ 2.469163] ALSA device list: [ 2.469166] No soundcards found. [ 2.469670] Freeing unused kernel memory: 448K [ 2.515434] random: systemd-udevd: uninitialized urandom read (16 bytes read) [ 2.515835] random: systemd-udevd: uninitialized urandom read (16 bytes read) [ 2.515877] random: systemd-udevd: uninitialized urandom read (16 bytes read) [ 2.660050] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy re gulator [ 2.660744] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver [ 2.660766] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 9 [ 2.661358] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.661369] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.661375] usb usb9: Product: MUSB HDRC host driver [ 2.661380] usb usb9: Manufacturer: Linux 4.14.51-sunxi64 musb-hcd [ 2.661386] usb usb9: SerialNumber: musb-hdrc.1.auto [ 2.662133] hub 9-0:1.0: USB hub found [ 2.662176] hub 9-0:1.0: 1 port detected [ 2.698329] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17 [ 2.836155] random: fast init done [ 3.217854] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) [ 3.870516] systemd[1]: System time before build time, advancing clock. [ 3.919164] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVIN IT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN) [ 3.919617] systemd[1]: Detected architecture arm64. [ 3.955554] systemd[1]: Set hostname to <npi-k1-plus>. [ 4.539030] systemd[1]: Listening on fsck to fsckd communication Socket. [ 4.554805] systemd[1]: Listening on Journal Audit Socket. [ 4.568812] systemd[1]: Listening on udev Kernel Socket. [ 4.580088] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 4.599862] systemd[1]: Listening on Journal Socket. [ 4.611467] systemd[1]: Reached target Swap. [ 4.624125] systemd[1]: Created slice System Slice. [ 4.944384] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro [ 5.748558] thermal thermal_zone0: failed to read out thermal zone (-110) [ 5.837106] lirc_dev: IR Remote Control driver registered, major 244 [ 5.843992] IR LIRC bridge handler initialized [ 5.844622] Registered IR keymap rc-empty [ 5.844751] rc rc0: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0 [ 5.844877] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0/input1 [ 5.848204] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-ir) registered at minor = 0 [ 5.848359] sunxi-ir 1f02000.ir: initialized sunXi IR driver [ 5.849894] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01f015c0 not registered [ 5.849905] sun4i-codec 1c22c00.codec: Failed to register our card [ 5.851025] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 5.851030] [drm] No driver support for vblank timestamp query. [ 5.857653] sun4i-drm display-engine: bound 1100000.mixer (ops sun8i_mixer_platform_driver_exit [sun8i_mixer]) [ 5.858100] sun4i-drm display-engine: No panel or bridge found... RGB output disabled [ 5.858132] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops sun4i_tcon_platform_driver_exit [sun4i_ tcon]) [ 5.879092] zram: Added device: zram0 [ 5.879597] zram: Added device: zram1 [ 5.880836] zram: Added device: zram2 [ 5.881293] zram: Added device: zram3 [ 5.882563] zram: Added device: zram4 [ 5.983398] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy) [ 5.984120] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver [ 5.984511] sun4i-drm display-engine: bound 1ee0000.hdmi (ops sun8i_dw_hdmi_ops [sun8i_dw_hdmi]) [ 5.984562] [drm] Cannot find any crtc or sizes [ 5.985216] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0 [ 6.009041] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok [ 6.075210] Registered IR keymap rc-cec [ 6.075400] rc rc1: RC for dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc1 [ 6.078480] input: RC for dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc1/input2 [ 6.105723] zram1: detected capacity change from 0 to 262479872 [ 6.123523] asoc-simple-card sound: i2s-hifi <-> 1c22800.i2s mapping ok [ 6.220590] Adding 256324k swap on /dev/zram1. Priority:5 extents:1 across:256324k SSFS [ 6.224728] zram2: detected capacity change from 0 to 262479872 [ 6.251541] Adding 256324k swap on /dev/zram2. Priority:5 extents:1 across:256324k SSFS [ 6.254327] zram3: detected capacity change from 0 to 262479872 [ 6.286192] Adding 256324k swap on /dev/zram3. Priority:5 extents:1 across:256324k SSFS [ 6.289517] zram4: detected capacity change from 0 to 262479872 [ 6.315259] Adding 256324k swap on /dev/zram4. Priority:5 extents:1 across:256324k SSFS [ 6.372077] zram0: detected capacity change from 0 to 52428800 [ 6.423676] RTL8211E Gigabit Ethernet 0.2:07: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr =0.2:07, irq=POLL) [ 6.425981] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available [ 6.425995] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW [ 6.426372] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 6.546460] EXT4-fs (zram0): mounted filesystem without journal. Opts: (null) [ 6.755217] thermal thermal_zone0: failed to read out thermal zone (-110) [ 7.011278] [drm] Cannot find any crtc or sizes [ 7.192861] systemd-journald[584]: Received request to flush runtime journal from PID 1 [ 7.588326] random: crng init done [ 7.588338] random: 7 urandom warning(s) missed due to ratelimiting [ 7.779228] thermal thermal_zone0: failed to read out thermal zone (-110) [ 9.507930] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 9.507972] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready' + logger -i -t armbian-hardware-monitor 'Sane shutdown' + sync + date + . /etc/armbian-release ++ BOARD=nanopik1plus ++ BOARD_NAME='Nanopi K1 Plus' ++ BOARDFAMILY=sun50iw2 ++ VERSION=5.47 ++ LINUXFAMILY=sunxi64 ++ BRANCH=next ++ ARCH=arm64 ++ IMAGE_TYPE=stable ++ BOARD_TYPE=conf ++ INITRD_ARCH=arm64 ++ KERNEL_IMAGE_TYPE=Image + . /usr/lib/armbian/armbian-common ++ export PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++ PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++ my_name=armbian-hardware-monitor ++ Log=/var/log/armbian-services.log + case $1 in + check_sd_card_speed + collect_information + '[' -f /var/log/armbian-hardware-monitor.log ']' + prepare_temp_monitoring + '[' -d /etc/armbianmonitor/datasources ']' + [[ -f /sys/power/axp_pmu/pmu/temp ]] + [[ -f /sys/devices/platform/sunxi-i2c.0/i2c-0/0-0034//temp1_input ]] + [[ -f /sys/devices/b0170000.i2c/i2c-0/0-0065/atc2603c-hwmon.0/ic_temperature ]] + [[ -f /sys/class/axppower/ic_temp ]] + [[ -d /sys/devices/platform/a20-tp-hwmon ]] + [[ -f /sys/class/hwmon/hwmon0/temp1_input ]] + ifconfig + ln -fs /sys/class/hwmon/hwmon0/temp1_input /etc/armbianmonitor/datasources/soctemp + grep -q eth0 ++ grep -c '^### df:' /var/log/armbian-hardware-monitor.log ++ mktemp /tmp/armbian-hardware-monitor.XXXXXX + RebootCount=25 + '[' 25 -eq 2 ']' + TMPFILE=/tmp/armbian-hardware-monitor.MNfj1i + trap 'sleep 1 ; rm "/tmp/armbian-hardware-monitor.MNfj1i" ; exit 0' 0 1 2 3 15 ++ lscpu ++ awk '/Architecture/ {print $2}' + CPU_ARCH=aarch64 ++ dpkg --print-architecture + DISTRO_ARCH=arm64 ++ uname -r + KERNELID=4.14.51-sunxi64 + dmesg + echo Nanopi K1 Plus + '[' 0 -ne 0 ']' + '[' -f /root/.machine.id ']' + log_hardware_info + Log=/var/log/armbian-hardware-monitor.log + '[' -f /etc/logrotate.d/armbian-hardware-monitor ']' + chmod 644 /etc/logrotate.d/armbian-hardware-monitor + '[' -f /var/log/armbian-hardware-monitor.log ']' ++ date + echo -e '\n\n\nSo 15. Jul 23:22:42 +03 2018 | Nanopi K1 Plus | 5.47 | arm64 | aarch64 | 4.14.51-sunxi64' + echo -e '\n### dmesg:\n' + cat /tmp/armbian-hardware-monitor.MNfj1i + echo -e '\n### armbian-release:\n' + cat /etc/armbian-release + echo -e '\n### boot environment:\n' + cat /boot/armbianEnv.txt + echo -e '\n### lsusb:\n' + lsusb + echo -e '\n### lscpu:\n' + lscpu + echo -e '\n### cpuinfo:\n' + cat /proc/cpuinfo + echo -e '\n### meminfo:\n' + cat /proc/meminfo + '[' -x /sbin/ip ']' + echo -e '\n### ip addr:\n' + /sbin/ip r s + /sbin/ip a + echo ' ' + echo -e '### partitions:\n' + egrep -v ' ram| zram' /proc/partitions + echo -e '\n### df:\n' + df -h + egrep '^udev|^tmpfs|^/dev/|log2ram|folder2ram' + which zpool + echo -e '\n### lsblk:\n' + lsblk -o NAME,FSTYPE,SIZE,MOUNTPOINT,UUID + grep -v '^zram' + echo -e '\n### mtab:\n' + egrep '^/dev/|\ zfs\ ' /etc/mtab + sort + egrep -v 'log2ram|folder2ram' + [[ -e /boot/script.bin ]] + get_flash_information + read Device + find /sys -name oemid + DeviceNode=/sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007 + DeviceName=mmc0:0007 + echo -e '\n### mmc0:0007 info:\n' + find /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007 -maxdepth 1 -type f + read + NodeName=fwrev ++ printf %20s fwrev ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/fwrev ++ tr '\n' ' ' + echo -e ' fwrev: 0x0 ' + read + NodeName=uevent ++ printf %20s uevent ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/uevent ++ tr '\n' ' ' + echo -e ' uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD32G MODALIAS=mmc:block ' + read + NodeName=cid ++ printf %20s cid ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/cid ++ tr '\n' ' ' + echo -e ' cid: 275048534433324730da7d50db0104b3 ' + read + NodeName=csd ++ printf %20s csd ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/csd ++ tr '\n' ' ' + echo -e ' csd: 400e00325b590000eeaf7f800a4000b9 ' + read + NodeName=manfid ++ printf %20s manfid ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/manfid ++ tr '\n' ' ' + echo -e ' manfid: 0x000027 ' + read + NodeName=ocr ++ printf %20s ocr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/ocr ++ tr '\n' ' ' + echo -e ' ocr: 0x00200000 ' + read + NodeName=preferred_erase_size ++ printf %20s preferred_erase_size ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/preferred_erase_size ++ tr '\n' ' ' + echo -e 'preferred_erase_size: 4194304 ' + read + NodeName=type ++ printf %20s type ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/type ++ tr '\n' ' ' + echo -e ' type: SD ' + read + NodeName=hwrev ++ printf %20s hwrev ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/hwrev ++ tr '\n' ' ' + echo -e ' hwrev: 0x3 ' + read + NodeName=date ++ printf %20s date ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/date ++ tr '\n' ' ' + echo -e ' date: 04/2016 ' + read + NodeName=dsr ++ printf %20s dsr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/dsr ++ tr '\n' ' ' + echo -e ' dsr: 0x404 ' + read + NodeName=erase_size ++ printf %20s erase_size ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/erase_size ++ tr '\n' ' ' + echo -e ' erase_size: 512 ' + read + NodeName=oemid ++ printf %20s oemid ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/oemid ++ tr '\n' ' ' + echo -e ' oemid: 0x5048 ' + read + NodeName=serial ++ printf %20s serial ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/serial ++ tr '\n' ' ' + echo -e ' serial: 0xda7d50db ' + read + NodeName=ssr ++ printf %20s ssr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/ssr ++ tr '\n' ' ' + echo -e ' ssr: 00000000050000000400900200ab00000000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000 ' + read + NodeName=scr ++ printf %20s scr ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/scr ++ tr '\n' ' ' + echo -e ' scr: 0235800001000000 ' + read + NodeName=name ++ printf %20s name ++ cat /sys/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0007/name ++ tr '\n' ' ' + echo -e ' name: SD32G ' + read + read Device + sleep 1 + echo -e '\n### Boot system health:\n' + armbianmonitor -s + egrep '^Time|^[0-9]' + rm /tmp/armbian-hardware-monitor.MNfj1i + exit 0
tkaiser Posted July 15, 2018 Author Posted July 15, 2018 47 minutes ago, guidol said: Directly after the reboot (with commented rm) the link is there and temperature-readout does work out of the box! I deleted removal of the symlink now: https://github.com/armbian/build/commit/52bef7ddf9d424eb65d831385714a9da66153078 (hopefully more people will test and report back, especiall wrt ondemand scheduler behaviour -- always remaining at max cpufreq with recent kernels)
yam1 Posted July 16, 2018 Posted July 16, 2018 Happy to report both SPI channels worked properly with 5.47 stable using 4.14.51-sunxi64:
guidol Posted July 16, 2018 Posted July 16, 2018 8 hours ago, tkaiser said: especiall wrt ondemand scheduler behaviour -- always remaining at max cpufreq with recent kernels) because of that I use the conservative governer as current governer.
tkaiser Posted July 16, 2018 Author Posted July 16, 2018 2 minutes ago, guidol said: because of that I use the conservative governer as current governer I read about that 'workaround' but this one is no option as already explained in detail (since not behaving correctly with I/O loads -- switching to conservative trashes storage performance). It would be better if users would help testing instead of promoting broken workarounds.
guidol Posted July 16, 2018 Posted July 16, 2018 2 hours ago, tkaiser said: It would be better if users would help testing instead of promoting broken workarounds. How could I help testing the broken ondemand? I did see on several SBCs that ondemand isnt working and switched to conservative? I didnt promote conservative - I only want the CPU to switch down - a thing that ondemand at this time doesnt do.
tkaiser Posted July 16, 2018 Author Posted July 16, 2018 36 minutes ago, guidol said: How could I help testing the broken ondemand? By testing with second part of the aforementioned commit. As @BRSS discovered the sampling_rate value changed with some kernel version and that affects the governor's behaviour: https://forum.armbian.com/topic/6398-orange-pi-zero-cpu-and-load-issues-with-538/?tab=comments#comment-58057 (let's ignore the 'average load' problem for now since unrelated). So by testing through different values and this also with some older kernels we could try to come up again with settings that match everywhere. 'Legacy'/default kernels aren't that much of an issue since we use with sunxi kernels lower than 4.x the interactive governor (since ondemand sucks with Allwinner BSP kernels and interactive is the only reasonable choice). So it's really just testing through higher sampling_rate values with some kernel variants. Discussion should IMO better happen in the other thread (even if 'wrong' subforum).
guidol Posted July 16, 2018 Posted July 16, 2018 3 hours ago, tkaiser said: So by testing through different values and this also with some older kernels we could try to come up again with settings that match everywhere. 'Legacy'/default kernels aren't that much of an issue since we use with sunxi kernels lower than 4.x the interactive governor (since ondemand sucks with Allwinner BSP kernels and interactive is the only reasonable choice). for testing I switched the K1 Plus back to ondemand and did take a look at root@npi-k1-plus(192.168.6.70):~# more /sys/devices/system/cpu/cpufreq/ondemand/sampling_rate10000 With 10000 ondemand doenst switch down with kernel 4.14.51-sunxi64, but when setting the rate to 20000 echo 20000 > /sys/devices/system/cpu/cpufreq/ondemand/sampling_rate ondemand as governer does beginn to switch down the frequency: root@npi-k1-plus(192.168.6.70):~# armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 15:23:30: 1152MHz 0.06 0% 0% 0% 0% 0% 0% 37.5°C 0/8 15:23:35: 1152MHz 0.05 0% 0% 0% 0% 0% 0% 37.4°C 0/8 15:23:41: 1152MHz 0.05 0% 0% 0% 0% 0% 0% 37.6°C 0/8 15:23:46: 1152MHz 0.04 0% 0% 0% 0% 0% 0% 37.3°C 0/8 15:23:51: 648MHz 0.04 0% 0% 0% 0% 0% 0% 37.5°C 0/8 15:23:56: 408MHz 0.04 0% 0% 0% 0% 0% 0% 37.6°C 0/8 15:24:01: 1152MHz 0.03 0% 0% 0% 0% 0% 0% 37.5°C 0/8 15:24:06: 408MHz 0.03 0% 0% 0% 0% 0% 0% 37.6°C 0/8 15:24:11: 408MHz 0.03 0% 0% 0% 0% 0% 0% 37.9°C 0/8 15:24:16: 408MHz 0.03 0% 0% 0% 0% 0% 0% 38.1°C 0/8 15:46:52: 408MHz 0.00 0% 0% 0% 0% 0% 0% 37.1°C 0/8 15:46:57: 1152MHz 0.00 0% 0% 0% 0% 0% 0% 37.0°C 0/8 15:47:02: 408MHz 0.00 0% 0% 0% 0% 0% 0% 37.3°C 0/8 15:47:07: 408MHz 0.00 0% 0% 0% 0% 0% 0% 37.1°C 0/8 15:47:12: 408MHz 0.00 0% 0% 0% 0% 0% 0% 36.7°C 0/8 15:47:17: 408MHz 0.00 0% 0% 0% 0% 0% 0% 36.8°C 0/8 15:47:22: 1152MHz 0.00 0% 0% 0% 0% 0% 0% 37.0°C 0/8 15:47:27: 408MHz 0.00 0% 0% 0% 0% 0% 0% 37.3°C 0/8 15:47:32: 408MHz 0.00 0% 0% 0% 0% 0% 0% 36.9°C 0/8 with one little peak to 1152Mhz (maybe a write to sd?) @tkaiser In the thread 'Orange Pi Zero - CPU and Load issues with 5.38" you did wrote about a value of 200000 Quote Simply edit /etc/init.d/armhwinfo and search for 'ondemand' there, then add the missing 'echo 200000 >${i}/sampling_rate' line, play around with the values and report back. Isnt 200000 to high - or is that a value for a Orange Pi Zero?
tkaiser Posted July 16, 2018 Author Posted July 16, 2018 21 minutes ago, guidol said: Isnt 200000 to high - or is that a value for a Orange Pi Zero? Boards and even SoCs are irrelevant. It's only about kernel family and settings. See chapter 2.4 here: https://www.kernel.org/doc/Documentation/cpu-freq/governors.txt I tested around with next branch on NanoPi Fire3, Clearfog Pro and RK3328. With those kernel settings 20,000 is way too low.
guidol Posted July 16, 2018 Posted July 16, 2018 8 minutes ago, tkaiser said: I tested around with next branch on NanoPi Fire3, Clearfog Pro and RK3328. With those kernel settings 20,000 is way too low. 2.4 Ondemand sampling_rate: Measured in uS (10^-6 seconds), this is how often you want the kernel to look at the CPU usage and to make decisions on what to do about the frequency. Typically this is set to values of around '10000' or more. So how much CPU usage we do get more when we use 200.000 against 20.000? The K1 Plus will also switch with 200.000 as samplingrate. Do we need a higher samplingrate with a faster CPU like on the NanoPi Fire3, Clearfog Pro and RK3328? (because Fire3 is a OctaCore)
guidol Posted July 16, 2018 Posted July 16, 2018 Strange I edited the /usr/lib/armbian/armbian-hardware-optimization ondemand-part for the samplingrate like # tweak ondemand cpufreq governor settings to increase cpufreq with IO load grep -q ondemand /etc/default/cpufrequtils if [ $? -eq 0 ]; then echo ondemand >/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor cd /sys/devices/system/cpu for i in cpufreq/ondemand cpu0/cpufreq/ondemand cpu4/cpufreq/ondemand ; do if [ -d $i ]; then echo 1 >${i}/io_is_busy echo 25 >${i}/up_threshold echo 10 >${i}/sampling_down_factor echo 20000 >${i}/sampling_rate fi done fi but after reboot I only get as value 10000: root@npi-k1-plus(192.168.6.70):~# more /sys/devices/system/cpu/cpufreq/ondemand/sampling_rate 10000 So the governor doesnt switch But when I insert echo 20000 > /sys/devices/system/cpu/cpufreq/ondemand/sampling_rate at the end of /etc/rc.local (before exit 0) then the governor does switch down to 408Mhz
tkaiser Posted July 16, 2018 Author Posted July 16, 2018 2 hours ago, guidol said: Measured in uS (10^-6 seconds), this is how often you want the kernel to look at the CPU usage and to make decisions on what to do about the frequency. Typically this is set to values of around '10000' or more. With 10,000 the kernel takes a look 100 hundred times each second, when set to 200,000 it's just 5 times any more. And this is all off-topic here as already said (but same applies to the other thread that talks about OPi Zero) As a first step I tried to consolidate timer frequency settings accross all kernels since what we have today is just chaos. 2
Marko Buršič Posted November 3, 2019 Posted November 3, 2019 I am interested in this board, but nowhere to get it in EU (I am from Slovenia). Is it obsolete or too new?
