Klaush Posted June 13, 2015 Posted June 13, 2015 I now connected a ssd drive to my cubietruck. with ls /dev/ | grep sd I got sda, but when I try to format this drive with mkfs.ext4 /dev/sda1 I get this errormessage: Could not stat /dev/sda1 --- No such file or directoryThe device apparently does not exist; did you specify it correctly? How can I format the ssd ?
Igor Posted June 13, 2015 Posted June 13, 2015 You need to create a partition, with fdisk /dev/sda ... create, write, exit. Than you proceed with mkfs. Wrote on mobile phone
