Allcon,
my pik2 constantly locks up. i havent been able to find anything that causes. going to cut this short before it locks up
http://ix.io/1e4Q
i have tried SD cards from san disk pny verbatim lexar: no change
i have tried different power supplies. the barrel jack under vairous voltages: many different power supplies i cannot find any consistancy.
Please download 5.42 image, updated u-boot should solve this issue, it is a memory problem with the storage location of the firmwares
i used the new release and its running like a "swiss car" j/k it is so much more smooth and stable. can we use the install to usb drive or is that still a no go?
I don't think that will work yet, the boot scripts are still what I had done to "make it work" with the old bootloader, so it's not ready.
Thank you for the update!
i have a 6 volt adapter into the barrel jack and with your revision things  seem to be running very well. thanks for thanking the time out for the help.
i will try to keep you updated of wierd happenings.
i am listening to youtube from a (Creative Xfi) and it sounds wonderful
Keep an eye on your system voltages, I thought (will verify) that was a generally unprotected 5V input
will do, i like to live on the edge so i ran 7.5 into the barrel and the lights just flash. no harm to the board.
i have used a y cable for the mcro usb but the  barrel worked better of course. i would have to scope it and im too lazy but if you need the data ill get it to you..
