dvachon Posted February 20, 2016 Share Posted February 20, 2016 Hi! On my Banana Pi PRO, i installed this «Armbian_5.00_Bananapi_Debian_jessie_4.4.1» but applications report 'no soundcards found'. I did the apt-get upgrade for 5.01 but still same problem. Link to comment Share on other sites More sharing options...
Igor Posted February 20, 2016 Share Posted February 20, 2016 Check some of those: http://linux.die.net/man/1/speaker-test Link to comment Share on other sites More sharing options...
zador.blood.stained Posted February 20, 2016 Share Posted February 20, 2016 Analog output in mainline kernel was activated (by patching DT files) only on non-Pro Banana Pi. Link to comment Share on other sites More sharing options...
Igor Posted February 20, 2016 Share Posted February 20, 2016 Analog output in mainline kernel was activated (by patching DT files) only on non-Pro Banana Pi. True, forgot that. But since u-boot selects normal banana by default it should work unless you don't change DTB to the one from Pro. Temporally / partial workaround is by using a DTB from normal Banana. Link to comment Share on other sites More sharing options...
dvachon Posted February 20, 2016 Author Share Posted February 20, 2016 Hi! I did your 'workaround' by using Pi DTB and now sound is working but i lost the 'Pro build-in' wifi Link to comment Share on other sites More sharing options...
Igor Posted February 21, 2016 Share Posted February 21, 2016 Hi! I did your 'workaround' by using Pi DTB and now sound is working but i lost the 'Pro build-in' wifi Known problem. I tried to create a general banana fix, but I produce more problems. Since I don't own Banana PRO (yet) and am out of office I can't deal with this problem in next 1-2 weeks. Try using DTB from Banana Pi + or work on those DTBs that everything will work Link to comment Share on other sites More sharing options...
dvachon Posted February 21, 2016 Author Share Posted February 21, 2016 Thank you very much for your support! For now, i will use the BananaPi (not Pro) DTB without wifi. I will wait for the fix. Have a nice day. Link to comment Share on other sites More sharing options...
