All of our tinkers are rock solid after removing network-manager and going with wpa_supplicant.  Today I apt update/upgrade and it brought network-manager back which killed our connectivity.  When I apt remove network-manager it also is removing armbian-config which I don't want to happen.
armbian@term1:~$ sudo apt-mark hold network-manager
network-manager set on hold.
armbian@term1:~$ sudo apt install armbian-config
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 armbian-config : Depends: network-manager but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
44 minutes ago, zador.blood.stained said:
and move network-manager from dependencies to suggested package for armbian-config.
Done. Checking armbian-config ...
