After reading several threads without success I need to ask again how I can get permission as a "normal" user to use the GPIO pins via my python script:
#!/usr/bin/python
import time
PIN_NUM = 200
print "GPIO %s" % PIN_NUM
try:
   # check to see if the pin is already exported
   open(''.join(['/sys/class/gpio/gpio',str(PIN_NUM),'/direction'])).read()
except:
   # it isn't, so export it
   open('/sys/class/gpio/export', 'w').write(str(PIN_NUM))
# set gpiochip198 to output
open(''.join(['/sys/class/gpio/gpio',str(PIN_NUM),'/direction']), 'w').write('out')
for i in range(1000):
   open(''.join(['/sys/class/gpio/gpio',str(PIN_NUM),'/value']), 'w').write("1")
   time.sleep(0.5)
   open(''.join(['/sys/class/gpio/gpio',str(PIN_NUM),'/value']), 'w').write("0")
   time.sleep(0.5)
# remove GPIO87 folder from file system
open('/sys/class/gpio/unexport', 'w').write(str(PIN_NUM))
I get this error:
Traceback (most recent call last):
  File "testGPIO.py", line 17, in <module>
IOError: [Errno 13] Permission denied: '/sys/class/gpio/gpio200/direction'
So I tried to add:
SUBSYSTEM=="gpio", ACTION=="add", RUN="/bin/sh -c '\
        chown -R root:gpio /sys/class/gpio && chmod -R 770 /sys/class/gpio;\
        chown -R root:gpio /sys$DEVPATH && chmod -R 770 /sys$DEVPATH\
into /etc/udev/rules.d/90-gpiomem.rules
and yes my username is the GPIO group....
Can someone help me further...thx
Andy
